*neuwertig* CROWN 800 CSL
mischlingsrüde
#1 erstellt: 26. Okt 2003, 23:51
Hat jemand Intresse an einer wirklich neuwertigen CROWN 800 CSL Endstufe. Sie hat nur minimalste Spuren vom Rackeinbau und war nie im Verleih oder ähnliches.
Technische Daten (kurzform):
2X310W 8Ohm
2X445W 4Ohm
900W gebrückt
905W parallel mode an 2Ohm
15,4Kg, 2HE, 2Lüfter
Technische Daten:
Amplifier Accessories: Accepts MT-XLR and MT-BB input modules
Signal-to-Noise: (A-weighted) Better than 105 dB below full rated power into 8 ohms with 26 dB gain. (Unweighted) Better than100 dB below full rated power
Input Impedance: Nominally 20 K ohms balanced and 10 K ohms unbalanced
Controls: Enable, channel 1 and 2 level controls, stereo/mono switch (Stereo, Bridge-Mono, Parallel-Mono), three-position input sensitivity switch (0.775 V or 1.4 V for full output or a 26 dB voltage gain)
Connectors: Inputs: Balanced 1/4-in. back panel phone jack for each channel.
Output: A pair of color-coded binding posts for each channel.
AC Line: Standard three-wire grounded connector.
Dimensions: 19 in. (48.3 cm) standard rack mount width, 3.5 in. (8.9 cm) height, 16 in. (40.6 cm) deep behind the mounting surface
Approximate Weight: 800 CSL: 34 lbs. (15.4 kg).
Total Harmonic Distortion (THD): Less than 0.05% at full rated power from 20 Hz to 1 kHz increasing linearly to 0.1% at 20 kHz.
Intermodulation Distortion (IMD): (60 Hz and 7 kHz 4:1) Less than 0.05% from less than 171 milliwatts to full rated power.
Load Impedance: Rated for 4 to 8 ohms in Stereo, 8 to 16 ohms in Bridge-Mono and 2 to 4 ohms in Parallel-Mono. Safe with all types of loads.
Maximum Average Power at 1 kHz With No More than 0.1% THD:
Output Power per Channel in Stereo Mode with Both Channels Driven: 800 CSL: 310 watts into 8 ohms, 445 watts into 4 ohms
Output Power in Bridge-Mono Mode: 800 CSL: 900 watts into 8 ohms.
Die Enstufe befindet sich wie gesagt in einem technisch und optisch einwandfreiem Zustand. Fotos kann ich auf Anfrage mailen.
Möchte dafür 333€ haben. Ggf.+Versand (ca. 10€, glaub ich)
Wäre abzuholen in Hannover.
Hier wurden grad welche bei eBay verkauft:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=3354262292&category=12907&rd=1
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=3352732412&category=12907&rd=1
[Beitrag von mischlingsrüde am 27. Okt 2003, 08:38 bearbeitet]
PA Endstufe Crown CSL 800 mit 4HE Koffer
kuddel-musik am 13.08.2006  –  Letzte Antwort am 16.08.2006  –  3 Beiträge
Sennheiser HD 800 - neuwertig
FLCL am 19.05.2010  –  Letzte Antwort am 28.05.2010  –  2 Beiträge
crown xls 1502
Testius am 01.12.2019  –  Letzte Antwort am 10.01.2020  –  3 Beiträge
Crown XLS 2502
master-psi am 07.09.2022  –  Letzte Antwort am 14.09.2022  –  2 Beiträge
Crown XLS 1502 2x525 Watt 4Ohm
locutusvonborg1 am 04.07.2020  –  Letzte Antwort am 23.07.2020  –  3 Beiträge
Sennheiser HD 800
My$ter¥ am 07.08.2011  –  Letzte Antwort am 10.08.2011  –  2 Beiträge
Jensen Power Station 2300 SPL, PA-LS !VERKAUFT!
kuddel-musik am 13.08.2006  –  Letzte Antwort am 29.10.2006  –  8 Beiträge
HD 800
Poe05 am 07.12.2022  –  Letzte Antwort am 10.02.2023  –  3 Beiträge
Sennheiser HD800! *neuwertig*
Phoenix1412 am 10.10.2011  –  Letzte Antwort am 06.11.2011  –  3 Beiträge
iGrado black - neuwertig
tiad am 03.06.2013  –  Letzte Antwort am 12.11.2013  –  4 Beiträge
2003
  • Registrierte Mitglieder928.390 ( Heute: 9 )
  • Neuestes MitgliedTurok-Dino
  • Gesamtzahl an Themen1.558.116
  • Gesamtzahl an Beiträgen21.694.621
