HIFI-FORUM » Suche / Biete / Verschenke » Biete » Archiv - BIETE » Verkauft: Matrix Mini-i | |
Verkauft: Matrix Mini-i+A -A |
j!more
#1 erstellt: 19. Dez 2012, 07:31 | |
Preis (Pflichtangabe!): 189 Euro inkl. Versand Standort: München Zustand: Sehr guter gebrauchter Zustand Artikelbeschreibung: KHV und Monitor-Controller Matrix Mini-i, 3 Jahre alt. Ideale Audio-Zentrale für den PC. Genug Power für alle Kopfhörer durch TI-Ausgangsstufen, beste Wandler, Dual AD1955 D/A chip, digital volume control,digital LCD display, balanced and unbalanced outputs, independent system clock, S/PDIF, AES/EBU, and USB inputs, as well as a built-in headphone amplifier. Features · Balanced structure with dual AD1955 24bit / 192kHz D/A converter units · Professional digital receiver chip of ultra-low jitter and an independent system clock · USB, AES/EBU, optical, coaxial digital inputs and a coaxial output · Up to 24bit / 192kHz digital input via coaxial and optical · Professional stereo OP-Amps OP275/OPA2134, offering the best signal playback quality · Digital step volume controller that covers -90 to 0 dB (1 dB each step) · Both balanced and unbalanced output, which makes it possible to connect two sets of analog devices with different interfaces at the same time · Multi-stage stabilized voltage power supply · Internal headphone amp unit can easily drive any headphones of 300 ohms and below · Large screen LCD panel displays user friendly information on current playback status and unit setting · Pre-amp mode and DAC mode selectable · While starting up or switching input channels, the volume will fade in to prevent shock and hearing damage caused by excessive volume · Displays track information when working with D-Sub code compatible CD players Digitale Eingänge: OPTICAL: Shielded/enclosed optical input Sampling Rate: 44.1kHz ~192kHz BNC : Standard BNC 75 ohm Sampling Rate: 44.1kHz ~192kHz USB : Standard USB-B connector Sampling Rate: 44.1kHz ~48kHz AES/EBU: Standard XLR interface Sampling Rate: 44.1kHz ~192kHz Digitaler Ausgang: Coaxial Output: standard RCA jack Supports AC-3, DTS data output Sampling Rate: 44.1kHz ~192kHz Output Level: 1Vp-p (75 ohm) Analog-Sektion: RCA Output Level: 0V~ 2.0V adjustable Balanced Output Level: 0V~ 4.0V adjustable (XLR : 1=GND, 2=HOT, 3=COLD) Frequency response: 20Hz~20KHz SNR: 105 dB Dynamic Range: 108 dB Distortion : <0.0002%(1KHz) [Beitrag von j!more am 19. Dez 2012, 07:42 bearbeitet] |
Matrix Mini-i DAC/Kopfhörerverstärker 'Verkauft' perfect_pitch am 25.05.2013 – Letzte Antwort am 29.07.2013 – 6 Beiträge |
Matrix mini-i DAC/KHV tf32h am 26.01.2014 – Letzte Antwort am 08.07.2014 – 8 Beiträge |
Matrix Audio Mini-i Pro P_S_Nelke am 02.06.2017 – Letzte Antwort am 05.06.2017 – 2 Beiträge |
Matrix Audio Mini-i Pro 3 (verkauft) maky100 am 14.03.2022 – Letzte Antwort am 06.04.2022 – 3 Beiträge |
Matrix Mini i DAC/ Kopfhörerverstärker 'Verkauft' perfect_pitch am 12.08.2012 – Letzte Antwort am 28.08.2012 – 4 Beiträge |
Audio-GD NFB6 Balanced Headphone Amplifier Anarion am 06.05.2012 – Letzte Antwort am 21.05.2012 – 2 Beiträge |
KHV Matrix M-Stage Quince am 28.01.2012 – Letzte Antwort am 06.02.2012 – 3 Beiträge |
Topping DX7s DSD DAC/KHV bei München Ongii am 28.12.2020 – Letzte Antwort am 11.01.2021 – 2 Beiträge |
DAC Matrix Wandler / Kopfhörerverstärker sebnest am 19.10.2011 – Letzte Antwort am 18.11.2011 – 4 Beiträge |
VERKAUFT Transistorkopfhörerverstärker SPL Phonotor mini - Top-Zustand MacGerry am 15.07.2018 – Letzte Antwort am 26.07.2018 – 2 Beiträge |
2012
Top 10 Threads in Archiv - BIETE der letzten 7 Tage
- Stax SRM-212 Kopfhörerverstärker
- Kef reference 104 aB aus 1975
- Shanling SLM-A40MKIII Class A Vollverstärker
- STAX Lambda SR-404 Signature
- Blaupunkt P-150 Studio Plattenspieler TOP
- Philips RB634/02 Nostalgie Radio 1983
- KHV Meier Audio Corda HA-2 aus 2005
- JBL Northridge E100 - 3-Wege Standlautsprechers
- Canton Vento 809 DC/ Vento 820 /Vento 805 CM 5.0 Surround -Set
- Röhren für Little Dot MK III / IV / SE
Top 10 Threads in Archiv - BIETE der letzten 50 Tage
- Registrierte Mitglieder928.252 ( Heute: 10 )
- Neuestes MitgliedSilmarlis
- Gesamtzahl an Themen1.557.847
- Gesamtzahl an Beiträgen21.687.932
