Neuer iBasso D14 "Bushmaster" DAC/KHV
AG1M
#1 erstellt: 14. Mai 2015, 19:59
Eben bei der iBasso Facebook Seite gesehen: https://www.facebook.com/iBassoAudio
Die mMn wichtigsten Punkte habe ich mal Fett markiert. Klingt nach einem neuen sehr guten portablen DAC/KHV von iBasso.
The iBasso D14. As a dac used with your computer, combined with a great internal amplifier many of your musical needs are met! There is no lag time if you listen to movies and with the OTG function, it works with any phone that has a proper functioning OTG output.
iBasso D14
The D14 is our new generation AMP and DAC combo that combines the advantages of and advances on our design of the D12 and D62. It utilizes the Sabre32 ES9018K2M DAC chip and with the XMOS USB receiver and the D14 is able to take up to a 32bit/384kHz PCM signal and native DSD up to 256x from computers. It also can work as a DAC for Android smart phones via a USB OTG. Other than the USB input, the D14 can take up to 24bit/192kHz optical input, coaxial input and analogue line in. On the Amplification section, we have an OPAMP based high output headphone amplifier, which can output up to 400mW into a 32ohm load. The sound quality from this little all-in-one AMP+DAC is better than any of our previous AMP+DAC products and achieves this from a combination of advanced technologies and superior implementation of components.
D14 Specifications:
Power Source: Built-in 4.2V Li-polymer Batteries or external power supply.
Frequency Response: 17Hz~20 KHz +/-1dB (DAC)
17Hz~100 KHz +/-0.2dB (AMP).
Signal to Noise Ratio:115dB (DAC), 116dB (Amp).
Crosstalk: 106dB (DAC).
Total Harmonic Distortion: 0.0018%@1kHz/-10dBF (DAC)
0.0012%@1kHz/max volume (AMP).
Output power: Up to 400mW+400mW into 32ohm.
Gain: +3dB and +9dB (AMP).
Battery Life: 13 hours AMP+DAC or 25 hours if amp only.
Battery Charge Time: 5 hours.
External Power supply: 5V DC.
Recommended Headphone Impedance: 8~300.
Output impedance: 0.1ohm.
Retail Price: $229.00 release date the beginning of June, 2015.
11119003_1064887060207172_6541695115213300815_n
11111918_1064887120207166_2381206376587499251_n
11060839_1064887143540497_4044062231249149815_n
AG1M
#2 erstellt: 18. Jun 2015, 17:08
Es wird langsam ernst, bald wird der D14 zu haben sein laut iBasso nur noch ein wenig „Feintuning“. Hab hier schon einmal einen Shop gefunden: http://www.son-video...-D14-Bushmaster.html wenn das wirklich bei 230 Euro liegen wird, wäre das imho absolut Konkurrenzlos in allen Gesichtspunkten was der portable DAC/KHV bietet. Ich werde ganz sicher schwach werden Die Maße würden mich noch interessieren und hoffentlich packt iBasso ein ganz kurzes micro USB auf micro USB OTG Kabel dazu, sonst hat man wieder den Adapter Alptraum, wenn man sein Android Smartphone dran stecken möchte. Beim Iphones ist ja eh ein CCC / Lightning Kabel nötig, aber so ein micro USB könnte iBasso schon mit dazu legen, gab es ja auch bei älteren DACs wenn ich mich richtig erinnere auch dazu.
housemeister1970
#3 erstellt: 18. Okt 2015, 11:44
Hi
Hast Du Dich dem feinen Gerätchen eigentlich weiter gewidmet?
Bin am überlegen mir das Teil primär als Desktop-Lösung in Verbindung mit meinem Grado RS2e zuzulegen.
Ein Händler in Deutschland konnte ich jedoch bisher nicht ausmachen.
Nur der von Dir genannte Händler aus Frankreich hat das Teil auf Lager.
Gruss
Ralph
[Beitrag von housemeister1970 am 18. Okt 2015, 11:57 bearbeitet]
AG1M
#4 erstellt: 18. Okt 2015, 12:22
nein habe da nicht weiter recherchiert. Aktuell direkt von iBasso.com zu bekommen, oder hier falls noch vorhanden: http://www.hifi-foru...m_id=265&thread=3813
Aber wenn es rein als Desktop Lösung dienen soll, lieber einen LH Labs Geek Out 450 bzw. 1000 nehmen, hatte ich selbst beide schon hier, die Audioqualität wie beim iFi Audio mircro iDSD (Geek Out 1000) sehr hoch, hatte da auch u.a. mit meinem RS2i verglichen.
housemeister1970
#5 erstellt: 18. Okt 2015, 12:51
Ja, über die LH Geek Out KHV/DAC Lösung bin auch am überlegen.
Hier im Biete Bereich findet man sogar den Geek Out V2 für round about 300 Euronen.
Das einzigste was mich an dem Teil stören könnte ist dessen Plastik-Gehäuse und daß das Teil eben direkt in
den USB-Port des Rechners gesteckt werden muss.
Nutze bisher den Audioquest Dragonfly und bei dem ist das ja das selbe. Bisschen frimelige Angelegenheit meines erachtens.
Aber klanglich sicherlich feine Teile, da Class A Verstärker und DSD Unterstützung. Zumindest beim V2.
Hmm, da grübel ich nun schon ein paar Tage rum.
AG1M
#6 erstellt: 18. Okt 2015, 13:00
Ich nutze da immer das USB Kabel zwischen solchen USB DAC/KHV Modellen, aber sonst ist der D14 in meinen Augen von all den Möglichkeiten/Leistung in dem Preisbereich sehr interessant keine Frage.
Btw. DSD und Co. können die Geek Out V1 auch alle, nur u.a. symmetrischer Ausgang ist beim V2 möglich.
[Beitrag von AG1M am 18. Okt 2015, 13:02 bearbeitet]
david_della_rocco
#7 erstellt: 19. Okt 2015, 06:31
Ich hab den D14 seit gut 4 Wochen.
Analog an den DX50 angeschlossen höre ich zum RSA Predator keinen unterschied, außer minimal mehr Rauschen (wobei der Predator absolut still ist).
Allerdings coaxial angeschlossen (optisch noch nicht versucht)
Offenbart der D14 einen Wahnsinns Sound ohne Rausch.
OTG USB-Kabel ist mit dabei.
Auf jeden Fall ist es ein klanglicher zugewinn zum DX50.
Power hat der AMP ohne ende.
Kleines minus für den Poti, nichts für extrem-leise-hörer.
Ist relativ laut bis er im gleichlauf ist.
Verarbeitung ist grandios, größe perfekt zum stacken mit DX50-DX90.
Für das Geld ein super Gerät.
Hören tu ich mit Fischer Amp FA-3E XB und Beyerdynamic T90.
iBasso P5 "Falcon" - portabler KHV mit wechselbaren Buffer und OpAmp
AG1M am 25.05.2015  –  Letzte Antwort am 05.08.2015  –  2 Beiträge
neuer DAP oder Smartphone mit USB/DAC-KHV
housemeister1970 am 10.04.2016  –  Letzte Antwort am 12.04.2016  –  15 Beiträge
KHV DAC für ipod
DJMDG am 24.09.2011  –  Letzte Antwort am 26.09.2011  –  8 Beiträge
DX170-Neuer iBasso im Anflug?
Roadfox am 09.07.2022  –  Letzte Antwort am 17.08.2022  –  51 Beiträge
Smartphone + KHV/DAC vs. DAP
sarah.10.03 am 24.12.2015  –  Letzte Antwort am 27.12.2015  –  15 Beiträge
FiiO E10K + Ibasso DX90
-Life- am 29.11.2018  –  Letzte Antwort am 01.12.2018  –  8 Beiträge
FiiO E12A - neuer portabler KHV
AG1M am 10.10.2014  –  Letzte Antwort am 29.05.2015  –  31 Beiträge
Ibasso DX90
robodoc am 02.02.2014  –  Letzte Antwort am 02.09.2016  –  496 Beiträge
KHV/DAC - Ifi hip-dac oder Beyerdynamic Impacto Universal?
thebuddha am 13.04.2020  –  Letzte Antwort am 13.04.2020  –  4 Beiträge
Mp3-Player an mobilen KHV/DAC anschleißen?
infinity650 am 22.09.2011  –  Letzte Antwort am 25.09.2011  –  5 Beiträge
  • Registrierte Mitglieder928.687 ( Heute: 1 )
  • Neuestes Mitgliededlalbertina
  • Gesamtzahl an Themen1.558.773
  • Gesamtzahl an Beiträgen21.710.283
