HIFI-FORUM » PC, Netzwerk & Multimedia » Multimediaplayer » Zidoo X20 / X20Pro | |
Zidoo X20 / X20Pro+A -A |
Ralf65
#1 erstellt: 28. Apr 2018, 06:55 | |
Nach dem Zidoo X10 sollen im Mai nun die Nachfolger X20 / X20Pro auf den Markt kommen, Hochwertige Verarbeitung und ein Gehäuse im Hifi Rastermaß sind hier die äußerlichen Haupteigenschaften die Fernbedienung zu den technischen Eigenschaften gibt es folgende Einzelheiten Zidoo X20 430MM standard cabinet size, all-aluminum case Newly upgraded Realtek 1296 4-core 64-bit A53 processor, high-quality high-power switching power supply, 2G DDR4 memory, 16GB eMMC large built-in storage, Gigabit cable, 802.11 AC 2T2R 867Mbps WIFI , Bluetooth 4.2 interface rich: SATA 3.0*2, USB 2.0*2, USB 3.0*1, TYPEC *1, coaxial *1, optical fiber *1, left and right channels *1, AV output *1, infrared input *1, RS232*1, HDMI OUT *2, HDMI IN 2.0* 1 comes standard with full-function backlight Bluetooth infrared learning triple remote control, remote control without dead ends. Front large LED display. Independent dual SATA 3.0 interface, NSS patented metal hard drive extraction rack, built-in two large-capacity hard drives, intelligent temperature control dual ball silent cooling fan. Dual HDMI output audio and video separation, without upgrading the original amplifier, you can enjoy 4K and HD audio at the same time a new image quality optimization engine technology, optimized HDR to SDR algorithm, even if there is no HDR TV, playback 4K HDR can also be accurately restored Original color Accurate frame rate switching and automatic resolution switching (23.976, 59.94, 25, 30, 50, 60) 4k 60p point-to-point output, wide color gamut HDR/HDR10, 10Bit color depth, 1.07 billion colors True 4K 60P decoding, H.265/HEVC 10bit hard solution Support 4K UHD Blu-ray navigation, powerful subtitles, support for any replacement fonts, a variety of color effects, support for online download subtitles; support SUP and ASS special effects subtitles. Unbeatable poster wall features, fully automatic scanning, automatic categorization of series of videos and TV shows, customizable layouts. Native support for lossless audio formats such as SACD, DFF, DSF, APE, FLAC, WAV, etc. Supports CUE tracking; Supports cell phone control without having to turn on the display device to listen to music. Supports NFS, SMB V2, SMB V1 Multiple Sharing Protocols Supports HTTP, RS232 (Controlled Switching), Control4 Various Ways to Control X20 PRO 430MM Standard Enclosure Dimensions, All-Aluminum Alloy Case New Upgraded Version Realtek 1296 4 Core 64-bit A53 processor, high-quality high-power switching power supply, 4G DDR4 memory, 32GB eMMC large built-in storage, Gigabit cable, 802.11 AC 2T2R 867Mbps WIFI, Bluetooth 4.2 rich interface: SATA 3.0*2, USB 2.0*2, USB 3.0*1 , TYPEC *1, Coaxial*1, Optical fiber*1, Left and right XLR balanced output*1, Left and right channel*1, AV output*1, Infrared input*1, RS232*1, HDMI OUT*2, HDMI IN 2.0* 1 standard full-backlight Bluetooth infrared learning triple remote control, remote control without dead ends. Front large LED display. Independent dual SATA 3.0 interface, NSS patented metal hard drive extraction rack, built-in two large-capacity hard drives, intelligent temperature control dual ball silent cooling fan. ESS 9038 professional DAC audio processing chip Dual HDMI output audio and video separation, without upgrading the original power amplifier, you can enjoy 4K and HD audio at the same time a new image quality optimization engine technology, optimized HDR to SDR algorithm, accurate restore on ordinary TV 4K HDR content Precise frame rate switching and automatic resolution switching (23.976, 59.94, 25, 30, 50, 60) 4k 60p point-to-point output, wide color gamut HDR/HDR10, 10Bit color depth, 1.07 billion colors true 4K 60P decoding , H.265/HEVC 10bit hard solution Support 4K UHD Blu-ray navigation, powerful subtitles, support for any replacement fonts, a variety of color effects, support for online download subtitles; support SUP and ASS special effects subtitles. Unbeatable poster wall features, fully automatic scanning, automatic categorization of series of videos and TV shows, customizable layouts. Native support for lossless audio formats such as SACD, DFF, DSF, APE, FLAC, WAV, etc. Supports CUE tracking; Supports mobile phone control without having to turn on the display device to listen to music. Supports NFS, SMB V2, SMB V1 Multiple Sharing Protocols Supports HTTP, RS232 (Controllable On/Off), Control4 Various Ways to Control eine Übersicht zu den Einstellungen und der Funktionsweise beim X20Pro werden in dem nachfolgenden Video gezeigt X20 Pro der Preis für die X20Pro Version soll den Infos nach bei ca. $600 liegen [Beitrag von Ralf65 am 28. Apr 2018, 07:08 bearbeitet] |
Ralf65
#2 erstellt: 21. Mai 2018, 20:03 | |
Ralf65
#3 erstellt: 09. Jun 2018, 06:31 | |
ein Test des Zidoo X20 |
netbeat76
#4 erstellt: 30. Jun 2018, 11:03 | |
Hi, habe mir nen X20 gegönnt. Ne WD Red 10TB reingesteckt und läuft bisher tadellos! Aus UK schicken lassen. Bin sehr angetan von der Qualität und auch die Lautstärke inkl. der HDD ist ok. Empfehlung meinerseits! VG |
robertx66
#5 erstellt: 30. Jun 2018, 22:58 | |
Preis und Bestelldetails ? |
CHL
#6 erstellt: 01. Jul 2018, 06:01 | |
Ich habe einen X10. Damit hin ich auch sehr zufrieden. Alles läuft top. |
netbeat76
#7 erstellt: 01. Jul 2018, 12:20 | |
@robertx66: über futeko.com für 486 EUR |
reelyator
#8 erstellt: 29. Jul 2018, 10:38 | |
...was sind denn eigentlich die Vorteile des X20 Pro gegenüber den X20? - mehr RAM - Audio Section mit XLR Ausgängen - Gehäusefarbe ... Was noch?? |
robertx66
#9 erstellt: 29. Jul 2018, 14:49 | |
Die Unterschiede sind im 1. Posting fett markiert...-somit hat der Pro noch ESS 9038 professional DAC audio processing chip zusätzlich. [Beitrag von robertx66 am 29. Jul 2018, 14:50 bearbeitet] |
tim631105
#10 erstellt: 02. Sep 2018, 09:14 | |
Der ESS 9038 professional DAC audio processing chip bringt den Leuten aber nur was wenn man viel mit Musik macht oder ? Für Filme hat der kein Vorteil .... |
GorillaBD
#11 erstellt: 02. Sep 2018, 11:54 | |
Der ESS DAC wirkt nur auf die analogen Stereo-Ausgänge des Players. Bietet sich somit nur für Anwender an, die nicht bereits über hochwertige Digital-Analogwandler in Ihrem Stereo-Verstärker oder AV-Receiver verfügen, weil ansonsten diese ja bereits die Wandlung übernehmen können. Filmton wird üblicherweise digital übertragen und daher bringt der DAC hier gar nichts. Den könnte man zwar auch im Player zu analog wandeln, dazu würde es aber analoge 5.1- oder 7.1-Ausgänge benötigen, die der Player nicht hat. GLG GBD [Beitrag von GorillaBD am 02. Sep 2018, 11:59 bearbeitet] |
tim631105
#12 erstellt: 02. Sep 2018, 18:13 | |
Danke für die Info. |
tim631105
#13 erstellt: 03. Sep 2018, 17:22 | |
Welche Vorteile hat der Zidoo X20 zum Dune HD 4K Pro ? |
teufel82
#14 erstellt: 04. Sep 2018, 08:26 | |
das würde mich auch interessieren. vor allem 4k BD-Menu? werden forced Subs (Avatar) dargestellt? |
Tomcat_Kurt
#15 erstellt: 13. Sep 2018, 07:42 | |
bei Futeko ist jetzt der Z10 neu mit Realtek RTD1296DD für Anfang Oktober angekündigt. Sollte doch all jenen genügen, die keine zwei HDD-Buchten wie beim 20/20Pro brauchen und weniger zahlen wollen, oder? VG Kurt [Beitrag von Tomcat_Kurt am 13. Sep 2018, 07:43 bearbeitet] |
bobi007
#16 erstellt: 16. Sep 2018, 10:12 | |
Kommt jetzt in den nächsten Tagen oder Wochen ein Player raus mit dem neuen RTD1296 ?? |
robertx66
#17 erstellt: 16. Sep 2018, 11:13 | |
Sofern die Welt nicht untergeht: schaun mer mal. |
brause
#18 erstellt: 29. Sep 2018, 08:59 | |
Moin, hab mir den X20 auch bestellt. Hardware gut, Software grauenvoll. Videowall kann man noch irgendwie gebrauchen, wobei die auch erstmal alles in einem Screen anzeigt, was an Filmen da ist, es muss jedes mal manuell sortiert werden, nach Genre oder sonstiges. Aber der "Music Player" ist das schlechteste was ich je gesehen habe. Als solches gar nicht zu gebrauchen. Optik Müll, Möglichkeiten zur Anpassung absolut keine, hinzufügen von Musik wirft einfach alles in einem Topf, es wird nach Titelname abgespielt, nicht nach Track, ändern geht nicht. Das für 500 € ? Das kann jeder Billigplayer mind. genau so gut/schlecht. Beim XAiOX R9 Plus war es zb auch nicht besser, der hatte aber zumindest den Google Playstore schon an Board, beim X20 kann man den noch nicht mal nachinstallieren. Alles irgendwie Frickelkisten |
tim631105
#19 erstellt: 30. Sep 2018, 10:56 | |
Wie schaut´s mit den Video Files aus ? Kann er alles .... BD Menu/ ISO...usw. abspielen ? |
bobi007
#20 erstellt: 10. Okt 2018, 08:38 | |
Hallo wie befüllt man die Festplatten vom PC aus wenn die im Player eingebaut sind? Und wenn man nur streamen möchte reichen die 2GB RAM und die 16GB ROM? Würde gerne die Pro Version nehmen wegen mehr RAM und ROM Speicher die Frage braucht man das? Und welche Android Version ist auf beiden drauf? Würde mich über Erfahrungswerte sehr freuen. Meint ihr die Box ist besser als wenn man einen Player mit NAS sich zusammenstellt oder doch besser wenn die Platten im Player sind? Und wie werden die eingebunden in Android? Sind die fest eingebunden und zeigt Kodi diese auch automatisch an? |
brause
#21 erstellt: 23. Okt 2018, 16:50 | |
Moin, also bis auf BD Isos hab ich alles abspielen können. BD Isos habe ich keine. Ich betreibe den X20 mit HDDs , spiele also nicht via NAS etc zu Habe von Zidoo das ZDMC laufen, also das von Zidoo modifizierte Kodi (17.6) Da braucht man keinen Wrapper, alles schon drin und läuft ruckelfrei. Ich nutze noch Addons wie zB Tidal etc. Läuft astrein. Ich denke nicht, dass die 2GB Ram zu knapp sind. Klar, wäre mehr drin, würde sich auch niemand beschweren. Android ist bisher die 6.0.1 drauf 7.1 ist in Mache, gibt eine beta dazu. Mit der derzeitigen FW 1.2.28 (29) Ist der Player, für mich zumindest, ohne den Einsatz von Kodi, nicht wirklich als "großer Player" zu bezeichnen. Einfach zu halbherzig umgesetzt. Was die neue FW mit den neuen Musikplayer 3 bringt wird sich zeigen. Man kann die internen HDDs entweder befüllen indem man sie am/im PC anschließt, dafür sind sie ja an der Front schnell aus den Wechselrahmen entnommen... Oder man spielt zB via FTP zu. Ja, Kodi zeigt die HDDs an. Ich habe mich für den Player entschieden, weil er "Hifi-Maß" hat, 2 HDD Schächte, eine gute Fernbedienung, eigentlich relativ wertig verarbeitet ist... Wobei ich ihn noch etwas modifiziert habe. Denn... Man konnte zeitweise den HDD-Zugriff, sowie den Lüfter hören, wenn dieser hochgedreht hat. Das Gehäuse klingt hohl wenn man drauf klopft. Die Resonanzen der HDDs haben sich auf das Gehäuse übertragen sodass diese hörbar lauter wurden, was mich gestört hat. Habe daher an mehreren Stellen im Deckel, den Seiten und hinten an den HDD-Trägern, Bitumen-Streifen eingeklebt, sowie auf den Auflageflächen in den HDD-Trägern und des Deckels Lenkerband geklebt, um Vibrationen zu mindern. Es hat sich definitiv gelohnt. Obendrein habe ich noch den Kühler getauscht. Im Leerlauf hat das bei mir ca. 9-10°C gebracht. [Beitrag von brause am 23. Okt 2018, 16:50 bearbeitet] |
sven29da
#22 erstellt: 01. Nov 2018, 16:37 | |
Hallo leute, täuscht der Eindruck oder spielen diese Modelle eher eine vernachlässigbare Rolle in der Android Media Player Welt? Wie kommt das Weil die zwei Modelle recht teuer sind? Grüße Sven |
Tomcat_Kurt
#23 erstellt: 02. Nov 2018, 01:44 | |
Hi, bei mir ist heute der Zidoo Z10 eingezogen - und darf bleiben. Hab bisher nur 4k-ISOs probiert, sie laufen aber problemlos. Verarbeitung und Software finde ich sehr gediegen. Beleuchtete, lernfähige FB, sogar ein HDMI-Kabel lag bei. Dafür finde ich 277 Euro angemessen. Okay, kein HiFi-Rastermaß und nur in silber zu haben. Hab keine Platte eingeschoben, sondern per USB 3.0 eine externe genutzt. Lüfter blieb aus, keine Temperaturentwicklung - geiles Teil. Gruß Kurt |
Tomcat_Kurt
#24 erstellt: 02. Nov 2018, 10:47 | |
BD-ISO funktionieren auch Kurt |
sven29da
#25 erstellt: 02. Nov 2018, 11:37 | |
Hallo Kurt, ich bin nur verwundert wegen den X20, da ja im Grunde nichts geschrieben wird. Mich wurde lediglich der X20 wegen dem HDMI OUT für Audio interessieren, aber ist dafür ein stolzer Preis und vermute das die Preise auch nicht zeitnah fallen werden :-( Grüße Sven |
Tomcat_Kurt
#26 erstellt: 02. Nov 2018, 19:19 | |
also der preiswertere Z10 hat ein HDMI-In, auch wenn in der Anleitung nichts darüber geschrieben wird. Out hat er aber nur einen, also keinen separat für Audio VG Kurt [Beitrag von Tomcat_Kurt am 02. Nov 2018, 19:22 bearbeitet] |
sven29da
#27 erstellt: 02. Nov 2018, 20:02 | |
Isch schweis |
tim631105
#28 erstellt: 02. Nov 2018, 20:09 | |
Wo bekommt man den den Z10 momentan ? |
Tomcat_Kurt
#29 erstellt: 02. Nov 2018, 22:17 | |
Über futeko.com zollfrei aus UK, Paypal und ca. eine Woche Lieferzeit mit UPS. Gruß Kurt |
tim631105
#30 erstellt: 03. Nov 2018, 01:06 | |
Danke |
sven29da
#31 erstellt: 03. Nov 2018, 01:19 | |
Sagt mir lieber weil ich den X20 für 300-400Euro her bekomme |
Roadrunner35578
#32 erstellt: 20. Dez 2018, 23:58 | |
Hallo Ich habe mir den X20 Pro bestellt. Im Vorfeld lade ich mir immer schon mal die Bedienungsanleitung. Die ist grauenhaft schlecht. Gerne würde ich den Player mit XLR anschließen, hier fehlt mit bisher die Pinbelegung. Habe Angst das diese anders sind als am Verstärker und was beschädigt werden könnte. Hilfe willkommen. Gruß Michael |
Roadrunner35578
#33 erstellt: 22. Dez 2018, 22:02 | |
Also das mit dem XLR anschließen hat geklappt, ABER das klingt grotten schlecht. Jetzt hab ich den Player mit Coaxial angeschlossen, klingt gleich besser. Sorry aber ich bin Laie und hab Verständnisprobleme die Euch sicherlich als bescheuert vorkommen, aber ich muss ein paar Fragen stellen. Ich schaue fast nur Musikvideos und höre Musik als FLAC. Ich habe nur Front-Lautsprecher, also Stereo. Im Moment habe ich unter "Audio" bei "SPDIF Audio" die Option LPCM 2 Channel" eingestellt. Bei "Playback" unter "Frame-Rate Switch" habe ich die Option "Frame-Rate And Resolution" gewählt. 1. Wird der DAC 9038 Pro immer genutzt, egal wie der Player am Verstärker angeschlossen wird ( XLR, optisch, coaxial ) ? 2. Der Verstärker hat auch einen DAC ( nicht so hochwertigen ). Es wäre ja blöd, wenn der X20 Pro den guten DAC verwendet, die Daten an den Verstärker weiter gibt und der Verstärker die Daten dann nochmals durch seinen schlechteren DAC schickt. Was muss ich wie einstellen ? 3. Was bedeutet RAW u. PASSTHROUGH ? Ich hab das bei Wiki gelesen, verstehe aber nicht wann und ob ich dies hier einstellen muss. Im Moment habe ich unter "Audio" bei "SPDIF Audio" die Option LPCM 2 Channel" eingestellt. Für jede Hilfe wäre ich dankbar. Gruß Michael |
Roadrunner35578
#34 erstellt: 23. Dez 2018, 15:17 | |
Vielen Dank für die Hilfe, es funktioniert jetzt alles SUPER. Frohe Weihnachten. Michael |
Bountyhunter1
#35 erstellt: 29. Dez 2018, 19:35 | |
Kann man beim X20 in der Posterview die Ansicht nach Serien und Filmen aufteilen? Und kann man eventuell das Gerät so einstellen, dass es beim Starten direkt in die Serienansicht geht? |
Klipsch66er
#36 erstellt: 10. Apr 2019, 08:09 | |
Bin grad im Web darüber gestolpert, schaut dem Zappiti 4K HDR Duo Media Player, den auch ich hier zuhause stehen habe sehr ähnlich aus, seis gewollt oder auch nicht. [Beitrag von Klipsch66er am 10. Apr 2019, 08:20 bearbeitet] |
Tomcat_Kurt
#37 erstellt: 10. Apr 2019, 22:56 | |
Hi, das ist ja mal eine Erkenntnis VG Kurt |
sven29da
#38 erstellt: 11. Apr 2019, 00:33 | |
Vielleicht funktioniert dafür der Zidoo besser |
Tomcat_Kurt
#39 erstellt: 13. Apr 2019, 08:26 | |
Hi, der Z10 mit dem selben Chip läuft bei klaglos, auch Urlaubsvideos in 4k-ISO mit HDR. Kurt [Beitrag von Tomcat_Kurt am 13. Apr 2019, 08:27 bearbeitet] |
Zidoo X10 Ralf65 am 11.04.2017 – Letzte Antwort am 18.04.2018 – 40 Beiträge |
Zidoo Z1000 werlechr am 04.09.2019 – Letzte Antwort am 07.09.2019 – 3 Beiträge |
Zidoo X6 Pro - Sammelthread grummel2005 am 30.12.2015 – Letzte Antwort am 26.05.2016 – 112 Beiträge |
Zidoo mit 4k120hz? franzli am 08.01.2024 – Letzte Antwort am 08.01.2024 – 2 Beiträge |
Zidoo X10: Interne Festplatte einrichten PR3T3ND3R am 24.02.2018 – Letzte Antwort am 20.12.2019 – 7 Beiträge |
Zidoo x9s und externe Festplatte ? stoffi20 am 12.06.2019 – Letzte Antwort am 23.06.2019 – 6 Beiträge |
NVIDIA SHIELD vs. Zidoo Z9s p4r4d0xs am 24.09.2019 – Letzte Antwort am 28.09.2019 – 2 Beiträge |
Zidoo UHD 3000 4K Mediaplayer hifipirat am 18.06.2022 – Letzte Antwort am 06.01.2023 – 10 Beiträge |
Zidoo Z10 Pro - Wiedergabe stockt Thaddäus_Tentakel am 16.08.2023 – Letzte Antwort am 21.08.2023 – 10 Beiträge |
Bildqualität zwischen Himedia q10Pro vs. Zidoo x9s selman am 04.01.2018 – Letzte Antwort am 16.01.2018 – 3 Beiträge |
Top 10 Threads in Multimediaplayer der letzten 7 Tage
- Amazon Fire-Tv Stick und LG OLED55CX9LA
- HI RES Streaming über QOBUZ
- INNUOS ZENmini - ZEN - ZENith -Pulse Serie - Roon Erfahrungsaustausch
- Noxon iRadio 400 keine Internetsender mehr
- Lösung der DENON WLAN Probleme
- Pioneer N-70AE / N-50AE / N-30AE
- Bluesound VAULT 2i
- Kodi v20 KEINE MKV Dateien & erkennt Bibliothek nicht mehr auf Nvidia Shild
- Anleitung für DUMMIES: Audiophiler Raspberry Selbstbau Low Budget Musikplayer/-streamer
- Audio Netzwerkplayer was bringts?
Top 10 Threads in Multimediaplayer der letzten 50 Tage
- Registrierte Mitglieder927.151 ( Heute: 4 )
- Neuestes Mitgliednackenlos
- Gesamtzahl an Themen1.554.922
- Gesamtzahl an Beiträgen21.624.881
