HIFI-FORUM » Suche / Biete / Verschenke » Biete » Selbstbau / DIY » Eighteensound 1.4" Neodym High-End Treiber ND... | |
Eighteensound 1.4" Neodym High-End Treiber ND1424BT+A -A |
Cantare
#1 erstellt: 10. Mai 2009, 22:08 | |
Preis (Pflichtangabe!): 290 Euro inkl. Versandkosten Standort: Stahnsdorf bei Berlin Zustand: NEU, UNBENUTZT, OVP Artikelbeschreibung: Verkaufe ein Paar unbenutzte 1,4 Zoll High-End Neodym Druckkammertreiber der Marke 18sound (Eighteensound). Key features * 109 dB 1W / 1m average sensitivity * 1,4 inch exit throat * 2,4 inch edgewound aluminum voice coil * 140 W program power handling * Pure Titanium diaphragm assembly * Patented phase plug design * Excellent thermal exchange * Neodymium magnetic structure Herstellerbeschreibung: The ND1424BT 1.4” exit neodymium high frequency compression driver has been designed for high level sound systems application. The titanium diaphragm is produced in house and has been developed to assure unmatched transient response. A proprietary treated Nomex bended former edge-wound aluminum 60mm voice coil completes diaphragm assembly. It has been made joining the proprietary treated Nomex former directly to the titanium dome through its upper bend edge. In comparison with usual straight former joint, the driver design assures extended frequency energy transfer for improved response linearity and unparallel reliability. This feature allows to keep proper motion control of the dome in real working conditions. Thanks to its physical properties, the proprietary treated Nomex former shows 30% higher value of tensile elongation at working operative temperature (200°C) when compared to Kapton. Moreover, this material is suitable to work also in higher moisture contents environments. Equipped with proprietary Patented Phase Plug architecture, the ND1424BT has been designed to give smooth coherent wavefront in the horn entrance in all working frequency range and high level manufacturing consistency. The phase plug with short openings and high flare rate value assures low distortion and remarkable improvements in mid-high frequency reproduction. Another big innovation in ND1424BT consists in the magnetic complex architecture. Through careful use of elementary pieces of neodymium magnets, Eighteen Sound engineers have developed a powerful neodymium magnet assembly able to reach 19KGauss in the gap in compact and lightweight structure. The motor structure, throughout the precisely coherent phase plug with 3 circumferential slots and copper ring on the pole piece, reduces inductance effects and distortion. The custom designed O-ring creates a tight seal between the plate and the cover assuring air chamber loading. Excellent heat dissipation and thermal exchange are guaranteed by the direct contact between the magnetic structure and the aluminum cover that allows to obtain a lower power compression value. [Beitrag von Cantare am 10. Mai 2009, 22:12 bearbeitet] |
Cantare
#2 erstellt: 10. Mai 2009, 22:11 | |
Cantare
#3 erstellt: 15. Mai 2009, 20:00 | |
up |
Cantare
#4 erstellt: 26. Mai 2009, 20:19 | |
up |
Cantare
#5 erstellt: 28. Mai 2009, 08:19 | |
VERKAUFT |
JBL High-End Chassis Cantare am 07.03.2010 – Letzte Antwort am 14.03.2010 – 2 Beiträge |
Verkaufe 4 High End 17er Glasfaserbässe hermes am 03.08.2008 – Letzte Antwort am 04.10.2008 – 17 Beiträge |
High End Tritec Luftspulen bassgott am 12.01.2012 – Letzte Antwort am 13.03.2012 – 4 Beiträge |
high end spikes donnerbass am 17.04.2012 – Letzte Antwort am 03.05.2012 – 2 Beiträge |
1 Paar neue RCF CD1710-MT3 High-End Druckkammer-Treiber Cantare am 14.03.2008 – Letzte Antwort am 14.03.2008 – 2 Beiträge |
Jabo KH-53 Kugelwellen-Horn + 2" Neodym Treiber Cantare am 20.01.2008 – Letzte Antwort am 20.01.2008 – 2 Beiträge |
V: Eighteensound ND 1030 / Paar ad2006 am 17.08.2011 – Letzte Antwort am 21.08.2011 – 2 Beiträge |
Precision Devices PDN.10MH25 Neodym 10" Tief-Mitteltöner für Hörner!!! PREISUPDATE Cantare am 08.07.2008 – Letzte Antwort am 20.08.2008 – 5 Beiträge |
Tangband W5-1138SM (NEODYM) saniiiii am 20.07.2018 – Letzte Antwort am 04.11.2018 – 3 Beiträge |
TangBand W5-1138SM (Neodym) saniiiii am 12.08.2019 – Letzte Antwort am 14.09.2019 – 2 Beiträge |
Top 10 Threads in Selbstbau / DIY der letzten 7 Tage
- Phonovorverstärker Volpe II mit Netzteil
- Lautsprecher Chassis für DONAR aus K+T mit Swans/HiVi, Audax, B+C
- 2x Tiefmitteltöner Vifa T-8110-581-1 4Ohm
- 2x A&D Audio R 1524
- 2x The Box 12-280/8-A *** verkauft ***
- JBL 2344A und 2426H
- Tang Band W5 1611 Sarah
- Ein Pärchen "AURUM" aus der K+T
- Goya Mini,Visaton FRS 8
- Hochtöner Monacor Monarch MHD 250/SL
Top 10 Threads in Selbstbau / DIY der letzten 50 Tage
- Registrierte Mitglieder927.103 ( Heute: 1 )
- Neuestes MitgliedBrentdok
- Gesamtzahl an Themen1.554.808
- Gesamtzahl an Beiträgen21.622.362
