HIFI-FORUM » English » Stereo (Engl.) » How important is impedance matching? | |
How important is impedance matching?+A -A |
zhopudey
13:49
erstellt: 06. Okt 2007, |||
Hi, I'm back again with my neverending problems ![]() I'd gone to surrealistix's place today. Had taken my sound card along. He has a really nice setup: PC(Creative X-fi spdif)-> Odeon Lite Dac -> Odyssey Candela Tube Preamp -> Odyssey Stratos Poweramp -> Monitor Audio RS 6 speakers. We plugged in my sound card, and tried 4 diff configs: 1) PC > Analog > Pre > Power This sounded quite nice. There seemed to be some overall noise. Highs were not completely clear, and bass was not as tight as it could have been. But overall, it was quite enjoyable. 2) PC > spdif (standard rca cable. Not special digital one) > DAC > Amp. The dac has a buffered output with a volume control. The sound suddenly opened up ![]() 3) PC > spdif > DAC > Preamp > Power Amp. Waah! Now everthing was perfect in the world. ![]() ![]() ![]() ![]() 4) Finally we tried to reproduce my situation. PC > Analog > Amp. Volume was controlled through my soundcard. Anndddd...it was still pretty good! It was somewhat worse than "1" above, but still very listenable. ![]() So what is wrong in my setup? ![]() ![]() ![]() ![]() Surrealistix is lending me his DAC next week. I'm hoping it'll solve my problem, else I fear something must be seriously wrong. ![]() Will keep you guys posted. |
Voodoo_CHild
17:24
hey zhopudey...this time someone else's sailing on the same boat as yours...with a different problem ![]() keep them coming! ![]() PS - Most of the problems can be solved ![]() |
bombaywalla
19:31
i think that your sound-card DAC does not (1) have a large enough output to drive the power amp directly. look @ your power amp specs & find out what its input voltage signal sensitivity is. Does it match up w/ what the soundcard DAC can provide? if you are operating at the max volume of the soundcard DAC to obtain reasonable listening volumes then any reduction in soundcard volume will only make the fidelity worse. (2) the soundcard was designed to be used more for a digital output rather than an analog output i.e. the DAC quality is not good. you might need to spend more money to get a better quality DAC. |
zhopudey
05:05
erstellt: 07. Okt 2007, |||
For some mysterious reason, I can't find output specs for my sound card. ![]()
Ahh, but I use my passive volume control at home. Sound card volume is always full. And if I connect the card directly, then I have to reduce volume, or I'll probably end up blowing my speakers.
Well, we tested that as well, and my card held its own just fine. The dac was better, but then it costs 10 times more than my card. ![]() |
Arj
05:25
Zhopudey, i believe what bombaywalla wants to say is that the symptoms may be the samke but your problem is not the same as your friends. your problem seems to be due to your Source-Amp-speaker combinations which is unique to that setup. the pre is not buffering the amp load and shielding the sourcew from it hence your problem. if you are not looking at an active pre then changing your amp into an int am (even if it means downgrading) might give you better results. B'Walla/Amp nut a slightly techie Quest for you. the following is the impedance curve of the audience 40..should not be very different for Zhops speakers as well ![]() the lowest impd seems to be at around 50-70hz and then around 200-300. both of which areas do contribute to the "fullness " of sound. do you feel the speakers load is being passed on to the source indirectly vi the amp (due to lack of enough input juice) and hence a lack of body ? room acoustics may oly add to it as these two freq are affected by suckouts as well as humps ! |
zhopudey
05:41
Ohh, can this happen? Now I can't wait to try out with the surrealistix's dac. Keeping all my fingers and toes crossed ![]() |
zhopudey
15:34
erstellt: 16. Okt 2007, |||
Wheeee ![]() ![]() Ok, so I'll spare everyone and not start a new thread ![]() So I was sitting at home, wondering what voodoo magic to invoke to make my system sound better. There were so many variables to take care of, I didn't know where to start. So I decided to tackle the biggest variable 1st - the room ![]() So I huffed and I puffed, and somehow managed to drag my stands out to the living room. Its 'L' shaped, and I placed the speakers length wise in the center, firing down one arm of the 'L'. Speakers were about 2 feet from the rear, and about 6 feet apart. One speaker was around 4 feet from the side wall, while the other had the other arm of the 'L' beyond it. And I was sitting some 8 feet away. The living room has the same flooring, which bhagwan69 had pointed out is a big no-no ![]() So I fired up my PC, prayed to the audio gods, and started the music. ![]() ![]() ![]() ![]() ![]() ![]() ![]() And there was bass! Without any boom! And the mids and highs suddenly seemed better ![]() ![]() I kept playing track after track, and tried a number of movies as well. Everything was so much better ![]() ![]() Now what do I do with my room?? |
Arj
16:55
er.. sell it ?? ![]() ![]() congrats on solving the mystery of the missing (hidden) bass. the problem may actually be your placement rather than the room so perhaps a different placement might work .. |
zhopudey
18:53
Today, I placed them lenghtwise in my room. About 18" behind them, and 2-3' on the sides. 5' apart, and I sit around 7' away. Quite an improvement over the earlier placement ![]() The negative point being, the speakers are blocking the wardrobe, so I can't access my fresh clothes. ![]() |
Arj
05:32
erstellt: 17. Okt 2007, |||
Cmmon you are a budding audiophile..music is more important than clothes! ![]() |
Impedence matching YAMAHA RXV450 Betelguese am 19.04.2005 – Letzte Antwort am 19.04.2005 – 2 Beiträge |
How important is RMS for selecting an Amplifier? jayashree am 15.12.2008 – Letzte Antwort am 20.12.2008 – 8 Beiträge |
How to find Matching BS Speakers in Delhi vjc am 16.12.2006 – Letzte Antwort am 15.06.2007 – 21 Beiträge |
Why amplifier power is important SUB_BOSS am 10.07.2006 – Letzte Antwort am 13.07.2006 – 48 Beiträge |
Connector.Is it important? vpriyan am 16.01.2007 – Letzte Antwort am 17.01.2007 – 12 Beiträge |
Why a professional Installation Is Important... Prithvi am 03.07.2005 – Letzte Antwort am 11.07.2005 – 25 Beiträge |
Power Cord : The most important cable in a hifi setup ? abhi.pani am 14.10.2010 – Letzte Antwort am 16.02.2011 – 87 Beiträge |
Impedance Question XandY am 25.11.2005 – Letzte Antwort am 08.12.2005 – 20 Beiträge |
How Do I Improve Image Height Amp_Nut am 25.07.2006 – Letzte Antwort am 19.09.2006 – 36 Beiträge |
Does 'Timbre Match' apply to the Sub? juggy_25 am 07.09.2006 – Letzte Antwort am 13.09.2006 – 45 Beiträge |
2007
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 1 )
- Neuestes MitgliedIngerlise_Spoor
- Gesamtzahl an Themen1.558.296
- Gesamtzahl an Beiträgen21.699.195
