HIFI-FORUM » English » Stereo (Engl.) » I burnt my fingers, but saved my subwoofer! | |
I burnt my fingers, but saved my subwoofer!+A -A |
Neutral
15:58
erstellt: 14. Sep 2006, |||
I was playing Brian Eno last night and the music sounded soft, so I turned up the volume. Then by some luck, I thought of touching the heatsink of the sub amp during a 11-min song. I was instantly scalded ![]() I promptly turned down the volume and switched the system off. Brian Eno has some really deep bass in his songs. This is relatively inaudible on a small sub but the amp has to put out a ton of current to reproduce these notes. Forum members, please be careful when playing songs with several minutes of continuous low bass. Inaudible parts of the songs can fry your components ![]() |
Manek
04:15
erstellt: 15. Sep 2006, |||
the way I see it , maybe your speakers impedance dropped during the low passages and the amp may not be able to keep up..... manek. |
screamgigi
05:19
If your sub is unable to cope up with the task it is expected to do, then there is something wrong with it. Although a sub amp is expected to put out high outputs intermittently, its should have sufficient grunt at its disposal. |
SUNILYO
05:38
[quote="Neutral"] I was instantly scalded ![]() [/quote] ouch!!! [Beitrag von SUNILYO am 15. Sep 2006, 05:40 bearbeitet] |
abhi.pani
05:54
I am still wondering whats wrong if the heat-sink were really that hot. I have seen many amps with external heat sinks getting that hot...so whats wrong ? ![]() |
SUNILYO
06:07
They are "heat sink". They themselves get hot to keep the inside cool. Just like an AC. ![]() |
Amp_Nut
06:09
Which Amp ( How many watts ) and Sub are you using ? Incidentally, the beginning of 'Too Hot To Touch' is 65 deg C |
Neutral
14:32
Not really! Most of us would burn all 5 fingers to save our equipment ![]() |
Neutral
14:35
The key word is "intermittent", not "continuous". 11 mins of low bass is excessive. A few secs here and there is fine. Brian Eno overdoes it, though this would sound simply fabulous on 12" drivers. |
Neutral
14:41
The equipment isn't too great. The HT amp puts out 44 watts (20W for sub and 24W for satellites). It's 130mm driver goes down to 55Hz (in room). Problem is bass tones go a lot lower than 55Hz. So the amp will struggle with a load that you won't hear because the driver can't deliver it. Abhi, I thought that a scalding hot heatsink meant that the output transistors inside were cooking. Do correct me if I am wrong. |
Sonic_Master
08:40
erstellt: 17. Sep 2006, |||
well the imagine if the heatsink itself is that hot then what about the core of the components may be transistors or ics inside they will be at their peak... you can do one ting thats go to a good electronics shoppe and then buy a big heatsink and just attach it from outside may be you can drill few holes to the heatsinks and then use a small heatsink gel or heatsink paste then use it it will get cool enough to touch it continuously... its best way to do that... probably it would cost you arroud Rs700 or so but worth trying it... cheers, Sandeep |
Sonic_Master
08:43
![]() check this link the heatsink must be arround of that size... then it will be very cool... cheers, Sandeep |
SDhawan
14:50
Please check for current leakages and proper earthing - not just from the component in question but also other connected components. Excessive heat usually means high current flow. Regards Sanjay [Beitrag von SDhawan am 17. Sep 2006, 14:51 bearbeitet] |
Neutral
18:52
Will do Sanjay. The HT amp uses only a 2-pin, so is unearthed. But I will check the electric connections. I am in a new house, so better play safe. |
Neutral
18:59
Thanks Sandeep, for your advice. I am a bit doubtful of my metal working skills ![]() If I use a table fan to blow air past the heatsink, will that help? Could a DC offset or some fault in the electrical conditions in my new house cause the HT amp to overheat? Or could be that Chennai is inherently a much hotter place than my native Mumbai. |
SUNILYO
05:08
erstellt: 18. Sep 2006, |||
What about the small fans used for PC's ?? this one can be helpfull to instead of using a dedicated fan for it. (this is if space is a constraint for u. May u could make a small cluster of these fans and then attach it to the heatsink. |
SUB_BOSS
Gesperrt |
10:51
erstellt: 19. Sep 2006, |||
Hey fit a radiator to cool your stuff... Jokes apart dude! with this kind of power it hardly gets hot and I'm sure your sub will have a clas D which runs as cool as aa A/C. I suspect something is frying inside. |
Neutral
14:38
Sorry Sub-boss, No more bass for me! I'll stick to vocals like John Denver. It doesn't heat up much with that stuff. I guess low current equals low heat. Building a multi-channel amp into a sub is inherently a problem. Vibration problems and heat dissipation are inherent issues with these products. But then you can't complain about the price. As Sandeep says, a large heatsink will cool the amp quickly. But such things are both heavy and space-consuming, so manufacturers skimp on them. |
Amp_Nut
15:40
I remember my days in a college hostel.... Had made a Single ended Transistor Class A amp running .... One Transistor + 3 resistors, 3 capacitors and a Transformer + Ofcourse a power source... ( 12 V @ 1 ampere ) Could not afford a Heatsink that cost more than the 2N3055 power transistor ( Rs 15 or was it Rs 30 ? ) so put the small heatsink in a saucerfull of water. Had to top the water frequently. Worked well and sounded beautiful ( to our ears, then ) untill one day the water ran out and we forgot to top it up.... ![]() Incidentally, used that with a National Cassette tape recorder and a Philips speaker placed over the mouth of a Water 'Matka' ( earthern pot ). Floyd sounded pretty good... ![]() |
SDhawan
17:35
Dear Amp_Nut ! That must have been a nice water-cooled engine (read SET amp) ![]() Trying hands on DIY music system & speakers on the mouth of a "Matka" seems like quite a common ailment ![]() Reminds me of the song "those were the days my friend.." Regards Sanjay |
Manek
11:52
erstellt: 20. Sep 2006, |||
doc...that song is so cute....brings back many many memories....max bygraves sings it so well. manek. |
Raising my budget vpriyan am 15.12.2006 – Letzte Antwort am 10.01.2007 – 75 Beiträge |
My stereo setup udayds am 06.09.2005 – Letzte Antwort am 24.09.2005 – 17 Beiträge |
how to wire my speakers into my amp? pumpanani am 14.12.2004 – Letzte Antwort am 15.12.2004 – 2 Beiträge |
My first DIY project Ronnie22 am 15.08.2005 – Letzte Antwort am 23.08.2005 – 22 Beiträge |
How do I repair my tube amp? hydrovac am 17.07.2013 – Letzte Antwort am 19.07.2013 – 2 Beiträge |
My 2 Ch Music System sat am 12.09.2005 – Letzte Antwort am 12.09.2005 – 5 Beiträge |
My hifi experiences in Chennai Neutral am 20.08.2005 – Letzte Antwort am 24.08.2005 – 10 Beiträge |
My SH-GE90 is broken!! :-( nfung am 01.04.2005 – Letzte Antwort am 01.04.2005 – 2 Beiträge |
speakers for my computer sledgehammer am 09.01.2004 – Letzte Antwort am 14.01.2004 – 5 Beiträge |
My New Setup surrealistix am 19.08.2008 – Letzte Antwort am 12.01.2009 – 61 Beiträge |
2006
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.513 ( Heute: 5 )
- Neuestes Mitgliedkaiserstuhlbruno
- Gesamtzahl an Themen1.558.354
- Gesamtzahl an Beiträgen21.700.548
