Polk Audio PSW 111 - audiophiler Subwoofer
M@$tEr
#1 erstellt: 15. Jun 2008, 14:20
Preis (Pflichtangabe!): 210€ + Versand
Standort: Apolda
Zustand: sehr gut
Neupreis: 399€
Artikelbeschreibung:
Ich habe den Subwoofer Polk Audio PSW 111 am 15.03.08 neu, also noch reichlich Garantie - Polk Audio gibt 5 Jahre!, über ebay von einem Händler gekauft.
Da ich nun auf hochwertigen Stereosound umsteige möchte ich einen meiner Subs verkaufen.
Der Polk Audio PSW 111 ist ein sehr audiophiler Sub, gut zu vergleichen mit Nubert AW 441 oder einem B&W ASW 300, meiner Meinung nach aber noch einen Tick präziser und pegelstärker.
"The evolution of high performance bass.
The PSW111 Powered Subwoofer delivers powerful, accurate and musical bass from a shockingly small enclosure. Small enough to hide behind (or in) furniture or tuck into a corner, the PSW111 easily disappears from view. But its big bass output will never let you forget that it's there, delivering all the visceral gut rumble for your favorite action movies as well as tight, accurate bass precision for your music. The PSW111 represents a continuing refinement of the highly regarded PSW Series and a great introduction to visceral home theater bass performance. Its compact design is the perfect complement to Polk RM Series and SurroundBar™ loudspeakers.
PSW111 Features:
* Measuring 12-1/8"H X 11"W X 13" D, the PSW111's unobtrusive size hides the fact that it pounds out really big bass.
* It is the perfect complement to Polk RM Series and SurroundBar™ models.
* 8-inch Dynamic Balance Composite Woofer Driver creates “tight,” musical bass.
* Downward firing port couples to the room for more bass impact.
* Powerful motor structure for a higher BL product,(the measure of the motive force applied to the cone) results in louder, deeper and punchier bass than previous Polk woofers in this price category.
* Klippel Optimized woofer – By using a state-of-the-art Klippel Distortion Analyzer, Polk engineers were able to optimize the woofer’s motor structure, voice coil alignment and suspension for the best possible performance even at extreme listening levels.
* Compression Circuitry limits distortion at earth-shaking volume levels.
* Built-in High Current Amplifier supplies all the good, clean power you need for the bass volume and and wide dynamic range necessary to recreate a life-like experience in your home.
* LINE and SPEAKER level inputs on the PSW111 ensure easy hook-up compatibility with virtually any system; There's also an Unfiltered LFE Input for use with low-pass filtered subwoofer output jacks.
* Amplifier features: Adjustable Low-Pass Crossover, Phase Switch and Subwoofer Volume Control to more easily control your bass output and the sub’s blending characteristics with your front stage speakers.
* Signal-sensing “smart amp” Auto ON/OFF Circuitry “knows” when to turn itself on and off.
* Non-resonant MDF construction with internal bracing for deep bass impact with superior detail, accuracy and musicality.
* The PSW111 is available in black only."
Technische Daten:
Maße: 30.80cm H x 27.94cm W x 33.02cm D
Subwoofer 1 - 8" Diameter (20.32cm)
Dynamic Balance Composite Cone
Overall Frequency Response: 38Hz-250Hz
Power Output: 150 watts Continuous Average Output
Dynamic Power Output: 300 watts
Inputs: Speaker level spring terminals, Line level L&R, LFE line level (unfiltered)
Outputs: Speaker level spring terminals
Bilder:
M@$tEr
#2 erstellt: 18. Jun 2008, 17:07
Preis ist noch verhandelbar ...
M@$tEr
#3 erstellt: 20. Jun 2008, 13:54
Neuer Preis: 200€ + Versand
M@$tEr
#4 erstellt: 23. Jun 2008, 14:02
Preisupdate: 190€ + Versand
M@$tEr
#5 erstellt: 26. Jun 2008, 14:30
Preisupdate: 180€ + Versand
M@$tEr
#6 erstellt: 01. Jul 2008, 09:06
*push*
M@$tEr
#7 erstellt: 04. Jul 2008, 16:31
Preisupdate: 170€ + Versand
M@$tEr
#8 erstellt: 07. Jul 2008, 13:09
*push*
M@$tEr
#9 erstellt: 10. Jul 2008, 15:13
*push*
M@$tEr
#10 erstellt: 13. Jul 2008, 17:25
push
M@$tEr
#11 erstellt: 17. Jul 2008, 13:50
Preisupdate: 160€ + Versand !!
M@$tEr
#12 erstellt: 21. Jul 2008, 14:58
push
M@$tEr
#13 erstellt: 24. Jul 2008, 18:05
*push*
BeastyBoy
#14 erstellt: 24. Jul 2008, 20:30
hier ein kleiner Auszug aus den Nutzungsbedingungen:
"Pushen" ist nicht zulässig. Zusätzliche Informationen zum Artikel oder Preisupdates von mindestens 5 % sind OK. Offenbar nur auf "Hochschieben des Angebots" ausgerichtete Beiträge hingegen sind unzulässig.
PhilFS
#15 erstellt: 24. Jul 2008, 21:16
@BeastyBoy: wenn du schon zitierst, dann kürze es nicht so zusammen wie du es gerade brauchst!
Denn dazu steht weiterhin:
(Unter Pushing versteht man das Hervorholen des eigenen Angebots durch einen erneuten Beitrag innerhalb von weniger als 72 Stunden)
Der vorherige Beitrag war älter als 72 Stunden
M@$tEr
#16 erstellt: 25. Jul 2008, 13:54
@ BeastyBoy: PhilS hat vollkommen recht ... also come down
BeastyBoy
#17 erstellt: 25. Jul 2008, 13:57
siehe #8
M@$tEr
#18 erstellt: 25. Jul 2008, 14:22
hast ja recht , sorry, aber man kanns auch übertreiben
M@$tEr
#19 erstellt: 28. Jul 2008, 14:31
Preisupdate: 150€ + Versand !!!
M@$tEr
#20 erstellt: 31. Jul 2008, 17:04
*push*
M@$tEr
#21 erstellt: 03. Aug 2008, 18:15
push
M@$tEr
#22 erstellt: 07. Aug 2008, 13:49
Preisupdate: 140€ + Versand !!
M@$tEr
#23 erstellt: 10. Aug 2008, 14:42
Sub ist reserviert, warte nur noch auf Zahlungseingang ...
M@$tEr
#24 erstellt: 14. Aug 2008, 09:24
VERKAUFT !!!
KEF Subwoofer PSW 2000
supermäxle am 24.08.2007  –  Letzte Antwort am 03.09.2007  –  5 Beiträge
Subwoofer KEF PSW 2500 gebraucht
maga136 am 27.01.2007  –  Letzte Antwort am 12.02.2007  –  6 Beiträge
KEF PSW 1000.2 Downfire Subwoofer
Lelli7 am 20.06.2009  –  Letzte Antwort am 12.07.2009  –  6 Beiträge
audiophiler Standlautsprecher mit Omnes Audio Bestückung Magnetostat
kaschak am 08.08.2010  –  Letzte Antwort am 17.02.2011  –  2 Beiträge
Polk Audio TL2C Center Lautsprecher schwarz
elchupacabre am 20.03.2013  –  Letzte Antwort am 12.05.2013  –  2 Beiträge
Subwoofer Kef PSW 1000,2, ahorn, Garantie
-Puma77- am 07.03.2010  –  Letzte Antwort am 04.04.2010  –  4 Beiträge
Biete KEF Subwoofer PSW 2010 neuwertig
Beosound3000 am 21.11.2010  –  Letzte Antwort am 06.12.2010  –  3 Beiträge
KEF PSW 3500
MR_WD_40 am 17.07.2015  –  Letzte Antwort am 02.08.2015  –  3 Beiträge
Polk Audio RTI 8 / CSI 5 / FXI 5
Forghorn am 13.08.2010  –  Letzte Antwort am 16.08.2010  –  2 Beiträge
KEF q1 (dark apple) 6x + psw 3000
chris77he am 10.09.2007  –  Letzte Antwort am 15.10.2007  –  9 Beiträge
  • Registrierte Mitglieder928.098 ( Heute: 19 )
  • Neuestes Mitgliedpeterlustig12345
  • Gesamtzahl an Themen1.557.439
  • Gesamtzahl an Beiträgen21.679.579
