Voltage Converter 220V/50Hz to 120V/60Hz
swamipr1977
#1 erstellt: 25. Apr 2005, 08:08
Is it possible to get a 220V/50Hz to 120V/60Hz converter. I am able to only find a step down converter that converts 220V/50 Hz to 110V/50Hz. i am not able to get the cycles/frequency also converted. Any suggestions on where to get such a converter from, Delhi/Chennai/Bangalore please.
I need it for using with my A/V receiver ( A Pioneer D914-K).
Thanks in advance
Regards
Swami
ariban
#2 erstellt: 14. Jun 2005, 11:32
Hi Swami
I faced the same problem when I moved to Bangalore from oveseas. Luckily I was able to buy a 1000 watts transformer doing both step up and step down.
Having said that you really need a step down don't you. Don't worry about the cycle. Its immaterial in the case of the AV receiver.
The other thing is that FM frequency bands are made differently for different countries. IN my case I can receive some channels but not all...There is a big technical explanation here which I am not gettiung into, but for all practical purposes a step down should be fine.
Arijeet
jsa_ind
#3 erstellt: 14. Jun 2005, 12:06
Dear Arijeet,
If you were refering to Swami post of "I am not able to get the cycles/freuency also converted" ...I feel the reference was to converting the transformer frequency from 50 Hz to 60Hz and not about Frequency Modulation of the air waves !
Regards,
Junia.
[Beitrag von jsa_ind am 14. Jun 2005, 12:10 bearbeitet]
jsa_ind
#4 erstellt: 14. Jun 2005, 12:23
Dear Swami,
Any Transformer manufacturer would be able to help you out as to a step down transformer. You need to decide if you want an E.I. core or Toridal (Donut) or R core transformers. EI are the least efficient then comes Toridial & finally R core. Cost wise EI core is the cheapest.
Please make sure you overate the current ratings as most transformer manufacturers don't keep up to the prescribed ratings in terms of current load & insulation specifications.
Regards,
Junia.
ariban
#5 erstellt: 15. Jun 2005, 06:16
Hi Junia
I appreciate the difference. The FM issue was a "side issue" that I mentioned.
What I was trying to say is that for purposes of amplification (Swami has a Pioner AVR) a step down transformer would do the trick adequately and the frequency/AC cycle is not relevant.
Cheers
Arijeet
Voltage Converter for nad320bee amplifier.
Hemanth am 17.01.2005  –  Letzte Antwort am 18.01.2005  –  2 Beiträge
USB to Digital converter
msb1 am 05.11.2008  –  Letzte Antwort am 08.11.2010  –  249 Beiträge
Voltage conversion
mmx_2 am 25.12.2004  –  Letzte Antwort am 28.12.2004  –  11 Beiträge
Krell voltage conversion??
hifidude100 am 03.08.2004  –  Letzte Antwort am 07.08.2004  –  3 Beiträge
Voltage stabilizer
cheraz am 02.02.2004  –  Letzte Antwort am 03.02.2004  –  8 Beiträge
Voltage stabilizer for audio system. Which one?
Neutral am 18.08.2006  –  Letzte Antwort am 12.10.2006  –  68 Beiträge
Denon AVR1505/485s Receiver Help
apurba999 am 07.12.2005  –  Letzte Antwort am 10.12.2005  –  2 Beiträge
NAD 320BEE in US
Srini am 20.01.2005  –  Letzte Antwort am 21.01.2005  –  12 Beiträge
Technics Turntable availability in India??
philipmorris am 17.03.2006  –  Letzte Antwort am 21.03.2006  –  6 Beiträge
Connecting SMPS devices to Hi-Fi
hifinovice1 am 12.04.2005  –  Letzte Antwort am 18.04.2005  –  3 Beiträge
  • Registrierte Mitglieder928.513 ( Heute: 5 )
  • Neuestes Mitgliedkaiserstuhlbruno
  • Gesamtzahl an Themen1.558.357
  • Gesamtzahl an Beiträgen21.700.595
