HIFI-FORUM » Surround & Heimkino » Blu-ray Player & Ultra HD Blu-ray Player » Toshiba HD-E1 Firmwareupdate | |
Toshiba HD-E1 Firmwareupdate+A -A |
Dischei
18:38
erstellt: 08. Feb 2007, |
Soeben von Toshiba die Nachricht bekommen dass ein neues Update zur Verfügung steht. Folgende Änderungen: This firmware update addresses certain disc playback and HDMI/DVI related problems identified by Toshiba. Wers raufgespielt hat kann ja mal berichten. ;-) mfg dischei |
Mark1972
20:23
Gerade mal gecheckt. Also via LAN findet der Toshi kein Update. |
Dischei
20:50
Firmware Update Version: 1.205 Applicable Models: HD-E1 Overview: This firmware update addresses certain disc playback and HDMI/DVI related problems identified by Toshiba. How to obtain and install the update: If you have a broadband internet connection you can obtain the update on-line using the Ethernet port in the back of your HD DVD Player. There are instructions for configuring the Ethernet port on page 44-45 of your user manual. Page 58 of the user manual describes how to download the firmware update. Here is an overview of how to proceed: • To configure the Ethernet port you may need to turn on the DHCP setting. Page 45 of the user manual explains how to do this. • After you have configured the Ethernet port, follow the directions on page 58 to check for a firmware update. • If an update is available for your player, it will take about 30 minutes to download and install. • PLEASE DO NOT TURN OFF THE POWER TO YOUR PLAYER during the update process – doing so could cause the player to malfunction. • If no update is available, the player will quickly exit the update process. • Please refer to your owners manual for full details. If you do not have an Ethernet-based broadband connection or prefer not to use one, you may contact Toshiba Customer Support and request that a firmware update disc be sent by mail. • You can update the firmware using this update disc by following the instructions provided with the disc. • PLEASE DO NOT TURN OFF THE POWER TO YOUR PLAYER during the update process - doing so could cause the player to malfunction. Please note: If you sent Toshiba the Firmware Update Request card included with your player, you will receive an update disc by mail from Toshiba as soon as it becomes available. Frequently Asked Questions: Q1. The HDMI output doesn’t work or works intermittently with the HDMI or DVI input on my HDTV or monitor. Does the new firmware address this problem? A1. Yes. The firmware update will fix any problems with HDMI and DVI connectivity. Should you continue to experience problems, please contact Toshiba Customer Service. Q2. During HD DVD playback I sometimes experience pixelization or ‘block noise’. Sometimes playback stops. Sometimes, playback is not smooth. Does the new firmware address these issues? A2. Yes. The firmware update addresses a number of playability issues. You should also check that the disc is clean. If the disc does not operate at all, check that you have inserted the disc the right way up. If you continue to experience problems, please contact Toshiba Customer Service. |
Mark1972
20:58
Alles gut und schön, aber via LAN Update wird nichts gefunden. Kommt vielleicht noch... |
Zoork
22:53
Bei den Geräten, bei denen schon mal das 1.2 Update aufgespielt wurde, wird das Update auch nicht klappen, ist nämlich die gleiche Version - sagt Toshiba! ![]() |
heh
16:04
erstellt: 12. Feb 2007, |
Hallo, hat das update eine Tonverbesserung (lauter und mehr bass) gebracht ? grüße heh |
Freakie
18:00
erstellt: 22. Feb 2007, |
Bei mir steht immer noch die Version 1.17 und über LAN kommt nix, obwohl Toshiba mir schon 2 emails geschickt hat, daß 1.20 verfügbar sei... ![]() |
heh
18:31
Hallo, wie kann ich die vorhandene Versionsnummer feststellen ? |
HD-BluRay
19:59
Da mein Player astrein läuft werde ich mich hüten, ein Update auzuspielen. ![]() |
Morgi7141
12:04
erstellt: 25. Feb 2007, |
Firmware Update Version: 1.205 hat bei mir einwandfrei hingehaun, 35 Minuten... |
pixel_
14:56
Wann wird wohl das 50hz update endlich kommen... |
heh
16:39
erstellt: 26. Feb 2007, |
Hallo, wo ist denn das Update möglich ? Auf der Homepage von Toshi wird nichts angezeigt ????????????? |
pixel_
18:35
Du musst den Player ans Internet anschliessen... |
Solomon
12:03
erstellt: 02. Mrz 2007, |
Hallo, hat jemand eine Idee, wie ich das Update einspielen kann, wenn ich keinen LAN-Anschluß über DSL etc. habe. Wir leben im Telekom-DSL-Nirvana. Auch KD macht bis bei uns kein Breitband. Das einzige was ich habe ist ein schwaches UMTS-Signal, das ich mit meinem Notebook nutze. Und laut Toshiba wird es keine Update-CDs oder DVDs geben, da ja heute jeder Breitband-Internet hat. ![]() ![]() Wäre mir das vorher bekannt gewesen hätte ich vielleicht auf ein Konkurrenzprodukt gewartet. Ich werde es mir nun 10 x überlegen, ob ich je wieder ein Toshiba-Produkt kaufe Beste Grüße Solomon |
heh
13:31
Hallo Solomon, hast ja im Grunde recht, aber bis jetzt gibt es noch gar kein update, jedefalls nach Aussage der Homepage in Deutschland. Keiner hat bisher bewiesen das er ein Update gemacht hat. Sollte es einmal eins geben kann ich dir nur raten mit dem Gerät zum Händler zugehen und dort das update vorzunehmen. Aber bedenke: Don`t touch a running System. Keiner weiß ob nach dem update es besser ist. Darum mache ich es so: Solange alles bestens läuft (bei mir ist es so) mache ich kein update. heh |
Solomon
14:24
Hallo heh, das Update ist definitv da. Du darfst nur nicht auf der Toshiba Webseite schauen. Diese Info findest Du nur unter: ![]() Die Hotline hat mir das Update auch empfohlen. Vor ein paar Wochen war das noch anders. Da gab es di eInfo von der englischen Toshiba per Email, in Deutschland war es aber noch nicht freigegeben. Beste Grüße Solomon |
heh
14:55
Hallo salomon, danke für info. Ich hab das gerade ausprobiert und festgestellt das mein Player diese Version bereits hat. Deshalb konnte ich wohl nicht updaten. Also neueste Version vorhanden. heh |
abraxox2k4
00:51
erstellt: 05. Mrz 2007, |
Hallo, ich hab grad bei der Toshiba-Hotline angerufen, ob sie mir wie auf ihrer Seite beschrieben eine CD mit der Aktuellen Firmware fuer den HD-E1 zuschicken koennen und die wussten garn nicht von diesem Service(der auf ihrer eigenen Hompage beschrieben ist ![]() Vielen Dank schon mal im voraus und viele Gruesse abraxox2k4 |
Solomon
09:48
erstellt: 18. Apr 2007, |
Hallo, inzwischen habe ich die neue Firmware per CD erhalten. sogar schon 2 x ![]() "Telefon: Sie erreichen uns unter 01805 - 66 00 55 (0,14 €/min) von Montag bis Sonntag (auch feiertags) zwischen 08:00 und 23:00 Uhr." und Email an service.ue@toshiba-teg.com, beides findet man auf der Webseite: ![]() Zuerst wollten die das auch abwimmeln...aber nun habe ich die CD zwei Mal bekommen. Leider wurde eine von meiner Frau entsorgt, sonst könnte ich diese weiterschicken. Beste Grüße Solomon |
Solomon
09:51
Hallo, inzwischen habe ich die neue Firmware per CD erhalten. sogar schon 2 x ![]() "Telefon: Sie erreichen uns unter 01805 - 66 00 55 (0,14 €/min) von Montag bis Sonntag (auch feiertags) zwischen 08:00 und 23:00 Uhr." und Email an service.ue@toshiba-teg.com, beides findet man auf der Webseite: ![]() Zuerst wollten die das auch abwimmeln...aber nun habe ich die CD zwei Mal bekommen. Leider wurde eine von meiner Frau entsorgt, sonst könnte ich diese weiterschicken. Ach ja, ehe ich es vergesse. Die Firmware-Version, die per CD kommt ist die Version 1.3 auf der Webseite wird noch von der 1.205 gesprochen. Es wäre interessant zu wissen, welche Firmware-Version online rüber kommt. Beste Grüße Solomon |
Pulpman
10:27
Und weil Du die FW 2 x bekommen hast, must Du das hier auch 2 x posten. ![]() ![]() |
Felix3
10:37
Gibt es eigentlich einen neuen Update? Die aktuelle 1.3 hat z. B. Probleme mit der HD-DVD "Le Pianiste" - obwohl die meinem Player beilag! |
Bilderspiele
13:33
In den USA gibt es für die G2-Player (second generation) die Firmware 1.5 Diese wird wohl bei uns in den nächsten Wochen über den Netzwerkanschluss verfügbar sein. |
luckybastard
12:52
erstellt: 12. Jun 2007, |
Ach, so steigt man zum Stammgast auf. |
schaguar
18:46
#25
erstellt: 26. Okt 2010, |
Hallo zusammen, ich hab mir vor kurzem einen Toshiba E-1 ersteigert. Ich bin mit der HD-Wiedergabe wirklich sehr zufrieden. Wenn ich allerdings eine normale DVD abspiele fängt der Player nach 20-30 Minuten an zu stocken und bricht die Wiedergabe dann irgendwann mit der Meldung ab er könne die Disc nicht lesen. Ich hab dann einfach mal versucht ein Firmwareupdate zu machen den es ist noch 1.2/T17M drauf aber das verweigert er mit folgener Meldung: Die Software wurde bereits aktualisiert. Der Updat-Vorgang wird beendet. Hast das schon mal jemand gehabt? Hab bei Toshiba angerufen aber die verschicken keine FW Disks mehr und im Netz hab ich keinen Link gefunden der noch geht. Die Toshihotline hat mir ne Firma in Hannover genannt aber da müsste ich den Player hinschicken.... Hat irgendjemnad hier noch ne FW CD übrig? Bin dankbar für jeden Tip! |
1000_Watt
12:00
#26
erstellt: 27. Okt 2010, |
Hallo Schaguar 4.0 ist die neuste und letzte Firmware. Gruß |
schaguar
18:42
#27
Servus, danke erstmal. Aber wie komm ich da denn am besten dran? |
1000_Watt
14:02
#28
erstellt: 28. Okt 2010, |
Hallo Schaguar Bitte bei Google.de hd-e1 firmware eingeben. Bei mir ist der 3. Eintrag "Alle Firmware Up- und Downgrades von: Forum Cinefacts.de". Da ist alles, was dein Herz begehrt. Gruß. |
schaguar
19:40
#29
Servus, vielen dank! Runtergeladen, mit isorecorder auf 1x gebrannt, update in knapp 10 Min gemacht und alles dufte jetzt. Mal sehen ob jetzt ne DVD auch ohne Zwischenfälle durchläuft... Ich geb bescheid aber erstmal vielen Dank! Gruß aus Stuttgart |
schaguar
20:02
#30
hmm, DVD Aussetzter hab ich immer noch aber nun ist der Zeitpunkt immer verschieden, mal bei 8 Min, dann bei 10, ganz unterschiedlich. Hat jemand ne Idee? |
n5pdimi
22:35
#31
Ja, der geht wohl langsam in den Sack. Ich hoffe, der war wenigstens spotbillig in der Bucht, sonst war es meiner Meinung nach der größte Fehlkauf. Zumindest als reiner DVD-Player, und funktionieren tut er anscheinend auch nicht mehr richtig... |
1000_Watt
10:03
#32
erstellt: 29. Okt 2010, |
Hallo Schaguar So schnell werfen wir die Flinte nicht ins Korn! Hast du nach dem Update Initialisiert? Hat der Player einen Permanenten Speicher, wenn ja, den gesamten Inhalt löschen! Sind die DVD Orginale? Da sich nach dem Update die Sache verändert hat, glaube ich an eine Kleinigkeit, aber die erstmal finden, oh oh. Gruß |
Toshiba HD-E1 update wie? Jensabel am 23.08.2007 – Letzte Antwort am 26.08.2007 – 27 Beiträge |
Toshiba HD-E1 Update 1.3 probleme mbmarc am 13.03.2007 – Letzte Antwort am 14.03.2007 – 3 Beiträge |
Newbie-Frage zu FW-Update Toshiba E1 taico100 am 02.12.2007 – Letzte Antwort am 02.12.2007 – 3 Beiträge |
Toshiba HD E1 codefree? Filmfest_Maik am 15.02.2008 – Letzte Antwort am 11.04.2008 – 7 Beiträge |
Toshiba E1 2.0 Firmware pixel_ am 18.02.2007 – Letzte Antwort am 20.02.2007 – 3 Beiträge |
Toshiba XE1 vs. Toshiba E1 matthias-klarinettenspieler am 02.07.2007 – Letzte Antwort am 25.07.2007 – 11 Beiträge |
Toshiba HD-E1 abgekündigt coolmanfrank am 14.11.2006 – Letzte Antwort am 19.12.2006 – 28 Beiträge |
Toshiba HD-E1 noch empfehlenswert ? radeonspeedy85 am 12.11.2007 – Letzte Antwort am 14.11.2007 – 5 Beiträge |
Toshiba HD-E1 und YUV Jensabel am 26.08.2007 – Letzte Antwort am 27.08.2007 – 3 Beiträge |
Toshiba HD-XE1 Codefree Update 3.0 aufspielen? rodin73 am 19.07.2008 – Letzte Antwort am 20.07.2008 – 2 Beiträge |
Top 10 Threads in Blu-ray Player & Ultra HD Blu-ray Player der letzten 7 Tage
- PS5 nicht als UHD Bluray player geeignet?
- Lautes Laufwerksgeräusch bei DVD- und BluRay-Playern
- Sony UBP-X800M2 Ultra-HD Blu-ray Player
- Reavon UHD-Player 2021
- UHD-BR mit DVD-Region-free?
- UHD Blu Ray wird über PS5 nur in 1080p abgespielt
- Panasonic 9004 Nachfolger?
- Beim Abspielen von BluRay nur Ton, kein Bild
- Samsung BluRay Player öffnet nicht das CD-Fach
- Oppo UDP-203/205 Firmware Update Thread
Top 10 Threads in Blu-ray Player & Ultra HD Blu-ray Player der letzten 50 Tage
- Registrierte Mitglieder928.983 ( Heute: 8 )
- Neuestes MitgliedMichael1957
- Gesamtzahl an Themen1.559.424
- Gesamtzahl an Beiträgen21.726.477
