HIFI-FORUM » Fernseher & Beamer » Anschluss & Verkabelung » DVI or Scart (samsung PS42P3S) | |
DVI or Scart (samsung PS42P3S)+A -A |
erwin805
05:31
erstellt: 08. Mai 2007, |||
Hello, Sorry I have to type this in English. I'm from Belgium and my German writing isn't so good. I'm planning to buy a new home cinema system (Harman Kardon HS 200) and i have a question about connecting it to my plasma screen. Its an older model plasma. resolution of 852 x 480. it doesn't have a HDMI connection or YUV connections. it does have DVI. but i don't know if it is HDCP. does anyone of you know this? what do you think is the best connection? using the DVI or the Scart-RGB? or other connection? Is connecting with the DVI at all possible (because not HD-ready??) ? Thanks for your help. |
Bufobufo
15:25
not at all, if you want to play real HDformats with protection flags (like premiere),so there is no way without HDCP (n.a. on your TV). With Files from PC it works well (640x480 for Text) 1024x768 is the max. Input-Resolution. It's also never ever HD-format. The best connection is to use the Scartplugs (RGB), because your native Resolution is near by this.
What want you connect there ? Greetings Jan |
erwin805
10:21
erstellt: 10. Mai 2007, |||
hi, thanks for the quick answer. are you sure the plasma has no HDCP? i read somewhere about a samsung dvd HD935 (with hdcp) connected using the dvi.. i was thinking about connecting the HDMI from the HK to the DVI... But, if that is not possible, can I use a cable like this one: ![]() or can i use a converter like this: ![]() or this: ![]() or can i connect the component output from the HK to the Scart input of the plasma. I've found this cable: ![]() What is the best solution? how do i get the best image? thanks [Beitrag von erwin805 am 10. Mai 2007, 12:58 bearbeitet] |
Bufobufo
14:30
Remember your Words, now tell me why you want a expensive converter. For this resolution is RGB the best, if you have too much money try the converters with YUV, but there are no Pixels more than before. It's the same bandwidth.
You have a DVI-D, a component DVI-I cable can't work here. Remember your text again,
So a Scart2YUV cable can't work, it's only a cable not a converter. Sorry for that bad Solutions. Greetings Jan |
erwin805
06:10
erstellt: 11. Mai 2007, |||
Bufobufo
11:13
Lock at the Samsung Datasheet: ![]() there are no analog connectors inside the DVI, but you can try. ![]() ![]() [Beitrag von Bufobufo am 11. Mai 2007, 11:15 bearbeitet] |
erwin805
12:58
erstellt: 18. Mai 2007, |||
I tested it with a HDMI-DVI cable and everything works ok. it seems the dvi does have HDCP... So i think i'll leave it like this. Thanks for the help... |
DVI SCART ayran am 29.05.2011 – Letzte Antwort am 17.06.2011 – 6 Beiträge |
SCART auf DVI - I ??? sevenofnine am 08.04.2004 – Letzte Antwort am 07.07.2008 – 6 Beiträge |
dvi oder scart andy1975 am 10.04.2006 – Letzte Antwort am 12.04.2006 – 3 Beiträge |
DVI auf Scart makrol am 04.12.2008 – Letzte Antwort am 08.12.2008 – 6 Beiträge |
dvi auf scart merzbach am 07.05.2009 – Letzte Antwort am 07.05.2009 – 3 Beiträge |
DVI auf Scart Julían1981 am 11.02.2013 – Letzte Antwort am 16.02.2013 – 6 Beiträge |
DVI D an SCART RöhrenTV soulmen am 28.05.2005 – Letzte Antwort am 30.05.2005 – 5 Beiträge |
Dringend Hilfe:Sanyo z2 scart-dvi Basketballking am 08.06.2006 – Letzte Antwort am 08.06.2006 – 3 Beiträge |
Scart zu VGA/DVI (TFT) panik88 am 11.02.2007 – Letzte Antwort am 11.02.2007 – 2 Beiträge |
Computer an Fernseher ---> DVI - Scart Andre1411 am 11.08.2007 – Letzte Antwort am 16.08.2007 – 4 Beiträge |
2007
- RF Eingang und RF Ausgang
- Registrierte Mitglieder928.464 ( Heute: 14 )
- Neuestes MitgliedShawnglicK
- Gesamtzahl an Themen1.558.277
- Gesamtzahl an Beiträgen21.698.692
