ZED Leviathan II
Kaufi333
#1 erstellt: 12. Apr 2013, 19:12
Verkaufe eine ZED Leviathan II 450€
Die Amp ist im besten Zustand! Einfach eine super Amp brauche aber für meine 6 20er eine Leistungsstärkere da die 6x300 zu wenig sind
Kenner wissen was die zed leistet.
Continuous Output Power into 2 ohm: 300w x 6
Continuous Output Power into 4 ohm: 150w x 6
Typical Output Power into 4 ohm per channel (1% THD): 180w x 6
Continuous Output Power 3 pairs of channels bridged into 4 ohm: 600w x 3 Channel pairs may be bridged independently
Continuous Output Power 2 channels bridged into 8 ohm: 300w x 3 Channel pairs may be bridged independently
Minimum Speaker Impedance: 2 ohm per channel
Minimum Speaker Impedance in Bridge Mode (2 channels): 4 ohm
Power Response at any power into 4 ohms: 10-60KHz -2dB
Frequency Response at rated power into 4 ohms: 10Hz-30KHz -0.1dB
Input Voltage range for rated power into 4 ohms: 0.25 to 8.6 volt
Input Impedance at 2KHz: 47K ohm
Noise below rated output (30KHz limited): -100dB
Channel separation at 2KHz: >80dB
Damping Factor at 20Hz with 4 ohms: >80
Total Harmonic Distortion with 4 ohm 20Hz-20KHz
From 1 watt to rated power. Typically less than 0.05%: <0.2%
Intermodulation Distortion: <0.2%
Phase response at 20KHz: Lagging 12 deg
Slew rate (volts per micro second)-In”Flat” mode: 12
High Pass Crossovers (24dB/octave) Channels 1+2 and 3+4: 55Hz-4KHz
Low Pass Crossovers (24dB/octave) Channels 3+4: 55Hz to 4KHz
High Pass Crossovers (24dB/octave) Channels 5+6: 10Hz-105Hz May be used as a Sub Sonic Filter
Low Pass Crossovers (24dB/octave) Channels 5+6: 40Hz to 235Hz
Protection - Short Circuit, DC, Thermal: Yes
Power Source: 10-14.5v DC Negative Ground
Current Consumption with Sinewave at 4 ohms: 94A
Current Consumption with Music at 4 ohms: 18 to 28A
Idling Current: <1.5A
Fuse rating with 4 ohm load: 30A-40A depending on usage
Fuse rating with 2 ohm load: 40A -80A depending on usage
Size W x H (247mmx55mm/9.7”x2.1”) x L: 410mm/16.14” Excludes connectors
Shipping Weight (Kg/Lbs): 5.9 / 13
Made in USA
Kaufi333
#2 erstellt: 16. Apr 2013, 13:10
Neuer Preis 420€
Kaufi333
#3 erstellt: 21. Apr 2013, 11:09
390€
Kaufi333
#4 erstellt: 27. Apr 2013, 09:08
Würde auch tauschen gegen eine Colli XI FE oder X3, X4, oder sowas in der Art!
Kaufi333
#5 erstellt: 16. Mai 2014, 06:14
Die Zed steht wieder zum verkauf oder Tausch!
Sie ist jetzt über 1 jahr verbaut und läuft einwandfrei.
Kaufi333
#6 erstellt: 19. Mai 2014, 07:06
Bilder gibt es natürlich auch.
DSC_0063
DSC_0061
DSC_0058
DSC_0057
DSC_0056
[Beitrag von Kaufi333 am 19. Mai 2014, 07:10 bearbeitet]
Hifonics Hawk & Falcon - designed by ZED Audio
PiercedBoy am 15.04.2009  –  Letzte Antwort am 24.04.2009  –  6 Beiträge
Alpine MRV-T 503 V12 2/1 Kanal Endstufe [ verkauft! ]
Dillinja am 08.10.2006  –  Letzte Antwort am 15.10.2006  –  8 Beiträge
µdimensions JR 15.2x
Daniel_525_24V am 01.11.2007  –  Letzte Antwort am 01.11.2007  –  3 Beiträge
Clarion APX401.2 Neuwertig
WarlordXXL am 26.02.2011  –  Letzte Antwort am 12.03.2011  –  4 Beiträge
ESX Quantum Q120.2 by Zed Audio
elbohm am 02.07.2007  –  Letzte Antwort am 02.07.2007  –  2 Beiträge
Alpine MRV F545 4 Kanal Endstufe mit Display
onkelz am 20.07.2011  –  Letzte Antwort am 03.09.2011  –  7 Beiträge
u-Dimension 15.2 x
Fuxster am 13.09.2005  –  Letzte Antwort am 01.11.2005  –  7 Beiträge
[V] Xetec P4 Prestige Evo - 4 Kanal Klang Amp
atari64 am 15.10.2007  –  Letzte Antwort am 04.11.2007  –  9 Beiträge
Hollywood Endstufe HV 600.2
michajan am 03.09.2005  –  Letzte Antwort am 09.09.2005  –  3 Beiträge
µ-Dimension µ-Jr 15.2X
Samuel21 am 30.09.2007  –  Letzte Antwort am 10.10.2007  –  10 Beiträge
  • Registrierte Mitglieder928.851 ( Heute: 2 )
  • Neuestes MitgliedManda_Monanda
  • Gesamtzahl an Themen1.559.141
  • Gesamtzahl an Beiträgen21.718.720
