TVX HD M-5000U
homebass
#1 erstellt: 15. Mrz 2006, 11:32
erst einmal hoffe ich, dass ich in dieser Kategorie diese Ankündigung schreiben darf, da dieses Center zum Abspielen sämtlicher Files anpreist, es jedoch kein wirklicher DVD Player ist.
Nach sämtlichen Tests und Fehlkäufen von DVD Playern für HDTV-fähige Files (wmv hd, divx hd, usw.), u.a. Zensonic Z500, DigitalRise Xstream Player, Kiss DP-600, usw. kam ich beim Stöbern im Internet auf dieses elegante Schmuckstück:
Herstellerangaben:
HD Playback
TViX HD can playback high definition video (up to 1920x1080i) and still images. Pre-recorded HDTV programs from a digital TV set-top box or personal digital video contents taken by a HDV™ camcorder can be played back with TViX HD on a high definition display. The TViX HD features a DVI connector and component, which matches the high resolution of HD level video contents.
Multimedia Player
TViX HD is a standalone, multimedia hard disk player which can play digital videos, digital music, digital still images and DVD files to a TV display and home entertainment system. Now you can enjoy digital contents in the comfort of your own living room without having to burn discs or having to play it back on a DVD or CD player anymore.
DVD Jukebox
TViX HD can playback DVD movies with the full functionality of DVD navigation. You can create your own virtual DVD library by storing your private collection of DVDs in .ISO or .IFO format and watch them exactly as if they were running from the original DVDs (all original features included: Menu, Chapter, Audio Stream, Subtitle, Fast Forward, Rewind, Slow, Pause, Step Forward, Repeat, Search, etc.).
Network Connectivity
The TViX HD can be networked with a PC system using its built-in LAN port. You are able to navigate to a file in a PC on TViX’s network and play the file from its original destination without having to first copy it onto the TViX HD.
USB2.0 Host
With two USB2.0 host ports, you can now attach additional external USB hard drives to further extend the storage capacity or transfer files from another USB device such as a thumb drive. You can also playback files from a digital camera, USB flash driver, USB flash card reader, or a MP3 player.
Hier nochmals der Links, mit weiteren Bildern und Infos:
http://www.tvix.co.kr/Eng/products/HDM5000U.aspx
Kennt jemand dieses Teil? Über die Schweiz hätte man schon eine Möglichkeit, dieses zu bestellen, inkl. 160GB Festplatte kostet es ca. 330 Euro zzgl. Versand und Steuern.
Bedingt durch die beiden USB 2.0 Ports können weitere HD´s angeschlossen werden, eine größere Version mit integrierter HD ist also nicht zwingend erforderlich.
Interessieren würde mich, ob die wmv hd´s und divx hd´s ohne Ruckeln abgespielt werden können und welcher Sigma Chip verbaut ist.
Hat jemand genaue Infos darüber ??
[Beitrag von homebass am 15. Mrz 2006, 11:34 bearbeitet]
homebass
#2 erstellt: 15. Mrz 2006, 11:40
habe soeben einen Testbericht gefunden:
http://www.mpcclub.c...view_TViX-M5000U.pdf
bigbac
#3 erstellt: 30. Mai 2006, 12:35
Hallo homebass,
ich habe mir das Gerät mal gegönnt und kann nur sagen das ich damit sehr zufrieden bin. Zum Design braucht man ja nicht viel sagen...ich finde es cool. Eine schöne Dose aus gebürstetem Alu!
Ich habe Sie über YUV an meinen Pio 435XDE angeschlossen und die 720p Auflösung gewählt. Also die Einstellungen funzen super, geht auch ohne TV über das Display. WMV-HD Inhalte gibt er nur wieder wenn sie nicht verschlüsselt sind. Mit anderen Formaten in HD hat sie auch keine Probleme (avi, mpg) aber die Kinotrailer in wmv-hd sehen natürlich besser aus. Über DVI habe ich das Gerät noch nicht angeschlossen, da ich noch kein Adapter-Kabel habe. Aber ich werde wohl die YUV Verbindung lassen. Bei Audio Fils und Fotos klappte bisher auch alles. Ich habe damals auch die aktuelle Firmware aufgespielt, welches auch super einfach ging. Netzwerk habe ich noch nicht probiert, kann aber auch nicht wirklich schwer zu machen sein. Also ich bin rundum zufrieden und kann die kleine (wirklich kleine) Box empfählen. Es soll ja auch bald noch einen TV Tuner dazu geben, dann hat man einen Vollwertigen HDD Recorder.
Also bis dann
bigbac
homebass
#4 erstellt: 30. Mai 2006, 12:43
danke für die infos, klingt sehr interessant!
hättest du noch ein paar weitere, welche files genau gehen, speziell hdtv files!
netzwerkintegration würde mich auch brennend interessieren!
bigbac
#5 erstellt: 31. Mai 2006, 05:32
moin moin,
also schon wie gesagt gehen alles wmv-hd, die nicht geschützt sind. DRM geschützte files laufen nicht. AVI und MPG files mit der 720 oder 1080 er Auflösung laufen auch. Was das genau für files sind....muss ich mal schauen. ansonsten läuft eigentlich alles was es noch so gibt. *.mov Dateien kann ich nicht sagen, habe ich noch nicht ausprobiert. Man kann auch DVD's auf die Box (mit HDD) spielen, die laufen ganz normal wie ein DVD Player also auch mit Menue. Ich werde in den nächsten Tagen mal schauen was noch so geht. Das mit dem Netzwerk werde ich mal ausprobieren, vielleicht wird das ja für mich auch mal interessant.
bigbac
was mir noch einfällt....ich habe die Box als 1. bei Radio Klann bestellt, das ist der offizielle Vertrieb in Deutschland. Steht auch auf der Homepage von TVIX. http://www.tvix.co.kr/Eng/WhereToBuy.aspx
[Beitrag von bigbac am 31. Mai 2006, 05:35 bearbeitet]
homebass
#6 erstellt: 31. Mai 2006, 06:08
okidoki, in erster linie interessiert mich nur die wiedergabe sämtlicher hdtv files, egal ob wmv9, ts, hd divx, usw !!!
bedingt durch die schlechten funktionen der neuen hdtv dvd player ala kiss, transgear, zensonic, usw. wäre dies eine alternative!
dumme frage: internetradio hat das teil nicht, oder?
bigbac
#7 erstellt: 31. Mai 2006, 09:05
Internetradio geht nicht, zumindestens habe ich noch nichts davon gelesen. *ts files sollen auch laufen, ich habe aber keine zum testen. Mir gfällt die Box richtig gut, sieht gut aus und spielt alles ab. Da ich einen Sony DVD Recorder habe ist es gut das ich dann noch ein anderes Gerät habe welches dann alles files abspielen kann. Nachdem ich die neue firmware aufgespielt hatte liefen einige videos auch viel schneller an als vorher, auch wurden mehrere Vorspulgeschwindigkeiten bei einigen dateien dazugefügt. Die Zoom funktion ist auch super, dann kann man alle dateien so abspielen das sie auch Formatfüllend sind. Gut für mich war auch das die Box nur IDE HDD's nimmt, da konnte ich dann eine "alte" 160GB HDD einbauen und das geht super einfach. Ich werde mir mal ein DVI-HDMI Kabel kaufen und mal ausprobieren ob das Bild digital übertragen noch besser wird......man man was will ich alles noch machen
Ich werde auf jeden Fall berichten wenn ich etwas ausprobiert oder was neues (für mich) gefunden habe.
PS: ich finde das die Box eine gute alternative für die genannten DVD-Player ist, schon alleine der HDD wegen.
Bartimausi
#8 erstellt: 06. Jun 2006, 08:28
ich interessiere mich auch für dieses Teil. Hat es eigentlich ein DVD-Laufwerk ? Ich lese darüber nur widersprüchliches. Und wie sieht es mit der Lautstärke aus ? Auf der Rückseite habe ich einen Lüfter entdeckt, und gegen sowas bin ich allergisch.....
B.
homebass
#9 erstellt: 06. Jun 2006, 08:34
!!! kein DVD Player !!!
nur HD
bigbac
#10 erstellt: 07. Jun 2006, 04:58
wie schon gesagt, kein DVD-Laufwerk. Der Lüfter auf der Rückseite ist nicht wirklich laut. Man kann ihn im Setup einstellen. Ich habe ihn auf "normal" gelassen. Mich stört er nicht. Es kommt immer darauf an wie man das selbst empfindet. Den einen stört das Geräusch, den anderen nicht. Ich sitze ca. 2m vom Gerät entfernt und meinem Empfinden nach ist er zwar hörbar, aber wenn ich einen Film schaue oder Musik höre, dann nehme ich ihn nicht wirklich wahr
Ich habe mir bei e-bay mal ein DVI-HDMI Kabe gekauft, mal schauen wie das Bild danach aussieht...ich hoffe noch besser.
bigbac
hgreimann
#11 erstellt: 07. Jun 2006, 05:44
Läuft am USB Anschluss ein externes DVD-Laufwerk? Das wäre dann eine gute Lösung.
HGR
bigbac
#12 erstellt: 07. Jun 2006, 05:49
oha, das kann ich nicht sagen und ausprobieren...ich habe kein USB DVD-Laufwerk....möglich wäre es allerdings. Man kann ja auch HDD's anschließen?!
bigbac
#13 erstellt: 09. Jun 2006, 10:26
ich habe heute meine Kabel bekommen und gleich angeschlossen. Die Box ist jetzt mit einem DVI-HDMI Kabel an einem HDMI-Switch angeschlossen. Und was soll ich sagen, das Bild hat sich in diesem Fall wesentlich verbessert. Ich hätte nicht gedacht das es einen großen Unterschied geben wird zwischen Komponente und DVI/HDMI.
bigbac
r2d2_media
#14 erstellt: 12. Jun 2006, 10:10
Hi zusammen,
ich habe das Teil nun seit einem Monat und bin begeistert.
Für mich war wichtig das sich Mpeg4 dateien abspielen lassen
insbesondere Nero Digital.
Das Teilt spielt alle meine Nero-Files und auch andere Formate problemlos ab.
Ein Firmware update habe ich auch schon gemacht.
Was problemlos funktionierte.
Der Lüfter stört überhaupt nicht.
Erlässt sich in 4 Stufen einstellen. (Per Software)
Das abspielen von Filmen über das Netzwerk habe ich auch schon ausprobiert.
Ein bisschen blöd finde ich das dies über eine normale Freigabe gelöst wurde und nicht als Streaming -Client.
Etwas unglücklich gelöst ist die Dia-Show für JPEG-Bilder.
Damit bei mir die Bilder als Dia-Show laufen muß ich
die Bilder im Format verkleinern. ca. 50%.
Bei 3264x2448 pixels einer 8 mega Pixel Aufnahme lässt sich das aber leicht verschmerzen.
Bei der Betrachtung auf dem Fernseher wirkt sich das eh nicht aus.
Aber vielleicht bring eins der nächsten Firmwareupdates eine
Änderung.
Zu Audio-Dateien kann ich noch nichts sagen.
Sonst bin ich aber rundum Zufrieden.
homebass
#15 erstellt: 12. Jun 2006, 11:55
schreib du doch mal etwas zu der wiedergabe hochauflösender videofiles, wmv9, divx hd, ts, usw !!!
das wäre klasse!
bigbac
#16 erstellt: 13. Jun 2006, 04:53
@ r2d2_media
danke für deinen Beitrag!
Das mit der Dia-Show ist mir auch aufgefallen das er bestimmte Fotos nicht anzeigen kann, da sie zu groß sind. Aber ich denke das beim nächsten Update der Firmware da einiges getan werden kann. Ein Bildschirmschoner während der mp3 Wiedergabe hätte auch was....aber man(n) kann ja den TV abschalten.
Schön das es noch jemanden gibt der die kleine schicke Dose hat!
@ homebass: ts wird auch wiedergegeben...und welche Info's brauchst du jetzt noch? Die Box spielt eigentlich alles ab, außer DRM geschützte wmvhd und auch keine h264, dafür wäre dann ein anderer Chip notwendig....Sigma Design EM8622 (in der Box ist der 8621)
Gruß bigbac
[Beitrag von bigbac am 13. Jun 2006, 05:00 bearbeitet]
homebass
#17 erstellt: 14. Jun 2006, 13:51
antworten sind für mich nun ausreichend, danke euch allen!
Sven1968
#18 erstellt: 27. Jun 2006, 17:47
Ich habe das Maxtor Shared Storage System als NAS und kann dort auch SMB-Freigaben erstellen.
Kann der Tvix diese Freigabe verwenden, sofern ich ihr den korrekten Namen gäbe, oder klappt das wirklich nur auf PCs mit den Gast-Account, wie in dem Testbericht zu lesen ist?
Sven1968
#19 erstellt: 27. Jun 2006, 17:59
Meine Anfrage hat sich bereits erledigt, ich habe im AVS-Foum einen Beitrag gefunden, wonach es problemlos funktioniert.
bigbac
#20 erstellt: 18. Jul 2006, 10:10
hallo stolze TVIX HD M-5000U Besitzer,
auf der Website des Herstellers gibt es seit Anfang Juli die neue Firmware. nette Sachen wurden umgesetzt und Hoffnung für die Zukunft gemacht.
also saugen und installieren.
bigbac
kjinet
#21 erstellt: 19. Jul 2006, 13:19
Hallo, Ich bin ein "stolzer M-300U" Besitzer und nun auch ein stolzer "HD-ready LG50PX4R Plasma TV" Besitzer. So nebenbei der Fernseher ist in allen Belangen ein Wahnsinn - zu diesem PReis. Aber meine Frage ist bezüglich der TVIX, vielleicht hat ein Experte hier Rat.
>>>>>>>> Gestern habe ich die beiden Components (tvix u. tv)
verbunden und bilder mit der box über 720p und 1080i probiert. Ich hätte mir schärfere bilder erwartet, als wenn ich die box normal über PAL-Composite am av-eingang des TV betreibe. Das Videos pal 720x576 nicht besser kommen können ist mir klar, aber die Bilder sind 3-5 megapixel. Das sollte doch wesentlich schärfer sein. Oder habe ich da einen Denkfehler. Was ist falsch ? Oder was mache ich falsch ?
thx
-j
bigbac
#22 erstellt: 20. Jul 2006, 07:21
thx
-j
Du musst die Box über den Componenten Anschluß (YUV / blau, grün, rot) verbinden, dann solltest du eigentlich die Bilder in HD sehen. Also die Verbindung über das Composite Kabel (gelb) ist die mit Abstand schlechteste Verbindung. Bei der HD M-5000U wurde durch die neue Firmware die Auflösung der Bilder auf 4096x4096 vergrößert. Vorher wurden nicht alle Bilder angezeigt, jetzt ja und natürlich in HD und super scharf....so wie die Aufnahme auch am PC aussieht.
ich hoffe das ich helfen konnte...
bigbac
kjinet
#23 erstellt: 20. Jul 2006, 07:48
hallo, danke für die antwort. ich habe das auch über component probiert und das nötige setup gemacht. gestern fragte ich das problem auch gleichzeitig bei DVICO an und habe diese antwort erhalten. Im Widerspruch zu deiner Aussage ...
Hello,
This is because it just upscale the output. Basically, M3000U is not for HD device. If you want to see high quality picture in your TV, I think you better check M5000 series.
Thanks,
Eric
bigbac
#24 erstellt: 20. Jul 2006, 08:05
Hello,
Thanks,
Eric
das ist schade das die Box die Bilder nicht in HD ausgeben kann, was ich mir aber nicht vorstellen kann. Ich hatte mal einen Samsung DVD-Player mit HDMI und dieser hat die Bilder dann auch in HD abgespielt (von DVD). Aber viele Andere Player mit HDMI und upscaling zeigen nur die SD Auflösung, also nur PAL. Wie lange hast du denn die Box schon? Kannst sie doch zurückgeben und die 5000U nehmen...das lohnt sich wirklich, da in Zukunft ja auch noch ein TV Tuner geplant ist, dann wird die Box zu einem HDD-Recorder. Also ich bin von der 5000U begeistert.
schöne Grüße aus HH
bigbac
kjinet
#25 erstellt: 20. Jul 2006, 08:25
hallo,
hm, das mit dem dvd-player ist eine gute idee. zumindest zum test. ich hab aktuell die samsung ht-p1200 heimkino anlage gekauft. über hdmi angeschlossen. dvds sind einfach ein wahnsinn auf dem tv. da kann ich ja mal bilder probieren.
nein, die box hab ich schon länger. kein umtausch möglich.
jetzt gerade weil wir wohnzimmer total umbauen habe ich meine tvs und stereoanlage verkauft und den LG50PX4R und die HT-P1200 gekauft. Und viel Freude damit. Nun werd ich halt an den Weihnachtsmann schreiben für die Dvico 5000er. Denn dz. ist das börsl LEER :))) Das mit dem Tuner, dann Box=HDD Recorder wäre sehr interessant, denn meinen alten Videorecorder möcht ich auch noch mit einem HDD-Rec ersetzen. Gibts da irgendwo schon detailinformationen, was das dann alles kann ? und wie das dann aussieht ?
Schöne Grüsse aus dem heissen österreich, heute bis zu 36 Grad !
bigbac
#26 erstellt: 20. Jul 2006, 09:41
kjinet schrieb:
Gibts da irgendwo schon detailinformationen, was das dann alles kann ? und wie das dann aussieht?
jo, Bilder gibt es schon...hier z.B.: http://www.ehomeupgrade.com/entry/2330/tvix_m5000u_media
was er können soll kann ich nicht sagen, die arbeiten noch an einer Umsetzung für DVB-T. Ich kann mir gut vorstellen das es in Naher Zukunft (wenn der alte Mann mit Bart kommt ) einen TV-Tuner geben wird, sowohl für DVB-S (inkl.HDTV) und auch für DVB-T....dann wäre die Box noch interessanter als sie jetzt schon ist.
schöne Grüße bei jetzt 31° im Raum
bigbac
kjinet
#27 erstellt: 20. Jul 2006, 12:36
hallo ! 2 mails von DVICO bezüglich tuner ....
Die Erste ...
Hello,
M-5000U or M-5000A will not work with DVB-T tuner that we are developing. Feature product(M-5100) is supposed to be work with DVB-T tuner option. New product is scheduled to ship Q4 this year. I am sorry but Exact shipping date is not know at this moment.
Thanks,
Eric
Und dann gleich drauf noch ....
HDTV Tuner for M5000 is currently for ATSC only which is for Korea and North America.
Thanks,
Eric
sieht also nicht so gut aus so schnell
bigbac
#28 erstellt: 21. Jul 2006, 05:11
kjinet schrieb:
sieht also nicht so gut aus so schnell :)
schauen wir mal was sich da noch tut. Schreiben kann man viel, Papie ist sehr geduldig. Wenn aber eine 5100 kommt muss ich eventuell auch noch mit meinem Finanzminister sprechen....aber bis zum 4/Q ist noch etwas hin und bis es dann in Deutschland erhältlich ist werden wohl auch noch 3 Monate vergehen. Also im März 2007 werden wir es sehen....upps, da habe ich ja Geburtstag....was für ein Zufall!!!
bigbac
kjinet
#29 erstellt: 21. Jul 2006, 05:39
Sodale,
Jetzt gibts einen Teilerfolg aber auch kleine "Katastrophenstimmung" irgendwie Der Teilerfolg. Gestern endlich sah ich ein Bild in HD, nämlich als ich eine SD-Karte mit dem Bild in den LG Fernseher steckte !! Traumhaft der Unterschied. Es ist wie ein Foto, Schärfe bis ins Detail. Und dann ! Meine TVIX M3000-U kann es doch. Mit 1080i sind die Fotos über den Component auch HD ! Da muss bei meinem ersten Test etwas schiefgelaufen sein. Meine PAL Videos kann ich dann aber mit 1080i nicht abspielen. Da ruckelts und zuckelts bei den seitlich Schwenks (motorrad-tour fahraufnahmen), das dir graut. Da muss man wieder auf PAL standard output umstellen. Das macht nicht soviel, aber bequem ist es nicht wenn du mit der Box Fotos und videos in einem Rutsch abspielen möchtest musst du wählen zwischen HD Bildern und Videoruckeln. Na gut, jetzt die kleine(n) Katastrophe(n). A) die Pana HT-P1200 Heimkinoanlage über HDMI schafft es weder von Usb-Stick, noch von DVD die Bilder in HD zu bringen, obwohl TV und Pana nachweislich auf 1080i arbeiten/eingestellt sind. Da muss ich mal anrufen warum das nicht geht. Katastrophe B betrifft wieder meine Box. Damals ... Es war einmal ...habe ich alle meine Slideshows als MPEG Videos gerendert und auf die TVIX kopiert, mit Titel und Musik, etc. Eben in Ermangelung ordentlicher Slideshow Features der TVIX. Nun ! toll, diese Slideshows können nun defintiv nicht in HD kommen -klar. Also müsste ich die neu machen, in HD rendern usw. denke ich. Oder die 5000er bringt bessere slideshow features. Wie auch immer, das ganze von vorne ? Wo bleibt da die Freizeit ? Naja, das sind so meine ersten Erfahrungen mit HD eben, und man sieht was da auf einem zukommt an Arbeit und an Kosten wenn man auf den HD-Zug aufspringt. Übrigens, zufällig gestern, österreiches Fernsehen !! Die stellen ziemlich brutal schon im Herbst 2006 auf DVB-T um. Parallelbetrieb DVB-T und heutige TV-Sender nicht möglich. Dann braucht ein jeder TV eine DVB-T Box. 40 Euro Förderung für die ersten 100000 freiwilligen Umsteiger.
Have some Fun !
bigbac
#30 erstellt: 21. Jul 2006, 06:28
also die 5000 hat eine Slidshow, da kann man Effekte, Zeit und auch Musik einstellen. Ist aber nicht so mein Ding, Hauptsache die Bilder sind in HD. Kannst du deine Auflösung auf 720p stellen, das sollte dann auch besser für deine Videos sein, da die Box dann nicht so belastet ist.
bigbac
kjinet
#31 erstellt: 21. Jul 2006, 06:51
halo, ja - auch mit 720p probiert. Videos ruckeln zwar weniger als mit 1080i aber trotzdem. Und richtig scharf werden die bilder erst mit 1080i. Die 5000er muss her ... Übrigens, falls sich jemand wundert in meinen vorherigen beiträgen spreche ich von einer pana HT-PT1200. Kleine geistige Verwirrung. Die heisst SAMSUNG HT-P1200 - sorry. ... und spielt meine bilder nicht in HD ab, die kleine schwarze ...
have a nice weekend !
bigbac
#32 erstellt: 21. Jul 2006, 07:08
Schönes WE zurück!
bigbac
Impresa77
#33 erstellt: 27. Okt 2006, 15:48
nach langem hin und her hab ich mich auch für einen TVIX 5000A mit 400GB entschieden. (Was eigentlich unterschied zwischen 5000A und 5000U?).
nun.. habe ein paar probleme damit.
er liest keine Xvid 1.1.0.
habe auch grössere (3,5gb und mehr) videodateien vom sat-reciver (mpg2) die kriege ich gar nicht auf die festplatte. er motzt, dass nicht genug platz sei..???
ausserdem ist schnelles vorwärtsspulen ziehmlich mühsam. bei jedem 2. film stürzt er fast ab und es geht mehrere sekunden bis der film wieder im normalen tempo läuft wenn ich das vorspulen abbreche.
stimmt da vielleicht was mit der festpaltte nicht?
bigbac
#34 erstellt: 01. Nov 2006, 09:46
Moin,
hast du die neueste Firmware auf der Dose?
bigbac
Impresa77
#35 erstellt: 01. Nov 2006, 16:43
Sali
ja, "firmware 1.9.5 (PAL)" habe ich seid kurzem drauf.
warum eigentlich diese verschiedenen FW's?
Ob PAL oder NTSC sollte bei der Firmware ja keine rolle spielen?!?
problem lag aber nich an der FW.
kenn mich nicht so aus mit PC-Technik.
habe die festplatte gar nicht formatiert gehabt. lief ja trotzdem vieles.
jetzt nach NTFS formatierung laufen alle formate ohne probleme. wenn man das vor- und zurückspulen mal weg lässt. das geht bei vielen filmen nicht. doch etwas mühsam.
Gruess
sww001
#36 erstellt: 08. Jan 2007, 09:13
@Alle,
was gibt es neues von diesem guten Teil?
Ich bin gerade dabei mir auch zu überlegen etwas neues zuzulegen, vor allem nachdem ich mein Pioneer PDP-427XD am Freitag bekommen habe. Insbesonderes da mein DVD Player woll demnächst kaputt geht.
sww001
sww001
#37 erstellt: 09. Jan 2007, 19:57
Hallo bigbac,
ich habe gerade den Test überflogen bezüglich Fotos (siehe Testbericht von mpcclub). Da schneidet der Player leider überhaupt nicht gut ab. Ist das, vielleicht mit neuem Firmware, immer noch so?
Ein Bereich der mich sehr interessiert ist auch der Fotobereich. Ich such einen Player (egal ob Mediaplayer oder DVD Player) der mir meine Bilder (von der Nikon D70) in einer anständigen Geschwindigkeit am Fernseher abspielen kann.
sww001
sww001
#38 erstellt: 17. Jan 2007, 09:31
@Alle,
sind hier keine mehr die diesen Player haben (oder nicht mehr zufrieden sind)?
sww001
yaan
#39 erstellt: 22. Jan 2007, 15:54
Wenn man den Aussagen anderer Nutzer in anderen Foren Glauben schenken darf, sind die allermeisten "Kinderkrankheiten" mittlerweile durch neue FWs behoben worden. Da ich bis dato sehr viel Gutes über das Teil gehört habe, habe ich es mir bestellt - ich hoffe es ist morgen oder übermorgen in der Post. Dann kann ich mir die Fotowiedergabefunktion (auch wenn ich sie selber nicht wirklich brauche) mal bzgl. der in dem Testbericht genannten Punkte anschauen...
sww001
#40 erstellt: 22. Jan 2007, 19:41
Hallo yaan,
danke.
In welchen Foren hast du was gelesen über den M-5000?
sww001
yaan
#41 erstellt: 22. Jan 2007, 19:46
Auch auf die Gefahr hin für "Schleichwerbung" eine Abmahnung zu kassieren
www.avsforum.com
www.beisammen.de
sww001
#42 erstellt: 22. Jan 2007, 19:48
Hallo yaan,
danke nochmal.
Hast du dir den 5000 gekauft? Welche Festplatte? Wo hast du bezahlt? Was sind deine Anwendungen?
sww001
yaan
#43 erstellt: 22. Jan 2007, 22:39
Ja und nein: ist bestellt, aber noch nicht da.
sww001 schrieb:
Welche Festplatte?
250GB sollten denke ich reichen. Wird direkt mit Festplatte geliefert - also weiß ich leider nicht, welche genau verbaut ist.
sww001 schrieb:
Wo hast du bezahlt?
Ich habe bei www.hdd-player.de bestellt.
Primär Wiedergabe von eigenem HD-Material (HD-Camcorder). Außerdem werd ich wohl meine CD-Sammlung in Teilen digitalisieren, damit ich nicht jedes Mal zum Musikhören ans Regal rennen muss
Ansonstem mal schauen, was sich noch so ergibt...HD-WMVs werde ich sicher auch mal probieren.
sww001
#44 erstellt: 23. Jan 2007, 09:12
Hallo yaan,
dann halte uns (mich )immer schön auf den laufenden. Danke.
sww001
wonigg
#45 erstellt: 28. Jan 2007, 15:36
Videoshow mit TVX in full HDTV
Ich habe Ende letzter Woche eine Videoshow in full HDTV gesehen und war von der Bildqualität sehr beeindruckt. Die Vorführung war von einer TViX Box über einen Beamer auf eine ca. 3x4m Leinwand!. Die Bildqualität kann mit entsprechenden Diashows mit mehreren Überblendprojektoren mithalten. Ich habe leider nicht das Beamer Modell nachgefragt. Die Webseite des Authors ist: www.travel-docus.de, dort sind auch die Kontaktdaten. Der Film ging über den Jakobsweg und war ein Zusammenschnitt aus Standbildern und Videosequenzen einer HDV Kamera. (Dies ist kein Werbeeintrag des Authors der Show, sondern die ehrliche Anerkennung eines Besuchers)
sww001
#46 erstellt: 05. Feb 2007, 12:27
Hallo yaan,
wie sieht's aus mit deinem bestellten DvX Player (M-5000) aus? Hast du ihn schon?
@Alle: weiß jemand mehr über den neuen Player von DvX?
sww001
myelin2
#47 erstellt: 10. Apr 2007, 16:27
Hallo zusammen,
hat jemand Erfahrung mit dem Abspielen von HD-Files,die
a)auf dem eigenen PC liegen
b)auf einer externen USB-Festplatte liegen
bezgl. des Streamings. Funktioniert das ohne Aussetzer?
Gruss Manfred
techfreak2006
#48 erstellt: 11. Apr 2007, 12:50
Hallihallo!
Hm... Also der M-5000 ist ja ganz nett.
Ich warte aber lieber noch auf den M-5100SH. Der hat SATA, HDMI und verwendet H.264 Komprimierung.
Hab ihn vorbestellt und soll (hoffentlich) Anfang Mai kommen...
sprutzi79
#49 erstellt: 21. Apr 2008, 23:49
Kann mir jemand den Unterschied vom M5000A und M5000U erklären?
dann noch eine frage zum Tvix T530 Tuner für den DVB-T Empfang...kann das mudol meine DVB-T Antenne mit 5Volt versorgen?Habe zur Zeut einen Techni-Sat Reciever über den meine Indoor Antenne mit Strom versorgt wird.
vielen dank vorab..
[Beitrag von sprutzi79 am 22. Apr 2008, 01:30 bearbeitet]
DigitalRise Xstream Player (HDTV, WMV, DVI, etc)
martin0815 am 31.10.2005  –  Letzte Antwort am 18.05.2006  –  33 Beiträge
Suche DVD Player für WMV-HD Files
fcl1976 am 28.09.2006  –  Letzte Antwort am 28.09.2006  –  3 Beiträge
Digitalrise Xstream Player
Sergio168 am 21.12.2005  –  Letzte Antwort am 21.12.2005  –  3 Beiträge
Mein Zensonic HD DVD-Player Z500 ist da....
megabyte0469 am 04.01.2006  –  Letzte Antwort am 22.02.2007  –  97 Beiträge
gibt es WMV-HD Player ?
pale am 17.11.2005  –  Letzte Antwort am 18.11.2005  –  2 Beiträge
KISS DP-600 Serie
StefanR am 22.11.2004  –  Letzte Antwort am 23.11.2004  –  4 Beiträge
WMV HD DVD-Player
Der_Prinz am 19.01.2005  –  Letzte Antwort am 20.01.2005  –  5 Beiträge
HDTV fähige DVD Player????
Mr._X am 10.10.2004  –  Letzte Antwort am 11.10.2004  –  4 Beiträge
Suche Netzwerkfähigen DVD-Player; KISS DP 600?
Parabolon am 28.11.2006  –  Letzte Antwort am 29.11.2006  –  4 Beiträge
kiss dp 600
nobsman am 13.06.2006  –  Letzte Antwort am 13.06.2006  –  2 Beiträge
  • Registrierte Mitglieder928.851 ( Heute: 1 )
  • Neuestes MitgliedVolkaMMMtus
  • Gesamtzahl an Themen1.559.149
  • Gesamtzahl an Beiträgen21.718.819
