HIFI-FORUM » English » Stereo (Engl.) » Yes a cable discussion :) | |
Yes a cable discussion :)+A -A |
Arj
#1 erstellt: 31. Jul 2006, 15:09 | |
Nice article on cables and how they have changed http://www.high-endaudio.com/RC-SpkrCab.html BTW I personally have found LOw Inductance/High capacitance cables to work for me too.. Again the intent is not to discuss on whether cables make a difference or not hence would request if anyone who feels they do not to kindly refrain from saying so ! I guess all of us have read enough of those to know and hence have tried and reached their own conclusions ! |
Amp_Nut
#2 erstellt: 01. Aug 2006, 02:59 | |
Hi Arj, GREAT topic, My thought is that Mains cables often do things that are not expected of them, and often make atleast as much a difference as the interconnects. Flying in the face of logic.... to me, speaker cables seem to make the least difference. But Most of all, the action of All Cables Is VERY system dependent... What is sauce for the goose is Not sauce for the gander. |
Debu
#3 erstellt: 01. Aug 2006, 17:25 | |
Cables do make a difference, let me list some desirable properties of the cable: - Preferably be thin - Should be gauge 16 or less - Should have a tough outer covering if you want to take it thru concealed wall pipes - Oxygen free for long life Can you add more points. Do cables specify ohms/ meter spec. - Debu |
Amp_Nut
#4 erstellt: 01. Aug 2006, 17:46 | |
Hi Debu, Which cables are U referring to ? Interconnects, Speaker or Mains Cables ? They are ( IMHO ) 3 different animals altogether.. |
raftuq
#5 erstellt: 02. Aug 2006, 08:13 | |
I would think that the quality and type of the connectors are equally important. For e.g. I'd favor banana type plugs for the speakers as against the spade lugs (or simply wrapping the cable around the binding posts). Also if biwiring, then using both A and B speakers binding post on the amp is preferable to having both the pairs of wires wrapped around a single set of posts - purely from a firm contact perspective. One reason why one should use good quality interconnects is that you have lower chances of shorts or broken strands of cable inside the sheaths. The humming that was there with some of my cheap interconnects, vanished when I upgraded to the DAC and MX cables. |
Debu
#6 erstellt: 02. Aug 2006, 17:14 | |
I was referring to speaker cables. |
Jeeves
#7 erstellt: 03. Aug 2006, 02:48 | |
Raftuq I agree that good connectors can may a difference. |
SUNILYO
#8 erstellt: 03. Aug 2006, 05:17 | |
hi raftuq Looks like u have got some experience with bi-wiring. I just want to reconfirm, when bi-wiring can i attach the wires to same binding post. I will be buying the Marantz SR-4600 within a couple of weeks. I have the Sonus 2605 which is bi-wireable. and there is no option of speaker B in SR-4600. |
raftuq
#9 erstellt: 03. Aug 2006, 07:07 | |
Yes, Sunilyo, your understanding is correct. If only one pair of speaker is supported by the amp, then both the blacks from left speaker go to the single black binding post for left speaker on amp and both the reds of the left speaker go to the single red binding post for left speaker on amp; ditto for right speaker. The problem one faces is that two wires twisted together are quite thick and wrapping it around a single binding post on amp is a shade flakey IMO. Minor movement of the amplifier also sometimes may get one of these connections off the binding post. Some people therefore attach a banana plug for one wire and the other wire is wound round the same binding post. Alternatively you could use a spade lug instead of winding it round the post - but these lugs are hard to find (at least in BLR). |
Manek
#10 erstellt: 03. Aug 2006, 07:47 | |
Lugs are not hard to find at all....Monster makes the soldering and the dry crimp(solderless) variety of bannas and spades. try em out. manek. |
raftuq
#11 erstellt: 03. Aug 2006, 08:10 | |
You are right Manek, they do make them, however I couldn't find this in BLR. THE place for all such stuff in BLR is S.P. Road. I buy my stuff from Sanson (have I got the spelling right) who stock all MX stuff. They, and all the other stores in this area do not have the lugs. Some shops suggested that I look around in a electrical hardware shop. The lugs available were way too small for speaker wires. Ditto for EMI suppression cores (http://www.konicaelectronics.com/products.asp?catid=3&grpid=91). I wanted to try these out in my setup, but Sanson doesn't stock these. |
zhopudey
#12 erstellt: 03. Aug 2006, 08:35 | |
Can someone please point me to a nice "Biwiring for Dummies" guide? I think I've understood biamping pretty well, but biwiring is still beyond me |
Manek
#13 erstellt: 03. Aug 2006, 10:50 | |
I think there are two places you can check...If there is a Harmon Kardon/Infiniti outlet "fx audio". They usually stock monster products. Second place to go is Profx, delears for kef, polk audio. They have QED bananas and spades and are I might add very good ! Manek. |
nietzsche
#14 erstellt: 03. Aug 2006, 11:03 | |
Lugs may be available with pro fx barton center. In SP road try with connectors shop(I am not able to recollect the exact name of the shop), it is located on the right hand side, 10 or 15 shops away from vishal electronics. or contact Mr. Murthy, commercial st. regards |
Which Cable is Most Critical sivat am 14.09.2006 – Letzte Antwort am 22.09.2006 – 18 Beiträge |
cinch cable sledgehammer am 02.10.2003 – Letzte Antwort am 05.11.2003 – 4 Beiträge |
SPDIF Cable Shahrukh am 16.11.2008 – Letzte Antwort am 01.05.2009 – 17 Beiträge |
Discovered a nice power cable abhi.pani am 01.04.2008 – Letzte Antwort am 02.11.2008 – 24 Beiträge |
cable measurements ! Arj am 05.03.2006 – Letzte Antwort am 16.03.2006 – 15 Beiträge |
Van de hul cable roshan am 29.04.2005 – Letzte Antwort am 29.04.2005 – 2 Beiträge |
Digital Cable Help Arj am 24.03.2009 – Letzte Antwort am 30.03.2009 – 19 Beiträge |
If you think a power cable makes a difference. msb1 am 07.03.2008 – Letzte Antwort am 07.03.2008 – 3 Beiträge |
Cable truth Part - 1 SUB_BOSS am 10.03.2006 – Letzte Antwort am 11.03.2006 – 11 Beiträge |
Power Cord : The most important cable in a hifi setup ? abhi.pani am 14.10.2010 – Letzte Antwort am 16.02.2011 – 87 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 7 )
- Neuestes Mitgliedeunicen907643281
- Gesamtzahl an Themen1.558.303
- Gesamtzahl an Beiträgen21.699.313
