HIFI-FORUM » Suche / Biete / Verschenke » Biete » Archiv - BIETE » Biete Vor-/Endkombi Nuprime DAC-9/STA-9 in schwarz | |
Biete Vor-/Endkombi Nuprime DAC-9/STA-9 in schwarz+A -A |
taubeOhren
16:11
erstellt: 04. Jul 2018, |
Preis (Pflichtangabe!): VB 1299,-€ als Bundle (Einzeln DAC-9 699,- und STA-9 649,-) Standort: Berlin Zustand: Gebraucht Artikelbeschreibung: Biete Nuprime DAC-9 (Vorstufe/Dac) in schwarz. Techn./Opt. sehr gut. Rechnung (5/17), OVP vorhanden sowie Nuprime STA-9 (Stereo-Endstufe) in schwarz. Techn./Opt. sehr gut. Rechnung (9/17), OVP vorhanden. DAC-9 Inputs: 1 x USB PCM / DSD Digital (PCM up to 384kHz & DSD up to DSD256 ) 1 x Coaxial Digital S/PDIF (PCM up to 192KHz supporting DoP format DSD64) 1 x Optical Digital S/PDIF (PCM up to 192KHz supporting DoP format DSD64) 1 x Bluetooth or WiFi receiver module (optional). 1 x AES balance XLR 1 x Analog Stereo RCA (does not go through A2D conversion, analog input is selected by the preamp directly to analog outputs) Outputs: 1 x pair of stereo RCA out (max output 4V) 1 x pair of stereo XLR balanced out (max output 8V) 1 x Optical S/DPIF out USB Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz, 384KHz and DSD 2.8MHz(64), 5.6MHz(128), 11.2MHz(256) S/PDIF Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96, 176.4KHz, 192KHz, 352.8KHZ, 384KHz (Coaxial) Bit Resolution: 16-32-bits THD+N: 0.0015% Dynamic range: >-113dB Frequency Response: 10Hz to 80kHz Dimensions: 235 mm W x 281 mm D x 55 mm H (including feet) Weight: 2.3Kg Worldwide AC voltage: (90VAC~130VAC // 210VAC~ 250VAC) With Voltage Select Switch AC Fuse: Slow-blow, 1A, 250VA STA-9 nputs: RCA: Un-Balanced input x 1 XLR: Balanced input x 1 Outputs: Stereo Speaker Out x 1 or Mono Speaker Out x 1 Power: 2 X 120W / 1 X 290W an 8 & 4 Ohms Peak Output Power: 2 X 280W / 1 X 320W an 8 & 4 Ohms Input Impedance: 47k Ohms Input sensitivity: 232.8mV, 1W an 8 Ohms; 1.4V to rated power Gain: x 22 Signal to Noise Ratio: < -95dB at 1W, 10W, 100W THD+N: 0.02% (Stereo) / 0.01% (Mono) Frequency Response: 10Hz to 50kHz Worldwide AC voltage: (115 VAC / 230 VAC) with Voltage Select Switch AC Fuse: Slow-blow, 3A, 250VAC Dimension: 235 mm W x 281 mm D x 55 mm H (including feet) Weight: 4.75 kg Die ist ein Privatverkauf - keine Garantie oder Rücknahme. Abholung oder versicherter Versand per DHL (zu Lasten des Käufers) Gruß taubeOhren ![]() ![]() ![]() ![]() ![]() ![]() |
taubeOhren
07:55
erstellt: 14. Dez 2018, |
Moin, die Endstufe STA-9 ist verkauft. Bleibt also nur noch DAC-9/Vorstufe Inputs: 1 x USB PCM / DSD Digital (PCM up to 384kHz & DSD up to DSD256 ) 1 x Coaxial Digital S/PDIF (PCM up to 192KHz supporting DoP format DSD64) 1 x Optical Digital S/PDIF (PCM up to 192KHz supporting DoP format DSD64) 1 x Bluetooth or WiFi receiver module (optional). 1 x AES balance XLR 1 x Analog Stereo RCA (does not go through A2D conversion, analog input is selected by the preamp directly to analog outputs) Outputs: 1 x pair of stereo RCA out (max output 4V) 1 x pair of stereo XLR balanced out (max output 8V) 1 x Optical S/DPIF out USB Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz, 384KHz and DSD 2.8MHz(64), 5.6MHz(128), 11.2MHz(256) S/PDIF Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96, 176.4KHz, 192KHz, 352.8KHZ, 384KHz (Coaxial) Bit Resolution: 16-32-bits THD+N: 0.0015% Dynamic range: >-113dB Frequency Response: 10Hz to 80kHz Dimensions: 235 mm W x 281 mm D x 55 mm H (including feet) Weight: 2.3Kg Worldwide AC voltage: (90VAC~130VAC // 210VAC~ 250VAC) With Voltage Select Switch AC Fuse: Slow-blow, 1A, 250VA Preis 509,- Die ist ein Privatverkauf - keine Garantie oder Rücknahme. Abholung oder versicherter Versand per DHL (zu Lasten des Käufers) Gruß taubeOhren |
NuPrime DAC-9 DAC-Vorstufe mit PCM384 und DSD256 taubeOhren am 07.01.2019 – Letzte Antwort am 28.01.2019 – 2 Beiträge |
Denon 2106, Wharfedale CS 9 und DFS 9 frale am 17.10.2005 – Letzte Antwort am 04.11.2005 – 16 Beiträge |
Biete Infinity Kappa 9 in Rosenholz manson am 08.01.2005 – Letzte Antwort am 04.03.2005 – 62 Beiträge |
B&W CDM 9 NT TGA am 09.01.2005 – Letzte Antwort am 14.01.2005 – 5 Beiträge |
Metz 16:9 TV Schmidrainer am 10.03.2006 – Letzte Antwort am 19.03.2006 – 6 Beiträge |
Yulong U100 USB DAC/Kopfhörerverstärker schwarz Phln909 am 05.11.2012 – Letzte Antwort am 08.11.2012 – 2 Beiträge |
Ultrasone Edition 9 [verkauft] Matzio am 17.10.2010 – Letzte Antwort am 28.10.2010 – 2 Beiträge |
Rollo Leinwand 16:9 wusel123 am 04.12.2023 – Letzte Antwort am 15.02.2024 – 3 Beiträge |
Biete SEG 16:9 Fernseher inkl. Stand 740er am 26.11.2006 – Letzte Antwort am 29.11.2006 – 4 Beiträge |
16:9 TV - Interesse ??? divehansen am 27.06.2005 – Letzte Antwort am 28.06.2005 – 3 Beiträge |
Top 10 Threads in Archiv - BIETE der letzten 7 Tage
- Stax SRM-212 Kopfhörerverstärker
- Kef reference 104 aB aus 1975
- Shanling SLM-A40MKIII Class A Vollverstärker
- STAX Lambda SR-404 Signature
- Blaupunkt P-150 Studio Plattenspieler TOP
- Philips RB634/02 Nostalgie Radio 1983
- KHV Meier Audio Corda HA-2 aus 2005
- JBL Northridge E100 - 3-Wege Standlautsprechers
- Canton Vento 809 DC/ Vento 820 /Vento 805 CM 5.0 Surround -Set
- Röhren für Little Dot MK III / IV / SE
Top 10 Threads in Archiv - BIETE der letzten 50 Tage
- Registrierte Mitglieder928.661 ( Heute: 8 )
- Neuestes MitgliedRaphael2025
- Gesamtzahl an Themen1.558.715
- Gesamtzahl an Beiträgen21.708.802
