HIFI-FORUM » Suche / Biete / Verschenke » Biete » Lautsprecher » Verkauft | |
Verkauft+A -A |
boysmile
#1 erstellt: 06. Dez 2010, 23:46 | |
Preis (Pflichtangabe!): 720,- Standort: Saarland Zustand: Bestzustand Artikelbeschreibung: Sound über jeden Zweifel erhaben. Verarbeitung und Look genügen in diesem Falle ebenfalls dem Anspruch auf High End (kann man leider nicht mehr von allen aktuellen Modellen sagen). Nochmals die Beschreibung im Detail: The RSW-12 powered subwoofer extends and intensifies low-frequency output in any audio system. Whether providing all the bass for a system built around small satellites or filling in and reinforcing the bottom end for full-range speakers, it dramatically enhances sonic impact and emotional intensity. The RSW-12 has a rear-firing active driver and a front-mounted passive radiator, both with 12-inch Cerametallic™ cones and rigid, low-resonance cast-aluminum frames. The active driver’s large magnet structure and high-temperature voice coil enable it to deliver rich, clean, thunderous bass down to the bottom of the audible frequency range without sacrificing clarity and detail. It is powered by a high-efficiency BASH® digital hybrid amplifier, capable of 2400 watts dynamic power output. The passive radiator enables the RSW-12 to generate high levels of very deep bass from a sensibly sized enclosure. To ensure seamless blending with a system’s main speakers, the RSW-12 incorporates an exceptionally steep 36dB/octave low-pass electronic crossover with a continuously variable frequency control and a phase switch. A bypass switch allows direct connection to the subwoofer amplifier for use with the crossover built into an A/V preamp or receiver. The RSW-12’s level control is mounted on the side of the cabinet for easy access. Input is line-level via a stereo pair of RCA jacks; another pair of RCA jacks provides unfiltered output for connection to a second subwoofer or other component. An “auto power” feature enables the subwoofer to turn on and off automatically. - Cerametallic cone driver and passive radiator, cast-aluminum frames - High-efficiency BASH digital hybrid amplifier with very high power output - Steep-slope 36dB/octave crossover filter with bypass option - Side-mounted level control for easy adjustment - Auto power feature turns sub on and off automatically ENCLOSURE TYPE 12'' Bass-reflex via 12'' passive radiator AMPLIFIER BASH digital hybrid FTC Rated Power: 625 watts continuous @ <1%THD Dynamic Power*: 2400 watts @ <1%THD AUTO POWER 2 second ON delay, 15 minute OFF delay BANDWIDTH 22-120Hz ± 3dB MAXIMUM OUTPUT 119dB @ 30Hz 1/8 space, 1 meter LOW PASS Continuously variable from 40-120Hz CROSSOVER 36dB/octave slope above 120Hz INPUTS Two line level RCA phono jacks, low pass enable/disable switch for LFE mode OUTPUTS Two line level RCA phono jacks (unfiltered) PHASE Switchable 0-180 degrees DRIVE COMPONENTS One 12'' (30.5cm) Cerametallic cone woofer and one 12'' (30.5cm) Cerametallic cone passive radiator NET WEIGHT 58 lbs. (26.3kg) HEIGHT 16.2" (41.1cm) WIDTH 15.6" (39.6cm) DEPTH 22.8" (57.9cm) w/grille, 21.5'' w/o grille FINISH Black Ash woodgrain vinyl VOLTAGE 110/120 VAC 60Hz EXPORT VERSION 230 VAC 50/60Hz |
boysmile
#2 erstellt: 12. Dez 2010, 10:08 | |
... Hallo, ... gebe ja zu - Saarland hört sich etwas abseits an, ist jedoch gut zu erreichen... und - da ich selbst viel unterwegs bin kann ich - entgegenkommenderweise - auch jemand von weiter weg bis in den Raum Trier oder Kaiserslautern entgegenkommen... [Beitrag von boysmile am 12. Dez 2010, 10:09 bearbeitet] |
boysmile
#3 erstellt: 24. Dez 2010, 16:36 | |
Weihnachten verpasst? 27.12: Preisupdate: 650,- Euro [Beitrag von boysmile am 27. Dez 2010, 11:44 bearbeitet] |
boysmile
#4 erstellt: 30. Dez 2010, 21:14 | |
VERKAUFT! |
Klipsch RSW 12 High End Subwoofer Bastler2003 am 03.07.2013 – Letzte Antwort am 13.07.2013 – 2 Beiträge |
Monitor Audio RSW 12 Subwoofer akourtis am 16.10.2009 – Letzte Antwort am 06.11.2009 – 4 Beiträge |
B&W ASW CDM- Subwoofer, 1000W RMS, in schwarz 666company am 22.01.2014 – Letzte Antwort am 12.02.2014 – 4 Beiträge |
Arendal Sound 1723 Subwoofer 2 ( 2 stück ) KKK101 am 02.02.2017 – Letzte Antwort am 12.02.2017 – 3 Beiträge |
High-End-Boxen I.Q System 200T goemichel am 01.08.2011 – Letzte Antwort am 14.08.2011 – 4 Beiträge |
Verkaufe Klipsch RSW 12 Europameister_Deutschland am 04.01.2009 – Letzte Antwort am 20.01.2009 – 5 Beiträge |
B: Klipsch RSW-12 RealC am 12.11.2008 – Letzte Antwort am 07.02.2009 – 7 Beiträge |
Mission 764 High End - Standlautsprecher -verkauft- pioneertapefan am 10.12.2012 – Letzte Antwort am 22.12.2012 – 3 Beiträge |
PLZ 03099 Klipsch RSW 12 fjordbutt am 24.04.2013 – Letzte Antwort am 29.05.2013 – 6 Beiträge |
B&W ASW 800 High End Subwoofer DonnyE am 12.01.2010 – Letzte Antwort am 14.05.2010 – 20 Beiträge |
- Sonus Faber - Grand Piano Home
- Teufel K300 SW Subwoofer aktiv schwarz hochglanz Kompakt 30
- Dynaudio Foccus in schwarz - Paar
- MBL 323 - Highend Made in Germany - SEAS Bestückung
- BOSTON ACOUSTICS VR2000 - THX Aktiv Subwoofer
- DUNTECH THE MARQUIS
- Biete: Elac FS 247 Sapphire Edition
- Harman Kardon aktiver Subwoofer SUB-TS2BQ
- B&W DM4 in weiss!
- ASW Cantius 604
- B&W DM4 in weiss!
- ASW Cantius 604
- Registrierte Mitglieder928.191 ( Heute: 12 )
- Neuestes MitgliedMrHoschy94
- Gesamtzahl an Themen1.557.659
- Gesamtzahl an Beiträgen21.683.907
