10 questions on computer based audio
Arj
#1 erstellt: 02. Feb 2009, 05:47
an excellent series of interviews on Positive feedback. please scroll down to Auddio discourses.. the second last article.
the same set of questions have been asked to some of the Sr folks in this business. have yet to go through all but found Steve Nugent to be very parctical
http://www.positive-feedback.com/Issue41/toc41.htm
[Beitrag von Arj am 02. Feb 2009, 06:44 bearbeitet]
Amp_Nut
#2 erstellt: 02. Feb 2009, 06:58
GREAT Read.
MANY Thanks
Arj
#3 erstellt: 02. Feb 2009, 08:30
AN,
it interesting to see the different views..but some things remain common
1. USB Vs Firewire is all on the technical domain. in the end it is all about the design and Implementation
2. Jitter is the worst culprit and reducing it is the key
3. Jitter Can be removed
4. There is no doubting on the future of PC based audio
I really liked the responses by Steve Nugent, Gordon Rankin, and Charles hansen
BTW there is another on Cables.. http://www.positive-feedback.com/Issue30/toc30.htm#interview
it is really funny as to how each person seems to have different eprspective here.
[Beitrag von Arj am 02. Feb 2009, 08:32 bearbeitet]
bhagwan69
#4 erstellt: 03. Feb 2009, 14:23
I will know in 2 weeks;
My Music Server is ready & so are my CD Players.
I will install every thing this week end.
Set up should be done over the next week.
Then, I shall do an 'a' against 'b' against 'c'
I will post.
All / Any forum member is welcome home - 2 weeks from now.
We can do a 'joint listening session' !!
Keep me in the loop.
bombaywalla
#5 erstellt: 04. Feb 2009, 04:28
I will post.
This is when I wished I was in Bombay!!
Arj
#6 erstellt: 04. Feb 2009, 04:49
I will post.
Sir I am waiting with bated Breadth.
From what I could find out with my Trends UD10 (which obviusly is not t"there")..the sound is not good enough for serious listening.
but must say that what took me a couple of listening sessions to figure out Abhi_Pani figured out in the first 1 minute of listening
maybe my copper ears are turning to tin now..which can be a curse as well as a blessing depending on how you look at it
but if the $100 trends could do such a relatively great decent...am convinced of the potential of this medium.
Amp_Nut
#7 erstellt: 04. Feb 2009, 05:09
Arj, As I have said before... ALL that you find sounding short in HDD playback compared to CD playback, using your DAC, is the fault of the UD-10. Its REALLY not a serious Hi Fi device... good for a second system of on the Work Table... even with the battery supply.
However USB DACs are emerging a plenty, and I am sure in a year we will have good playback at a decent price.
The Positive feedback opinions were an eye opener, and represent a range of thoughts - for the serious applicationh of mind to those that should not have come from anyone associated with serious Hi-Fi.
I am REALLY looking forward to listening to Bhagwan69's Music server. Sir - put me in line for a listen, I would like that VERY much
reignofchaos
#8 erstellt: 04. Feb 2009, 10:58
Bhagwan69 could you please post some more details of your music server? Personally I seem to have hit a roadblock with PCI internal cards and am looking to move away from that into an external USB or preferably Firewire device with a high quality dedicated external power unit.
About the UD10, have folks owning it tried the usb-audio.com driver instead of the default windows driver? Seems to bring in some benefits. However cheap Burr Brown PCM27xx devices will only do that much. You need something else to do better.
[Beitrag von reignofchaos am 04. Feb 2009, 10:59 bearbeitet]
Arj
#9 erstellt: 04. Feb 2009, 12:10
i use the ASIO driver to Bypass the Kmixer and also use it only for USB to SPDIF..feeing into my Dac.
surrealistix
#10 erstellt: 04. Feb 2009, 12:42
I use the SPDIF out from my M Audio Audiophile 192 PCI Sound Card with ASIO drivers to feed into my DAC. I don't have an external USB sound card to do an A to B comparison. But, I am curious to know if going with an external sound card will make a difference.
reignofchaos
#11 erstellt: 04. Feb 2009, 13:39
Do you use ASIO4ALL or the usb-audio.com ASIO driver? ASIO4ALL is okay but not as good as a real ASIO driver. If you use foobar and vista, you could try the WASAPI output too. Seemingly the performance of that is better than ASIO. My music rig is too slow to run vista because I've underclocked it.
@Surreallistix:
It might make a difference only if the SPDIF of the external device is well implemented - for example the empirical audio off ramp devices. My current internal EMU 1212M is a whole lot better than the external M-Audio Audiophile I had earlier. So if people blindly advocate USB/Firewire solutions, take their opinions with a pinch of salt :).
An excellent option if someone knows modding is to feed I2S straight from the controller chip of the soundcard to the DAC. Not that easy, but potentially the best solution.
[Beitrag von reignofchaos am 04. Feb 2009, 13:43 bearbeitet]
bhagwan69
#12 erstellt: 04. Feb 2009, 18:58
bombaywalla schrieb:
bhagwan69 schrieb:
This is when I wished I was in Bombay!! :cut
Sir,
My doors are wide open for you.
You are most welcome - without a phone call too;;;
In any case, when evr you come - all 3 should be there, unless any 1 [or 2] gets 'badly' beaten & I am forced to sell it.
You can come & we will listen to your CD on a CD Player & EAC it on a HDD & play it off the Weiss !!
bhagwan69
#13 erstellt: 04. Feb 2009, 19:06
Amp_Nut schrieb:
I am REALLY looking forward to listening to Bhagwan69's Music server. Sir - put me in line for a listen, I would like that VERY much :)
Hello AN !
My house just finished this evening.
I am get all the goods moved in from the warehouse on Saturday.
I shall get the system started by mid next week - hopefully.
I am going to play the Penaudio to start with;
I shall request you to come home some time towards the end of next week.
I too shall need 'help' to decide on what is going on.
In my case there is no USB - there is Firewire - 6 pin.
bhagwan69
#14 erstellt: 04. Feb 2009, 19:13
Hello Sir !
My knowledge on computers is redamentary.
I just did what a fellow forum member helped me with - sbfx -
I have used an ANTEC HTPC Case + Asus MB + Firewire [6 pin] put to a Weiss DAC @ 24/192.
I will use foobar.
Shall let you know how it goes.
bhagwan69
#15 erstellt: 04. Feb 2009, 19:29
Why go to a card ?
Motherboard out to DAC - straight - that too on 24/192 & you DAC will lock @ 192.
USB can do 24/96 - not more.
Dual SPDIF or Dual AES/EBU too will do 24/192, but no sound card will support 2 digital outs [not to my knowledge] !!
This is what Chord / Teac Esoteric use between transport & DAC.
Savyasaachi
#16 erstellt: 04. Feb 2009, 20:42
Bhagwan,
you should really try to get a Scott Nixon USB DAC to compare along side too. The difference that a NOS DAC makes is going to be huge and apparent against all the other oversampling DACs. I personally feel that the Scott Nixon is a lot more enjoyable than the Bel Canto DAC2 and this is at a third of the price.
Also, I now that there is an Indian with a Twisted Pear Audio Buffalo DAC in Mumbai...perhaps you might be tempted to rope him in andcheck out the ESS chip based DAC.
[Beitrag von Savyasaachi am 04. Feb 2009, 20:53 bearbeitet]
bhagwan69
#17 erstellt: 05. Feb 2009, 03:40
Thanks;
I am open to trying things out.
I have my Music Server.
We can take a Firewire or USB out from it to any DAC & play it through the rest of the chain.
Who has that DAC ?
Let me know so I could PM & request a visit home with it.
Appreciate it.
[Beitrag von bhagwan69 am 05. Feb 2009, 03:44 bearbeitet]
Amp_Nut
#18 erstellt: 05. Feb 2009, 07:25
Please post / PM his contact details. i would LOVE to contact him.
Thanks
Savyasaachi
#19 erstellt: 05. Feb 2009, 08:06
I have sent a PM to him to see if he is interested. I will post/PM when he replies.
surrealistix
#20 erstellt: 05. Feb 2009, 08:17
I use the ASIO drivers from M Audio rather than ASIO4ALL.
I have recently upgraded from my Odeon Lite Dac to Scott Nixon NOS Dac - and it's a day and night difference.
Savyasaachi
#21 erstellt: 05. Feb 2009, 08:21
Cheers to that buddy...such a good DAC isn't it the Scott Nixon?
True giant killer i tell you.
[Beitrag von Savyasaachi am 05. Feb 2009, 08:22 bearbeitet]
DrTebi
#22 erstellt: 13. Feb 2009, 07:34
Browsing through this post I thought I would let you know what PC I will aim for soon:
http://www.endpcnois...nless_mcubed_pc.html
What's really important to me is, that there are no fans. I am intending to use this machine in the living room, install a very basic Linux on it, and run XBMC on it (amazing free and open-source media center software). Especially when watching movies, I want the machine to be absolutely quiet. I will only play music and videos that are hosted on another Linux file server in another room of my house.
Any comments are appreciated
[Beitrag von DrTebi am 13. Feb 2009, 07:35 bearbeitet]
Arj
#23 erstellt: 25. Feb 2009, 11:06
Ran into another USB to SPDIF converter by Lindemann.
http://www.aaudioimports.com/ShowProduct.asp?hProduct=125
has anyone come across this ?
Bhagwan how was your experience with the media center ? eagerly awaiting information !
bhagwan69
#24 erstellt: 03. Mrz 2009, 03:02
Superb !
I really like it.
Amp Nut has heard it, maybe he could comment on it;
Gear is all still Brand New - need some time to burn in & will compare after 1 month & will write a full report then.....
Arj
#25 erstellt: 03. Mrz 2009, 04:59
[Do you use ASIO4ALL or the usb-audio.com ASIO driver? ASIO4ALL is okay but not as good as a real ASIO driver. If you use foobar and vista, you could try the WASAPI output too. Seemingly the performance of that is better than ASIO. My music rig is too slow to run vista because I've underclocked it.
Apologies, i saw this only now.
I do use the Asio4All as am still on XP(older Processer ) is there a version fo XP ? if so i will try out the other one once i get my digital cable back..it is with someone who is trying it out. BTW I use a Monarchy reclocker with the trends SPDIF out as it makes the sound smoother.
[Beitrag von Arj am 03. Mrz 2009, 05:04 bearbeitet]
Arj
#26 erstellt: 03. Mrz 2009, 05:12
bhagwan69 schrieb:
Superb !
I really like it.
Great to hear that.
AN sir ..your impressions please.
Arj
#27 erstellt: 23. Mai 2009, 13:58
aparently the products have an option of USB-SPDIF conversion as well.
http://forum.audiogon.com/cgi-bin/fr.pl?icomp&1238247027
as per Steve Nugent
in fact in the empirical audio website he recommends it with his DAC/Jitter reducer.
Arj
#28 erstellt: 30. Mai 2009, 15:12
Questions
SUB_BOSS am 19.01.2005  –  Letzte Antwort am 14.02.2005  –  75 Beiträge
Two technical questions
Neutral am 01.09.2005  –  Letzte Antwort am 03.09.2005  –  9 Beiträge
2 Questions & a new CDP
Voodoo_CHild am 18.12.2007  –  Letzte Antwort am 21.12.2007  –  16 Beiträge
Lyrita's Fostex based speaker
purnendu am 17.03.2008  –  Letzte Antwort am 04.04.2010  –  66 Beiträge
Questions regarding Dali Royal Tower
Sourav am 03.04.2005  –  Letzte Antwort am 04.04.2005  –  4 Beiträge
have a few questions on my 6 disc cd changer
clipperstud am 05.01.2005  –  Letzte Antwort am 05.01.2005  –  3 Beiträge
Section for HDD/Computer Audio
Krish am 02.11.2010  –  Letzte Antwort am 02.11.2010  –  4 Beiträge
Lyrita Audio back on-line
viren am 22.12.2005  –  Letzte Antwort am 22.12.2005  –  2 Beiträge
3d imaging via Computer speakers
Arj am 20.11.2010  –  Letzte Antwort am 23.11.2010  –  6 Beiträge
Stereo and Computer Speakers
Alexb123 am 12.01.2004  –  Letzte Antwort am 12.01.2004  –  6 Beiträge
  • Registrierte Mitglieder928.513 ( Heute: 6 )
  • Neuestes MitgliedPokeball
  • Gesamtzahl an Themen1.558.359
  • Gesamtzahl an Beiträgen21.700.715
