HIFI-FORUM » English » Stereo (Engl.) » CDPs that live up vs. CDPs that don't | |
CDPs that live up vs. CDPs that don't+A -A |
raftuq
08:37
#51
erstellt: 13. Jul 2006, |||
I wonder if someone on this forum owns a Samsung HD950 (DVD player) and would let us know how it sounds. The latest (Indian) issue of What Hi-Fi? has given it a 5 star rating and says it has excellent sound as well... Arj, One question on adding an external DAC - are these DAC's independant of the formats (mp3, SACD) or are designed to handle specific types? |
Arj
09:40
#52
commercially available 2 channel DACs are meant specifically for PCM. ie for 2 channned DACs it needs a PCM input . hence regular CDs, HDCDs, MP3s etc are ok as inputs. SACD digital standards being different do not allow a separate DAC for DSD decoding. hence for SACD, DVDA/DVDs if you need to use the dac u need to force the output from the player as a PCM..else the DAC will not be able to lock on to the signal. |
SUB_BOSS
Gesperrt |
09:43
#53
Arj how do you rate the Black Box 50 DAC's?? |
Arj
09:57
#54
hi SuB, have not really heard about it. can you post a link to it .? |
Amp_Nut
10:04
#55
The SACD standard in fact PROHIBITS ( to avoid piracy) a 'Digital Output' from an SACD. Universal players Mute the Digital O/p when an SACD spins .... Hence cant use any External digital processing with an SACD. Some Studio SACD players, do, now provide a Digital data stream... |
Arj
10:17
#56
you are right.. i forgot that point ![]() |
bhagwan69
10:24
#57
I am not so sure; There are machines that have 'digital outs' in SACD There is the Accuphase DP-100 & DC-101 model TEAC Esoteric - P-0 & D-0's dCS Verdi and gang. All have digital outs on SACD. Maybe not recordable. since the hardware [blank SACD's] itself is not existant. Besides there are no SACD recorders either. BHAGWAN69 |
bhagwan69
10:27
#58
I forgot to mention the 'father of them all' - EMM Labs - Ed Meitner too has a digital out on the Transport. In fact it too has 3 digital outs. Left + Right + Word Clock. Bhawagan69 P.S. The Teac Esoteric has seperate DACS for the Left & Right & also has 2 word clocks in the same chasis for the sync. The digital signal is split in many ways before it gets converted onto analogue sound. In fact the reference digital play back is a 7 chassis set up. Mad - Absolutely Crazy !!!! [Beitrag von bhagwan69 am 13. Jul 2006, 10:29 bearbeitet] |
Arj
10:33
#59
i believe the entry level SACD players do not have a digi out.. it is the univesal players which have.. but even for them from what I understood, they do not give an output out as PCM from a pure SACD recording |
purnendu
11:23
#60
Hi Folks, Beyond NAD and Marantz is there an 'entry level' player in India? I auditioned the Marantz at home with my own equipment and in contrast to what many others hold, I found it to be harsh sounding at the high frequencies although it is very detailed. Quite frankly it was hard to listen to at times. I told the dealer that I did not like it, and auditioned another CD player which he suggested.This is the budget model Audio Analogue player the half width Primo. There was a very clear difference at first listen. The high frequencies are so much more refined. Violin can be heard a live levels without stress. There is plenty of detail too. Although the imaging is nothing to write home about I was impressed enough to buy it along with an AA interconnect which didnt come cheap. For a high quality starter CDP, this is a very respectable choice. I did not compare it with a NAD but it beat the pants out of the Marantz 5001. Its nice looking too. My only complaint is a lousy remote and controls that are much too limited. No program play for instance. The role of a good CD player in a system should not be underrated. In some ways it is the weakest link. In my experience a decent entry level amp can expose the limitations of the CDP. One of the best CD Players I ever heard was the Marantz CD80. It was so well organized in its presentation. The instruments were taut and the sound firm and clear without a hint of aggression. This may be getting mystical, but a really good CD player can enhance attentiveness to the music, although I wonder if its just my imagination. Purnendu |
SUB_BOSS
Gesperrt |
11:30
#61
No it's not your imagination, Infact CD 72 and the best is 94 are extremely good players..I can vouch that CDP's costing a lot cannot come close to these in terms of refinement and noticebale was very good vocals and bass to die for.. |
Amp_Nut
12:20
#62
1. You are correct. As I said in my earlier post, Sony's SACD standard PROHIBITS any drive providing an SPDIF digital output, for consumer applications, from an SACD. Even Computer drives like the Plextor mute their SPDIF outputs, when confronted with an SACD. I have researched this long & hard, in an effort to Copy SACDs and DVD-as. Pro SACD Players have emerged with SACD Digital Outputs. They claim Pro use.... hence can offer the outputs. 2. SACDs, do NOT carry the music inb the same format as CDs. CDs use PCM encoding. SACDs use DSD, which will produce the Audio output, in principle, using only 1 Resistor + 1 capacitor, as a Low pass filter, ie a passive Low Pass Filter. It does Not require a seperate DAC ! THAT is why Sony is SO TOUCHY in not offering the digital datastream directly, which can then be copied... Incidentally, the SACD disc holds approx as much data as a DVD ! |
Shahrukh
12:40
#63
The Europeans have similar words for the CD 63. No wonders there are three versions: The Mk II, The KI signature and the SE (Special Edition). |
SUB_BOSS
Gesperrt |
12:55
#64
In fact I drew this conclusion after I had a good listening sessions with 94..it's extremely good, good refinement and dead heavy..will beat many amps of today...And as far as 63 KI I have to give good opinion becoz I did intensive listening. [Beitrag von SUB_BOSS am 13. Jul 2006, 12:56 bearbeitet] |
Jeeves
12:56
#65
Its sad that Soundsmiths broke up with Rega. I believe their minimum order quantities were unrealistic for the Indian market and we are the losers. Their Planet (single case) was real value for money I think around 40k. Even their new model the Apollo has got great reviews and is priced similarly. I think it (Planet) was Sam Tellig's reference for a while. Jeeves |
Arj
13:17
#66
aparently has a great transport.especially the reading and error correction. from what i hear , is the definitely the most VFM at that price range.. Planet was not the best when it came to detail, but the Appolo has apparently got over that as well..and it reads MP3s too ! |
Jeeves
13:20
#67
It may be worth someone's while to check if SS has some unsold stock. Jeeves |
Shahrukh
13:24
#68
They do. They have a clearance sale going on for some time now. I just saw an ad in this month's AV Max. |
Jeeves
13:26
#69
Guys pl grab the CDPs and TTs those who are in the market. Jeeves |
Shahrukh
13:29
#70
Yes they have some Rega stuff, Dali's ASR and Blue series, Gale monitors and Ecosse cables among other stuff on 'sale'? I was thinking at looking at the Ecosse myself! |
Arj
13:30
#71
jeeves could you share something on your new speaker ? ![]() |
Jeeves
13:42
#72
Arj dont get me started...I am sick of getting on Google to read reviews on the speaker!(I know them all by heart by now) Maybe you know the feeling...till you physically get the thing you try and find anything about it! Most certainly looking fwd to the damn things and will write about my impressions a few days after they are delivered. Jeeves |
Duncan_Idaho
13:43
#73
If you´re interested in a cd-player that really sounds good an natural you should also consider the Audiomeca Obsession II.... in comparison to Rega Planet it delivers more of everything. |
Jeeves
13:45
#74
Ah Duncan..if only life in India was so easy and plentiful.... |
Arj
13:49
#75
hehe.. I went into the extent of downloading files and making PDFs of them !! and had to wait for 1 full month before i got them ! know exactly what you are saying. BTW what ARE you buying ? |
Duncan_Idaho
14:00
#76
Well.... the Obsession is worth some pains.... if you wisch I can send you the adress of their hompage. Wichi part of India do you live in? Close to Mumbai? |
Shahrukh
14:02
#77
IN Mumbai! |
Duncan_Idaho
14:05
#78
Hope you´re well... Funny thing is... on of my Professors at University was also from Mumbai... and guess what kind of paper I wrote in his course... Salman Rushdi´s book about Mumbai...... the world is really small.... ![]() Even more funny.... today I had for lunch a really god Dahl I cooked yesterday. [Beitrag von Duncan_Idaho am 13. Jul 2006, 14:06 bearbeitet] |
Shahrukh
14:23
#79
What did you have the Dal with? Rotis? Apparently the Philips DVDPs here in India can PLAY ROTIS too. ![]() We're all ok here... touch wood! |
Jeeves
14:45
#80
Hi Duncan, Your suggestion and offer to help with the homepage address is appreciated. I think many of us who are passionate about this hobby in India are extremely well read on the market offerings. We read a lot. However when it comes to buying we have limitations because of a few reasons listed below in no particular order of importance. India has a small or no mind share with major audio companies The high end audio market is small The import duties and therefore the final cost is prohibitive This hobby is not well known There are only a few brands available Because the market is small distributors cannot stock many brands etc etc.. Jeeves |
Jeeves
14:47
#81
Oh Duncan, a day old dahl or what we call 'basi' dal is always tastier than fresh dal. basi actually means smelly! Jeeves |
Duncan_Idaho
14:48
#82
Well... a comapny over here showed how you can play a salami in a CD-Drive... ![]() Actually I had plain rice with it.... but I really like indian cooking.... my Currys are feared/enjoyed. ;). Well... more or less the same over here... noone tried to blow up Gorge Bush on his visit to Stralsund... but a friend of mine who works on a police scuba unit had to go there... would have rather been with his wife an his newborn daughter. On the other hand... looks like the Near East really is going to blow the fuse this time.... ![]() I can´t understand terrorism.... a friend of mine lives in Sri Lanka and he just wants to live in peace... no chance... a few dung-heads and all others have to suffer. |
Jeeves
14:56
#83
Arj, Proac Response One SC Jeeves |
Arj
15:32
#84
oh the 1 SCs .. nice choice and definitely a move up from the studios ! must quote you this line from another forum on the comparison between an SC and a tablette ![]()
Jeeves
02:07
#85
erstellt: 14. Jul 2006, |||
Hey the one Sc woman kinda suits me! Thanks Arj! Jeeves |
Linn to stop producing CDPs ! Arj am 21.11.2009 – Letzte Antwort am 30.11.2009 – 39 Beiträge |
Reputation : Amps that live up/Amps which dont Manek am 23.06.2006 – Letzte Antwort am 03.07.2006 – 61 Beiträge |
Apodising (& Digital) Filters used in CDPs bombaywalla am 05.10.2009 – Letzte Antwort am 08.10.2009 – 12 Beiträge |
Graduating to NAD and don't know what ...? SDhawan am 15.08.2004 – Letzte Antwort am 21.08.2004 – 15 Beiträge |
HIFI VS WIFEY SUB_BOSS am 03.05.2006 – Letzte Antwort am 21.05.2006 – 23 Beiträge |
Marantz PM7200 vs NAD 320 BEE Rishi am 20.04.2005 – Letzte Antwort am 21.04.2005 – 9 Beiträge |
Kimber 8TC -vs- Van den Hul whitese am 04.10.2003 – Letzte Antwort am 02.01.2004 – 17 Beiträge |
Does CDP really matter Debu am 14.07.2006 – Letzte Antwort am 25.07.2006 – 39 Beiträge |
Freed up my diamonds.At last! benkenobi am 04.03.2005 – Letzte Antwort am 05.03.2005 – 5 Beiträge |
dynaudio VS monitor audio plasma am 09.07.2004 – Letzte Antwort am 12.07.2004 – 5 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 12 )
- Neuestes Mitgliedclaribelrimmer
- Gesamtzahl an Themen1.558.311
- Gesamtzahl an Beiträgen21.699.467
