Dual 1219 hums
tamagaba
#1 erstellt: 14. Mai 2024, 17:39
Greeting
Dual 1219 hums quite a bit at the bottom around -35 dB
Is it worth cleaning the idler rubber wheels with the metal pair or should I buy a belt player?
Dual 1219
Dual 1219
8erberg
#2 erstellt: 15. Mai 2024, 07:07
Hello,
Ask http://dual-board.de
Peter
tamagaba
#3 erstellt: 15. Mai 2024, 21:29
Thank you
raindancer
#4 erstellt: 15. Mai 2024, 22:37
tama, your data does not say anything to me. Can you provide a narrow band analysis (fft) of the signal?
einstein-2
#5 erstellt: 16. Mai 2024, 07:46
Hallo
Bitte wenn möglich Beiträge auf Deutsch.
tamagaba
#6 erstellt: 16. Mai 2024, 12:19
Sorry, I can't speak Deutsch I will be short in English
I mistake because the problem is MM phono preamp not the turntable
Between two track was -35-40 dB noise level after MM phono. I was thinking about this effect of the LP player humming
Same recording in directly to Tascam DR100 (without preamp and RIAA) show -55-57 dB
This means that DR100 input amp unit much better than my tube MM phono stage. I have to contact with MM phono producer and clarify the reasons. PSU noise or other malfunction maybe
pic a: with tube MM phono
pic b: directly Tascam DR100 mk3
I will make recording from my Clearaudio test LP with MM phono and without - I can show you more concrete results
I hope so I wrote clearly
a
b
8erberg
#7 erstellt: 16. Mai 2024, 15:15
Hello,
If the DIN cable is still there, check that there is no cable break, it´s > 50 years old....
If in doubt, replace the cable from the muting switch (choose a coaxial cable with low capacity) and new RCA-plugs.
Peter
doc_sisiphus
#8 erstellt: 16. Mai 2024, 18:00
in beide Richtungen
Übersetztungsprogramme helfen hier ganz gut weiter....
Dual 1254 automatic belt drive
kikala5 am 13.04.2020  –  Letzte Antwort am 14.04.2020  –  3 Beiträge
DUAL 1219
Frank-Ulrich_Fuchs am 05.11.2018  –  Letzte Antwort am 06.11.2018  –  13 Beiträge
Dual 1219
martin am 25.04.2003  –  Letzte Antwort am 14.05.2003  –  12 Beiträge
dual 1219
sabafan66 am 14.08.2013  –  Letzte Antwort am 19.08.2013  –  14 Beiträge
Dual 1219
Tatanka_Yotanka am 17.10.2014  –  Letzte Antwort am 20.10.2014  –  7 Beiträge
Dual 1219
schmolke am 21.11.2021  –  Letzte Antwort am 23.11.2021  –  6 Beiträge
"Reparatur" eines Dual 1219
Basil9000 am 23.02.2004  –  Letzte Antwort am 24.02.2004  –  6 Beiträge
DUAL 1219 Wartung
hasemaus am 07.09.2004  –  Letzte Antwort am 07.09.2004  –  6 Beiträge
DUAL 1219 Zu leise ??
bobosiebenschläfer1 am 19.01.2005  –  Letzte Antwort am 19.01.2005  –  7 Beiträge
DUAL 1219: welcher Tonabnehmer
Henning81 am 15.02.2005  –  Letzte Antwort am 28.02.2005  –  5 Beiträge
2024
  • Registrierte Mitglieder928.910 ( Heute: 6 )
  • Neuestes Mitgliedgoeresh
  • Gesamtzahl an Themen1.559.267
  • Gesamtzahl an Beiträgen21.721.889
Top Hersteller in Analogtechnik/Plattenspieler Widget schließen
