HIFI-FORUM » Suche / Biete / Verschenke » Biete » Kopfhörer, KHV und mobile Quellgeräte/ DAP » Hifime 9018 High resolution Asynchronous USB Sabre... | |
Hifime 9018 High resolution Asynchronous USB Sabre DAC 384kHz/32 Mac/Linux/PC+A -A |
ZeitGeistSound
00:20
erstellt: 30. Nov 2015, |
Preis (Pflichtangabe!): 70 VB Standort: Köln Zustand: Einwandfrei Artikelbeschreibung: ![]() Hier die Produktbeschreibung: In the Hifime 9018 dac we have managed to fit the high resolution, audiophile Sabre ES9018K2M DAC chip in a tiny compact box, the same used in our U2 and UAE23 Sabre dac's. We used a double PCB to be able to fit in this small box. This chip has great specs like 127dB DNR, -120dB THD+N and patented Time Domain Jitter Eliminator. It supports all sample rates up to 384kHz/32 bit and are clocked by two onboard oscillators. Hifime 9018 has MAX97220A headphone chip that can drive headphones down to 16 ohm as well as higher impedance headphones as the Sennheiser HD650. The volume level goes quite loud, more than enough for 300ohm HD650's. It works without drivers in Mac, Linux, and requires drivers to be installed in Windows. Note that 384kHz only works with ASIO which is accepted by some programs only, and not by Chrome, Youtube etc. Chrome on Mac's also doesn't support 384kHz. It uses by default USB Audio Class 2 which is required for sample rates above 96kHz. It will switch down to Class 1 if USB High speed mode is not available. It also have (like the U2 and UAE23) an optical output, which works up to 192kHz. In addition to normal PCB format It can play DSD files. We think the sound of this DAC is really great! Another cool features is that it works withAndroid 5.0! This makes it a super small portable highly audiophile solution.The Nexus 6 battery lasts for 6 hours when playing constantly with the 9018 dac. Also reported working with LG G Flex running Android 4.4 Features: Compact size Audiophile Sabre ES9018K2M chip No drivers required for Mac and Linux. Drivers available for Windows Accepts all sample rates up to 384kHz/32bit Asynchronous USB transfer Analog and digital (optical) output from 3.5mm connector Volume level responds to computer hot keys, -however only in 8 steps. This is the behaviour of SA9227 USB receiver. You can fine tune volume level in software. Works plug-n-play with Android 5.0 Lollipop (Nexus 6 tested). Responds to system volume level/vol+/. keys. Specifications: SNR: 112.5dB 1kohm, 109dB 600ohm THD: 0.0035% 32ohm, 20mW Crosstalk: 1kHz,10kOhm: -125dB, 1kHz, 32ohm -125dB Output power: 1.05Vrms/2.94Vpp 1kHz. 31mW 32ohm. In real life this DAC is much more powerful than UAE23/U2. It can drive most 16-300ohm headphones. Output impedance: 2 ohm Power consumption: Standby 170-190mA. Max draw 270mA [Beitrag von ZeitGeistSound am 30. Nov 2015, 00:21 bearbeitet] |
HiFimeDIY Sabre USB DAC 2 Sub_6 am 10.06.2016 – Letzte Antwort am 27.06.2016 – 2 Beiträge |
iBasso D14 Bushmaster High-Performance Stereo DAC & Kopfhörer Verstärker ZeitGeistSound am 24.09.2015 – Letzte Antwort am 28.09.2015 – 2 Beiträge |
Div. USB DAC/KHV + In-Ear Kabel samt Zubehör AG1M am 23.08.2015 – Letzte Antwort am 31.10.2015 – 5 Beiträge |
Sony MDR-10RC High Resolution Kopfhörer thebuddha am 13.08.2015 – Letzte Antwort am 18.08.2015 – 2 Beiträge |
Sony MDR-Z7 High Resolution Kopfhörer ingo74 am 27.03.2018 – Letzte Antwort am 02.04.2018 – 2 Beiträge |
LH Geek Out 1000 - USB-DAC/KHV housemeister1970 am 18.04.2016 – Letzte Antwort am 11.05.2016 – 4 Beiträge |
Fiio E10K DAC/KHV cyfer am 01.12.2015 – Letzte Antwort am 05.12.2015 – 2 Beiträge |
Arcam rPAC USB DAC Tommistar am 24.02.2017 – Letzte Antwort am 11.05.2017 – 3 Beiträge |
Audioquest Dragonfly USB-DAC /KHV h-hannah am 02.03.2014 – Letzte Antwort am 16.03.2014 – 2 Beiträge |
Apogee Groove USB DAC / KHV marty.wap am 21.01.2016 – Letzte Antwort am 04.02.2016 – 2 Beiträge |
2015
Top Produkte in Kopfhörer, KHV und mobile Quellgeräte/ DAP
Top 10 Threads in Kopfhörer, KHV und mobile Quellgeräte/ DAP der letzten 7 Tage
- Exzellenter Kopfhörer MB Quart QP 400
- AKG K301
- Handgefertigtes Kabel für AKG
- Sennheiser HD800 Rechnung vom 17.2.2017! original XLR-Kabel extra
- [verkauft] AKG K712 Pro made in Austria Preisanpassung
- Meier Audio Corda DACCORD und Violectric V200 mit verbautem DAC
- Bowers & Wilkins PX8, schwarz
- Hifiman HE 1000 V2
- STAX LAMBDA und NOVA Kopfhörer, ALpha Centauri V7 von high-amp Räuenbühler, Stax SRM 1 - MK II
Top 10 Threads in Kopfhörer, KHV und mobile Quellgeräte/ DAP der letzten 50 Tage
- AKG K301
- Registrierte Mitglieder928.575 ( Heute: 4 )
- Neuestes MitgliedEuphorismus
- Gesamtzahl an Themen1.558.503
- Gesamtzahl an Beiträgen21.703.900
