HIFI-FORUM » English » Stereo (Engl.) » Black CDR interesting article | |
Black CDR interesting article+A -A |
ani
17:27
erstellt: 04. Mrz 2007, |||
[Beitrag von ani am 04. Mrz 2007, 18:11 bearbeitet] |
bombaywalla
02:55
erstellt: 05. Mrz 2007, |||
yes, certainly an interesting article. it's been out for quite a few years now. You should also go to Audioasylum & read up on the ancilliary discussions that this article spawnwed. it should round out your knowlegde on CD-R quality. |
ani
06:04
Hi Bombaywalla, Yes I came across this link at Audioasylum ![]() |
Manek
06:23
so how can we find black cdr's in India ? |
neono
18:00
Samsung made black CD's were available long back.And not just black, red too.but my cd player had problem,reading them.i dont know why,is it my recording or something else.. i dont remember how good the sound quality was? |
Kamal
19:45
Read the article.Qn-how can a copy made on a black CDR sound better than the source CD? Does'nt appear very logical! Is this for real or just another "Emperors New Clothes" sort of a thing? Any one on the Forum with a personal experience re black CDRs? |
stevieboy
06:00
erstellt: 06. Mrz 2007, |||
maybe thats why records sound better. they're black ![]() would be interesting to hear a black cd and see if there's a difference though. maybe its to do with black absorbing better? while the pits are being burned? black absorbs, white reflects more. basic science. ![]() |
neono
17:50
But then,if black absorbs,something has to be reflected back.... ![]() |
bombaywalla
15:34
erstellt: 07. Mrz 2007, |||
tho' it does not sound logical, CD-R sounding better than the source CD is a daily occurance. I have not personally tried black CD-R myself but friends I know have & attest to it sounding better than most other CD-R types. I also have several blue-green material CD-Rs that are far better sounding than the original CD. When I burnt them, they were burnt using 1X speed. MY CD burner also has a mode wherein it makes pits that are longer than the usual length (these longer pits are within the redbook CD standard) & these types of CD-Rs sound remarkably better than the original. what's happening w/ the black CD-R is that the black is used to absorb the back scatter of the pick-up laser. The pick-up laser is able to distinguish between a pit & no pit thru the minute changes in reflected light off the CD-R surface but the blackness of the surrounding material enables the laser back-scatter to be absorbed thereby allowing the detector to operate in a much quieter environment. This in turn has the effect of fewer glitches in the power supply running the detector & laser circuits. Less glitches in the power supply imply less corruption in the supply lines. A clean power supply has vast advantages - same deal as cleaning up your AC power supply coming to your house. This is the principal reason that black CD-Rs, putting a ring of green or black on the rim of your CDs, colouring the clear plastic in the center of your CDs with black have an effect of removing "digitis" from CDs. They are all assisting in the same thing - reducing laser back scatter. Before you even go to black CD-Rs, take a permanent/water-proof black marker & colour the clear plastic in the center of your CDs. Also colour a black ring on the outer periphery (be careful not to colour the recorded surface! Usually, the music does not extend all the way to the outer rim so the user can be a bit sloppy making this peripheral black ring). Listen to that CD. Hear any difference? << if you system is up to the task, you should. >>
It's for real! Try my above suggestion before you even bother with black CD-Rs. If you cannot hear a difference with my above suggestions, black CD-Rs will probably not be worth your time either. |
ALS
13:27
erstellt: 09. Mrz 2007, |||
True, it makes diff. I had tried it earlier. |
neono
17:25
What if we rip CD into 24Bit wave and create a cd.will it sound different? |
bombaywalla
19:21
yes, it will sound different! ![]() ![]() whether it will be better or worse is hard to say. When you are ripping CDs, the ripping process does NOT create any new data. So, ripping to 24-b wave is nearly a futile exercise in itself. From whatever little I know, when making CD-Rs, the things that matter the most are quality of the rip i.e. is it bit exact of the original or not?, the CD-R medium quality - some blanks are better than others such as the black CD-R blank, the CD-R writer - again some machines are better than the others such as Plextor, the burning speed - I favour 1X & it has rewarded me each time thus far & finally (they say) vibration control of the CD burner - this I have not paid much attention to simply because it is inconvenient right now. if I try to vibration conrol the burner, I end up covering some of the ventilation vents, which I'm loathe to do. FWIW. |
Neutral
18:22
erstellt: 11. Mrz 2007, |||
I use Exact Audio Copy to back up my friend's classical collection. It reads the disks carefully and slowly. It also warns of errors. How do I get Nero Express 6 to burn at 1X? In my computer, that option seems to be grayed out. A question? Does there exist a way to back up DVD Audio or SACD discs? |
deathlord
22:23
This already states, in which category the article belongs... |
bombaywalla
14:22
erstellt: 12. Mrz 2007, |||
Neutral, it is probably greyed out because your burner probably does not support 1X burning. check the data sheet of your CD burner to ensure that it can support 1X. Most modern computer burners do not support 1X anymore. |
Amp_Nut
16:37
Actualy, I believe that the MINIMUM burning speed is software dependent. I use a Plextor PX 716A burner, and faced EXACTLY the same problem as you , Neutral. EAC supports only a few CD burners, and Murphy's laws will ensure that EAC will not support yr CD Burner. ![]() I use Apple's iTunes software. Its a rather large but free download, ( ![]() I have been doing this for over a year ![]() Cheers ! |
deathlord
17:06
What's the point of burning at 1x? Drives and CD-R's are optimized for burning at hight speeds, error rates are lower there! |
Interesting survey on Brands Arj am 15.04.2006 – Letzte Antwort am 19.04.2006 – 14 Beiträge |
Future of systems and music? Jeeves am 23.10.2005 – Letzte Antwort am 03.11.2005 – 14 Beiträge |
An interesting and amusing read benkenobi am 20.03.2005 – Letzte Antwort am 21.03.2005 – 5 Beiträge |
Interesting categorization of audio gear square_wave am 13.11.2007 – Letzte Antwort am 13.11.2007 – 2 Beiträge |
Article on the SI Amp Arj am 03.10.2005 – Letzte Antwort am 04.10.2005 – 4 Beiträge |
Lovely article from Stereophile newsletter! Jeeves am 13.07.2006 – Letzte Antwort am 25.07.2006 – 19 Beiträge |
Nice article on Amplifier design abhi.pani am 26.07.2010 – Letzte Antwort am 28.07.2010 – 4 Beiträge |
Original CD v/s CDR Manek am 25.06.2006 – Letzte Antwort am 27.06.2006 – 5 Beiträge |
Audiophile downloads? Jeeves am 15.10.2005 – Letzte Antwort am 17.10.2005 – 3 Beiträge |
Amp/speaker interface Krish am 04.01.2006 – Letzte Antwort am 04.01.2006 – 3 Beiträge |
2007
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 7 )
- Neuestes Mitgliedeunicen907643281
- Gesamtzahl an Themen1.558.305
- Gesamtzahl an Beiträgen21.699.377
