BEHRINGER EURORACK defekt!
b3nn1_@_PA
#1 erstellt: 03. Mrz 2006, 17:02
hallo!
es handelt sich um das MX2642A...
daten habe ich aus einer abgelaufenen ebay auktion....
Technische Daten:
INPUT CHANNELS
Mic Input: Electronically balanced, discrete input configuration
Mic E.I.N. (22 Hz - 22 kHz): -129.0 dBu, 150 Ohm source
-117.3 dBqp, 150 Ohm source
-132.0 dBu, input shorted
-122.0 dBqp, input shorted
Distortion (THD & N): 0,007 % @ +4 dBu, 1 kHz, bandwidth 80 kHz
Gain Range: +10 dB to +50 dB
Max Input (Mic): +12 dBu
Line Input: Electronically balanced
Gain Range: Unity to +40 dB
Max Input (Line): +22 dBu
Channel Fader Range: +10 dB to -85 dB
Aux Send Gain Range: off to unity to +15 dB
EQUALIZATION
Hi Shelving: 12 kHz, +/- 15 dB, Q fixed at 2 oct.
Hi Mid Shelving: 3 kHz, +/- 15 dB, Q fixed at 2 oct.
Mid Sweep: 100 Hz - 8 kHz, +/- 15 dB, Q fixed at 1 oct.
Lo Mid Shelving: 500 Hz, +/- 15 dB, Q fixed at 2 oct.
Lo Shelving: 80 Hz, +/- 15 dB, Q fixed at 2 oct.
Lo Cut (High Pass) Filter: 75 Hz, 18 dB/oct.
CHANNEL DIRECT OUT
Max Output: +22 dBu
Noise @ Unity Gain: -94 dBu
Output Impedance: 120 Ohm
CHANNEL INSERT
Max In-/Out: +22 dBu
Channel to Channel Crosstalk: -95 dB @ 1 kHz
SUBGROUP SECTION
Noise: Bus noise @ fader 0 dB: -102.5 dBr (ref.: +4 dBu);
-92.5 dBr (ref.: +4 dBu, 16 channels assigned and set @ unity gain)
Submaster Output Max Out: +22 dBu balanced/unbalanced
Fader Range: +10 dB to -85 dB/off
MAIN MIX SECTION
Noise: Bus noise @ fader 0 dB: -101.0 dBr (ref.: +4 dBu);
-92.5 dBr (ref.: +4 dBu, 16/20 channels assigned and set @ unity gain)
Max Output: +28 dBu balanced, +22 dBu unbalanced, 1/4" jacks
Aux Returns Gain Range: off to unity to +20 dB
Aux Send Max Out: +22 dBu
GENERAL
Distortion (THD & N): 0.007 % @ +4 dBu, 1 kHz, bandwidth 80 kHz
Frequency Response: 20 Hz - 40 kHz, +/- 1 dB any input to any output;
10 Hz bis 120 kHz, +/- 3 dB
PHYSICAL
Dimensions (H * W * D): 2.4" / 6" (61 / 152.4 mm) * 17.15" / 19" (435.6 / 482.6 mm) * 14" (355.6 mm)
Net Weight: 7.5 kg
so nun zu dem defekt:
das mischpult war an und mein pc auch...dann hab ich das kabel zwischen PC und MP in den PC-out gesteckt...dann hat rumms gemacht und die sicherung des hauses war raus!
danach gings nich mehr...
was da genau dran is weiss ich nich...hab von innenleben von geräten keine ahnung..
vielleicht innenleigende sicherung oder so?
es geht noch an wenn man das netzteil anschließt und dann nach 2 sekunden wieder aus!
Preis: 150€ ? weiss nich wieviel es dann noch weg.. bei ebay geht es defekt für bis 150€ weg...
ist aber Verhandlungsbasis!!! also bei interesse... PM, bei fragen: posten!!!!
MFG b3nn1
[Beitrag von b3nn1_@_PA am 03. Mrz 2006, 17:06 bearbeitet]
b3nn1_@_PA
#2 erstellt: 05. Mrz 2006, 22:41
hallo!
is jetzt bei ebay drin!
KANN DICHT GEMACHT WERDEN!
MFG b3nn1
V: Acurus 100X3 3-Kanal-Endstufe
IronEagle am 24.04.2004  –  Letzte Antwort am 29.04.2004  –  4 Beiträge
Musical Fidelity Preamp 3a, 2x Monoblock MA 50
sikibalon am 08.11.2006  –  Letzte Antwort am 19.11.2006  –  5 Beiträge
Infinity Reference 31mkII
McNölti am 15.10.2006  –  Letzte Antwort am 20.11.2006  –  12 Beiträge
Mehrere Y-Dimension Endstufen
holzy81 am 10.03.2016  –  Letzte Antwort am 24.04.2016  –  5 Beiträge
Vincent Kombi LS-1/D-150
Huf am 14.07.2004  –  Letzte Antwort am 15.07.2004  –  2 Beiträge
Stereoverstärker Harman Kardon HK 670
Durstig am 01.03.2006  –  Letzte Antwort am 04.03.2006  –  5 Beiträge
Verkaufe Dali Center aus der Blue-Reihe in der Farbe buche
vandeus am 03.06.2005  –  Letzte Antwort am 02.05.2006  –  5 Beiträge
Verkauft
audiomanic am 01.02.2014  –  Letzte Antwort am 04.03.2014  –  6 Beiträge
Kenwood Basic M1 Endstufe
titan66 am 07.12.2004  –  Letzte Antwort am 16.12.2004  –  4 Beiträge
KHV CORDA PREHEAD-1 MkII MEIER-AUDIO
Wolf352 am 27.07.2011  –  Letzte Antwort am 26.08.2011  –  3 Beiträge
2006
  • Registrierte Mitglieder928.646 ( Heute: )
  • Neuestes Mitglied
  • Gesamtzahl an Themen1.558.683
  • Gesamtzahl an Beiträgen21.708.022
