HIFI-FORUM » Car-Hifi » Car-Hifi: Endstufen » Rainbow Germanium Four 2ohm load | |
Rainbow Germanium Four 2ohm load+A -A |
Noiseprojekt
08:12
erstellt: 28. Jun 2019, |
Rainbow Audio are not a big brand in Sweden, thats why im turning to you. Im wondering if the Germanium Four amp allows for a 2 Ohm load in bridged mode. or will it overheat/fail? Thanks. |
Neruassa
08:19
Rainbow does not say yes. So, try it on own risk. |
Noiseprojekt
08:31
Yes, thats why im asking. If anyone tried it and have the knowledge about it. Gonna run 2x Germanium GL-W6 /door and want more than 105-110w/mid Thats why i want to run a bridged Four |
Joze1
Moderator |
08:44
I don't think that it is capable of doing that over a long period. It's a heat sink with a rather small foot print thus has limited cooling capacities and Rainbow is not a brand famous for overbuilding its amps... I mean you could always try it, but I would rather consider using a strong 2 channel amp for this application. Something that puts out stable ~300-500 Watts RMS in a 2 Ohm load. There are several candidates that are able to do so and which are easily available on the market in used condition (though I don't know too much avout the swedish situation there...). I have just recently seen a SPL Dynamics S6002 for instance which would be suited. My experience with bridged 4 channel amps is that even in 4 ohm loads there may be issues already, that's the reason for my conclusion above ![]() |
Magnat Edition Four Limited sanjaycream am 07.11.2010 – Letzte Antwort am 09.11.2010 – 5 Beiträge |
rainbow kraftwerk 2kw wieviel power kingtofu am 22.10.2008 – Letzte Antwort am 29.10.2008 – 7 Beiträge |
Probleme mit Genesis Four Channel Martin_C280_AMG am 07.10.2007 – Letzte Antwort am 08.04.2008 – 5 Beiträge |
Genesis "Four Channel" setzt aus damianbochi am 26.05.2009 – Letzte Antwort am 18.06.2009 – 11 Beiträge |
[gelöst] Helix DB Four Wackelkontakt (?) Thnallgzt am 30.10.2012 – Letzte Antwort am 07.12.2012 – 6 Beiträge |
Magnat edition four limited, Netzteil daweed97 am 01.02.2014 – Letzte Antwort am 02.02.2014 – 5 Beiträge |
Magnat Edition four Limited Protect. Passiyo am 04.03.2016 – Letzte Antwort am 07.03.2016 – 4 Beiträge |
ESX Q-FOUR stark genug? Micha_K. am 27.09.2016 – Letzte Antwort am 27.09.2016 – 3 Beiträge |
Magnat Edition Four - Protect leuchtet Karkadam am 13.08.2019 – Letzte Antwort am 14.08.2019 – 2 Beiträge |
Passt Rainbow dpa 1.2500 zum woofer? Diablo_ am 12.05.2012 – Letzte Antwort am 12.05.2012 – 6 Beiträge |
2019
- Protect Lampe leuchtet !
- Registrierte Mitglieder928.828 ( Heute: 2 )
- Neuestes MitgliedAlex.Post
- Gesamtzahl an Themen1.559.080
- Gesamtzahl an Beiträgen21.717.066
