Help - Marantz PM-57 trouble!
shad
#1 erstellt: 16. Dez 2003, 01:16
My Marantz PM-57 has given my trouble-free service since 1996. This week it has started 'blanking' - switching off the selected input(sometimes with a small 'pop' noise) and then switching back after a short time. It does this regardless of input. Power supply seems OK as all lights stay on. It is as though I have switched the source.
Any ideas of what causes this, if it can be fixed easily?
All help appreciated.
I check all the speaker wire etc. to ensure no shorts (I run cabletalk 3.2 biwire in banana plus in + 1 passive sub on the same cable to speaker set 2).
Simon
Manek
#2 erstellt: 16. Dez 2003, 05:05
the relays in your source selection section may be faulty or the relay controller could be faulty...or maybe its just needs a good service.
sledgehammer
#3 erstellt: 16. Dez 2003, 20:10
check your remote control, maybe it sends faulty signals.
shad
#4 erstellt: 16. Dez 2003, 21:58
Thanks,
It may be the relays or controller. It can't be the remote.
I opened it up to check for dust - anything obviously loose but all seemed OK and still doing it.
Any idea if this is fixable or terminal?
Shad
Manek
#5 erstellt: 17. Dez 2003, 06:21
It may be fixable but you may need to take it to the Marantz service centre to diagnose the problem correctly..
sledgehammer
#6 erstellt: 18. Dez 2003, 07:19
manek is right. you should not try to repair it by yourself! at first you need to know hat exactly is damaged.
Manek
#7 erstellt: 18. Dez 2003, 13:40
yeah....just a lookover and then if reapirs are too costly...check out some brand new stuff....a relay problem is easily sorted out at an authorised service station.
Help!
mmx_2 am 27.12.2004  –  Letzte Antwort am 29.12.2004  –  12 Beiträge
Help Needed
RRao am 06.09.2006  –  Letzte Antwort am 09.09.2006  –  39 Beiträge
Help!!!!!!!!!!!!!!!!
neckie am 15.04.2005  –  Letzte Antwort am 15.04.2005  –  3 Beiträge
neckie am 16.09.2005  –  Letzte Antwort am 21.09.2005  –  20 Beiträge
marantz PM 7200 amp problem. service in mumbai
toob_noob am 15.12.2008  –  Letzte Antwort am 16.12.2008  –  8 Beiträge
Speaker Help
txs_dude am 22.02.2004  –  Letzte Antwort am 23.02.2004  –  3 Beiträge
need help !
plasma am 23.04.2004  –  Letzte Antwort am 12.06.2004  –  17 Beiträge
Help required!!
AKG am 10.03.2005  –  Letzte Antwort am 14.03.2005  –  2 Beiträge
Help needed!!
neckie am 21.03.2005  –  Letzte Antwort am 23.03.2005  –  30 Beiträge
pls help
filmguy am 26.03.2005  –  Letzte Antwort am 08.04.2005  –  6 Beiträge
2003
  • Registrierte Mitglieder928.520 ( Heute: 3 )
  • Neuestes Mitgliedtusahivasat
  • Gesamtzahl an Themen1.558.364
  • Gesamtzahl an Beiträgen21.700.818
