HIFI-FORUM » English » Stereo (Engl.) » The perfect wave transport from PS Audio | |
The perfect wave transport from PS Audio+A -A |
square_wave
12:15
erstellt: 31. Aug 2009, |||
![]() Plays the music from the solidstate memory. Never plays it from the disc. No jitter or error correction required. Uses an asynchronous clock. Impressive. No idea about the price |
sivat
13:39
hhmmmmmm ![]() Excellent sales pitch.. [Beitrag von sivat am 31. Aug 2009, 13:39 bearbeitet] |
reignofchaos
15:39
Err doesn't every CD player worth its name have a reclocker and some form of buffering off solid state memory? Whats so special in this one then? What about the data that is lost while reading the CD itself? The only special thing about this player seems to be the fact that it has I2S output which very few transports do. |
Arj
16:10
I think it uses an HDMI cable for I2S...and it is a special non standard HDMI so you needd to have PS audios transport, cable and DAC for I2s. thank god the power cables are standard IEC ![]() this is different in the sense that it "rips" from the disc and puts the entire song into a SS memory and then plays it.. |
sivat
03:22
erstellt: 01. Sep 2009, |||
I2S is a signal that cannot be transmitted beyond a few inches. If you need to (transmit I2S over a few feet)... then use the SPDIF. Else you need your properiraty arrangement to do the same...like Zanden and now PS audio. Honestly, i do not see this to be of any significant advantage. A lot of these theory of buffering in memory etc., does not really help with PCM because of the nature of the format itself. Hence, It is not correct to assume..what is good for formats like "WAV" will be good for PCM as well. PCM is a very different format. Do read on the net....you will get some idea. Once you have a good idea of PCM and also about how I2S/SPDIF actually works....listen to this Video again. |
sivat
03:35
sivat
03:37
A quick google returned this.. ![]() From the above link, you can understand how the data on a red-book CD should be interpreted...there are no obvisous 1's and 0's like in computer audio-file formats like WAV, MP3, etc., Also, you could verify what i'm saying form the below link.. ![]() |
Arj
03:57
The above has been my understanding as well ie about the Redbook being in "Words" and not bits.. which need to be interpreted with utilisation of the Reed Solomon Error correction. An interesting (and heated) discussion ![]() |
Arj
04:02
Siva any reason for this ? ie is it a problem of the Format that is open to some sort of distortion or loss of synchronisation during longer tramnsmission ? |
sivat
06:04
No Arj, it is not the content that matters. But how the content is retrieved. Unlike in a WAV file, where the 1's and 0's are guaranteed to be correct....the data from Redbook CD is retrieved through a sampling algorithm. This is the part that is most error prone and requires excellent mechanial and electrical isolation for the CD transport to a good job. If you would have observed "time" is a factor in the sampling process...so the "memory storage" is really not of much help at all in reducing Jitter. This is exactly the reason why companies like Esoteric, Philips, Sanyo have spent lots of money in developing good transport modules (VRDS, CD-PRO2, etc.,) This is also the reason why filters came into existence. But nothing can compensate a good "transport module" to begin with....rest are all hypothesis and not actual facts. [Beitrag von sivat am 01. Sep 2009, 06:10 bearbeitet] |
sivat
06:08
If you need to transmit data over a cable through some distance it requires a proper design. You cannot just transmist any form of data over any length of cable. So the problem is not really the 'content' of I2S format or the format itself, but the physical limitations that one needs to over-come for transmitting data over long lengths of cable. This is also the reason why it is recommend to use transformers for driving long lengths of SPDIF cable. |
square_wave
06:48
So it all depends on the quality of the mechanical transport which reads the cd. Whether it is stored in memory and send via i2s or send directly via spdif to a DAC doesn't really matter. The logic is that the error originates while the disc is being read initially. What happens after the disc is read is immaterial. [Beitrag von square_wave am 01. Sep 2009, 06:54 bearbeitet] |
Amp_Nut
08:29
IMHO, everything else too DOES matter. But if garbage is made of the data on the CD... its GIGO ( Garbage In Garbage Out ) ![]() |
Manek
09:31
Amnut I am with you on this. Every stage matters, perhaps to different degrees but they all matter. Manek |
sivat
10:02
Folks, My discussion was limited to getting the 1's and 0's correct fromm a CD. What i referred to as "rest of ..." was the predictive algoritms that are employed in some of the filters...including oversampling, upsampling, etc., Everyone know the application of such predictive algoritm do not result in correct output at all scenarios. Ofcouse, other stages are important. But the idea behind this discussion was to bring to light some important aspect of the PCB/Redbook format that is being taken for granted, with the advent of media servers. The idea was to emphazie on the need for a good quality laser-picup and associated mech and electrical aspects. This should be the focus of a good transport....atleast in my opinon. ![]() Peace ![]() Regards Siva. [Beitrag von sivat am 01. Sep 2009, 11:29 bearbeitet] |
Amp_Nut
10:46
HI Sivat, I doff my cap to you, for highlighting what you have. ![]() To me its also a pointer why some systems seem to provide better sound via HDD Lossless (wav. flac. ape etc ) than Off a CD ! [Beitrag von Amp_Nut am 01. Sep 2009, 11:27 bearbeitet] |
Amp_Nut
12:18
Arj, I found your audioassylum thread very illuminating. FWIW, I also liked the following side link from the AA thread: ![]() Please do post more links on the topic... Thanks |
Arj
11:56
erstellt: 08. Sep 2009, |||
Another nice link but this talks about the evolution of the cd transports in phillips.. found it very interesting ! ![]() AN, the link you posted is really nice...even i could understand it all in 1 reading ! ![]() |
Arj
16:51
erstellt: 04. Okt 2009, |||
RMAF show report here.. ![]() Interesting fact is a new $1300 firewire interface from Weiss more info ![]() my experience with Firewire (M-Audio FW Solo) shows that the Firewire card needs to be very very good. I used a PCMCIA cardbus and that sucks. apparently the via chip is a drag and the TI chip is what is good |
The Perfect Question Sonic_Master am 20.12.2006 – Letzte Antwort am 28.12.2006 – 36 Beiträge |
REMEMBER ALL TWEAKS ARE NOT PERFECT.-PART-1 (PLS READ) Prithvi am 13.01.2005 – Letzte Antwort am 19.01.2005 – 2 Beiträge |
The 10 Biggest Audio Lies herculepirate am 23.06.2007 – Letzte Antwort am 25.06.2007 – 4 Beiträge |
Cd Transport myriad am 18.09.2006 – Letzte Antwort am 20.09.2006 – 15 Beiträge |
Hum from Turntable myriad am 12.10.2007 – Letzte Antwort am 13.10.2007 – 7 Beiträge |
Can there ever be a single perfect music system? zhopudey am 07.02.2007 – Letzte Antwort am 21.08.2007 – 25 Beiträge |
Buzz from Tweeters. Voodoo_CHild am 01.10.2007 – Letzte Antwort am 08.10.2007 – 33 Beiträge |
'Perfect' Recording(s) For Bass Reproduction ? Amp_Nut am 20.08.2010 – Letzte Antwort am 24.08.2010 – 22 Beiträge |
The Linkwitz orion square_wave am 10.02.2010 – Letzte Antwort am 12.02.2010 – 13 Beiträge |
Learn from this - Part-1. Prithvi am 03.05.2005 – Letzte Antwort am 10.05.2005 – 3 Beiträge |
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.520 ( Heute: 4 )
- Neuestes Mitgliedccancce
- Gesamtzahl an Themen1.558.381
- Gesamtzahl an Beiträgen21.701.022
