Gehe zu Seite: Erste 2 3 4 5 6 . 10 . Letzte |nächste|
Oppo Digital - OPDV971H
m2004
#1 erstellt: 17. Okt 2005, 19:22
Kann jemand so gut ENglisch um mir die Vor und Nachteile dieses Players aufzuzählen:
MPEG Maker: Mediatek
MPEG Model: MT1389FE
Deinterlacer Maker: Genesis
Deinterlacer Model: FLI-2310
MSRP: $199.00
Website: http://www.oppodigital.com
OPDV971H (DVI) - Default
Passed Borderline Failed Not Tested
Layer Change
Responsiveness
Chroma, 3-2 Film Flags
Chroma, 3-2 Alt. Flags
Chroma, 2-2 Film Flags
Chroma, 4:2:0 ICP
Video Levels
Blacker-than-Black
YC Delay
Image Cropping
Sync Subtitle to Frames
3-2 Cadence, Film Flags
3-2 Cadence, Alt. Flags
3-2 Cadence, Video Flags
3-2 Cadence, Mixed Flags
Film Mode High Detail
Bad Edit
Video to Film Transition
Incorrect Progressive Flags
Motion Adaptive
Recovery Time
2-2 Cadence, Film Flags
The 971H is the premier DVD player from a brand new company here in the US: Oppo Digital. The company is a spring off from the electronics giant, BBK Electronics. BBK has been in the business for a long time and is a world leader in the electronics field with total manufacturing output matching Sony and Matsushita. If the 971H is any indication, we have a lot to look forward to from Oppo Digital.
As you can see from the Benchmark scores, the 971H is an outstanding budget DVD player. But I must advise you that the scores only pertain to the DVI output. This player’s component outputs do not support progressive playback, only 480i, so we were not able to plot a video frequency response curve. I was quite surprised, because I’ve never seen this before. The DVI video board in the player houses the Genesis FLI-2310 video processing chip, so the component video connections cannot take advantage of it.
This is the second union of the FLI-2310 and a Mediatek MPEG decoder. Ever since I first tested the Mediatek chips, I’ve been hoping for their fusion with a high line de-interlacing solution. The first player that I tested with this was the Toshiba 593 DVD/VCR combo. Unfortunately, that player had inconsistent performance from player to player, and the implementations of the chips were not what they should have been. I left feedback with Toshiba on this, but they didn’t take advantage of the suggestions. When Oppo originally sent me their player, I found some problems that needed to be addressed, I let them know, and they fixed them. I must say I was extremely impressed with how Oppo handled the issues I brought up, as well as the issues that I’ve seen raised on some of the Internet A/V forums. Their fixes led to a score of 94 in our benchmark, which is only second to the Denon DVD-5910. Not bad for a sub-$200 player!
This player offers the standard upscaling resolutions of 480p, 720p and 1080i. The DVI output is not HDCP compliant, so consumers with older DVI monitors that don’t support HDCP are in luck! The Faroudja chip seems to be set up appropriately, though it lacks a mode for 2-2 cadences. Oppo informed me that this is a feature that will be implemented on their next player. The Genesis chip has the same limitations as every other player using it. This includes somewhat sluggish transitions between film and video material and the unfortunate macroblocking issue. When I used my standard A Bug's Life test, the player did show signs of the macroblocking bug but it isn’t as bad as some other players such as the Teac Esoteric UX-1 or Samsung HD-1000.
The Mediatek chip is utilized to its fullest potential here. The player breezed through our chroma tests with no signs of banding or jaggies at all. The chip is also extremely fast with menu navigation and supports a seamless layer change.
I did find a few additional problems with the player and hope to see Oppo resolve them with a future firmware change. The cross color suppressor function of the Faroudja processing is defaulted to ON with no way of turning it off. We saw this same issue with the Panasonic RP-62 a while back, and it can cause some abnormalities with chroma performance, including slight flickering. I played animation material, including Toy Story, A Bug’s Life, The Incredibles, and Finding Nemo (think I’m a Pixar fan??) and didn’t see any issues at all. But I did notice a big drop off in vertical chroma resolution using the test patterns from Avia Pro.
Some of the bonus features of this player include excellent PAL support with PAL to NTSC conversion. On top of that, the player is region free out of the box making it an excellent choice for fans of foreign cinema or foreign market DVDs. The player also supports DiVX and MPEG-4 files. On the audio side, you’ll find an internal Dolby Pro Logic II decoder that can be used with the analog audio outputs. There is also full DVD-Audio support with bass management and time alignment.
If you are in the market for a budget DVD player, with DVI output, and which has exceptional video performance, the 971H definitely meets those criteria. This player passes below-black, has no pixel cropping, and there are no signs of Y/C delay. I personally can’t wait to see what Oppo has in store for us next.
Danke und Gruß
M
das6Mio$ohr
#2 erstellt: 17. Okt 2005, 20:31
Hab mir den OPPO971H aus den USA mitgebracht.
Das Bild ist der absolute Hammer.Habe zum Vergleich den Samsung HD850 HDMI->DVI Kabel am Plasma und der Unterschied ist wie Tag und Nacht.Man bekommt den oppo auch in Holland für 225€ + Versand.
http://www.livingcin....php?products_id=127
oder auch in England
http://www.itsupplies.net/product_info.php?products_id=247
Habe den oppo mit diversen DVDs getestet(Gladiator,Die Mumie,Iceage,Monster AG,Star Wars II....) und muß sagen das Bild ist sehr sehr GEIL.Gestochen scharf und sehr sauber.Die einzige Spaßbremse ist die schlechte quallität er meisten DVDs.
Der De-Interlacer ist der gleich wie bei den Denon 2910/3910 der FLI2310.
Selbst der Panasonic S97 hat den kleineren FLI2301.
Der Video DAC besteht aus 2x 12bit 108Mhz
Das allerbeste ist, er ist CODEfree und auch HDCPfree.
Das ist besonders interesant für die Plasma/Beamer besitzer mit einem nicht HDCP copatieblen DVI Eingang.
Der Player ist absolut Lautlos und hat 1000 features die man über die FB steuern kann(Lautstärke,Pitch,Zoom,Audio Equalizer...).
Unterstüzte DivX Forate: Simple Profile (SP) and DivX Pro: Advanced Simple Profile (ASP). DivX Pro: MPEG4 ASP, B-frame, GMC, Q-pel, Post Processing, Interlaced Video.
Hier werden diverse DVD-Player austattungsmäsig verglichen.
http://www.extremephono.com/Oppo_DV971.htm
Der im Test bessere Denon hat bei uns die bezeichnug A11.
Wer öfters in die USA kommt sollte sich den Player unbeddingt mitnehmen.
Habe schon mehrmals den eMail support genutzt da ich ein paar Fragen hatte und habe alle mein Frage am nächsten Tag beantwortet bekommen.
Der Support wimmelt einen nicht gleich ab mit den Worten "dieser Fehler ist uns völlig unbekannt" - nein die prüfen die Angaben und beheben die Fehler mit Softwareupdates die nicht Jahre brauchen.
Im amerikanischen AVS-Forum beantworten OPPO Mitarbeiter fragen auch direkt
http://www.avsforum.com/avs-vb/showthread.php?t=491306
Das nenne ich SERVICE AM KUNDEN.
Ich bin Happy und werde meinen OPPO nicht so schnell hergeben.
[Beitrag von das6Mio$ohr am 17. Okt 2005, 20:34 bearbeitet]
m2004
#3 erstellt: 18. Okt 2005, 07:05
Aha, das hört sich ja sehr gut an.
Gibt er denn 50Hz sauber wieder? Mußtest Du keinen Stromadapter haben? Wie kann er skalieren? Auch am YUV?
Ist sein YUV Bild auch sehr gut? Hast Du beim Zoll die Mehrwertsteuer nachbezahlt?(Wieviel?).
Fragen über Fragen.
Vielen Dank für Deine Hilfe.
M
Nachtrag: Ist der Player Baugleich mit dem Unlike Momitsu V880N? Beide werden des öfteren zusammen genannt.
Ich beziehe mich auf folgenden Text:
" Please note: Unlike Momitsu V880N, OPDV-971H does not support DVI-I, i.e. cannot use any DVI to VGA adapter, it does not support 480P, 720P or 1080i via the component connection."
Weiss darüber jemand bescheid?
lg
Michele
[Beitrag von m2004 am 18. Okt 2005, 08:55 bearbeitet]
das6Mio$ohr
#4 erstellt: 18. Okt 2005, 14:38
Beim Zoll waren es 13% Einfuhr.
Habe mir bei einem unserer Elktro-Türken einen Adapter US-Flach auf D-Rundstecker für 2€ gekauft.Der Player selbst hat ein Universlnetzteil(110V/60Hz-235V/50Hz).
Über YUV gibt er zur Zeit nur 480i un 576i aus.Man überlegt aber mit dem nächsten SW update dies zu ändern.
Ich habe nur einen einfachen Plasma von Hyundai und es ruckelt nix mit meinen PAL-DVDs.
Weiß ich nicht .Der OPPO971H ist aber Baugleich mit dem BBK971H(ist die Europaversion mit Scart.)
http://www.livingcinema.nl/catalog/index.php?manufacturers_id=25
Auf Nachfrage bei OPPO kann man aber die SW updates nicht für den BBK nutzen.
Heißt das der OPPO kein DVI-I(analog) unterstüzt,und somit auch keine DVI-I->VGA Adapter funktionieren.
Und wie oben schon beschrieben funktioniert zZ auch kein 480P, 720P or 1080i über YUV.
Man hat sich bei der Herstellung des OPPO voll und ganz auf ein sauberes digital Bild konzentriert.
Das ist den auch sehr gut gelungen.
w0rl
#5 erstellt: 18. Okt 2005, 20:56
Wo kann man den denn in Holland bestellen??
tere13
#6 erstellt: 19. Okt 2005, 07:04
Man muß sich schon die Mühe machen und den Thread auch mal durchlesen !!
Fang doch am besten mit der ersten Antwort von unserem das6Mio$ohr an
Bißchen Fantasie im holländischen wäre bei der Bestellung wohl angebracht.
Bekommst hier in Europa allerdings nur den BBK,
wenn du die genaue Bezeichnung bei Google eingibst,
findest du auch noch einige Händler aus dem skandinavischen Raum.
mfg.
m2004
#7 erstellt: 19. Okt 2005, 07:07
steht doch oben
Allerdings nur den BBK, ist aber wie gesagt bis auf die änderungen für EU baugleich. Kann man sogar abholen ist aber am Nordmeer, so also etwas weit. Ich habe mir ihn aber erst mal nicht geholt weil mein LCD (siehe Sig.) anscheinend nicht mit allen Playern klar kommt. Darum habe ich mir erst mall den LG 9900h bestellt und werde ihn testen.
M
w0rl
#8 erstellt: 19. Okt 2005, 07:33
Geil! Man muss schon lesen können Danke für den Hinweis
chris715
#9 erstellt: 19. Okt 2005, 15:57
Hätte da auch mal eine Frage:
Was bedeuteten den bei livingcinema.nl die Zahlungsmethoden
1. PayPal (secure creditcard transaction, 2% paypal charge)
bzw.
2. Internet Payment/Money Order
Möchte mir den Player dort eigentlich bestellen, bin aber unsicher, welche Zahlungsart ich wählen soll.
Gruß, chris
Hat jemand noch die komplette Anschrift der Firma?
[Beitrag von chris715 am 19. Okt 2005, 15:59 bearbeitet]
m2004
#10 erstellt: 19. Okt 2005, 17:37
Hi
so viel ich weiss kann man über das Paypal System mit Kreditkarte bezahlen (siehe www.paypal.de)und die 2 % sind bestimmt Gebühren die normalerweise der Verkäufer für die Geldtransaktion bezahlen müßte. Wenn man als Käufer mit Kreditkarte über Pay bezahlt fallen nämlich für den Verkäufer Gebühren an.
Das 2. ist bestimmt nur Internetbanking. Weiss ich aber nicht genau. Du kannst den Verkäufer übrigens auch auf Deutsch nach allem Fragen. Er spricht ganz gut Deutsch.
Es scheint mir aber alles seriös.
M
w0rl
#11 erstellt: 19. Okt 2005, 19:43
Ich hab mal auf der englischen Seite nachgeschaut ... Da ist der ein bisschen teurer als auf der Niederländischen, da der Versand etwas stärker zu buche schlägt. Insgesamt komm ich auch auf der engl. Site etwas besser klar
Des weiteren bekommt man auf der engl. Seite den originalen, also den OPPO
chris715
#12 erstellt: 19. Okt 2005, 19:59
28 Pfund (38€) Versandkosten, hinzukommen 140 Pfund für den Player. Macht dann zusammen ca 234€. Damit könnte ich leben. Kommt den aus England noch Zoll hinzu?
w0rl
#13 erstellt: 19. Okt 2005, 20:28
Zoll eigentlich nicht, weil ist ja EU also quasi Inland... Aber ich bin mir nicht sicher, wie das mit der MwSt ist... Eigentlich müsste man die Englische ausgezahlt bekommen und sie gegen die 16% angerechnet bekommen... Irgendwie so läuft das
w0rl
#14 erstellt: 19. Okt 2005, 20:39
Also ich hab gerade mit meinem Dad gesprochen, der kennt sich mit sowas aus ;D und meinte eben, dass England aus EG Sicht Inland sei, die Einfuhrsteuer (Zoll) wegfällt und dadurch dass die engl. "MwSt." schon drin ist, die deutsche auch nciht mehr zu zahlen ist (Weil die 139Pfund schon quasi der Brutto Betrag sind).
Dem zufolge könnte man ihn für ~235€ haben. Die Frage ist nur, wie das mtm Versand läuft Von Wegen Geld etc
tere13
#15 erstellt: 20. Okt 2005, 06:38
Und denk noch dran das die Engländer andere Netzstecker als wir haben, brauchst also noch ein Kabel.
@das6Mio$ohr
Was für einen Netzanschluß ist denn hinten am Gerät ??
Wie bei den Kofferradios, D-Box2 usw., dieser Standardanschluß ???
mfg.
tere13
#16 erstellt: 20. Okt 2005, 07:22
Ist euch auf der englischen Seite eigentlich dieser Text am Ende der Oppo Seite aufgefallen :
Price excludes VAT. Total order costs for UK with Next Day Courier and VAT is £171.55.
Shipping costs and delivery times for outside UK will differ, please proceed to checkout for quotes
Heißt ja wohl das der Preis von 139 Pfund ohne Mwst. ist
und dann kommt ja wohl noch die Differenz für den Auslandsversand dazu, oder irre ich mich da?
mfg.
w0rl
#17 erstellt: 20. Okt 2005, 10:58
Ja stimmt, hab ich ganz übersehen. D.h. auf die 139Pfund kommen 16% deutsche MwSt. drauf + Shipping Costs.
Dann wird der wohl 250€ kosten
Über den holländischen Anbieter wirds sicher günstiger, aber man hat nicht den "originalen" Oppo
Ob sich das wohl dann noch lohnt?!
m2004
#18 erstellt: 20. Okt 2005, 11:39
HAAAALLLLO! Es wurde schon mal geschrieben das der OPPO baugleich mit dem BBK oder BKK oder wie er heisst ist. Der andere hat halt nur noch einen Scartausgang.
Sprich doch mal den holländischen Versender an er wird es bestätigen. Nur halt muß man den Oppo importieren und das ist wohl zu teuer laut dem Händler in Holland.
Es gibt also was die Qualität betrifft 0 Unterschied!!!!!!
M
[Beitrag von m2004 am 20. Okt 2005, 11:40 bearbeitet]
tere13
#19 erstellt: 20. Okt 2005, 13:27
@m2004
Nun aber du vergißt das wie hier schon mehrfach erwähnt wurde die Firmware vom Oppo nicht auf dem BBK laufen soll,
und für den BBK hab ich noch keine Anlaufstelle gefunden!!
mfg.
das6Mio$ohr
#20 erstellt: 20. Okt 2005, 14:37
OPPO ist ein Tochterunternehmen von BBK.
Ich habe die Antwort von OPPO nochmal durchgelesen.
1. Is the BBK DV971H the european Modell of the Oppo DV971H?
They are similar. But the firmware may be different.
(Die sind gleich aber die Firmware ist unterschiedlich)
2. Can i use the the oppo Firmware updetes for the bbk?
In theory it may work, we have not done that before. Doing it at your own risk.
(Theoretisch funktioniert die FW des OPPO,haben wir aber selbs noch nicht auprobiert)
3. Where can i buy the oppo or bbk in europe?
You can buy OPPO from the link below.
http://www.itsupplie...id=247&reviews_id=14
Best Regards,
Antwort steht oben
Es gibt ein neues Update in dem man einen gut funktionierenden Bildrauschfilter, und einen manuell umschaltbaren Videomode eingebaut hat.Wobei die automatic 1a war.
m2004
#21 erstellt: 20. Okt 2005, 15:57
Es wird für den BBK allerdings auch neue Firmware geben und diese kann man dann auf der niederländischen Seite herunterladen. Angeblich schon diese Woche.
@tere
danach wurde ja auch nicht gefragt
[Beitrag von m2004 am 20. Okt 2005, 15:59 bearbeitet]
chris715
#22 erstellt: 20. Okt 2005, 18:38
Hab die Jungs in Holland mal angemailt. Wie m2004 schon sagte, man kann den Player gegen Barzahlung auch abhohlen. Leider haben sie mir aber nicht die genaue Anschrift verraten. Daher nochmal meine Frage
@m2004
Wie lautet deren Anschrift? Hattest in deinem vorherigen Beitrag etwas vom Nordmeer geschrieben.
m2004
#23 erstellt: 20. Okt 2005, 18:56
Hi
ich hatte nur gefragt wo man den Player abholen kann und das ich aus duisburg komme. Da meinte der Verkäufer das man nur am Nachmittag oder Abends und am Wochenende abholen kann und das es von Duisburg aus wahrscheinlich etwas weit wäre da es am Nordmeer sei. Frag doch nochmal genau nach der Adresse.
M
PS: Von wo kommst Du denn chris?
w0rl
#24 erstellt: 20. Okt 2005, 22:48
Wie istn das mit so nem Update? Wie bekomm ich sowas auf den DVD Player??
[Beitrag von w0rl am 20. Okt 2005, 22:49 bearbeitet]
tere13
#25 erstellt: 21. Okt 2005, 07:14
Also wenn ihr auf der Seite unter Kontakt schaut kommt das dabei raus :
Onze bedrijfsgegevens:
RevoDesign
Seringenlaan 47
2241VK Wassenaar
Tel: 06-24652564
Kvk Haaglanden 27177679
Er hat auf der Seite ja beide abgebildet, aber wenn ich das richtig verstehe steht jetzt nur noch der BBK zur Auswahl, richtig!?
Hab schon an die Möglichkeit einer Sammelbestellung gedacht, wobei ich noch etwas unentschlossen wäre
und mein max. wären auch €200.- inkl. Versand.
Aber vielleicht melden sich hier ja noch andere die Interesse hätten.
mfg.
@w0rl
Man lädt sich die Datei runter, entpackt sie und brennt sie im Iso Format mit Nero auf ein CD Rohling,
dann in den Player und updaten.
m2004
#26 erstellt: 21. Okt 2005, 08:07
@tere, richtig nur noch der BBK steht zur Auswahl.
An das mit der Sammelbestellung habe ich auch schon gedacht.Ich habe einen Freund in Amsterdam der ihn deswegen mal kontaktieren kann. Es wäre auch möglich die Player durch Ihn oder ich fahre selber abzuholen. Den Preis könnte ich mal versuchen auf holländisch zu verhandeln.
Wer hat denn alles interesse an dem Player?
Ich finde es immer sehr schade das man meistens die interessantesten Geräte in den Städten oder überhaupt wie in diesem Beispiel zu sehen ist, bekommt.
Vielleicht werde ich mir mal eine Liste der attraktivsten "Exoten" machen für die die Leute hier Interesse zeigen und diese importieren. So nebenbei mit Gewerbeschein.
Mal sehen.
M
w0rl
#27 erstellt: 21. Okt 2005, 10:28
Ich hätte an dem Player auch interesse. Hatte eben mal meine Daten eingegeben (auf der holl. Seite) und bekam dann eine email wo drin stand (kann kaum holländisch ), dass die Lieferung an diese Adresse nicht möglich sei
Das wir unter 200€ kommen, kann ich mir kaum vorstellen.
Gibts eigentlich Probleme mit Garantiefällen (falls etwas passieren sollte?), bzw wer hat mit dem Import in der Hinsicht Erfahrung??
m2004
#28 erstellt: 21. Okt 2005, 10:43
Hallo
ab 10 Geräten kämen wir auf ganz knapp unter 200 Euro.
Habe mich da schon mal schlau gemacht. Ich bin mit dem Händler in Kontakt und lote noch ein paar Möglichkeiten aus.
Vielleicht gibt es noch andere Möglichkeiten. Ich suche gerade den europäischen Vetrieb für die BBK Player, aber bis auf eine Seite aus Schweden die den Player aber nicht auf Ihrer Seite haben, einer russischen und der Amerikanischen Oppo Seite habe ich noch nichts gefunden. Ich habe allerdings die Schweden mal angeschrieben und werde mal sehen was die dazu sagen.
Ich wäre ja schon froh wenn man die Geräte in D für 225 Euro kaufen könnte. Wenn jemand einen Link zu dem Hersteller findet wo man die europäische Version beziehen kann, immer her damit.
Die Frage ist nur, ist er wirklich so gut wie man angeblich in den US foren liest und unschlagbar über den DVI Anschluss, so das sich der Aufwand lohnt?
Bzgl. Garantie gelten in diesem Fall natürlich die Niederländischen Garantiegesetze. Ich vermute mal 1 Jahr oder die des Herstellers, wobei in beiden Fällen das Gerät eingeschickt werden müßte. Also nach Holland oder direkt an den Hersteller. Es sei denn es findet sich noch ein deutscher Händler. Wie gesagt mal sehen was ich über die Firma eines Freundes machen kann. Interessenten sollten sich in jedem Fall mal eintragen.
M
M
w0rl
#29 erstellt: 21. Okt 2005, 10:58
Das mit der Bildqualität ist auch so eine Sache... Aber immerhin soll er ja den großen DCDi Chip drin haben (der selbe der im Denon 3910 drin ist, wenn ich mich nicht täusche).
Was dagegen spricht, ist dass man ihn eben über Umwege bestellen muss, und der Samsung HD950 auch ein sehr gutes Bild machen soll (und das für 160€).
Ausserdem könnte (das betrifft nur mich ), ich meinen _einen_ HDMI Anschluss noch sehr gut anderweitig gebrauchen
tere13
#30 erstellt: 21. Okt 2005, 12:47
So, ich hab mal die schwedischen und dänischen Händler kontaktiert, betreffend Versand nach Deutschland und Preis bei Abnahme von 5 ST.
Sobald die Antworten eintrudeln meld ich mich.
Nach Umrechnung kostet der in Schweden €189.-
Meines erachtens darf man Waren doch einführen im Wert von ca. €150-200 !!??
Weiß aber nicht ob das nur gilt wenn man sie persöhnlich einführt.
mfg.
tere13
#31 erstellt: 21. Okt 2005, 12:51
Der erste hat sich gemeldet :
Hi!
We would be glad to send you 1-5 players! Shipping is 300:- (SEK) per piece. Im sorry but its not possible to give a better price if you order more than one.
MVH
Tommie
Reference Audio
Götgatan 35
116 21 Stockholm
Tel. 08-642 80 64
Fax. 08-642 80 65
www.ref.se
incl. dem Preis von 1790SEK macht das dann 2090SEK,
nach Umrechnung ca. €221.-
mfg.
chris715
#32 erstellt: 21. Okt 2005, 12:58
Bei ner Sammelbestellung währe ich grundsätzlich auch dabei. Müsste man nur mal überlegen wie man das praktisch abwickelt. Wenn die Holländer nicht so blöde Zahlungsmethoden hätten, währe er sowieso schon bestellt. Wobei mir das mit dem importieren und der Garantie im Schadensfall auch nicht so wirklich zusagt.
m2004
#33 erstellt: 21. Okt 2005, 13:08
Laut BBK Schweden werden sie in naher Zukunft einen deutschen Händler präsentieren können. Sie sind auch daran interessiert mit weiteren Händlern in Kontakt zu treten.
M
audiohobbit
#34 erstellt: 21. Okt 2005, 14:24
servus teures ohr! wo wohnst du denn wenn man fragen darf? vielleicht mag sich ja jemand den player mal live anschauen...
die berühmte hausdachüberflugszene in gladiator packt er also ohne weiteres oder wenn ich das richtig gelesen habe.
das6Mio$ohr
#35 erstellt: 21. Okt 2005, 17:34
Die berühmte hausdachüberflugszene in gladiator packt er also ohne weiteres oder wenn ich das richtig gelesen habe.
Prüfe es morgen nochmal wenn ich die neue Firmware drauf habe.
das6Mio$ohr
#36 erstellt: 22. Okt 2005, 13:07
Habe soeben nochmal "Gladiator" getestet.
Es geht um Chapter 12/5:50 - flug über die Dächer Roms zum Coloseum.
Gemeint ist das Dach unter rechts,das in richtung 1-Uhr zeigt.
Das Bild sowie auch das Dach werden absolut sauber dargestellt.
Habe zum vergleich den PIO575 genommen, bei dem sieht es so aus als würde eine weise Welle über das Dach laufen.
Beim OPPO hingegen sind die Dachziegel scharf und deutlich zuerkennen.
Am Coloseum sind ein paar Vorsprünge in der Mauer die beim PIO gezackt dargestellt werden - auch hier wieder beim OPPO perfekt.
audiohobbit
#37 erstellt: 23. Okt 2005, 23:11
alles klar, danke. genau die szene meinte ich. was beim pio ausschaut wie eine welle nennt sich übrigens Moiré-Muster.
w0rl
#38 erstellt: 07. Nov 2005, 11:40
Was gibts denn mitlerweile für Neuigkeiten bzgl. des Players??
kirmesstenz
#39 erstellt: 08. Nov 2005, 16:21
moin zusammen,
habe mir den oppo in den usa bestellt. bin gespannt wie lange es dauert bis er geliefert wird.
bedenkt bitte wenn ihre eine sammelbestellung macht ob die kabel dabei sind. beim oppo sind ein dvi-dvi und ein dvi-hdmi kabel dabei. diese angebot gilt allerdings nur bei bestellung von der internetseite von oppo. wenn ihr die zusätzlich kaufen müsst seit ihr schnell euren sammelrabat von ca. 40 euro los.
das6Mio$ohr
#40 erstellt: 08. Nov 2005, 17:57
Das beiliegende 2m Kabel ist aber nichts besonderes.
Habe mir ein 5m Kabel der Firma MONITOR zugelegt,aber die Bildqualli ist deutlich schlechter geworden(lauter rote Pixel).
Bleibt zu hoffen daß,das Kabel defekt ist.
w0rl
#41 erstellt: 09. Nov 2005, 11:15
@Kirmesstenz
Wie teuer ist der Player denn insgesamt inkl Versand, Zoll etc ?
tere13
#42 erstellt: 09. Nov 2005, 12:38
Also nach meiner Berechnung :
$250.- Gerät inkl. Versand
+ 12% Einfuhrsteuer
+ 16% Mwst.
macht so um die $330.-
So war es bei meinen Jeans, weiß aber nicht genau wie die Einfuhrsteuer bei Elektrogeräten ist.
mfg.
das6Mio$ohr
#43 erstellt: 09. Nov 2005, 15:49
@ all
Also ich habe das Gerät aus den USA mitgebracht und habe einzig und allein beim deutschen Zoll 13,5% Einfuhrsteuer auf den Garätepreis bezahlt.Auf Versankosten wird kein Zoll verlangt.Mehrwertsteuern werden auch nicht bezahlt da das Gerät nicht in Deutschland gekauft wurde.
Also -
199$ für den Player + 13,5% Eínfuhrsteuer
50$ für den Versand
Macht bei einem Dollarkurs von 1,2 ca. 230€.
Mehr wird es nicht.
kirmesstenz
#44 erstellt: 10. Nov 2005, 07:51
yep, das ist auch mein kenntnisstand. mehr dürfte es nicht werden!
tere13
#45 erstellt: 10. Nov 2005, 17:00
Also bei meiner Jeans Bestellung war es definitiv so das auch noch die Mwst. drauf kam.
Ich glaub am Frankfurter Flughafen ist die Hauptzollstelle
für solche Angelegenheiten,
vielleicht einfach mal anrufen!?
mfg.
Zoll-Infocenter
Hansaallee 141
60320 Frankfurt am Main
Telefon: 069/469976-00
Telefax: 069/469976-99
oder per E-Mail
info@zoll-infocenter.de
Persönlich erreichen Sie das Zoll–Infocenter
Montag - Donnerstag
07:00 - 17:00 Uhr
Freitag
07:00 - 16:00 Uhr
[Beitrag von tere13 am 10. Nov 2005, 17:11 bearbeitet]
das6Mio$ohr
#46 erstellt: 10. Nov 2005, 20:24
Bin über Frankfurt eingreist und habe den Player am Zoll angegeben.
Es waren 13,5% und keine weiteren MWST.
Ideal
#47 erstellt: 13. Nov 2005, 21:06
Habe den Thread sehr aufmerksam verfolgt und finde das der BBK für mich eine echte alternative sein könnte.
Jetzt habe ich bloß nochmal eine Verständnisfrage.
Der Player ist ja HDCP-Free.
Es kommt also nicht zu Problemen bei einem Anschluss an ein Plasma/LCD Panel welches HD-Ready ist und somit HDCP unterstützt?
Weil andersrum scheint es Probleme zu geben wenn der Player das HDCP Signal ausgibt,das Panel aber nichts damit anfangen kann.
Ich hoffe ihr wisst was ich meine
das6Mio$ohr
#48 erstellt: 14. Nov 2005, 14:08
Ob das am BBK auch alles funktioniert weiß ich nicht.
Auf jeden fall kannst du aber einen HDCPfreien DVD Player an einem HDPC Display betreiben.
NeWJoe1
#49 erstellt: 14. Nov 2005, 15:24
auch ich verfolge diese Diskussion hier und im englischen avforums und amerikanischen avsforum mit. Der Player, egal ob Oppo oder BBK, ist interessant.
Aber zur Zeit sollte man auch wie bei anderen Playern bedenken, dass gerade das PAL Upscaling über DVI zu 720p bzw. 1080i nicht an jedem Bildschirm garaniert werden kann. Es sind Fälle bekannt, in denen es keine Funktion bei Loewe LCD's, Sony LCD's und BenQ LCD Projektoren gibt, andere Geräte könnten auch betroffen sein. Oppo hat dieses Problem auch zugegeben.
Ich selbst beitze seit kurzem den Sony KDF-E42A11 und habe wegen der PAL Schwierigkeiten direkt Kontakt mit Oppo aufgenommen. In einer Mail wurde mir versichert, dass man an einer Lösung im nächsten Firmwareupdate arbeitet, dass innerhalb der nächsten Wochen erscheinen soll. Solange erscheint mir ein Kauf zu heikel. Wohlgemerkt ist nur das PAL Upscaling betroffen, nicht das NTSC Upsacling, aber ich selbst besitze nur PAL DVD's.
Die interessante Firmwareentwicklung findet zur Zeit in erster Linie beim Oppo und nicht beim BBK statt (hier tauchen Firmwareupdates nur nach größerer Verzögerung zum Oppo auf). Die Firmware des Oppo ist zwar auf den BBK flashbar, danach ists aber für viele Essig mit dem Scartausgang, da der anstelle von RGB bzw. YUV nur noch YUV ausgibt und dies können per SCART viele Displays dann nicht darstellen. Unter diesem Aspekt erscheint der Original Oppo auch die bessere Wahl zu sein.
Bis bald
Gerald
The_DJ
#50 erstellt: 15. Nov 2005, 19:42
Moin moin!
Kann mir jemand sagen, mit wieviel Hz der Oppo PAL DVD´s bei 720p und 1080i am DVI ausgibt?? 50 oder 60?? Ist für mich wichtig, da mein Plasma leider nur 720p und 1080i mit 60Hz kann...
Danke!!!
das6Mio$ohr
#51 erstellt: 16. Nov 2005, 14:49
Der Oppo Support beantwortet auch technische Fragen innerhalb von 24 Stunden.
Versuch es mal da.
http://www.oppodigital.com/opdv971h_support.html
Oppo Digital - OPDV971H DivX HD Problem
VvoODy am 10.05.2006  –  Letzte Antwort am 10.05.2006  –  4 Beiträge
Oppo OPDV971H-E oder welche Alternative?
sptotal am 20.06.2006  –  Letzte Antwort am 21.06.2006  –  11 Beiträge
Oppo Digital DV-981HD
herbi14 am 04.12.2006  –  Letzte Antwort am 29.03.2009  –  226 Beiträge
Läuft Plus Piano HE 3100 mit Oppo OPDV971H über DVI ?
Markus-71 am 04.01.2006  –  Letzte Antwort am 04.01.2006  –  2 Beiträge
OPPO DV-970HD
inomics am 31.05.2006  –  Letzte Antwort am 04.06.2006  –  9 Beiträge
Vergleich zwischen DVD-S52 und OPDV971H
DamienX am 20.06.2006  –  Letzte Antwort am 21.06.2006  –  5 Beiträge
Oppo DV981 Konfiguration HDMI-Ausgang
AKHAAS am 19.11.2008  –  Letzte Antwort am 05.12.2010  –  6 Beiträge
Oppo vs Denon 1910
michael_hoch am 05.01.2006  –  Letzte Antwort am 06.01.2006  –  5 Beiträge
Kombination Oppo - Sanyo z4
michael_hoch am 27.01.2006  –  Letzte Antwort am 06.02.2006  –  2 Beiträge
Oppo DV-981HD
bully2 am 16.03.2007  –  Letzte Antwort am 16.03.2007  –  2 Beiträge
  • Registrierte Mitglieder928.793 ( Heute: 10 )
  • Neuestes Mitgliedtimundstruppi_
  • Gesamtzahl an Themen1.558.989
  • Gesamtzahl an Beiträgen21.715.060
