HIFI-FORUM » Fernseher & Beamer » LCD-Fernseher » Philips » HELP !!!! 46pfl6605d Ambilight problem in SAM mo... | |
HELP !!!! 46pfl6605d Ambilight problem in SAM mode+A -A |
zjxgjp
#1 erstellt: 03. Okt 2016, 14:56 | |
Sorry guys , I can't speak Deutsch . So please read English below. The model is 46pfl6605d/93 It is in the SAM mode ,Alignments , Ambilight option. I turned the "module 01" brightness down under 100 by mistake, but can't go back getting over 100.Now the light comes from the left side is darker than before. you can see the brightness is 212, which is over 100 in "module 02" and this is the original value. Is there some way like adding some code to the "FacAligns.txt" then send it back to the TV? And , what code should be added? I'll be more than grateful if you help me with this!!! [Beitrag von zjxgjp am 03. Okt 2016, 15:23 bearbeitet] |
zjxgjp
#2 erstellt: 03. Okt 2016, 14:58 | |
And this is how my FacAilgns.txt looks like <swver>Q5521</swver> <item>FacAlignWhiteRNormal</item> <Xaddr>300</Xaddr> <lastvalue>112</lastvalue> <item>FacAlignWhiteGNormal</item> <Xaddr>308</Xaddr> <lastvalue>127</lastvalue> <item>FacAlignWhiteBNormal</item> <Xaddr>310</Xaddr> <lastvalue>118</lastvalue> <item>FacAlignWhiteRCool</item> <Xaddr>318</Xaddr> <lastvalue>102</lastvalue> <item>FacAlignWhiteGCool</item> <Xaddr>320</Xaddr> <lastvalue>122</lastvalue> <item>FacAlignWhiteBCool</item> <Xaddr>328</Xaddr> <lastvalue>127</lastvalue> <item>FacAlignWhiteRWarm</item> <Xaddr>330</Xaddr> <lastvalue>125</lastvalue> <item>FacAlignWhiteGWarm</item> <Xaddr>338</Xaddr> <lastvalue>127</lastvalue> <item>FacAlignWhiteBWarm</item> <Xaddr>340</Xaddr> <lastvalue>81</lastvalue> <item>FacAlignBlackLevelOffsetR</item> <Xaddr>348</Xaddr> <lastvalue>8</lastvalue> <item>FacAlignBlackLevelOffsetG</item> <Xaddr>34c</Xaddr> <lastvalue>8</lastvalue> <item>FacAlignMainAnaIfAgcTOP</item> <Xaddr>350</Xaddr> <lastvalue>64</lastvalue> <item>FacAlignAuxAnaIfAgcTOP</item> <Xaddr>358</Xaddr> <lastvalue>64</lastvalue> <item>FacAlignAuxAnaIfAgcTOPPos</item> <Xaddr>360</Xaddr> <lastvalue>28</lastvalue> <item>FacAlignMainAnaIfAgcTOPPos</item> <Xaddr>368</Xaddr> <lastvalue>28</lastvalue> <item>WhiteRCustom</item> <Xaddr>378</Xaddr> <lastvalue>127</lastvalue> <item>WhiteGCustom</item> <Xaddr>380</Xaddr> <lastvalue>127</lastvalue> <item>WhiteBCustom</item> <Xaddr>388</Xaddr> <lastvalue>127</lastvalue> <item>BlackLevelOffsetGCustom</item> <Xaddr>390</Xaddr> <lastvalue>8</lastvalue> <item>BlackLevelOffsetRCustom</item> <Xaddr>394</Xaddr> <lastvalue>8</lastvalue> <item>TunerIfGainCalibrationLow</item> <Xaddr>398</Xaddr> <lastvalue>127</lastvalue> <item>TunerIfGainCalibrationMid</item> <Xaddr>3a0</Xaddr> <lastvalue>127</lastvalue> <item>TunerIfGainCalibrationHigh</item> <Xaddr>3a8</Xaddr> <lastvalue>127</lastvalue> |
zjxgjp
#3 erstellt: 03. Okt 2016, 15:08 | |
http://www.supportfo...viewfull=1#post79540 I saw this post on the Philips support fourm, and it shows that Ambilight options can be set through coding the FacAligns.txt . But in my FacAligns.txt , there is nothing about the Ambilight. I think it just hidden and it will active when you add some code in it. But I don't know what should be added. Could you tell me ? Thanks a lot!! [Beitrag von zjxgjp am 03. Okt 2016, 15:15 bearbeitet] |
zjxgjp
#4 erstellt: 04. Okt 2016, 10:13 | |
Anybody here? |
zjxgjp
#5 erstellt: 05. Okt 2016, 14:41 | |
http://www.supportfo...viewfull=1#post95784 Please see here. The later firmware have solved the problem. As you can see , the highest value of Ambilight brightness in SAM mode is 255, not 100 . It just firmware writer's fault to make the highest value 100 and this is really a child's play. |
Philips SAM - Speicherung / Rücksicherung? FlightCom am 11.01.2015 – Letzte Antwort am 12.03.2015 – 3 Beiträge |
Problem mit Ambilight applecom1de am 19.01.2010 – Letzte Antwort am 21.01.2010 – 4 Beiträge |
Philips Ambilight (Problem?) playboy49 am 03.11.2008 – Letzte Antwort am 03.11.2008 – 6 Beiträge |
Ambilight Problem ! Philips 37PFL8404 inc2k am 04.10.2009 – Letzte Antwort am 07.10.2009 – 5 Beiträge |
Ambilight Most_Wanted1 am 15.12.2008 – Letzte Antwort am 15.12.2008 – 3 Beiträge |
Virgin Mode Mellow1980 am 24.11.2007 – Letzte Antwort am 30.11.2007 – 4 Beiträge |
AMBILIGHT? orausch am 16.09.2008 – Letzte Antwort am 17.09.2008 – 10 Beiträge |
32 - 7613 d ambilight problem el_marc0 am 23.09.2008 – Letzte Antwort am 24.09.2008 – 5 Beiträge |
Philips VS Samsung Help Bazzo am 07.12.2007 – Letzte Antwort am 07.12.2007 – 6 Beiträge |
Ambilight defekt darksoldier1984 am 21.10.2009 – Letzte Antwort am 22.10.2009 – 2 Beiträge |
2016
Top 10 Threads in Philips der letzten 7 Tage
- 'interner Speicher fast voll' - Was tun?
- HD+ Operator App funktioniert nicht
- Bluetooth Kopfhörer an Philips TV
- Lauter Knall - TV kaputt
- GELÖST / Defekt / Pixelfehler / Streifen im Bild (mit Kulanzgarantie)
- Philips TV schaltet sich nachts selbst an
- Philips 50pfl3807k/02 Bild flackert und hat Streifen
- [Philips 2022] 4K MiniLED TV xxPML9507
- Philips Fernbedienung (Alu Oval) öffnen
- Umschalten mit Fernbedienung zwischen Radio und Fernseh beim 9715
Top 10 Threads in Philips der letzten 50 Tage
- Registrierte Mitglieder927.074 ( Heute: 1 )
- Neuestes Mitgliedpastathommyk
- Gesamtzahl an Themen1.554.720
- Gesamtzahl an Beiträgen21.620.375
