HIFI-FORUM » English » Stereo (Engl.) » Any suggestions about heybrook speakers | |
Any suggestions about heybrook speakers+A -A |
bobbybpl
13:51
erstellt: 27. Feb 2007, |||||||||
Hi all, I am new to this forum and found very helpfull and interesting suggetions. I have a query if anybody can suggest me buying a heybrook hb4 speakers with nad 320bee. Thanks [Beitrag von bobbybpl am 27. Feb 2007, 13:52 bearbeitet] |
Shahrukh
13:59
Two brands Deaf has very high opinions about. Maybe he can help you. FWIW, I've heard the Heybrook .5 with the NAD and quite like the sound! [Beitrag von Shahrukh am 27. Feb 2007, 13:59 bearbeitet] |
Manek
14:42
heybrooks for their price we nice sounding speakers.... manek. |
bobbybpl
08:45
erstellt: 28. Feb 2007, |||||||||
Thanks manek,my friend has got a pair which he used for 3 months and ready to sell this for 20k,is this price ok for the used one. |
square_wave
09:15
HB4 for 20 k ? Pick it up fast if you like them. They are good speakers. But remember that all speakers have a “house sound”. Certain voicing based on the target audience and beliefs of the chief designer. Listen to them once, pick them up if you like the sound. |
bobbybpl
09:54
Yes i would, i have auditioned them and found little diffrence in between both the speakers, i mean one peace is little less responsive around 7 to 10 percent comparetively and as i lower down the balance of the speaker which is more responsive they started sounding ok, my friend says it happens and doesn't attacks the quality of music, how true is that |
abhi.pani
10:03
What happens.. ![]() ![]() ![]() Two speakers with different loudness? ![]() Check the amp...try the amp with another pair of speakers (any ordinary speakers), if there is still a difference in loudness then its the prblem with the amp else...the speakers.. ![]() |
paj4x4
10:13
I'd be concerned with this. Culprit could be the amp or the speakers themselves. Make sure there's nothing wrong with the speakers before taking the plunge. |
bobbybpl
10:22
i'll try to find out the culprit, should i go for arcam alfa 9 amplifier(used one) for 17k, its 2003 make and in good condition. |
stevieboy
11:07
its most probably the amp whose balance setting needs to be done as you've done. never heard of speakers having different volume levels to date. ![]() |
square_wave
11:15
Long back while buying used speakers / amps, I used to carry one “single TO double” RCA interconnect with me. This way, I could play the same signal through both channels and check for loudness, distortion etc…I once had a guy trying to push me a pair of big Sansui speakers. Both pairs were working but in one speaker, the woofer was a re-wound one and the other side, the tweeter was the culprit. Look for distortion and loudness and you can locate the issue. Remember that there are a lot of unscrupulous fellows in this business. Watch out. |
bobbybpl
11:46
I think i was babied, i have paid the amount to him for heybrook and thats 20k not supposed to be cheap, i didn't notice that diffrence in sound when i took an audition at his home but now i can barely notice it. I have changed the interconnects, channels,amp and everything to make out the fault but it remained same and infact by balancing with nob from the amp they perform good but still there is a strain in my mind regarding the quality, now he is ready to barter it with aram alfa9 which is 2003 make. Since i am upgrading after 10 years of campanionship with cosmic i am little afraid of jump. Please advise me whether to retain this heybrooks or should i change it with alfa 9 and should buy new speaker later. bobby |
abhi.pani
11:51
The amp looks good on specs...if you like the amp and you want to own them...then barter it. But before that, check that the amp is perfectly fine. |
Manek
11:51
If you are sure its the speakers then sensitivity of each speaker is the problem. maybe they were not of the same batch. Swap it for something different as if ever you go for an amp with no balance control you will be stuck. manek. |
abhi.pani
11:54
Moreover you may not be able to sell these speaker later because anyone would make out this problem...you cant ask him him to use balance controls so you would be stuck with the speakers later on big time or sell it dirt cheap. ![]() |
bobbybpl
12:26
Thanks all, I will try to check the amp and then matrilize the deal, and i am sure i'll be carefull enough in future buying. |
bhagwan69
10:47
erstellt: 01. Mrz 2007, |||||||||
![]() Is Heybrook still around ? ![]() |
bobbybpl
11:39
Yes bhagwan, unwantedly i got merried to them, but i am convenceing myself by listening at balanced mode and now seems ok, anyway i am loking for a amp in the bugdet of 25k to drive them and sortlisted auzor 640a and nad 352, need suggetions. |
abhi.pani
11:43
Rotel RA-03... |
abhi.pani
11:43
Could also try out Sonodyne Pre-Power (27k) |
bhagwan69
11:46
I like the Pulz alot. I do not know the prices, but the amps are nice. You could consider it. |
Savyasaachi
11:49
lol ![]() [Beitrag von Savyasaachi am 01. Mrz 2007, 11:49 bearbeitet] |
abhi.pani
11:55
Why?? ![]() |
bobbybpl
11:55
how about auzor 640a |
abhi.pani
11:57
#25
Didnt hear this particular amp..I have heard the 540A, they sounded thin and cold.. |
Savyasaachi
11:58
#26
You know very well why. We have been over this way too many times. I have no respect for Sonodyne products..simple as that. |
abhi.pani
12:07
#27
But then I didnt reccomend it to you... ![]() Where is the irony... ![]() Incidentally, I still like some of their products, even after hearing much higher end stuffs...hence I reccomend a audition where its suitable. To each his own buddy... ![]() ![]() |
bobbybpl
12:09
#28
As the earlier dissusions says, nad 320bee and 352 plays equally good and 320 even at 50 watts doesnt lacks power to drive any moderate speakers,does that makes sense spending 9k more in 352 ? |
Savyasaachi
12:11
#29
stevieboy
12:11
#30
if you're in bangalore why dont you drop in for the meet? you just might go the valve way ![]() |
abhi.pani
12:14
#31
Good thought Steve...Hey Bobby, are you listening!! ![]() |
bobbybpl
12:27
#32
yes sir but i am 1500 km away from you guys, sad |
Arj
12:59
#33
It doesnt, unless you gave a huge Room. the NAD is an excellent VFM entry level amp.. |
bobbybpl
13:40
#34
I am going to setup my system in living area that is 500 sqfeet. |
Kamal
23:24
#35
500 sq ft? Are you,(gulp) an Arab Sheikh by any chance?!!! |
bobbybpl
08:52
#36
erstellt: 02. Mrz 2007, |||||||||
No kamal i am not a shaikh, i am putting up here in bhopal so a middle class person can own a big appartment at low cost. |
abhi.pani
12:25
#37
Hi Bobby, You definitely are lucky to have in abundance, the most expensive parameter in hifi i.e Real Estate ![]() But to do justice to your setup, you would need a cracker of an amp for sure. You would need an amp which is not only revealing but also high-current. I suppose you may need to spend time on finding a decent amp for your room and setup. Are you aware of Rotel ? They have an integrated amp RA-03 which has got very good reviews and is high on current as well...try to audition them if reachable. [Beitrag von abhi.pani am 02. Mrz 2007, 12:26 bearbeitet] |
bobbybpl
13:11
#38
Thanks abhi, Rotel yes i have heard about it and have read many reviews about but i dont have any chance to audition it so my buy will be only on friends recommendations. Do you have any idea about denon pma7000 abhi?, its 29k as dealer in mumbai says |
abhi.pani
13:41
#39
Denon are decent but are generally over-priced for the sound they offer. ![]() |
abhi.pani
13:42
#40
What are the amps you have auditioned yet ?? What are the amps that you have the previlege to audition ?? |
bobbybpl
16:43
#41
320bee with psb dont remeber the model,marantz 7001 with kef iq5 and an indian make norge gold 1000. [Beitrag von bobbybpl am 02. Mrz 2007, 16:45 bearbeitet] |
Voodoo_CHild
17:25
#42
hey bobby, 320bee with psb image b25 bookshelves were the ones for me, have ordered the speakers and should be getting them in a couple of days...since u have such a huge room luxury, I would suggest you to audition more powerful setups. |
Lithos Speakers - Any comments vinodt am 30.12.2004 – Letzte Antwort am 06.01.2005 – 17 Beiträge |
Small speaker suggestions? tomhifi am 04.10.2003 – Letzte Antwort am 07.10.2003 – 8 Beiträge |
Sound card for recording: Any Suggestions! Neutral am 07.10.2007 – Letzte Antwort am 11.10.2007 – 31 Beiträge |
Opera Pavarotti speakers Dzigi10 am 13.02.2004 – Letzte Antwort am 23.02.2004 – 2 Beiträge |
Subwoofer suggestions? benkenobi am 30.01.2005 – Letzte Antwort am 31.01.2005 – 4 Beiträge |
CDP Suggestions SDhawan am 20.07.2006 – Letzte Antwort am 05.08.2006 – 24 Beiträge |
Urgent...any info on Klipsch RF3 abhi.pani am 21.03.2005 – Letzte Antwort am 21.03.2005 – 6 Beiträge |
how about this Sonic_Master am 02.06.2005 – Letzte Antwort am 03.06.2005 – 4 Beiträge |
8 speakers knownothing am 03.04.2005 – Letzte Antwort am 05.04.2005 – 6 Beiträge |
Hi-Fi suggestions sanathan am 28.03.2005 – Letzte Antwort am 29.03.2005 – 14 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder929.126 ( Heute: 7 )
- Neuestes MitgliedAruz953
- Gesamtzahl an Themen1.559.769
- Gesamtzahl an Beiträgen21.734.365
