HIFI-FORUM » Fernseher & Beamer » HDTV » HDTV-Receiver » Duolabs QBox HD | |
Duolabs QBox HD+A -A |
Bionic66
23:44
erstellt: 11. Nov 2008, |||||
- 266 MHz ST40 CPU SH4 Core. STi 7101 based. - Linux Operating System - Linux DVB-API compatible. - 2,2” TFT high definition Display - WiFi - 802.11n. Stand-Alone internal Module 3 Antennas. WEP/WPA/WPA2 supported. - 2 x Common Interface Slots - Ethernet 10/100 MBit compatible interface - MPEG-2 / H.264 Hardware decoding - Tuner: DVB-S2, DVB-C, DVB-T - 3 x Tuner Module Input - Plug&Play - 2 x Smartcard-Reader ISO 7816-3 with programmable clock speed - V.24/RS232 Interface - 10/100Mbit Ethernet Interface - 2 x Scart (RGB, FBAS or S-Video) - HDMI Output - 2 x USB 2.0 external USB - 1 x USB 2.0 internal for FileSystem - S/PDIF Interface for digital bit stream out (AC-3) - 8 MByte NOR for Secure Bootloader, 128 MByte RAM - Internal SATA for PVR Use either as internal SATA HDD 2,5“ - unlimited channel lists for TV/Radio - EPG (electronic program guide) - multiple LNB-Switching control (supports DiSEqC) - OSD in many languages and skin-support - Videotext Decoder DVB-S2 Tuner: Frequency Range 950 .... 2150 MHz Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK) Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK) Video decoder: Video Compression MPEG-2 and MPEG-1 compatible, H.246 Video Formats 4:3 / 16:9 Letterbox for 4:3 TV-Device Capable Resolution: (1080I, 720P, 480P/576P, 480I/576I) Audio decoder: Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3 Audio Mode Dual (main/sub), Stereo Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz Video parameter: Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm Teletext filter in conformity with ETS 300 472 Standard TV-Scart: Output: FBAS, RGB, S-Video Serial Interface RS 232: RS232 bidirectional BitRate 115,2 kBit/s max. Plug Connector SUB-D-9 Function: Update of Firmware Ethernet: 10/100 MBit compatible interface Function: Update of Firmware SATA Interface: For use either as internal HDD 2,5“ USB 2 x USB 2.0 Host 1 x USB 2.0 Host Internal Slot for USB stick to hold the Firmware. Count of active satellite position diSEqC 1.0/1.2 SAT POSITION / SAT OPTION DiSEqC - Rotor Control Power Supply: Input: 110-240V AC / 50-60Hz / 0,6A Physical specification: Ambient Temperature +15°C...+35°C Humidity < 80% Size (W x D x H):370 mm x 230 mm x 60 mm Weight: 2,5 kg ca without HDD ![]() ~ 450 € |
Oldboke2
11:48
erstellt: 12. Nov 2008, |||||
Das ist, mit Abstand, der hässlichste Receiver, den ich je gesehen habe. ![]() Wo gibt es dieses "Schmuckstück" denn zu kaufen ? |
Seelenfaenger
12:05
Es zählen nur die inneren Werte und wenn die stimmen, wird das bestimmt eine ernstgemeinte Alternative zur Dream, da diese Box auch Enigma 2 beherrscht, dürften auch die meisten Dream-Plugins ohne größere Probleme laufen. Dazu noch der Benefit mit der imbedded Diablo oder WLAN, da kann m.M. nach die Box noch "häßlicher" daherkommen..... Bin schon auf die ersten Erfahrungsberichte gespannt! |
ciaccom
16:37
die gäbe es auch noch in anderen farben - blau, grün, orange, schwarz. zu haben angeblich ab dezember (dieses jahr ![]() also für die features und doch auch den eher renomierten hersteller - dualoabs - sieht die box zu dem preis (~450EUR) seeehr interessant aus - fast halb so teuer wie die dreambox 8000 (wenn sie dann jemals zu haben sein wird). gruß, ciax |
Leo_Feuerstein
17:03
Vielleicht kann man sie ja im Gehäuse einer alten DB unterbringen ![]() Der Preis ist natürlich unschlagbar. Ich warte mal ab, ob sie auch hält was die inneren Werte versprechen. |
Bionic66
19:04
noch mehr infos und bilder, u.a. auch vom innenleben gibt es hier: ![]() ![]() ![]() ![]() |
RayPutzi
20:14
ja verdammt, sowas kann nur eine Mutter lieben :-) mal im Ernst: "schick" ist was anderes... |
Die_Antwort_ist_42
20:20
Naja, da sage ich nur "Affe und Seife" = Geschmackssache ![]() Ich finde ihn in komplett schwarz gut: ![]() [Beitrag von Die_Antwort_ist_42 am 19. Jan 2009, 18:55 bearbeitet] |
Bionic66
21:37
also, ich finde ihn nicht häßlich! und ein farbtupfer in manchem teilweise neumodern-schlicht-kaltem wohnzimmer muß auch nicht schlecht sein. mal ehrlich, wenn ich was häßlich und gar nicht gelungen finde, ist es das design der dreambox, mit dieser "kurve" zum aufklappen!!! |
ciaccom
10:11
erstellt: 13. Nov 2008, |||||
naja, ich würde schon meinen, daß Duolabs in dem bereich einiges auf lager hat - sprichwort: diablo, dragon .. klar, sind keine receiver, doch die materie ist in etwa analog.. ![]() über das design will ich gar nichts sagen - zu cool sieht sie nicht aus, aber man gewöhnt sich an einiges - "prototypendesign" .. ![]() gruß, ciaccom [Beitrag von ciaccom am 13. Nov 2008, 10:13 bearbeitet] |
RayPutzi
13:02
letztendlich ist das hier ja auch nen Technik-Forum, über Design zu streiten macht keinen Sinn hat doch jeder eine eigene Vorstellung von "schön"....und mir gefällt er nicht. Aber egal! Wie sich der Receiver im Test schlägt ist sicher viel wichtiger. Mit den Diabolo-Genen versehen hat der kleine sicher andere Qualitäten und andere Ansprüche an seine kommenden Fans! Also einfach mal abwarten! |
BigBlue007
15:05
Eigentlich ist sie eher digital... ![]() Trotzdem hat das absolut nichts miteinander zu tun. Ein Receiver samt PVR-Funktionen und ein CAM-Modul (noch dazu ein "Halblegales") haben kaum was miteinander zu tun, außer halt, dass man Letzteres in Ersteres reinstecken kann. Und da mein ursprüngliches Posting gelöscht wurde, hier nochmal in netter:
Bei einem technischen Gerät, das üblicherweise im Wohnzimmer steht, zählt für jeden Menschen, der halbwegs Wert darauf legt, wie es bei ihm aussieht, natürlich auch das Design. Egal ist das eigentlich nur, wenn das Ding entweder hinter einer Wand verschwindet oder in einem Kinder- oder Jugendzimmer steht... ![]() Ob man dieses spezielle Teil hier schick findet oder nicht, ist natürlich Geschmacksache. Aber die grundsätzliche Aussage, dass bei sowas nur die inneren Werte zählen und das Design folglich überhaupt nichts, ist natürlich unsinnig. [Beitrag von BigBlue007 am 13. Nov 2008, 15:09 bearbeitet] |
ciaccom
17:05
stimmt eigentlich ![]()
.. trotzdem meine ich, dass DuoLabs keine "popelfirma" ist, wie bei so manchen anderen HD-PVR-receivern. gerade das "halblegale" dürfte so manche reizen ... ![]()
.. so böse war das doch gar nicht ![]() geschmackssache - wie gesagt. ich finde die box eigentlich gar nicht soo häßlich ... ![]() [Beitrag von ciaccom am 13. Nov 2008, 17:07 bearbeitet] |
BigBlue007
17:17
Bis vor Kurzem wäre das wohl auch so gewesen. Im Moment dürfte das hingegen kaum jemanden interessieren... ![]() |
ciaccom
13:09
erstellt: 14. Nov 2008, |||||
.. das böse ding darin hat bisher immer am "frühesten" etwas erleuchtet .. upps! ![]() [Beitrag von ciaccom am 14. Nov 2008, 13:10 bearbeitet] |
Cabi
15:34
hm, also ich find der Receiver sieht nicht schlecht aus. Farblich passt er halt nicht überall hin, aber so wichtig ist das doch nicht. Ich kann auch nicht nachvollziehen wie man auf einen guten Receiver nur wegen dem Aussehen verzichten kann. Klar bei Möbeln, Sofa etc... ist das aussehen sehr wichtig, aber so ein kleiner Kasten fällt doch kaum auf und er ist jetzt ja nicht lila o.ä ![]() |
Leo_Feuerstein
15:59
Ob er gut ist, muss er ja erst noch beweisen ![]() Dann würde ich aber auch das Aussehen in Kauf nehmen. |
BigBlue007
16:51
Wenn er wirklich richtig gut ist, dann ja. Und in vollschwarz ist er ja auch ok. ![]() Vorher finde ich persönlich aber die Azbox HD Premium erheblich interessanter. Aussehen tut DIE wirklich gut (alleine schon das Display wäre der Hammer, wenn es wirklich so käme), und preislich nochmal deutlich interessanter. OK, kein Enigma. Man kann halt nicht alles haben... ![]() |
Packe
23:38
erstellt: 15. Nov 2008, |||||
Die Beschriftung vom Display könnte man ab bekommen. Dann ist esdoch ein sehr guter Reciever der die Dream 8000 richtig in die Preisrichtung weißt. Leider kannman nur eine 2,5" Platte einbauen, aber dre SATA lässt sich estimmt nach außen legen. Alle Plugin der Dream kan man verweden, schlecht für die Dream. MFG Packe |
aroaro
23:57
ooch Leude, so einfach is das nich nur weil E2 läuft die Python Plugins laufen auf anderer Architektur nicht automatisch viele der Python Plugins gehen auch schon auf der Kathi mit oder ohne Anpassung Was definitiv nicht geht sind Binär Files die für Mipsel kompiliert wurden und "laufen" heisst nicht "gut laufen" - Python ist eine Interpreter Sprache - d.h. CPU-lastig, und da wird der Engpass sein verbreitet doch keine falschen Versprechungen aber etwas wirkliche Konkurrenz für DMM kommt allen zu Gute, große Versprechungen wurden ja schon von einigen gemacht, und auch ich hab schon zwei Mal fehlgekauft (...und jeder der das Teil kauft, und seine Sat-Anlage auf 8°W erweitert, spart garnix zu einem Abo ... ![]() [Beitrag von aroaro am 16. Nov 2008, 08:55 bearbeitet] |
alex1971
11:47
erstellt: 16. Nov 2008, |||||
Sobald die QBOX-HD verfügbar ist liegt sie für mich im Warenkorb ;-) Falls sie wirklich zu diesem Preis kommt und auch mit dieser Funktionalität, wird sie der Dreambox8000 sofort das Wasser abgraben... wieso dann noch 900 euro ausgeben... [Beitrag von alex1971 am 16. Nov 2008, 11:53 bearbeitet] |
mmtux
16:51
Kaufen würd ich mir das hässliche Ding nicht... Was mir gerade ziemlich dreist erscheint ist, dass das Ding irgendwie eine Kopie der Dreamboxen ist ![]() ![]() ![]() [Beitrag von mmtux am 16. Nov 2008, 16:51 bearbeitet] |
windtalker
17:09
#25
....das kann man schon alles woanders lesen.Nichts Neues also.Würde vorschlagen, die Praxis entscheiden zu lassen... Gruß windtalker ![]() |
alex1971
17:56
#26
Die Fernbedienung der QBOX ist vom gleichen OEM Hersteller wie die der Dreambox.. dafür gibts ja OEM-Produkte... Da die Qbox auf einen völlig anderen Chipsatz (nicht kompatibel) besitzt, kann man auch nicht von einer Kopie sprechen. Die Vorabeit in Sachen Enigma2 macht ja gerade das TDT (TeamDuckTales) für u.a. die Kathrein UFS-910. Bis die QBOX-HD auf dem Markt kommt, haben bereits viele Kathrein Besitzer kostenlos Beta-Tester gespielt (finde ich aber positiv für die Kathrein-User..) |
Packe
20:38
#27
Ist auch für alle gut, wenn es getestet wird. Dann kan es ja auch gleich beim 922 weiter ghen. Die Fernbedienung der Qbox ist baugleich, aber die Box nicht. Die Dream 8000 soll einen Broadcom drin haben. MfG Packe |
mmtux
21:24
#28
Na dann warten wir mal ab. Das Problem mit den binär kompilierten PlugIns für den Mipsel wird aber immer noch bestehen ... ![]() |
Packe
20:48
#29
erstellt: 17. Nov 2008, |||||
Da ja auch für das Modul von Denen immer noch Support beibehalten wird, denke ich haben die auch was für die Q-Box. Gruß Packe |
Bionic66
02:20
#30
erstellt: 23. Nov 2008, |||||
so, laut einem telefonat mit dem hersteller duolabs soll die box noch mitte dezember in deutschland erscheinen. ![]() scheint also los zugehen, es sollen wohl echte fachleute an der box sitzen. es gibt jetzt übrigens auch ein neues forum speziell für die duolabs Qboxen, dieses ist jetzt auch offizielles supportforum mit kontakt zum hersteller und distributor. ![]() grüße Bionic |
windtalker
11:04
#31
Hi, habe gerade mal reingeguckt......und, wen findet man da???Na??? @tommy(vormals @tommyspain)und Co,wie @habibi,@tobangi et all.Ist ja ne sehr rürige und auch geschäftstüchtige Truppe. Letzte Idee: Manual der Dreams gegen Cash.Tja so kann man sein Beginner Board, Black-Box-Board etc, auch betreiben. Bin mal gespannt, wie er das Q-Board aufziehen wird. Gruß windtalker ![]() PS: Betreiber: Firmensitz/ Adresse TOBARO Service LTD. MC 8366 P.O.Box 6180 Jersey, UK 46206-6180 E-Mail: office@tobaro.org [Beitrag von windtalker am 23. Nov 2008, 11:59 bearbeitet] |
aroaro
15:08
#32
erstellt: 30. Nov 2008, |||||
![]() der Preis ist aber auch heiß - so ein großer Preisvorteil wird das nun auch nicht (in Vollausstattung) aber abwarten (wie immer) |
sattaz
19:39
#33
@aroaro, Ich weiss nicht ob es als nicht so gross zu bezeichnen ist aber in gleicher Ausstattung (2xDVB-S2 + 1xDVB-T) beträgt der Preisvorteil so ungefähr um die 500 Euro. Wobei die Qbox HD als Extra nog ein internes Diablo Cam hat dass bei der Dreambox 8000 HD DVD nicht anwesend ist. Mit freundlichen Grüssen ![]() sattaz [Beitrag von sattaz am 30. Nov 2008, 19:40 bearbeitet] |
Bionic66
19:50
#34
wieso Dreambox 8000 HD DVD? muß man das dvd-laufwerk nicht extra dazukaufen? ------- tja, dann bin ich mal gespannt, was hier weihnachten zu lesen sein wird, wenn jemand eine von den boxen bekommen kann |
sattaz
20:51
#35
@Bionic66, Es stimmt was du sagst, das DVD-laufwerk muss dazu gekauft werden. Aus Gewohnheit schreibe ich es (leider) manchmal so. Richtig ist gewiss DM 8000 HD ![]() Mit freundlichen Grüssen ![]() sattaz |
fesko
09:50
#36
erstellt: 01. Dez 2008, |||||
Hallo, wo steht denn, dass die HD Box das Diablo intern verwendet??? Bei der normalen Box wurde das mit angepriesen, aber bei der neuen kann ich es nirgends lesen. Ist das nun drin oder nicht? Habe soeben gelesen, das das WiFi auch nur optional ist und das schon bei 450€ ![]() Gruß Fesko [Beitrag von fesko am 01. Dez 2008, 11:12 bearbeitet] |
Bionic66
18:56
#37
genau, so viel geld für einen triple-tuner-receiver! frechheit! andere hersteller verlangen da viieeeel weniger! sorry, aber wirklich ![]() ![]() ich denke, du hast gelesen? der link steht oben, für dich jetzt hier: ![]() grüße |
humax-hasser
19:45
#38
Wenn der EMU wieder rennt, wird diese Box Papa's Liebling! ![]() HH. |
BigBlue007
19:54
#39
Bis es soweit ist, kräht nach dieser Box freilich kein Hahn mehr - vermutlich wird sie dann nichtmal mehr produziert... ![]() |
Bionic66
20:13
#40
was so natürlich auch für die dreamboxen gelten dürfte. oha, für den unbedarften hört sich das so an, als würden die boxen defekt ausgeliefert. ![]() man könnte sich aber zumindest doch die kosten für ein alphacrypt oder sogar nds-modul sparen, was sagt du so als fachmann/frau? ![]() |
meier2003
08:31
#41
erstellt: 02. Dez 2008, |||||
Also ich finde das Ding absolut suspekt und bin mir nicht sicher, ob die Box nicht nur ein Werbegag ist. Hat irgend wer schon mal irgend was offizielles vom Hersteller zu der Box gesehen? Ich finde generell nur Foren im Netz, in denen überall der gleiche Salat von technischen Daten gepostet wird und maximal ein paar bunte Bildchen. |
Bionic66
17:28
#42
hab ich grade gelesen |
meier2003
06:33
#43
erstellt: 03. Dez 2008, |||||
Hab ich auch gelesen. Allerdings verweisen die Aussagen immer auf einen .it Webshop, der angeblich ab 20. liefern will. |
fesko
12:29
#44
Sorry, aber irgendwie sollte man bei den Tatsachen bleiben. Tripple Tuner? lol Der wird mit DV-S2 und evtl DVB-T ausgeliefert! Hinzukommt das Wifi noch garnicht erhältlich ist! Alles Versprechungen, die nicht eingehalten werden, wie bei allen Herstellern. Und wer sagt Dir , dass zwei DVB-S2 Tuner nebeneinander laufen? Man kann ja hoffen, aber bisher haben alle Hersteller total versagt im HD-Receiver Bereich! Gruß Fesko |
aroaro
21:03
#45
ciaccom
11:48
#46
erstellt: 05. Dez 2008, |||||
.. jetzt auch offiziell auf der Duolabs HP ![]() --> ![]() grüße edit: .. und auch schon in diversen ausführungen aufgelistet zB. --> ![]() bzw. geizhals.at --> ![]() edit: .. allerdings schon ein wenig suspekt - siehe feature list und auslieferungsdatum über den online-shop auf duolabs homepage (mindestausführung 1x DVB-S2 + 1x DVB-T, "WiFi" 802.11N optional ?) --> ![]() [Beitrag von ciaccom am 05. Dez 2008, 12:07 bearbeitet] |
skondus
13:29
#47
erstellt: 10. Dez 2008, |||||
ciaccom
14:30
#48
erstellt: 11. Dez 2008, |||||
na das ist ja wohl ein beschi..enes demo ![]() |
whopper1
22:57
#49
erstellt: 23. Dez 2008, |||||
Da wird doch deutlich gezeigt das Enigma2 nicht rund läuft und das das Umschalten ewig dauert! Bin froh das es endlich ne Alternative zur Dream 8000 gibt, hab selber ne 7025 und bin bis auf die Welt hässlichste und billigst wirkende Fernbedienung zufrieden! |
Bionic66
19:47
#50
erstellt: 02. Jan 2009, |||||
Qbox HD Disponibility: Stock € 449.00 im shop von ![]() will denn keiner zuschlagen und den ersten erfahrungsbericht schreiben? ![]() |
whopper1
23:49
#51
Ich hätte schon Interesse nur traue ich dem ganzen nicht, hab ein schlechtes Gefühl bei dieser Box, die Hardware passt so wie ich mir ne Box wünschen würde, nur glaube ich noch nicht ganz das Enigma 2 Offiziell unterstützt wird, also das es auch immer weiter Updates geben wird! |
Bionic66
22:53
#52
erstellt: 14. Jan 2009, |||||
![]() immer noch keiner zugeschlagen? ![]() |
Schoko666
19:57
#53
erstellt: 15. Jan 2009, |||||
Nö denn in wirklichkeit gibs die noch garnicht. Das erfährt man aber nur wenn man bei denen direkt nachfragt. Soll ende des Monats kommen... ![]() |
Marusys MS750S VU+ Duo Twin Linux HDTV Receiver PVR ready Bionic66 am 25.11.2009 – Letzte Antwort am 04.03.2012 – 2036 Beiträge |
Clarke-Tech ET9000 Enigma2 Twin Tuner roft am 12.12.2010 – Letzte Antwort am 09.03.2016 – 5618 Beiträge |
Xtrend ET8000 kalle1111 am 24.03.2014 – Letzte Antwort am 26.03.2014 – 2 Beiträge |
Marusys MS-630S Linux HDTV PVR Receiver Bionic66 am 19.08.2009 – Letzte Antwort am 05.11.2009 – 11 Beiträge |
Marusys MS-850S Twin Linux HDTV PVR Receiver Bionic66 am 19.08.2009 – Letzte Antwort am 22.08.2009 – 6 Beiträge |
Philips PFS0001 DVB-S2 Receiver Neu auf Ifa It-meister am 04.08.2009 – Letzte Antwort am 09.12.2010 – 59 Beiträge |
AB IPBox 9000HD wauwau am 14.10.2007 – Letzte Antwort am 16.05.2009 – 45 Beiträge |
Octagon SF 1018 HD-ALLIANCE Bionic66 am 05.06.2009 – Letzte Antwort am 15.03.2012 – 381 Beiträge |
DVB-C HDRekorder Aufnahmeformate Almdudler189 am 27.04.2010 – Letzte Antwort am 28.05.2010 – 7 Beiträge |
MVISION HD 200 Combo = DVB-S2+DVB-T2 : Meine Erfahrungen. aren08 am 27.12.2008 – Letzte Antwort am 15.05.2009 – 2 Beiträge |
- Registrierte Mitglieder928.718 ( Heute: 5 )
- Neuestes MitgliedJalali
- Gesamtzahl an Themen1.558.824
- Gesamtzahl an Beiträgen21.711.598
