HIFI-FORUM » English » Stereo (Engl.) » Request 'Gyan' On Digital Interface Formats | |
Request 'Gyan' On Digital Interface Formats+A -A |
Amp_Nut
12:17
erstellt: 06. Mrz 2008, ||
I am keen to know more on the Various Digital Interface Formats used for transferring Digital Data between different components of a Hi Fi System... (usually Transport To DAC) The ones that come to mind are : SPDIF AES/EBU Optical ( Glass and Toslink) I2S I am primarily looking for the following info : 1. An overview of the advantages / disadvantages of one vs the other . ( w.r.t. Subjective sound and / or technical) 2. Technical info on each ... Links to informative articles welcome. 3. Personal experiences in comparisions, w.r.t the sound. Also, is I2S ever used for External ( Transport to DAC ) links ? Any example / listing of equipment that uses this format externally ? The ( VERY Little) that I know seems to indicate that SPDIF is most prone to jitter.... yet seems to be the most widely deployed .. ![]() Any pointers, experiences, Info & noteworthy links, most welcome. Thanks |
SNV
14:26
Dear Amp_Nut, The I2S interface is generally found on USB Convertors/Dacs. This interface is supposedly the best. Although I have no personal experience. ![]() dCS recommends the firewire interface from their transport to the dac, as the cd is upsampled to a dsd signal only via the firewire. Next best option is ofcourse the AES/EBU then the dig coax and the least preferred is the optical. Regards SNV |
Amp_Nut
17:31
Thanks, SNV. Would love to know some more on the the AES/EBU .. |
SNV
08:46
erstellt: 07. Mrz 2008, ||
Whatever little bit I know : AES/EBU - American Engineering Society/Erupean Broadcasting Union (Im sure you already know this) Not a consumer, but a professional serial interface. Terminated generally with XLR connectors. Dedicated 110 ohm cable. Carries digital audio signals only - pcm and maybe even dd 5.1 Also known as AES3. Uses shielded twisted pair cables. Found mostly on high end gear. Regards SNV |
Amp_Nut
09:31
Hmmm... informative. Many thanks Guys... some feedback please on the practical aspects, such as popularity of one vs the other ( I guess SPDIF is the most widespread used ) and sound quality ? |
sivat
03:29
erstellt: 10. Mrz 2008, ||
Simple explanations.....from what i've understood I2S - The "native" interface. Generally this signal cannot be transmitted over long cables (not even 1 feet). Since I2S cannot be transmitted over to an external DAC, the signal is converted into SPDIF. For even better transmission (especially over long length of cables), u use AES/EBU. Again u arrive at AES/EBU from either I2S or SPDIF (depending on the design of the transport). Some folks use only a transformer to covert SPDIF into AES/EBU (impedance !!)...but i do not think it is the correct approach. Once the SPDIF/AES-EBU arrives at the DAC, the receive chip (like the CS8414) converts the SPDIF/AES-EBU back into I2S....so that the DAC can process the signal. Between the Receiver and DAC, the digital filters (like DF1704) are used (typically!!). Hope that helps. Regards Siva. [Beitrag von sivat am 10. Mrz 2008, 03:32 bearbeitet] |
sivat
03:37
I use I2S between the transport module and the DAC. Both connected to each other through a 10cm wire. The DAC is placed right below the CDPRO2M. There are lot of people who argue that SPDIF is better than I2S....and vice versa. I have not seen any convincing argument from either camp (no easy answers for you, Amp_Nut). From my experience i will say that conversion of I2S to SPDIF or AES/EBU does not really affect the sound very much. But then again....its those very little things that finally matters ![]() Regards Siva. |
Arj
03:42
ok..my do paise gyan to add on to the above.. AEs/EBU aka XLR aka balanced is supposedly the superior one since being balanced can run over 30M without signal deterioration. also supposedly the best hold out against EMI. almost all high end digital equipment has this SPDIF can have 2 possible terminations ie BNC (supposedly the more superior one) and standard RCA. PSDIF/RCA is more popular among mid fi+Hifi . the next is Toslink..which is supposedly the worst performing but more popular in entry level and cheap dvpds.. there is an older version called the AT&T glass interface which was supposedly as good as the SPDIF, but not so popular now. only very few equipment have it these days.. these days the USB interface is catching on as well. this does direct USB to I2S conversion for use on PCs/Macs [Beitrag von Arj am 10. Mrz 2008, 04:53 bearbeitet] |
Amp_Nut
06:42
Arj Said :
Interesting... can you tell me something more, or point me to a link that elaborates on the portion in bold ? Thanks ! |
Amp_Nut
06:45
Sivat said:
Does the CDPRO2M output a I2S signal directly ? Other drive mechs, do they also directly output I2S ? Thanks for the gyan.. ![]() |
sivat
07:52
Yes. CDPRO2M has both I2S and SPDIF out. It also has a inbuilt DAC...and has a very low level analgoue output (some folks i know have justed added a valve buffer using this analog output). Most mech's should have an I2S o/p....probably not SPDIF. Regards Siva. |
Request Gyan On DACs Amp_Nut am 09.10.2007 – Letzte Antwort am 21.10.2007 – 33 Beiträge |
Request Adive & Info On Upsampling DVD Players Amp_Nut am 26.06.2007 – Letzte Antwort am 21.07.2007 – 22 Beiträge |
Request links To Munich Show 2009 Reports Amp_Nut am 22.05.2009 – Letzte Antwort am 30.11.2009 – 49 Beiträge |
Request Info & Guidance In Acoustics Amp_Nut am 18.12.2006 – Letzte Antwort am 03.01.2007 – 32 Beiträge |
DAC on a Budget purnendu am 03.06.2009 – Letzte Antwort am 04.06.2009 – 6 Beiträge |
Amp/speaker interface Krish am 04.01.2006 – Letzte Antwort am 04.01.2006 – 3 Beiträge |
Digital Cable Help Arj am 24.03.2009 – Letzte Antwort am 30.03.2009 – 19 Beiträge |
First views on Nad 320BEE benkenobi am 25.02.2005 – Letzte Antwort am 18.07.2010 – 110 Beiträge |
Pearls of Wosdom - 8 G_S_Madhav am 16.01.2009 – Letzte Antwort am 18.01.2009 – 7 Beiträge |
HDCD Vs DDD abhi.pani am 08.12.2006 – Letzte Antwort am 10.12.2006 – 24 Beiträge |
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 6 )
- Neuestes Mitgliedintruder#
- Gesamtzahl an Themen1.558.299
- Gesamtzahl an Beiträgen21.699.283
