Meier Audio Corda DACCORD
#sonic#
#1 erstellt: 26. Sep 2021, 08:22
Meier Audio - Corda DACCORD
Sehr guter, top erhaltener DAC von Jan Meier. Ausführung in silber, wenige Gebrauchspuren, gepflegt, aus Nichtraucherhaushalt.
Der DAC nutzt 2x WOLFSON WM8741 D/A Converter-Chips in dual-mono Mode und bietet den sehr guten crossfeed Filter. Verkauf wegen Umstieg auf Corda SOUL.
279.-
Technische Daten:
2 coaxial S/PDIF inputs (Cinch)
1 optical S/PDIF input (Toslink)
1 USB-input port (24bit/192kHz)
All inputs electrically isolated using pulse transformers.
1 pair of outputs with fixed output level.
Output level 2.2 Vrms
1 pair of volume-controlled preamplifier outputs.
Output level: 6.0 Vrms / High gain
2,4 Vrms / Medium gain
0.9 Vrms / Low gain
Gold-plated output jacks
Silver plated heavy duty switches
Separate powerlines for the analog circuitry and the digital circuitry
All voltage lines double or three-fold regulated
Wide-range powerinput: 85..265V AC / 85..370V DC
Built-in groundloop breaker
Low impedance audiophile electrolytic buffer capacitors (Nichicon Fine Gold). Buffer capacity > 30.000 uF
Polystyrol and polypropylen (Vishay) capacitors in the signal path
C-MEDIA CM6631 USB-to-S/PDIF receiver (24bit/192kHz)
WOLFSON WM8804 S/PDIF receiver
Three IQD temperature compensated 2.5 ppm crystal oscillators (TCXO's) for minimal jitter.
2 pieces WOLFSON WM8741 D/A converter-chip in dual-mono mode
Sampling frequencies / resolution
32, 44, 48, 88, 96, 192 kHz / 16, 20, 24 bit (S/PDIF, USB)
AD797 opamps biased into class-A
ALPS RK27 potentiometer for volume-control
Extended natural crossfeed filter
3 intensity levels for the crossfeed signal.
Star-grounding
Weight: 1.7 kg
Size: 28.0 x 17.5 x 6.7 cm
Power uptake: 6 Watts
siehe auch:
http://www.meier-audio.homepage.t-online.de/daccord.html
an Selbstabholer in Bottrop / Düsseldorf oder zzgl. versichertem Versand per DHL (+ 5,99€)
#sonic#
#2 erstellt: 07. Okt 2021, 07:56
269.- inklusive Versand !
#sonic#
#3 erstellt: 03. Nov 2021, 23:21
up
#sonic#
#4 erstellt: 07. Dez 2021, 10:12
.... noch zu haben.
#sonic#
#5 erstellt: 15. Dez 2021, 15:54
255 € inkl. Versand
Meier-Audio Corda Classic/Corda DACcord
FairFlex am 17.08.2021  –  Letzte Antwort am 25.08.2021  –  3 Beiträge
Meier Audio Corda Symphony
bensch am 27.11.2010  –  Letzte Antwort am 29.12.2010  –  5 Beiträge
Meier Audio Corda Headfive
bastis am 14.06.2011  –  Letzte Antwort am 12.07.2011  –  2 Beiträge
Meier-Audio Corda Swing
Grinzha am 29.12.2012  –  Letzte Antwort am 09.01.2013  –  2 Beiträge
Meier Audio Corda Arietta
Leipziger am 10.05.2020  –  Letzte Antwort am 18.05.2020  –  3 Beiträge
Meier Audio Corda Aria
sicknote am 24.01.2021  –  Letzte Antwort am 31.03.2021  –  3 Beiträge
Kopfhörerverstärker / Meier Audio / Corda Aria
e.lurch am 18.10.2006  –  Letzte Antwort am 01.11.2006  –  3 Beiträge
KHV - Meier Audio - Corda Aria
Azimuth am 17.08.2010  –  Letzte Antwort am 02.09.2010  –  2 Beiträge
Meier Audio Corda Swing KHV
Terr0rSandmann am 04.10.2011  –  Letzte Antwort am 15.10.2011  –  2 Beiträge
Meier Audio Corda Concerto Kopfhörerverstärker
perfect_pitch am 05.08.2012  –  Letzte Antwort am 04.09.2012  –  6 Beiträge
  • Registrierte Mitglieder927.991 ( Heute: 3 )
  • Neuestes MitgliedLondonist
  • Gesamtzahl an Themen1.557.076
  • Gesamtzahl an Beiträgen21.671.969
