Grace Design m902 Reference Preamplifier / Headphone Amplifier / DAC / Monitor Controller
CHX1968
#1 erstellt: 15. Mrz 2014, 22:50
Preis (Pflichtangabe!): VHB 1000,- € inkl. versichertem Versand
Standort: Oldenburg
Zustand: gebraucht (wie neu)
Artikelbeschreibung:
ich verkaufe meinen Grace Design m902 KHV / DAC / Pre in technisch und optisch absolut einwandfreiem Zustand (Nichtraucherhaushalt). Das Gerät wurde im März 2010 gekauft und besitzt somit aufgrund der 5jährigen Garantiezeit noch Restgarantie.
Das Gerät wird inkl. komplettem Zubehör, Bedienungsanleitung, Rechnung und in OVP verkauft.
Weitere Informationen:
Grace Design Homepage
Stereophile
Ansonsten einfach mal die Suchfunktion hier im Forum nutzen
Grace m902 Features:
- Rear panel XLR's and RCA jacks accept stereo analog, balanced +4dBu and unbalanced -10dBV input sources, respectively.
- Ultra-low distortion 24-bit DAC included as standard and accepts stereo digital input sources in AES3, (XLR) S/PDIF (RCA) and TOSLINK (Optical) formats. Auto sample rate detection and digital de-emphasis filter - sample rates from 44.1 to 192kHz are supported.
- USB input provides a convenient way for user's to enjoy a reference quality monitoring experience when connected to their computer. This interface supports 16-bit audio at 44.1 or 48kHz sample rates.
- The m902 incorporates our unique s-LockTM dual stage PLL (Phase Lock Loop) circuitry for the ultimate in low jitter sample clock stability and sonic integrity.
- A pair of line outputs are provided via RCA jacks on the rear panel for connection to stereo monitors.
- A front panel rotary encoder provides precision level control of both headphone and line output levels and level adjustments are made in 0.5dB steps within a 95dB range.
- An astounding 0.05dB channel level matching ensures true stereo balance at any monitoring level.
- A large, blue 7-segment display is used to show headphone and stereo main output levels.
- Calibration modes provide a means by which a number of m902 system parameters may be adjusted for both headphone and mains outputs. There's also a display dim mode that turns off all LED's except for the main power switch LED.
- The m902 includes an exciting new feature labeled Xfeed that simulates the acoustics of a loudspeaker listening environment which significantly improves imaging while reducing listening fatigue when using headphones. This feature employs carefully designed signal cross-feed, filtering and delay circuits to simulate HRTF (Head Related Transfer Functions).
- High current transimpedance output amplifier design drives 25 Ohm loads. The m902 was specifically designed with low impedance headphones in mind.
- Only the highest quality 0.5% and 0.1% metal film resistors are used throughout and there are no electrolytic capacitors in the signal path. Sealed gold contact relays are used for all signal switching.
[Beitrag von CHX1968 am 16. Mrz 2014, 03:57 bearbeitet]
CHX1968
#2 erstellt: 18. Mrz 2014, 23:18
hoch
CHX1968
#3 erstellt: 27. Jul 2014, 09:46
Verkauft.
Grace Design m902 (KHV, DAC, PreAmp)
bensch am 12.05.2014  –  Letzte Antwort am 17.10.2014  –  4 Beiträge
Micro Cmoy headphone amp - Opamp2227 - Amplifier
collapseandrelax am 25.03.2008  –  Letzte Antwort am 29.03.2008  –  4 Beiträge
Pioneer Reference Stereo Amplifier A-757
unerfahren am 20.03.2008  –  Letzte Antwort am 20.03.2008  –  3 Beiträge
(V) Pioneer A-757 Reference Stereo Amplifier Top Zustand!
Flüssigdünger am 25.06.2007  –  Letzte Antwort am 05.09.2007  –  22 Beiträge
SPL Volume2 - High End Volume Controller + Restgarantie
Ohrnator am 05.10.2011  –  Letzte Antwort am 12.11.2011  –  6 Beiträge
Pioneer Reference M-90a, C-90a etc.
guenti123 am 03.04.2007  –  Letzte Antwort am 18.04.2007  –  2 Beiträge
Biete Micro Headphone Amp
wolffsed am 31.08.2007  –  Letzte Antwort am 06.09.2007  –  4 Beiträge
Dolby Headphone Kopfhörerverstärker Phillips
cosmopragma am 28.09.2007  –  Letzte Antwort am 20.12.2007  –  11 Beiträge
Musical Fidelity A308CR Dual Mono Preamplifier Vorstufe
Andi1986 am 29.09.2011  –  Letzte Antwort am 03.10.2011  –  2 Beiträge
McIntosh Vorverstärker/Multi-Room-Controller CR12
Spectral_ am 13.04.2007  –  Letzte Antwort am 22.04.2007  –  5 Beiträge
  • Registrierte Mitglieder928.946 ( Heute: 2 )
  • Neuestes Mitgliedleonanord5914
  • Gesamtzahl an Themen1.559.345
  • Gesamtzahl an Beiträgen21.724.174
