VA1 and Avita in small room
Manek
#51 erstellt: 29. Nov 2006, 05:16
myriad,
I have currently connected by tube pre with my nad integrated. Its pretty cool. I dont expect the moon from it but it sounds pretty good for the price.
But I dont think you will get the same refinement and tonal quality of a VA if you bundle a tube pre with the nad 214. You will have to go much higher. I have tried many SS power amps under and upto a lac with my tube pre. Nothing equaled the VA on refinement and tonality. Search is on but not desparate anymore. The right amp will come along when it comes along.
Manek.
sivat
#52 erstellt: 01. Dez 2006, 16:29
Amp_Nut schrieb:
Manek said:
changing the load resistor on the cd input of the amp would do it, i think.
Yes, Manek.
I think that integrated amp has a passive pre amp section ? I am not sure..
If it is a passive preamp, then the input goes directly to the Volume control pot, through the input selector switch.
In such a case an 1 SERIES resistor at the Hot point of the CD input for each channel.
Will not cost more than Rs 1 x 2.
You will have to crank the volume control knob higher up, after the series resistor, but that should not be a problem, sonically.
Instead, bypass this Passive Preamp (Pot), use the VA1 only as a power amp and add an active preamp into the setup...or if you insist on Passive, then try the transformer based passive preamp
Regards
Siva.
sivat
#53 erstellt: 01. Dez 2006, 16:39
To add my note above ...
VA1 is a terrific amp. However, the inside layout and wiring on the inside is not the cleanest. If you take time to rewire, replace the stock wiring with good quality wiring....and maybe even upgrade some of the passive components...you will be rewarded with a much better sound.
Note : I have not tried...but i'm very sure it will help in a big way.
Regards
Siva.
myriad
#54 erstellt: 02. Dez 2006, 04:52
Regards
Siva.
I don't want to diy till the amp is under warranty.
Cadence Avita
myriad am 30.03.2006  –  Letzte Antwort am 03.04.2006  –  19 Beiträge
Problem with Small Room
mars_visa am 22.09.2008  –  Letzte Antwort am 06.10.2008  –  26 Beiträge
Which Amp with Cadence Avita
myriad am 02.05.2006  –  Letzte Antwort am 04.05.2006  –  12 Beiträge
Room Treatment?
myriad am 30.07.2007  –  Letzte Antwort am 11.08.2007  –  13 Beiträge
How to get better bass in a small untreated room?
zhopudey am 24.10.2007  –  Letzte Antwort am 25.10.2007  –  9 Beiträge
planning on buying Cadence VA1-HP and Arista pair
nautilus_d am 28.06.2009  –  Letzte Antwort am 05.05.2011  –  71 Beiträge
New living room project!
_Ana_ am 29.11.2005  –  Letzte Antwort am 30.11.2005  –  2 Beiträge
Acoustic Room treatments
sidvee am 30.06.2007  –  Letzte Antwort am 02.07.2007  –  12 Beiträge
Flooring for Stereo room
benkenobi am 04.10.2005  –  Letzte Antwort am 06.10.2005  –  13 Beiträge
Small speaker suggestions?
tomhifi am 04.10.2003  –  Letzte Antwort am 07.10.2003  –  8 Beiträge
  • Registrierte Mitglieder928.520 ( Heute: 3 )
  • Neuestes Mitgliedtusahivasat
  • Gesamtzahl an Themen1.558.364
  • Gesamtzahl an Beiträgen21.700.808
