HIFI-FORUM » English » Stereo (Engl.) » Bi-amp- power+ int. amp with a pre-amp | |
Bi-amp- power+ int. amp with a pre-amp+A -A |
nietzsche
10:45
erstellt: 04. Aug 2006, |
hi, I would like to try bi-amp, an integrated amp + power amp with a pre-amp. Is it advisable? regards |
Arj
10:56
Yup. use the Int amp as a power amp.with its normal inputs, this can be done By increasing the volume knob at MAximum. some have a power amp in so there it is easu I am assumoing that both are the same brand/power rating. different amps have different gains hence if not matched well you will have a problem ! |
Amp_Nut
11:02
Does your intergrated amp have a Pre amp out / Power amp Input jumper at the rear ? You can then remove the jumper and use it as a Power Amp. The KEY Issue to using 2 separate Power amops, is to ensure that they both Have EXACTLY the same internal gain. |
nietzsche
11:24
Thanks Amp_nut and Arj, My pre is rotel, power amp and integrated amplifiers are of different make and power ratings also differ. The power amp rating is – 200 watts at 8 ohms. The integrated amp rating is – 100 watts at 8 ohms. Yes, the int. amp is having a jumper. As suggested by Amp_nut, I will remove the jumper and then try. But the problem is power ratings are different, in that case gain will differ as rightly pointed out by Arj. What shall I do? Shall I hook up the int. amp out to highs and power amp out to lows on both the speakers. Is it ok? Whether this type of bi-amping will give me night and day difference? Or Shall I wait to pick up a similar power amp and then try? regards |
TROJAN_HORSE
Gesperrt |
09:22
erstellt: 09. Aug 2006, |
Dude your understanding has shook me violently.. ![]() Let me know what make of speakers are you planning to connect with and which is the int and power amp???.. If you don't gicve us details it's tough to advice you. |
SUB_BOSS
Gesperrt |
10:35
Nietzsche What do you intend to do with all this??? |
Amp_Nut
10:44
nietzsche said
Bi Amping will generally improve the sound... more power, more resolution.... but dont look for a night & day difference ... ![]() |
SUB_BOSS
Gesperrt |
10:55
Day and night diffrence, I'm yet to see some tweak which can give that quantum of diffrence.. of course you stupidly do something you will end up in such situations where your SQ as good as day will turn into night [Beitrag von SUB_BOSS am 09. Aug 2006, 10:57 bearbeitet] |
kspv
17:47
Here is an article which thoroughly discusses bi-amping with pictures. I respect this author, and has been subscribing to his school of thought since long. Subbu may go through it. ![]() For this firstly, Subbu needs a pair of speakers that allow bi-amping (= bypassing of the internal passive crossover). Secondly, he needs a good active crossover, which needs to be connected in the following manner to the drivers. Source----> Preamp ----> active crossover (low pass)-----> Poweramp ----> Woofer Active crossover (high pass) ------> Poweramp------------> Tweeter In India, a good active crossover is very difficult to obtain. I experimented on these lines using a Behringer analog active crossover with variable crossover frequencies (basically meant for PA systems) for sometime, but was not very successful in obtaining good sound quality. However, some (including well respected members of ![]() However, if he is still interested, there is a guy in Singapore, who will make an audiophile grade fixed active crossover according to your specifications, and send it across to India for a reasonable price (let me know in that case). F-Mods, which are passive, can also be used instead of an active crossover after the preamp and before the poweramp in the chain. Oulaw Audio manufactures an active crossover for home users, for bi-amping purposes. There is another company in the link given below, which manufactures a product specifically for biamping of speakers by audiophiles. It says all speakers with passive crossovers are going to be dinosaurs that will become extinct in few more years. ![]() Sonodyne too has an active crossover in its product line, but it is again for PA systems. I do not know about its suitability for audiophile setups. Thirdly, scientifically speaking, I do not think different brands of amplifiers would have any adverse bearing on the bi-amped sound, as long as these amplifiers are well measured, and belong to well-respected companies. The lower powered amplifiers should typically power the tweeters in a bi-amped setup. Gains of both amps need to be suitably calibrated and adjusted in any case (same brand /different brands), which would again be an arduous process. [Beitrag von kspv am 09. Aug 2006, 18:00 bearbeitet] |
kspv
18:37
The website of the guy from Singapore (Michael Chua) is here: ![]() Though the above is more subwoofer specific, you can order for a crossover frequency between mids and tweeters as well. John Pomann's active crossover kit based on Rod Elliott's design is here: ![]() Soundlabs' active crossover is here: ![]() Rod Elliott himself sells a kit based on his design. Refer to the Wethost website for this. |
nietzsche
06:00
erstellt: 10. Aug 2006, |
My sincere thanks to Trojan horse, Sub boss, Amp-nut and KSPV for your responses. ![]() “Day and night difference, I'm yet to see some tweak which can give that quantum of difference. Of course you stupidly do something you will end up in such situations where your SQ as good as day will turn into night” (Emphasis supplied) Agreed sub-boss, I am unable to stop the belly laughter… Good punch!!! ![]() “Dude your understanding has shook me violently. Let me know what make of speakers are you planning to connect with and which is the integrated and power amp???.. If you don't give us details it's tough to advice you. – Trojan Horse.” Hi, TJ, I am looking out for ultimate-bliss. ![]() ” Bi Amping will generally improve the sound... more power, more resolution.... but don’t look for a night & day difference ... ” Roger, amp-nut. Thanks, Pawan garu. ![]() |
kspv
16:41
Subbu, I am beginning to suspect that what you are aiming at, is passive biamping, for which you do not need an external active crossover. However, passive biamping (where two amplifiers are used in a bi-wiring connection) is thought to be a waste of money. Although there may be some moderate sonic benefits, they are not worth the expense of the extra amplifier. True biamping can only be with a top-quality, external stereo active crossover! [Beitrag von kspv am 10. Aug 2006, 16:43 bearbeitet] |
SDhawan
17:18
Yes, but the external cross-over should be perfectly compatible with the speakers - something not easy because the speaker designers design the cross overs to cover the flaws of the drivers and give the best result. Moreover, there should be the option of bypassing speaker crossover. Even without using external crossover biamping gives good sonic improvement. Using an active sub is also a form of bi-amping. Regards Sanjay |
Recommended Power/Int Amp powersupply am 05.01.2006 – Letzte Antwort am 28.02.2006 – 37 Beiträge |
Amp Choice SUB_BOSS am 04.04.2005 – Letzte Antwort am 17.07.2005 – 52 Beiträge |
Bi-Amp confusion vpriyan am 10.10.2008 – Letzte Antwort am 11.10.2008 – 3 Beiträge |
Bright amp with which speaker. Alymangy am 02.02.2005 – Letzte Antwort am 02.02.2005 – 12 Beiträge |
Power Amp and Volume Control Combo Manek am 10.11.2003 – Letzte Antwort am 11.11.2003 – 5 Beiträge |
which Speaker with which amp? Manags am 28.10.2005 – Letzte Antwort am 29.10.2005 – 6 Beiträge |
Amp hunt SUB_BOSS am 11.04.2005 – Letzte Antwort am 21.04.2005 – 24 Beiträge |
bose speakers with denon amp. kewl am 21.10.2006 – Letzte Antwort am 23.10.2006 – 10 Beiträge |
Valve amp huming Rick_F am 18.11.2003 – Letzte Antwort am 08.06.2007 – 20 Beiträge |
Which Amp with Cadence Avita myriad am 02.05.2006 – Letzte Antwort am 04.05.2006 – 12 Beiträge |
2006
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 7 )
- Neuestes Mitgliedeunicen907643281
- Gesamtzahl an Themen1.558.305
- Gesamtzahl an Beiträgen21.699.370
