HIFI-FORUM » Suche / Biete / Verschenke » Biete » Quellen / Abspielgeräte » Beresford Bushmaster 7530 DAC/KHV schwarz + Sboost... | |
Beresford Bushmaster 7530 DAC/KHV schwarz + Sbooster Stromfilter -> zuschlagen!+A -A |
Phln909
10:26
erstellt: 19. Nov 2012, |
Preis: VERKAUFT! Standort: Bremen Zustand: Wie neu. Gekauft 07/12 direkt bei Stanley Beresford, es besteht Garantie. Der DAC wurde zwischendurch für ein Hard- und Softwareupdate eingeschickt, ist jetzt auf dem neuesten Stand und funktioniert 1a. Stromkabel für Deutschland ist dabei. Kein Adapter o.ä. nötig. Der SBooster wurde 08/12 direkt beim Hersteller erworben. Beide Geräte: Technisch und optisch keine Schäden! Aus Nichtraucherhaushalt. Artikelbeschreibung: Zum Bushmaster: The Beresford TC-7530DC Bushmaster DAC is a reference quality, 2-channel audio digital-to-analog converter with market leading performance levels, laden with money saving features, and innovations. Fixed LINE output 4 Digital inputs (2* optisch, 2* koaxial) Powerful Headphone Amplifier (bis 600 Ohm!) AUTO/MANUAL input selector Battery Level Monitor. "I've received this DAC last week, and kept it on constant burn-in for the past five days. I did some side-by-side comparison with the following DACs: 1. Beresford Caiman (Gatorized) 2. Cambridge Audio DacMagic 3. Easter Electric MiniMax 4. Naim DAC Of the four, only Naim DAC did not stay with me; I was only able to listen to it for a few hours while the friend who brought it was staying with me. This means that I was not able to re-listen and check my initial impressions and observations related to that DAC vis-a-vis the Bushmaster. I must say that, to me, the Bushmaster outperformed all four DACs listed above. It just sounded as if it's in a completely different league. What's interesting, shocking even, is that I was able to pre-order this DAC for a price that's way less than the price of a decent pair of interconnects, or even a single entry-level power cable! Talk about the giant killer. The other DACs were on the loaner (except for my Caiman), and have all been properly burned-in. Beresford Bushmaster DAC offers previously unheard continuity in the way it converts digital signal into the analog output. Of course, it goes without saying that it expects/hopes to be fed healthy, noise-free digital signal. Failing to do that, the resulting sound will end up being flat and lifeless. This was confirmed by switching from feeding the DAC from the Logitech Squeezebox Touch to feeding it through Sony PlayStation 3 Slim. The difference in the sound quality between these two digital transports were palpable, and unforgivable. A word of warning: in my case, it took around 48 hours of burn-in time before this DAC could start sounding good. During the first few days, it sounded very nice, warm and authoritative, however with a bit too much rolled off highs. It took about two full days for the DAC to open up and deliver the punch and the bite it is now capable of. Please keep this in mind when evaluating this product. Comparing it to the other DACs enlisted above, I found in those other DACs all kinds of deficiencies that I wouldn't be able to detect otherwise. In other words, without a benchmark that the Bushmaster now establishes, many of the not-so-desirable traits of DACs such as Caiman, DacMagic, even Naim, would've remain unnoticed. For example, I've now discovered that many DACs tend to actually gloss over some of the finer details in music reproduction, leaving it to the listener's brain to connect the dots and fill in the blanks. Not so with the Bushmaster, who is always making sure to dutifully spell all the details out, not leaving anything to the listener's imagination. Furthermore, I wasn't able to detect any syntactical sugar coating from the Bushmaster. Naim DAC, on the other hand, tended to editorialize a bit, and to smear over certain musical details in favor of painting a prettier-than-life picture. Some people may prefer this sugar coating, but I most certainly don't. Similar thing seemed to have been going on with the MiniMax DAC, especially with its tube pre-processing, where a bit of an artificial warmth and a denser-than-expected sound was emanating. At the other end of the spectrum, I found Beresford Caiman to be on a very lean side, quite two-dimensional and harsh sounding. DacMagic appeared to be somewhere in the happy middle, but it was also quite anemic sounding, and of the four in the list, I'd be the least upset if I were to lose that one. In conclusion, I highly recommend you try the Beresford Bushmaster DAC. It's extremely affordable, it is supported by one of the best customer services I've experienced, and it's brain dead easy to return it for a refund in case it doesn't work out for you." Zum Sbooster: "Sbooster - Switch mode power supply upgrade for Beresford Bushmaster DAC The Sbooster is a small filter device that is designed to be used with the switch mode power supply that was provided by Stanley Beresford with the Beresford Bushmaster. The Sbooster Plugs into the existing DC power lead from the manufacturers power supply and then the lead from the Sbooster is plugged into the DC power input socket on the DAC. The SBooster contains components to reduce the ripple and noise on the DC output of the switch mode power supply that was supplied with the DAC. Stanley Beresford has tested the SBooster with the Bushmaster DAC and he recommends it as an approved accessory for the DAC, if you have any doubt about this speak to Stanley Beresford." DAC: ![]() Sbooster: ![]() Für mehr Info bitte die Seiten der Hersteller besuchen. Unzählige positive Meinungen gibt es in diversen Foren! Ich war mit der Kombi bis heute sehr glücklich. Steige aber nun auf einen AVR um und benötige die Geräte nicht mehr. ![]() [Beitrag von Phln909 am 19. Nov 2012, 23:24 bearbeitet] |
Beresford Bushmaster DAC raz86 am 09.12.2012 – Letzte Antwort am 14.12.2012 – 2 Beiträge |
Beresford TC-7520SE Caiman DAC raz86 am 04.06.2012 – Letzte Antwort am 17.06.2012 – 4 Beiträge |
MyTek Brooklyn Dac mit Sbooster Netzteil Happajoe am 27.09.2018 – Letzte Antwort am 03.10.2018 – 3 Beiträge |
lite audio dac-am DAC und KHV - wie neu! noexen am 14.12.2008 – Letzte Antwort am 18.12.2008 – 5 Beiträge |
Marantz HD-DAC1 (DAC, KHV, VV) *reserviert* spawnsen am 20.12.2014 – Letzte Antwort am 06.02.2015 – 2 Beiträge |
MATRIX Mini-i // Klasse DAC/KHV H3liX am 03.07.2015 – Letzte Antwort am 21.07.2015 – 3 Beiträge |
Beresford Caiman 7520SEG DAC D/A-Wandler in OVP Phln909 am 28.11.2011 – Letzte Antwort am 03.12.2011 – 2 Beiträge |
Rega Dac schwarz marty.wap am 15.01.2012 – Letzte Antwort am 26.01.2012 – 3 Beiträge |
Rega DAC schwarz Happajoe am 09.09.2012 – Letzte Antwort am 28.09.2012 – 3 Beiträge |
Beresford TC 7520 buschi_brown am 15.05.2011 – Letzte Antwort am 19.05.2011 – 2 Beiträge |
2012
Top 10 Threads in Quellen / Abspielgeräte der letzten 7 Tage
- Moon Harbour CD-S2 TUBE HDCD Player
- AVM EVOLUTION CD1 PLUS + AVM EVOLUTION DAC3 (Laufwerk + Wandler) in CHROM
- Yamaha CDX 393 MK II -schwarz-
- Marantz CD 273 | mit CDM-2 Laufwerk - Sichel/Schwenklaser
- Tapedeck Crown CTD-2200
- Grundig Fine Arts CD1000 Update,Pics da.
- Stax UA7 , Fidelity Research FR 24 MK2 und Scheu Classic Tonarme
- Thorens TD 320 / TP 16 MK IV mit Audio-Technica At-OC 9 und Straight-Wire Anschlußkabel
- Audionet ART V2
- PIONEER DV-610 AV-S (silber) (SACD & DVD-Audio)
Top 10 Threads in Quellen / Abspielgeräte der letzten 50 Tage
- Audionet ART V2
- Registrierte Mitglieder928.586 ( Heute: 14 )
- Neuestes Mitglieduvomaisie361263
- Gesamtzahl an Themen1.558.521
- Gesamtzahl an Beiträgen21.704.337
