HIFI-FORUM » English » Stereo (Engl.) » Biwire or not | |
Biwire or not+A -A |
SUB_BOSS
Gesperrt |
10:25
erstellt: 02. Mrz 2006, ||
Does biwiring help?? Linn's can be tri-wired ..oops triple your speaker cable budget if your amp permits..does this really benefit you in proportion ??.....
Arj
10:33
well it really depends on the speaker. some speakers take to it, some dont and some dont even have that option. IMHO if you have a budget for cables better to spend it all on the best quality cable rather than 2 lower quality cables... but again other may have a different opinion. and some dont believe cables make a difference (Do they ?) ![]() in the end i prefer the final option of spending it all on CDs ![]() |
Manek
13:05
bi-wire with bi-amping sometimes would make a difference in sound quality. Just simple biwiring(two sets of wires from the same amp terminals to speakers) is a no no in my books. Just use the same small piece of jumper wire as the speaker cable and you are set. Manek. Manek. |
Amp_Nut
13:23
I totally agree ! ![]() |
Shahrukh
13:40
A cable company that doesn't believe in biwiring? Now that's an interesting read: ![]() |
square_wave
13:56
I agree with ARJ. If it works for you, do it. Endless debates are there on numerous audio forums. End of the day, it is like the “electrical cable vs hi-end cable” debate only. Some can make out the difference, others can’t. |
nindo
14:04
guys...i think the bi-wire funda was introduced by the cable manufacturers just to boost the sales...rather double it.... ![]() |
Shahrukh
14:08
Not all cable manufacturers nindo. Refer to my last post. |
bombaywalla
20:07
Amp_nut, Manek: can you please explain why you guys think that "two sets of wires from the same amp terminals to speakers is a no no in my books"? Thanks! Re. biwiring, my experience seems to mirror what "Arj" said earlier: some speakers take well to it, others are ho-hum about it & in still others it makes no diff. There seem to be several reasons to biwire (or not) & one of the reasons is back-EMF from the speaker drivers into the x-over network. When I used to have B&W speakers, upon the manuf suggestion, I did biwire them in the "no-no" method cited by Manek & I can tell you that it made a diff to the sound for the better. I did compare the sound thru them single-wired & biwired. The jumpers I used were from the same manuf as the speaker cables. I'm not sure that I have a concrete explanation for why the "no-no" biwiring method was successful but 1 hypothesis that I had was that with biwiring, the tweeter-mid xover & the woofer xover BOTH saw a low impedance (that of the amp) at the same time. Hence, if there was any back-EMF from the drivers to the x-over, there was a very low imp path for it rather than this back-EMF running around the x-over boards & polluting everything. Empirically, I find that those speakers whose x-overs are carefully & well-designed, biwiring has little or no effect on their overall sound. In fact, manuf of those speakers specifically tell the user to not biwire. |
Amp_Nut
06:24
erstellt: 03. Mrz 2006, ||
Hi Bombaywalla, I agree, that bi-wiring should in theory better seperate the Back EMF paths, and each damped seperately, at the speaker terminals. However, my limited Practical experience showed no difference.... but I must admit that I tried alny using ordinary ( but thick, multi starnded ) wire. I did not have at hand, 2 pairs of exotic cables... Even when I tried 1 exortic pair + 1 ordinary pair, bi wiring.... the result was worse than no bi wiring. I agree that results will probably vary with speakers and amp used in the set up. Cheers |
stevieboy
06:28
those whose tastes don't run to straight wiring can use 'bi' wire. ![]() i agree with bombaywalla and amp nut. i think it all depends on the speaker and amp that you have. |
Manek
07:29
bombaywalla, hi I agree on theory that providing a dedicated route for back-EMF, practically whenever I have tried it, its been an extremely small difference or no difference at all. As a matter of fact the times I thought there was a minor difference, I wondered if it were my ears just playing tricks with me or was there a real difference. Not a large enough difference to convince me that it actually is benificial. But if it has worked for you......great ! Manek. |
Does CDP really matter Debu am 14.07.2006 – Letzte Antwort am 25.07.2006 – 39 Beiträge |
Does this price seem right to you? Virgil am 19.07.2005 – Letzte Antwort am 20.07.2005 – 7 Beiträge |
Can You Hear A High Frequency 'Squeal' Your Colour TV ? Amp_Nut am 30.06.2006 – Letzte Antwort am 04.07.2006 – 17 Beiträge |
Proportion of spending on respective equipments SUB_BOSS am 03.02.2006 – Letzte Antwort am 06.02.2006 – 15 Beiträge |
Need your help, folks ! sandeep am 23.06.2005 – Letzte Antwort am 24.06.2005 – 13 Beiträge |
Need your opinion novice00 am 25.04.2005 – Letzte Antwort am 28.04.2005 – 3 Beiträge |
How does this Cheap Set-Up Sound? gplatt2000 am 01.11.2003 – Letzte Antwort am 11.11.2003 – 7 Beiträge |
Digital Cable Help Arj am 24.03.2009 – Letzte Antwort am 30.03.2009 – 19 Beiträge |
Your signature SUB_BOSS am 04.12.2006 – Letzte Antwort am 02.01.2007 – 109 Beiträge |
The Perfect Question Sonic_Master am 20.12.2006 – Letzte Antwort am 28.12.2006 – 36 Beiträge |
2006
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.513 ( Heute: 6 )
- Neuestes MitgliedPokeball
- Gesamtzahl an Themen1.558.358
- Gesamtzahl an Beiträgen21.700.642
