HIFI-FORUM » PC, Netzwerk & Multimedia » PC & Hifi » Super Klang durch wlan! | |
Super Klang durch wlan!+A -A |
collec
#1 erstellt: 18. Aug 2006, 09:25 | |
Ich suche eine gut Soundcard,aber habe Squeezebox 3 gefunden. Audio Outputs Audio outputs (general) Digital and analog outputs All RCA connectors are gold-plated Volume control is provided for all outputs Multiple outputs may be used at the same time Analog RCA outputs High fidelity Burr-Brown™ 24-bit DAC Two dedicated linear power regulators for DAC and line-out stages Full 6.0Vpp line-level signals Signal-to-noise ratio: over 100dB Total harmonic distortion: less than -93.5dB (0.002%) Digital S/PDIF outputs Optical and coax digital connections Dedicated high-precision crystal oscillators (no PLL, no resampling) Standard IEC-958 (S/PDIF) encoding Optical connector: TOSLINK 660nm Coax connector: RCA, 500mVpp into 75 ohms Sample rates: 44.1Khz, 48Khz Audio format: linear PCM, 16 or 24 bits per sample Intrinsic jitter: less than 50ps (standard deviation) Headphone output Standard 1/8" jack also functions as an IR blaster Minimum headphone impedance: 16 ohms Total harmonic distortion: less than 0.03% Left/right crosstalk attenuation: 92dB Audio Formats Audio formats Lossless Formats (Apple Lossless, FLAC, WMA Lossless) "Bit-perfect" CD audio streaming, with reduced storage and bandwidth usage. Approximately 2:1 compression ratio Uncompressed formats (AIFF, WAV, PCM) Supports raw pass-through of uncompressed PCM audio formats Digital passthrough to S/PDIF for DTS Compressed formats (MP3, AAC, Ogg Vorbis, MP2, MusePack, WMA) MPEG decoding uses MAD software, widely regarded as the most accurate, most compatible MP3 decoder. High accuracy 24-bit synthesis Supports all MP3 data rates and sample rates, including VBR May be streamed in PCM (raw), MP3 (transcoded), or FLAC (transcoded) formats Sound Check and Replay Gain support for automatic volume control. Some formats may require additional software installation (e.g. Quicktime), depending on platform. Internet Radio "Always-on" Internet Radio, powered by SqueezeNetwork, lets you tune in to Internet Radio streams even when the home PC is switched off. Quick selection from hundreds of Internet Radio streams offered by Slim Devices' partners. Internet Radio favorites can be saved in a playlist for easy access. Displays song title information during playback Support for MP3, Ogg Vorbis, and WMA formatted Internet Radio streams Tech Notes Firmware Flash upgradeable firmware Network settings are stored in non-volatile memory Auto-configuration for most networks Easy setup for wireless networks Architecture 250 MHz 8-way multithreaded RISC processor "Pure software" SlimDSP™ architecture Field-upgradeable Xilinx CPLD 64Mb high-speed RAM 16Mb program flash Low-power design, all solid-state, fanless Viele leute sagen,es kann mit LOSSLESS musicformat eine 500Euro Cdplayer gegen.Natruelich kann man ausser DAC benutzen,um Qualitaet zu erhoehen. [Beitrag von collec am 18. Aug 2006, 10:21 bearbeitet] |
kani
#2 erstellt: 18. Aug 2006, 12:39 | |
Was willst du jetzt von uns wissen, oder uns sagen? Nur Werbetext hinzuklatschen is nicht sonderlich hilfreich Ich gehe mal davon aus, dass du wissen willst, ob das Ding taugt. Dafür musst du nicht ne ganze Latte an technischen Daten in deinen post knallen. Derjenige, der dir was zu dem Teil sagen kann, weil er es kennt, wird dir auch technische Daten einen Bericht abgeben können. Für denjenigen, der es nicht kennt, sind die technischen Daten unnötiger Ballast, der ihm auch nicht weiterhilft, dir etwas über das Teil sagen zu können, weil er ausschließlich mit den technischen Daten, dir NIX zu den Qualitäten des Produkts sagen können wird. |
Soundaussetzer durch Wlan Volteran am 23.10.2006 – Letzte Antwort am 24.10.2006 – 4 Beiträge |
Audikabel PC-Receiver ersetzen durch WLAN fragensteller4711 am 07.10.2012 – Letzte Antwort am 09.10.2012 – 4 Beiträge |
Besseren Klang durch externe Soundkarte? dieglo am 18.03.2008 – Letzte Antwort am 19.03.2008 – 10 Beiträge |
WLAN-Router Fehr am 17.01.2006 – Letzte Antwort am 18.01.2006 – 3 Beiträge |
WLAN einrichten Boardfreak am 27.07.2008 – Letzte Antwort am 29.07.2008 – 4 Beiträge |
Problem WLAN padddy am 06.01.2009 – Letzte Antwort am 07.01.2009 – 10 Beiträge |
WLan - Repeater Leo93 am 25.12.2009 – Letzte Antwort am 28.12.2009 – 8 Beiträge |
Arcam rdac WLAN Dongle Stört WLAN Amice am 28.02.2013 – Letzte Antwort am 28.02.2013 – 2 Beiträge |
Schlechter Klang durch Digita-Ausgang der Soundkarte Link2 am 29.08.2014 – Letzte Antwort am 04.09.2014 – 7 Beiträge |
dumpfer Klang grendel32 am 01.10.2015 – Letzte Antwort am 02.10.2015 – 3 Beiträge |
2006
- Was ist WASAPI und ASIO?
- Registrierte Mitglieder928.098 ( Heute: 15 )
- Neuestes MitgliedEugenpap
- Gesamtzahl an Themen1.557.432
- Gesamtzahl an Beiträgen21.679.462
