Strange issue with my arcam player
square_wave
#1 erstellt: 16. Sep 2010, 11:49
My arcam cd player has developed a problem.
If I eject, the tray comes out and then it goes right back in without staying in the open position. Is there a way I can fix this myself?
Manek
#2 erstellt: 17. Sep 2010, 04:33
Depends on what transport mechanism the arcan uses.
Usually a cleaning should solve it.
My pioneer does this a lot. There is a small spring loaded slider switch on the left of the transport mechanism which when cleaned with cleaning fluid solves it temporarily until it happens again after a while.
So you need to be quick on the draw when loading and rmoving cd's in the tray.
This is when you wish you had a top loading mechanism or just a hdd full of music :-)
Manek
Amp_Nut
#3 erstellt: 17. Sep 2010, 05:04
When the CD drawer ejects, it activates a 'Limit Swirch' at the end of its travel....
As Manek has pointed out, the Limit Switch has turned bad... Clean or better still replace.
square_wave
#4 erstellt: 17. Sep 2010, 06:22
Thanks and bunch guys.
I'll check on this and post back. The player is an Arcam cd73t.
msb1
#5 erstellt: 17. Sep 2010, 16:40
Probably the Limit switch as AN mentioned. Relays and Limit switches get bad over time due to arcing. Try spraying some WD40 into the limit switch and manually press a few times while doing so. Make sure you dont get any mist from the spray on the lens. Should solve the problem.
Manek
#6 erstellt: 18. Sep 2010, 03:58
Whilst you have the cover opened,you may want to damp those open cavities with blu tac ?
Where did you buy the cdplayer from ? Probably the dealer can help you too.
Manek
HELP me with my Seminar!
benkenobi am 30.03.2005  –  Letzte Antwort am 05.04.2005  –  36 Beiträge
My experience with speakers from Sandeep
bluemoon am 17.05.2005  –  Letzte Antwort am 23.05.2005  –  10 Beiträge
Need help with placement
zhopudey am 23.01.2007  –  Letzte Antwort am 07.02.2007  –  17 Beiträge
Arcam A70 -> Marantz PM7001: Huge step down?
particleman am 02.10.2008  –  Letzte Antwort am 02.11.2008  –  23 Beiträge
Problem with Pioneer 383 DVD player
Edges am 09.09.2005  –  Letzte Antwort am 09.09.2005  –  3 Beiträge
Problem with turntable
viv am 06.04.2005  –  Letzte Antwort am 11.04.2005  –  8 Beiträge
My New Setup
surrealistix am 19.08.2008  –  Letzte Antwort am 12.01.2009  –  61 Beiträge
Share your thoughts with me!
Shaman am 19.09.2003  –  Letzte Antwort am 07.12.2010  –  19 Beiträge
Raising my budget
vpriyan am 15.12.2006  –  Letzte Antwort am 10.01.2007  –  75 Beiträge
My first speaker audition
Voodoo_CHild am 23.10.2006  –  Letzte Antwort am 23.01.2007  –  25 Beiträge
  • Registrierte Mitglieder928.520 ( Heute: 1 )
  • Neuestes Mitgliedclimber74
  • Gesamtzahl an Themen1.558.369
  • Gesamtzahl an Beiträgen21.700.923
