HIFI-FORUM » Stereo » Elektronik » CD-/SACD-Player & andere digitale Quellen » Philips CD 713 fernbedienbar? | |
Philips CD 713 fernbedienbar?+A -A |
doc_relax
17:02
erstellt: 06. Okt 2009, |
Hallo zusammen, weiß jemand zufällig, ob der kleine Bruder des CD 723, der ohne Fernbedienung ausgeliefert wurde, trotzdem fernbedienbar ist? Der Empfänger ist unter dem Displayglas zu erkennen, aber wenn man ihm unter die Haube guckt, kann man leider nichts weiter erkennen... Viele Grüße doc |
tri-comp
15:56
erstellt: 09. Okt 2009, |
The easiest way to find out is to try with a RC5-code remote. The service-manual doesn't say if the IR-receiver is mounted or not. However, you may be able to decide yourself when you know what to look for. The IR-receiver has position-no.:7810 When you look at the back-side (copper-side) of the front-PCB the IR-receiver is positioned to the near-left of the microprocessor position-no.:7800 It has 3-pins only, indicated by numbers 1 & 3 (2 is not shown but is obviously between 1 & 3 ![]() IF the receiver is NOT mounted it will be very easy to insert one. It's just a standard 3-pin module that could be taken from any scrapped Video (Philips preferred, biggest chance of getting it to work) Pin 1 = Output IR-signal to Microprocessor Pin 2 = +5V (actually around 4,8V) Pin 3 (and MAYBE pin 4) = Ground Pin-4 on the schematic diagram probably refers to a shielding of the IR-module. Yours may have it or not. You also need to make sure the electrolytic capacitor position-no.:2807 (100uF/10V) and resistor position-no.:3808 (47-Ohm/0,25W) are both in place. If not, just mount them and you'll be ready for remote-controlling the 713-CD. (Negative pin of electrolytic cap. 2807 goes to Pin-3 of the IR-module if you are in doubt on how the position it) mfg, /tri-comp EDIT: Ups, just noticed that wire-bridge position-no.:9804 HAS to be mounted for the IR-receiver to work. It makes the Ground-connection to the receiver. It's to the near-left of 3808 with just a couple of resistors between. [Beitrag von tri-comp am 09. Okt 2009, 16:03 bearbeitet] |
doc_relax
11:56
erstellt: 10. Okt 2009, |
Hi Comp, thanks for your help. I don´t know much about RC5 remotes. Do you mean I can test every RC5 capable remote control without entering a specific code first? I have two Philips remotes here, one from a TV and one from a DVD Player. Both don´t work with the CD Player. Now I guess either they are to new and only support RC6, or the IR Receiver is not ready. |
cr
13:41
I would contact the Philips Customer Support and ask them. |
tri-comp
21:42
erstellt: 11. Okt 2009, |
You will just need an AUDIO-Remote with dedicated buttons for a CD-player. Any Philips remote with these buttons will do. mfg, /tri-comp |
_ES_
Administrator |
21:51
Genau. Die Codes für TV oder DVD differieren gegenüber dem CD. Den Job sollte jede Universal-FB unter 10 Euro erledigen können. [Beitrag von _ES_ am 11. Okt 2009, 21:52 bearbeitet] |
CD-Text bei Philips CD 713/23 weise-eule am 24.04.2007 – Letzte Antwort am 05.05.2007 – 3 Beiträge |
Philips CD 713 - Lade öffnet nicht, Transportsicherung? tolk am 09.04.2008 – Letzte Antwort am 10.04.2008 – 2 Beiträge |
CD Player von Philips fernbedienbar machen sschall am 25.01.2021 – Letzte Antwort am 25.01.2021 – 5 Beiträge |
Yamaha CDX-E410 Fernbedienbar? spyne am 13.07.2018 – Letzte Antwort am 16.07.2018 – 2 Beiträge |
CD Player Philips CD 624 pafnuzzi am 07.09.2011 – Letzte Antwort am 07.09.2011 – 2 Beiträge |
Philips CD-Recorder pole am 06.10.2003 – Letzte Antwort am 06.10.2003 – 7 Beiträge |
Philips CD 940 Problem pet2 am 02.06.2006 – Letzte Antwort am 05.06.2006 – 4 Beiträge |
Philips CD 303 Densch am 28.06.2006 – Letzte Antwort am 28.06.2006 – 3 Beiträge |
Fernbedienung Philips Cd 930 Densch am 22.01.2007 – Letzte Antwort am 31.01.2007 – 5 Beiträge |
Philips CD 960 Riemensatz fineline am 06.04.2007 – Letzte Antwort am 07.04.2007 – 2 Beiträge |
Top 10 Threads in CD-/SACD-Player & andere digitale Quellen der letzten 7 Tage
- Wie viel Sinn machen 32 Bit, 192 kHz und 384 kHz?
- Musik CD abspielen mit BluRay Player
- Laufwerksgeräusche von CD-Playern
- Klangverlust durch XLR auf Cinch?
- Bluesound Node + ext Netzteil Teddy Pardo
- Was tun , wenn CD nicht erkannt wird?
- CD-Wiedergabe - knistern etc
- Panasonic SC-PM02 erkennt USB-Stick nicht
- Wann wird Jitter hörbar? Und kann man Digitalgeräte mit hörbarem Jitter tatsächlich kaufen?
- Marantz SA 11 S3 oder Ruby KI
Top 10 Threads in CD-/SACD-Player & andere digitale Quellen der letzten 50 Tage
- Registrierte Mitglieder928.750 ( Heute: 4 )
- Neuestes Mitgliedmarienberg
- Gesamtzahl an Themen1.558.884
- Gesamtzahl an Beiträgen21.712.980
