YUV Kabel Selbstbau
skymen
#1 erstellt: 23. Nov 2004, 09:29
wollte mir ein YUV Kabel auf die benötigte Länge selbstanfertigen lassen. Was haltet ihr von diesem Kabel ( Technische Daten) Wollte das Kabel auf BNC stecker gehen lassen um eine 100% 75Ohm Stabilität gewährleisten zu können. Bitte um eure Hilfe
Mfg
CVD 1300
3 COAX CACTUS CABLE
Click Here to Enlarge
PRODUCT DESCRIPTION
Covid’s high performance Cactus cable provides a quality solution for the transmission of High and Super High resolution signals. Manufactured for applications requiring the routing of computer-video and RGB signals, Cactus Cable maintains excellent signal strength through the interfacing, routing, and distribution of signals. Ideal for system integration, Cactus Cable is used to connect computer, RGB, or video sources to display devices such as projectors, video walls, and monitors. Construction materials selected by Covid are ideal for transmitting Super High Resolutions and Frequencies. Air foamed Fluorinated Ethylene Propylene dielectric maintains an air foam ratio which allows rapid, uninhibited transmissions for Velocity of Propagation of 85%. Excellent capacitance measures of 16.3 pF/ft are also a result of construction materials and unique manufacturing processes at Covid. Serve [spiral] shield increases flexibility and is easier to terminate than braided shield. Cactus Cable maintains the best flexibility in its performance and gauge class.
GENERAL SPECIFICATIONS
PRIMARY
26 AWG (7/34) Tinned Copper, Stranded
DIELECTRIC
Natural Foamed Fluorinated Ethylene Propylene
.072 +/- .002 Diameter
SPIRAL SHIELD
38 AWG Tinned Copper, 97% min. Coverage
Aluminum (In)/Polyester Tape, 25% min. Overlap
JACKET
Polyvinyl Chloride, .0085 Nominal Wall Thickness
.102 +/- .005 Diameter
OVERALL CABLE
Number of Coax: 3
Color Code: 1. Red
2. Green
3. Blue
Aluminum (Out)/Polyester Tape, 25% min. Overlap
22 AWG (7/30) Tinned Copper Drain Wire, over tape
JACKET
Polyvinyl Chloride, Color: Blue
.032 Wall Thickness
.290 +/- .010 Final Diameter
PRINT LEGEND
E192255 (UL) CL2 26 AWG 75°C
Cactus Cable CVD 1300 Video Cable (TEL 800-638-6104) http://www.covid.com
FINISHED PRODUCT REQUIREMENTS
UL LISTING: Type CL2 as specified in Article 725 of the National Electric Code
COAX ELECTRICAL CHARACTERISTICS
Impedance: 75 Ohms Nominal
Capacitance: 16.3 pF/ft Nominal
Time Delay: 1.22 ns/ft Nominal
Velocity of Propagation: 85%
Center Cond. DC Resistance: 40 Ohms/1000 ft.
Attenuation: 4.65 dB/100 ft Nominal @ 100 MHz
LIST PRICE $1.98/ft
YUV-Kabel selber basteln
MarcelH am 19.02.2005  –  Letzte Antwort am 19.02.2005  –  3 Beiträge
YUV Kabel
skymen am 23.11.2004  –  Letzte Antwort am 24.11.2004  –  4 Beiträge
Welches YUV-Kabel?
derchiller am 26.02.2007  –  Letzte Antwort am 26.02.2007  –  2 Beiträge
Kabel von YUV - VGA ????
Mongoo am 09.04.2004  –  Letzte Antwort am 09.04.2004  –  4 Beiträge
YUV Kabel
Jack am 06.01.2004  –  Letzte Antwort am 08.01.2004  –  11 Beiträge
Hilfe! Welches YUV-Kabel und Antennen-Kabel?
DW_1980 am 05.07.2006  –  Letzte Antwort am 06.07.2006  –  2 Beiträge
suche BNC Stecker to VGA-Stecker kabel
PharaDOS am 02.07.2008  –  Letzte Antwort am 04.07.2008  –  5 Beiträge
Kaufempfehlung YUV-kabel
mdbsurf74 am 21.01.2007  –  Letzte Antwort am 21.01.2007  –  3 Beiträge
YUV Kabel
Hausl am 06.02.2008  –  Letzte Antwort am 06.02.2008  –  3 Beiträge
Suche gutes YUV-Kabel?
Dr.Schnaggels am 10.06.2005  –  Letzte Antwort am 11.06.2005  –  8 Beiträge
2004
  • Registrierte Mitglieder928.637 ( Heute: 3 )
  • Neuestes MitgliedTK261
  • Gesamtzahl an Themen1.558.645
  • Gesamtzahl an Beiträgen21.707.286
