Gehe zu Seite: |vorherige| Erste . 8 9 10 11 12 13 14 15 16 17 . 20 . Letzte |nächste|
OPPO BDP-103D DARBEE EDITION
racethepace
#551 erstellt: 24. Apr 2014, 11:04
habe gerade mal die Tasten VOL + - ausprobiert.
Beim Drücken von VOL + steht die 100 im Display, ich kann den Wert aber durch Drücken auf VOL - nicht reduzieren !?
Ist das bei euch auch so?
racethepace
Mickey_Mouse
#552 erstellt: 24. Apr 2014, 11:14
guck mal in den Einstellungen, da kann man das ändern (fixed/variable)
racethepace
#553 erstellt: 24. Apr 2014, 11:22
Other Audio Processing Settings -> Output Volume: Variable/Fixed
Danke für den Hinweis!
racethepace
djbeat
#554 erstellt: 07. Mai 2014, 22:16
neue Beta verfügbar:
http://www.oppo-blur...d-beta-firmware.aspx
1. Fixed a bug in calculating acoustic propagation delay from the "Speaker Distance" parameters of the "Speaker Configuration" setting.
2. Upgraded the Netflix application to the latest version certified for OPPO BDP-10x models. This version features a brand new user interface. It also contains improved adaptive streaming technology which will improve streaming quality for high-speed internet connections. The new Netflix application should help customers who have reported poor streaming quality during peak hours. (On a related note, recently customers reported that Netflix streaming on OPPO players and other streaming devices could become unstable with error message like "not connect to internet". In our experience this issue is not caused by the player or its firmware update. It could be either a server-side problem or an Internet traffic problem. Should this happen to your device, please report the outage to Netflix. Netflix recommends a troubleshooting method of de-activating the device and re-activating it. De-activation can be done from the OPPO player’s setup menu (Setup -> Device Setup -> Netflix -> De-activate). Re-activation canbe done by accessing the Netflix application from the Home Menu. In most cases, Netflix service can resume working after a few tries. The new Netflix application in this update contains additional network troubleshooting tool which can be used to test your connection to Netflix servers.)
3. Added the "Digital Concert Hall" application from Berliner Philharmoniker, which provides live and recorded classical music concerts in HD video from leading orchestras all over the world. Removed the "Film Fresh" application which is no longer functional due to the service provider stopping the service.
4. Improved Gapless Playback performance. Resolved issues such as the second track playing twice before moving to the third track, and resolved an issue where the Gracenote information could not be fetched when playing WAV files.
5. Resolved an issue where user settings (Size, Distance, Trim) inside the Speaker Configuration were incorrectly applied to the Headphone Out signal route. We revised the algorithm in this firmware and the Headphone Out signal is no longer affected by the Speaker Configuration changes.
6. Added a safety feature for BDP-103/103D: the "SACD Output" format is set to "PCM" by default. The reason is that the digital-to-analogue converter (DAC) used on these two models cannot adjust the volume for DSD signals, so the analog volume level could automatically switch back to 100 when a DSD stream is detected. This safety feature will force the DSD stream to be decoded as a PCM stream before sending it to the DAC, which can help control the volume when loading SACD disc(s).
7. Added support for the "4Kx2K@50/60Hz" resolution to the BDP-103D/105D (HDMI 1 only, and in YCbCr 4:2:0 format only). The "4Kx2K Output" setting for the BDP-103D/105D is set to "Auto 4K 50/60Hz 4:2:0" by default.
8. Resolved an issue of “Reset Factory Defaults” not erasing the user account for the Youtube Leanback application.
9. Resolved an "A/V Sync" related issue where the A/V Sync data was not be automatically applied to the Coaxial and Optical digital audio outputs after the player was powered on.
10. Improved the file sorting algorithm for the media center (the Music, Photo and Movie options on the Home Menu). The player can automatically detect numbers located at the beginning or end of the filenames and sort the files by the numeric value. Albums with numbered tracks will play in the proper order.
11. Extended support for the PCM audio format for up to 24-bit, 352.8 kHz / 384 kHz via the USB DAC IN port (BDP-105D only).
12. Added the timing adjustment for external subtitles. This can be accessed from the "Option" menu -> "Subtitle Adj." -> "Sync." when playing movies from a USB flash drive or external hard drive.
13. A new version of the Windows driver for the USB Audio DAC is available fordownload here (v2.22). It is compatible with BDP-105, 105D and the upcoming headphone amplifier HA-1. Please uninstall the previous version(s) of the OPPO USB DAC driver from your computer before installing this new one.
BennyTurbo
#555 erstellt: 08. Mai 2014, 06:21
Hat sie schon jemand probiert?
splatteralex
#556 erstellt: 08. Mai 2014, 06:31
In der neuen Video ist ein Test des 103D enthalten, wen es von Euch interessiert! Hat gewohnt gut abgeschnitten...
Huberer
#557 erstellt: 08. Mai 2014, 07:27
Leider noch immer kein Wake-on-Lan in der neuen Firmware, obwohl ich sie diesbezüglich schon angeschrieben habe. Benutze den Oppo auch als Netzwerkplayer der auf meinen WHS zugreift. Leider kann der Oppo den ja nicht aufwecken wenn der WHS im Ruhezustand ist.
Wäre super, wenn so etwas auch mal kommen könnte
racethepace
#558 erstellt: 08. Mai 2014, 08:26
Hallo zusammen,
ich habe mal den Film (Blu Ray) MERIDA mit makemkv gerippt, incl. der Dolby Plus Tonspur (7.1)
Diese Tonspur spielt mein Oppo 103D aber nicht via Fileshare vom NAS.
Die DD 5.1 Tonspur fkt. ohne Probleme.
Ist das jemandem auch schonmal aufgefallen?
racethepace
cege
#559 erstellt: 08. Mai 2014, 10:35
Bei mir funktioniert jedes (HD)-Tonformat, ob von SMB-Freigabe oder NFS.
Was hast Du für die Tonausgabe eingestellt... Bitstream?
racethepace
#560 erstellt: 08. Mai 2014, 10:43
Kann ich heute Abend mal checken, aber von der Disc spielt der Oppo die DD Plus Spur ohne Probleme ab!
dennis75
#561 erstellt: 08. Mai 2014, 13:40
Kann nur Einstellungssache sein, da er bei mir auch jede Tonart die es gibt von der NAS ohne Probleme per NFS oder Samba abspielt!
racethepace
#562 erstellt: 08. Mai 2014, 14:00
Und die Files mit makeMKV erzeugt?
cege
#563 erstellt: 08. Mai 2014, 16:21
Ich nutze auch nur makemkv für die Umwandlung von Blurays - alles ok bislang.
Zugegebenermaßen ist DD Plus 7.1 ein wenig exotisch und ich muss mal sehen, ob ich einen solchen Film finde.
dennis75
#564 erstellt: 08. Mai 2014, 16:23
Ja makemkv. In makemkv hast du auch die richtigen Tonspuren ausgewählt?
racethepace
#565 erstellt: 08. Mai 2014, 16:59
So, Player steht auf Bitstream. Auch ich hatte bisher nie Probleme mit den HD-Tonformaten, bis jetzt bei Merida. Zu Merida muss man wissen, dass das der erste Film war, der in Dolby Atmos aufgenommen wurde!
Im Anhang seht Ihr ein Foto der drei Tonspuren. Dabei liefert der Oppo keinen Ton bei der Dolby Digital Plus Tonspur, die anderen beiden fkt. ohne Probleme. Wie gesagt, bei Wiedergabe von Disc kein Problem, da funktioniert das als 7.1 Tonspur ohne Probleme.
Also wer hat Merida um das mal zu testen ...
Foto
Mickey_Mouse
#566 erstellt: 08. Mai 2014, 17:19
ich behaupte mal, dass da bei der "Konvertierung" (ich fange nicht wieder mit dem Thema an, warum/wie man das überhaupt macht) etwas schief gegangen ist.
Die Dolby Plus 7.1 Trailer (ich habe den Namen der Trailer Seite wieder vergessen) werden hier (103EU) ohne Probleme vom NAS abgespielt, also prinzipiell geht das!
racethepace
#567 erstellt: 08. Mai 2014, 17:26
Ich habe das Rippen mit makeMKV jetzt 3x gemacht, immer das selbe Ergebnis. Ich habe da auch makeMKV in Verdacht ....
Denn viel kann man ja nicht falsch machen mit makeMKV
dennis75
#568 erstellt: 08. Mai 2014, 18:08
Eben, viel falsch machen ist da nicht, Tonspur auswählen und fertig. Mhh komisch.. aktuellste Version haste installiert von MakeMkv?
racethepace
#569 erstellt: 08. Mai 2014, 18:55
Jepp, mit V1.8.10
Und gerade nochmal ausprobiert, den Film über den USB-Stick direkt am Oppo abzuspielen -> gleiches Ergebnis, hatte auch nichts anderes erwartet. Ich habe da auch makeMKV unter Verdacht ...
Mal sehen, werde mal mit FABilio probieren
cege
#570 erstellt: 08. Mai 2014, 21:11
Google mal nach makemkv und dolby digital plus - scheint nicht unbekannt zu sein... das Thema!
Gut, dass DD+ keine wirkliche Rolle spielt. Gefühlt 97% meiner HD-Filme haben DTS-HD und der Rest Dolby TrueHD.
racethepace
#571 erstellt: 09. Mai 2014, 05:49
Da scheint makemkv definitiv einen Bug zu haben, siehe hier aus dem makemkv Forum:
I have some problems ripping the german "Merida" (Pixar's "Brave") Blu-ray. Analyzing the m2ts files with MediaInfo, i found the following audio track:
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=5698
In makemkv erscheint der DD+ Track als 4.0. Das hatte mich sowieso schon gewundert.
Allerdings überrascht mich auch, dass der Post aus dem November 2012 stammt, das sollte m.E. längst gefixed sein!
Mal sehen, ob FABilio das besser macht ...
[Beitrag von racethepace am 09. Mai 2014, 07:08 bearbeitet]
Kinobi
#572 erstellt: 10. Mai 2014, 16:57
Kann der Oppo vobsub?
racethepace
#573 erstellt: 10. Mai 2014, 17:31
Raal2k
#574 erstellt: 15. Mai 2014, 18:36
Die Kombi Oppo 103D und Sharp UQ70 ist ein Traum. Hab nun einen Panasonic Kabelreceiver gekauft und schleife das Bild durch den Oppo. Hat sich extrem gelohnt. Darbee ist einfach genial.
racethepace
#575 erstellt: 21. Mai 2014, 19:38
Die neue Firmware ist da !!
skratchy
#576 erstellt: 23. Mai 2014, 04:31
Hallo zusammen,
Ich mache immer öfter die Erfahrung, dass es eigentlich einen festen Darbeewert im High Def Modus eigentlich nicht
gibt. Mal gibt es Filme, wo man gut mit 65% gut gucken kann! gestern z.B. "Gangster Squad" definitiv to much....
Ansonsten macht der Player schon Spass
Haitek
#577 erstellt: 23. Mai 2014, 13:24
Der OPPO macht mir viel Freude, auch im Audiobereich, besitze recht viele SACD und kaufe zunehmen BD Audio.
Er hat allerdings zwischendurch mal "seine Tage", heißt grüßt mit freundlichem "hello" um dann erst einmal gar nichts zu machen,
ggf muss der Stecker gezogen werden, kommt zwar selten vor, verwundert aber etwas. Jemand eine Idee?
BennyTurbo
#578 erstellt: 23. Mai 2014, 13:26
Das hab ich noch nie gehabt?
Mickey_Mouse
#579 erstellt: 23. Mai 2014, 14:02
ist bei mir (ohne "D") auch schon 2-3 Mal vorgekommen. Dabei lag dann aber immer eine Scheibe (ich bin mir nicht sicher ob immer eine SACD?) im Laufwerk. Auf der anderen Seite konnte ich das aber auch mit genau dieser Scheibe dann nicht ein zweites mal reproduzieren.
Einmal hatte ich es, dass er so gehangen hat, ich aber eh noch Sat-TV gucken wollte und zu faul war aufzustehen. Und nach vielleicht 20 Minuten hat er dann auf einmal die Scheibe eingelesen und angefangen abzuspielen.
Peter_J.
#580 erstellt: 24. Mai 2014, 16:41
das passiert mir mit meinem Oppo auch manchmal, nur mit SADC´s; der Player stoppt nach 3 bis 4 Sekunden die Wiederabe und verweigert die Annahme aller FB-Befehle. Ausschalten, neu starten, die Scheibe entnehmen, neu einlegen, und dann hat es bis jetzt immer funktioniert. Seltsam!
Peter J.
Vv_ReZuS_vV
#581 erstellt: 24. Mai 2014, 16:50
Wollte fragen ist einer von euch von einem pioneer bdp 450 auf den oppo gewechselt? Lohnt es sich?
calle75
#582 erstellt: 25. Mai 2014, 09:18
maSp (Beitrag #524) schrieb:
@lokutus1964
@calle75
Musst doch nicht streamen, der Oppo kann doch auf Netzwerkfreigaben zugreifen und von dort direkt abspielen.
Ja der Oppo findet auch meinen PC im Netzwerk, aber ich soll Benutzname und Passwort eingeben, habe aber sowas nicht vergeben, bzw. weiß auch nicht genau, welches er haben will. TV und Receiver benötigen sowas nicht, um auf den PC im LAN zuzugreifen.
Deshalb bin ich etwas ratlos.
cege
#583 erstellt: 25. Mai 2014, 14:27
Probiere mal gast oder guest und dann ohne Passwort...
calle75
#584 erstellt: 25. Mai 2014, 16:40
Danke für den Tipp, funktioniert bei mir aber nicht. Auch nicht mit dem Namen meines Profiles.
Haitek
#585 erstellt: 26. Mai 2014, 11:43
10XEU-75-0515 ?
Jogitronic
#586 erstellt: 26. Mai 2014, 15:54
10XEU-75-0515 ist richtig
Haitek
#587 erstellt: 26. Mai 2014, 20:16
Thx
calle75
#588 erstellt: 26. Mai 2014, 20:31
OK, habe jetzt auch mal das Handbuch zu Rate gezogen, aber auch keine genauen Informationen dazu gefunden, wie ich das Streaming ermögliche.
Letzten Endes bin ich jetzt auf folgende Einstellungen gestoßen:
Systemsteuerung\Alle Systemsteuerungselemente\Netzwerk- und Freigabecenter\Medienstreamingoptionen
Dort ist es dann möglich, den Oppo für Streaming zu aktivieren.
Jetzt funktioniert es auch endlich.
Gruß,
CALLE
Wutbürger
#589 erstellt: 09. Jun 2014, 12:22
Hallo haitekk,
auch ich habe SACD's gesammelt. Die japanischen Neu Produktionen sind leider nicht in 5.1 abgemischt.
Wo kaufst Du zunehmend BD Audio?
Gruß Wutbürger
t3
#590 erstellt: 11. Jun 2014, 15:36
Hallo Zusammen,
Falls jemand Interesse hat: http://www.hifi-forum.de/viewthread-170-7359.html
Verkaufe oder Tausche meinen Oppo BDP 103EU Darbee Edition !!!!!!
Deswegen der Link am Anfang des Post.
Meldet euch einfach per PM bei mir.
Mit freundlichen Grüßen
t3
[Beitrag von t3 am 12. Jun 2014, 13:21 bearbeitet]
BennyTurbo
#591 erstellt: 12. Jun 2014, 20:22
weiß jemand, wie man mp4v Dateien abspielen kann? Der Oppo erkennt sie noch nicht.... Sind 4K Ultra HD Videos ... der PC spielt sie auch auf Full HD ab, daher hatte ich gehofft ich kann das irgendwie auch dem Fernseher oder Beamer zuspielen.
Danke.
Seeker622
#592 erstellt: 13. Jun 2014, 13:31
Wie ist das mit dem verschieben der Untertitel, funktioniert das zuverlässig ?
Bei einigen Filmen soll dies ja technisch nicht möglich sein(Java ?!), wie sieht das so prozentual aus, sind das viele ?
TheWolf
#593 erstellt: 14. Jun 2014, 08:23
Bei mir hat das bisher immer einwandfrei geklappt.
Man muss nur drauf achten, wo der Untertitel liegt.
Mehr im unteren Bild-Teil: Verschieben nach unten klappt, nach oben nicht.
Mehr im oberen Bild-Teil: Verschieben nach oben klappt, nach unten nicht.
Ist mir bisher weder bei DVD's noch bei BR's aufgefallen.
Aber nicht vergessen: Es gibt auch feste Text-Einblendungen in Filmen, die keine Untertitel sind und die lassen sich dann natürlich nicht verschieben.
Michi121
#594 erstellt: 14. Jun 2014, 12:05
Rrrrrrichtig! Die festen Einblendungen sind ja keine UT, die def Player erstellt, sondern Bestandteil des Films.
Übrigens: Du kannst die UT nicht nur verschieben, sondern auch noch die Text- und Randfarbe einstellen.
Seeker622
#595 erstellt: 14. Jun 2014, 16:50
Hm, also es geht mir nicht darum Filme im Original Ton, mit deutschen Untertiteln zu sehen.
Zum Beispiel der Film "Malavita the Family" deutsche Tonspur, da wird wenn die Franzosen sprechen,
die deutsche Übersetzung im schwarzen Balken angezeigt. Das ist auf einer 21:9 Leinwand natürlich ungünstig, so etwas meine ich.
Generell müsste ich den UT vom unteren Rand nach oben schieben, wobei TheWolf schreibt das genau das nicht geht ?
Mickey_Mouse
#596 erstellt: 14. Jun 2014, 17:06
das ist kein Untertitel der BD sondern gehört zum Film!
Seeker622
#597 erstellt: 15. Jun 2014, 20:34
Oh, sind diese einblendenden, wenn kein UT ausgewählt wurde, also generell Bestandteil des Films ?
TheWolf
#598 erstellt: 16. Jun 2014, 08:05
Von "ganz" unten nach "ganz" oben geht nicht aber das "zeigt" Dir der Oppo auch: Weiter hochschieben geht einfach nicht".
Auch das "zeigt" Dir der Oppo.
Wenn keine Untertitel zum verschieben da sind, dann "verbietet" er das auch.
Mal so nebenbei: Warum probierst Du's nicht einfach aus, dann siehst Du doch, was geht und was nicht.
Seeker622
#599 erstellt: 16. Jun 2014, 17:05
Das würde ich ausprobieren, aber ich wollte mir eigentlich einen gebrauchten kaufen, wenn es dann nicht wie gedacht geht, stehe ich da.
TheWolf
#600 erstellt: 17. Jun 2014, 07:03
Seeker622 (Beitrag #599) schrieb:
... aber ich wollte mir eigentlich einen gebrauchten kaufen ...
Ah, jetzt, ja.
Ist denn jetzt alles klar bei Dir oder haste noch Fragen dazu?
Wutbürger
#601 erstellt: 27. Jun 2014, 13:26
Hallo haitekk, habe Dich schon einmal gebeten, mir zu sagen, wo Du die BD Audio kaufst?
Wäre nett, wenn Du antworten würdest!
Gruß Wutbürger
Oppo BDP-103D (Darbee Edition)
splatteralex am 12.11.2013  –  Letzte Antwort am 12.11.2013  –  4 Beiträge
Oppo BDP-103D und BDP-103EU
SubSon am 18.08.2014  –  Letzte Antwort am 18.08.2014  –  4 Beiträge
Oppo BDP-83SE NuForce Edition
derschröder am 01.07.2010  –  Letzte Antwort am 07.01.2011  –  6 Beiträge
Soundproblem Oppo BDP-105d
DanielP83 am 09.12.2016  –  Letzte Antwort am 27.12.2016  –  2 Beiträge
Oppo BDP-103/103D autom. Umschaltung Modus Bildanpassung
TheWolf am 20.02.2014  –  Letzte Antwort am 15.03.2014  –  4 Beiträge
Oppo 103d Konvertierung von 2D => 3D
Tom2962 am 24.03.2014  –  Letzte Antwort am 28.06.2014  –  7 Beiträge
Oppo 103D und DVP 5000 gleich?
Stephan.M. am 05.06.2014  –  Letzte Antwort am 05.06.2014  –  3 Beiträge
Oppo 103D: Upgrade auf 203 sinnvoll?
peepshow am 30.03.2018  –  Letzte Antwort am 02.04.2018  –  3 Beiträge
Oppo BDP-80
Buschel am 23.01.2010  –  Letzte Antwort am 20.09.2010  –  193 Beiträge
Oppo BDP-93EU Netzstecker
danny1581 am 05.04.2011  –  Letzte Antwort am 05.04.2011  –  3 Beiträge
  • Registrierte Mitglieder928.313 ( Heute: 1 )
  • Neuestes Mitgliedjasonpitcher
  • Gesamtzahl an Themen1.557.921
  • Gesamtzahl an Beiträgen21.690.131
