HIFI-FORUM » PC, Netzwerk & Multimedia » Multimediaplayer » Zappiti 3D Media Player | |
Zappiti 3D Media Player+A -A |
qfactor
#1 erstellt: 12. Jan 2013, 22:17 | |||
Hallo Freunde, um nicht alle Player in einen Topf zu werfen, starte ich einen neuen Thread, in dem wir ab sofort alle Fragen zum Zappiti 3D Media Player diskutiern können. Der Player gleicht hardwaretechnisch dem "Dune Base 3D" und soll ab kommender Woche lieferbar sein! So sieht der Bursche aus: und das soll er können: ● Processor: Sigma Designs 8672 - most stable solution from Sigma Designs. ● RAM: 512 MB. ● Flash memory: 256 MB + 4 GB (System Storage). ● Media sources: HDMI 1.4, 3x USB 2.0 (2x rear, 1x front), composite, component, analog stereo output, optical and coaxial S/PDIF, Ethernet 10/100/1000 Mb/s, Wi-Fi 802.11b/g/n (in option via Dune HD Air ), SD card slot (front), power input, power switch On/Off (back), LED indicator (front), LED Front Panel. ● Internal storage: Internal HDD rack with hot swap function for SATA HDD 3.5". Plug your HDD in computer tray or optional eSATA / USB 3.0 HDD Dock Station for the fastest possible way of transferring data between PC and HDD. ● DVB-T support: via Dune DVB-T USB Dongle in option. ● Media sources: external HDD (USB), external optical drive (USB), USB devices (USB flash drive, USB card reader, etc), built-in SD card reader (SD/SDHC), PC and NAS in local network (SMB, NFS, UPnP, HTTP), other Internet and local network media sources (HTTP, multicast UDP RTP). ● Web Browser: NetFront (ACCESS) or WebKit. ● Widgets support: when using NetFront browser. ● HbbTV and iPlayer support: when using NetFront browser. ● DLNA: Full DLNA (1.5 or 2.0) standard support. ● Adobe Flash: 3.1 (Lite, standalone) supported. ● DRM options: Microsoft DRM10 and PlayReady, Verimatrix, Secure Media, Flash Access (in work). ● Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264; support for very high bitrate video (up to 50 MBit/s and higher). ● Video file formats: 3D BD ISO, BD ISO, BDMV, MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, DVD-ISO, VIDEO_TS. ● Video output modes: wide range of supported output resolutions (up to 1080p) and framerates (including 23.976p, 24p, PAL, NTSC). ● Video output framerate: automatic (according to the played content) and manual. ● Audio codecs: AC3, Dolby Digital (bitstream, PCM), DTS (bitstream, PCM), Dolby Digital Plus (bitstream, PCM), DTS-HD (bitstream, PCM)*, Dolby TrueHD (bitstream, PCM), MPEG, AAC, LPCM, WMA, WMAPro, FLAC, multichannel FLAC, Ogg/Vorbis; support for very high quality audio (up to 192 kHz / 24-bit). ● Audio file formats: MP3, MPA, M4A, WMA, FLAC, APE (Monkey's Audio), Ogg/Vorbis, WAV, AC3, AAC. ● Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, external SUB/IDX), PGS (Blu-ray, TS, MKV). ● Picture file formats: JPEG, PNG, BMP, GIF. ● Playlist file formats: M3U, PLS. ● Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle. ● Audio playback functions: browse playlist, repeat, shuffle, ID3 tags, plasma TV burn-in prevention. ● D-BOX: digital audio outpout in both S/PDIF and HDMI simultaneous for multi-room audio and D-BOX compatibility. ● Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3 (read-write), NTFS (read-write). ● Ethernet: 10/100/1000 Mb/s. ● Network Playback Accelerator: special optimizations ensuring best-in-class network playback performance for the Sigma Designs 8672 platform and enabling smooth playback of any supported kind of media content via any network protocol (including NFS and SMB) even in 100 Mbit/s Ethernet networks. Viel Spaß, qfactor |
volverine
#2 erstellt: 14. Jan 2013, 08:53 | |||
Der Preis ist auf 299,- Euro gestiegen. Allerdings gibt es jetzt auch eine WLAN Antenne mit dazu: Zappiti Player - Full HD Mediacenter inkl. WLAN Antenne Ich denke mal, dass die "Vorbesteller" ihn "billiger" bzw. "zu dem alten Preis" ohne die WLAN Antenne bekommen werden........ |
volverine
#3 erstellt: 15. Jan 2013, 01:17 | |||
Beim baugleichen Dune Base 3D ist er mittlerweile "offiziell" nicht mehr gelistet: Der ISO-Support...... |
qfactor
#4 erstellt: 15. Jan 2013, 13:16 | |||
das feature stand bei dune noch nie in der liste, wurde also nicht jetzt erst rausgenommen... ob aus versehen oder weil er es in der tat nicht können wird wissen wir erst, wenn die ersten auftauchen... tippe aber auf das erste der zappiti wird doch schon irgendwo getestet... das wäre sicherlich rausgekommen, wenn der das nicht können würde... |
volverine
#5 erstellt: 15. Jan 2013, 14:02 | |||
Ich bin mir relativ sicher, dass dieses Feature "in den Anfängen" angekündigt worden ist, da ich vor der Wahl zwischen Dune und Zapitti stand, beide Geräte hinsichtlich des Funktionsumfanges komplett identisch waren und mich letztendlich nur aufgrund des (angeblich) früheren Erscheinungsdatums für den Zapitti entschieden habe. Aber vielleicht habe ich es auch falsch in Erinnerung........ [Beitrag von volverine am 15. Jan 2013, 14:08 bearbeitet] |
qfactor
#6 erstellt: 15. Jan 2013, 15:24 | |||
laut lipando.de soll es ja diese woche soweit sein bin mal gespannt, wann meiner ankommt |
DeXoN
#7 erstellt: 15. Jan 2013, 22:24 | |||
Ich bin ja mal sehr gespannt auf die ersten User Berichte. |
OssiF
#8 erstellt: 16. Jan 2013, 00:21 | |||
Vielleicht kann mir mal jemand auf die Sprünge helfen. Also der Zappiti 3D Media Player ist augenscheinlich Baugleich dem Dune HD Base 3D. Gibt es trotzdem Unterschiede? Welchen denn nun kaufen? Bin etwas verwirrt. |
qfactor
#9 erstellt: 16. Jan 2013, 00:29 | |||
die funktions-unterschiede, wenn vorhanden, werden sich erst beim release zeigen kaufen/bestellen kann man derzeit nur den zappiti... |
UdoG
#10 erstellt: 16. Jan 2013, 10:48 | |||
Du kannst bei sat-technik.net auch den Base 3D bestellen. |
DavidK
#11 erstellt: 16. Jan 2013, 10:51 | |||
Die (recht schlichte und karge) bda für den zappiti: http://www.zappiti.com/Download/Zappiti_Player_qsg_lang_EN_FR.pdf [Beitrag von DavidK am 16. Jan 2013, 10:52 bearbeitet] |
OssiF
#12 erstellt: 16. Jan 2013, 13:57 | |||
Wenn ich das richtig sehe, dann hat Zappiti auch schon eine Software drauf mit der ich dann "Plug & Play" loslegen kann wo ich beim Dune diese erst instalieren muss? Wie ist das mit der Firmware? Wenn beide Player identisch sind, funktioniert dann die Firmware von Dune auf dem Zappiti? |
qfactor
#13 erstellt: 16. Jan 2013, 18:19 | |||
das ist eine gute frage, wenn sie keinen "flash-schutz" haben, sollte das funktionieren... vielleicht wird es aber auch so sein, dass sich dune-besitzer die zappiti drauf spielen lassen wollen viele grüße, qfactor PS.: Zitat lipando.de "Leider wurde vom Hersteller Zappiti in Frankreich der Termin von Anfang Januar auf mitte Januar verschoben! Wir warten alle ganz gespannt auf die Auslieferung der Geräte hier bei uns in Deutschland! Wir bitten noch um etwas Geduld!" Hm, heute ist der 16.01. mehr Mitte Januar geht wirklich nicht |
Koloss78
#14 erstellt: 16. Jan 2013, 19:20 | |||
Ich glaube sowieso das der Dune Base 3D und Zappiti Player gleichzeitig rauskommen. |
qfactor
#15 erstellt: 16. Jan 2013, 20:44 | |||
habe bei lipando angerufen: - zappiti bekommen sie ende dieser, anfang nächster woche! - dune in etwa 10 tagen, also märz beim zappiti soll man wohl beim start die option haben, zwischen zappiti und dune GUI zu wählen! |
malei
#16 erstellt: 16. Jan 2013, 20:48 | |||
da lassen wir uns mal überraschen, dann warte ich weiter auf den Zappiti. |
harryhirsch76
#17 erstellt: 16. Jan 2013, 21:01 | |||
Steht auf Seite 10 der oben verlinkten Anleitung. Bin mal echt gespannt ob der Zappiti echt BD Iso unterstützt und der Dune Base 3D nicht. Danach richtet sich wohl meine Kaufentscheidung und bzgl der BD-Menüs. |
volverine
#18 erstellt: 17. Jan 2013, 11:31 | |||
Da glaube ich noch nicht so recht dran. Andere ausländische Anbieter des Zapitti (Reseller List) sprechen von "Ende Januar"......
Das hört sich doch gut an! Jetzt bleibt nur noch ein Feature "offen"...... |
Memphis
#19 erstellt: 17. Jan 2013, 11:47 | |||
Warum sagen die denn seit Anfang des Jahres, dass die Geräte beim Zoll liegen? Nun kommen sie doch später, als wäre das mit dem Zoll bereits eine Lüge gewesen, um die Kunden zu vertrösten! |
thorkogel
#20 erstellt: 20. Jan 2013, 20:15 | |||
Der Zappiti Player ist von Dune HD Hergestellt. Siehe hier ganz unten; "Manufactured in Taiwan by Dune HD" |
Hanfer
#21 erstellt: 20. Jan 2013, 20:24 | |||
Gibt es hier eigentlich schon erste Tests oder Hand ons? Der Player könnte meinen Fantec mal ablösen. |
volverine
#22 erstellt: 21. Jan 2013, 01:56 | |||
Das dürfte schwer werden, da er noch nicht bzw. noch nirgendwo ausgeliefert worden ist...... Eventuell gehen die ersten Geräte ab der nächsten Woche in den Versand, mittlerweile wurde bei einigen ausländischen Versendern die Lieferfrist von "Ende Januar" auf "3-5 Tage" geändert. [Beitrag von volverine am 21. Jan 2013, 01:57 bearbeitet] |
danielpuetz
#23 erstellt: 21. Jan 2013, 11:25 | |||
Der Knackpunkt ist für michBD ISO Menüs. Aber ich denke, da brauche ich mir keine großen Hoffnungen machen, wg. fehlender Lizenz, oder? |
Memphis
#24 erstellt: 21. Jan 2013, 12:51 | |||
Menüs wird er nicht haben. Trotzdem traurig, Ende des Jahre zu behaupten dass die Geräte beim Zoll liegen und 3 Wochen späte noch kein einziges Gerät geliefert zu haben. |
qfactor
#25 erstellt: 21. Jan 2013, 15:00 | |||
die nette dame von lipando nannte mir vor knapp 2 wochen auch firmware/lizenz-probleme als typische gründe für eine verzögerung ohne dabei explizit zu sagen, dass das beim zappiti der fall sei... |
volverine
#26 erstellt: 21. Jan 2013, 20:36 | |||
Jetzt ist der Lieferstatus wieder auf "Ende Januar" geändert worden . Wieso wird die Lieferzeit andauernd geändert? Das dürfte doch mit einem "Logistik-Problem" nicht zu erklären sein. Die bereits von qfactor gepostete "Erklärung" mit den Firmware-/Lizenz-Problemen (er-)scheint da eher zutreffend....... [Beitrag von volverine am 21. Jan 2013, 20:48 bearbeitet] |
volverine
#27 erstellt: 22. Jan 2013, 16:40 | |||
Aha, es scheint so langsam loszugehen. Die Homepage von "lipando.de" wurde gerade aktualisiert, dort heißt es wörtlich: "Bestätigung: Ware wird am 25 geliefert. Freigabe heute in PARIS! Das Warten hat endlich ein Ende! An alle Kunden: vielen Dank für Ihre Geduld!" Dann dürften die ersten Geräte in der nächsten Woche bei den Vorbestellern eintrudeln...... |
AllEars
#28 erstellt: 23. Jan 2013, 12:03 | |||
Hallo, weiß jemand wie der Support für den Zappiti Player läuft? Macht das DUNE oder Zappiti selber? Gibt es: - Telefon-Hotline - Supportforum - email-Adresse für Servicethemen - Internetseite mit Infos Wenn ja: in welcher Sprache (z.B. deutsch/englisch/französisch)? Wie kommt man an neue Firmware bzw. kann auftretene Probleme klären? Gruß, AllEars |
boccherini
#29 erstellt: 23. Jan 2013, 18:39 | |||
Hallo, ich hab mal eine dumme (?) Frage: kann ich beim Rippen von CDs auf dem Laufwerk in meinem PC die Datei auf die Platte des im gleichen Netzwerk angeschlossenen Media-Player ausgeben, kann ich also die Hard-Disc des Zappiti von meinem PC aus mounten? Schönen Tag wünscht Kris |
horr
#30 erstellt: 23. Jan 2013, 19:27 | |||
Das weis wohl nur der Entwickler von Dune, da der Zappiti-Player noch nicht ausgeliefert worden ist. Ich kann nur sagen, dass es bei meinem Dune Smart D1 funktioniert. MFG Christoph |
John-Sinclair
Gesperrt |
#31 erstellt: 24. Jan 2013, 02:50 | |||
Mein Gott, wie naiv seid Ihr? Ich hatte es schon im Base-Forum gepostet. ...das mit dem Zoll ist eine typische Ausrede. Ich hatte sogar schon Ausreden, wobei der Flieger abgestürzt sein soll. Es ist immer wieder das Gleiche. Langsam sollte auch der Letzte wissen, dass es sich dabei nur um Kundenfang handelt und darum damit deren Konten gefüllt werden. Die Zinsen sind auch in Zeiten von Niedrigzinsen nicht zu verachten. Vor Ende Februar, Anfang März wird das nichts. |
ilascu
#32 erstellt: 24. Jan 2013, 08:53 | |||
Ich habe heute bestellt. Laut Lipando sollte am 25 Jan. lieferbar sein. Mal sehen... |
marcus-e
#33 erstellt: 24. Jan 2013, 10:08 | |||
Warum kauft ihr nicht den Base 3D? Der soll laut dem passenden Thread schon lieferbar sein. |
Memphis
#34 erstellt: 24. Jan 2013, 10:10 | |||
Mehr Freunde macht man sich vor allem, wenn man einfach mal die Wahrheit sagt. Wenn ich ein Gerät bestellt und bezahlt habe, wäre ich auch schon zufrieden, wenn sie einfach sagen, dass es wohl noch Probleme bei der Auslieferung gibt, egal welcher Art. Aber diese Ausreden andauernd. Das ist viel schlimmer. |
murby81
#35 erstellt: 24. Jan 2013, 10:43 | |||
das denk ich mir auch ständig |
qfactor
#36 erstellt: 24. Jan 2013, 12:30 | |||
wo ist der lieferbar und was kann der mehr? |
Memphis
#37 erstellt: 24. Jan 2013, 12:39 | |||
Abgesehen vom Äußeren sind sie identisch. Auch der Autostart von z.B. yaDIS soll bei beiden Funktionieren. |
marcus-e
#38 erstellt: 24. Jan 2013, 12:43 | |||
http://www.hifi-foru...read=9402&postID=8#8 Wie ich gerade geschaut habe steht er ist sofort lieferbar. Aber jetzt steht drunter in ROT Anfang nächster Woche liferbar. Auch die wiederprechen sich also was die Verfügbarkeit betrifft. |
Memphis
#39 erstellt: 24. Jan 2013, 12:45 | |||
Das tun sie seit Dezember. |
GorillaBD
#40 erstellt: 24. Jan 2013, 14:45 | |||
Hm. Wie machen die das denn, weil Geräte mit unklarer Liefersituation bestelle ich nur per Nachnahme. Ohne Lieferung sehen die also mein Geld nicht... GLG GBD |
Memphis
#41 erstellt: 24. Jan 2013, 14:49 | |||
Ob man ein bischen auf Zinsen verzichtet oder ob man an den Postman eine Gebühr entrichten muss und meistens auch noch beim Shop zusätzlich mehr zahl, weil man Nachname bestellt, macht doch auch nichts mehr. |
quanah
#42 erstellt: 24. Jan 2013, 20:45 | |||
weil Du mit dem Player nur die Zappiti Lizenz fürs Programm bekommst |
KeVe1983
#43 erstellt: 24. Jan 2013, 23:59 | |||
Und was hat Dune davon das ich an den Shop Nachnahme Gebühren zahle, die der Shop dann an die DHL weitergibt? [Beitrag von KeVe1983 am 24. Jan 2013, 23:59 bearbeitet] |
GorillaBD
#44 erstellt: 25. Jan 2013, 07:37 | |||
Ich stell mir doch auch keinen Rolls-Royce in die Garage, wenn ich den als Bentley kriegen kann. GLG GBD |
Memphis
#45 erstellt: 25. Jan 2013, 09:00 | |||
Dune ist es so oder so egal, da die nicht mehr bekommen. Man zahlt aber erstens an den Lieferservice und oftmals noch an den Shop. Bei Vorkasse verdienen die Shops (Zinsen). Bei Nachname verdienen oftmals auch die Shops, da sie die Versandart teurer machen. Also noch mehr, als per Vorkasse. Zudem verdient der Lieferservice. Ein Freund von mir war mal bei DHL. Der hat kein Wechselgeld oder so bekommen und musste Nachnamegebühr immer so irgendwie wechseln. DHL verdient also auch noch mit relativ wenig Aufwand etwas. Somit ist der Verlust der Zinsen bei Vorkassezahlung eigentlich in jedem Fall niedriger, als bei Zahlung per Nachname, bei dem heutigen Zinssatz.... Aber wir sollten das hier nicht diskutieren, ist ein wenig Offtopic. |
GorillaBD
#46 erstellt: 25. Jan 2013, 09:13 | |||
Der Zinsaspekt ist ja nur ein Teil des Themas, die andere Frage ist: Wie schnell kann ich mein Geld bei dem Shop wieder loseisen, wenn der nicht liefern kann und ein anderer hat das Gerät. Da bin ich bei einer Stornierung meist weit besser dran, schneller und flexibler, wenn der Shop mein Geld noch nicht hat. Das ist mir dann auch die wenigen Euro Aufschlag für die Nachnahme wert. Ist speziell im Falle des Zappiti nicht das Thema, weil es den eh nur in D bei Lipando-PC gibt, aber bei anderen Gerätschaften mit Händlerwettbewerb sehr wohl. Offtopic ENDE. GLG GBD [Beitrag von GorillaBD am 25. Jan 2013, 09:15 bearbeitet] |
GorillaBD
#47 erstellt: 25. Jan 2013, 14:26 | |||
*** MELDUNG *** Ich kann vermelden, dass Lipando-PC den Zappiti-Player nun ausliefert. Mein Auftragstracking dort hat nun "Gerade im Versand" gemeldet. GLG GBD [Beitrag von GorillaBD am 25. Jan 2013, 14:29 bearbeitet] |
qfactor
#48 erstellt: 25. Jan 2013, 14:36 | |||
freue dich nicht zu früh... diesen status habe ich bereits seit dem 09.01. |
GorillaBD
#49 erstellt: 25. Jan 2013, 14:39 | |||
"Freigabe Versand" habe ich seit Bestelldatum. "Gerade im Versand" seit heute morgen. Und die Rechung mit Lieferdatum 25.01.2013 ist jetzt auch vorhanden, war gestern noch nicht im Status. Also bin ich zuversichtlich. GLG GBD [Beitrag von GorillaBD am 25. Jan 2013, 14:46 bearbeitet] |
qfactor
#50 erstellt: 25. Jan 2013, 15:15 | |||
dann drücke ich dir die daume bei mir sieht es so aus: 09.01.2013 06:43 [6] Gerade im Versand 08.01.2013 16:12 [5] Freigabe Versand 08.01.2013 16:12 [3] Warten auf Zahlung Rechnungsdatum auch vom 09.01. bestellt hatte ich bereits mitte DEZ, aber am 08.01. hatte mir dann die nette dame meine bestellung ohne rückfrage storniert, nachdem ich mich über die informationspolitik beschwert hatte mal sehen, was passiert... der laden ist für erst einmal auf der blacklist! |
ilascu
#51 erstellt: 25. Jan 2013, 15:50 | |||
Laut Lipando wird meine Bestellung in meine Hände nur Dienstag. Ich habe gerade die Hotline angerufen. Die Ware ist noch nicht aus Frankreich gekommen aber, sagte sie, kommt noch heute und wird dann auch weiter geliefert. Also... GEDULD !!! |
Zappiti Media Center el_dude1 am 20.09.2013 – Letzte Antwort am 11.01.2023 – 1471 Beiträge |
Zappiti Player 3d wird immer langsamer ramon_raumklang am 04.11.2014 – Letzte Antwort am 25.11.2014 – 2 Beiträge |
Frage zum Zappiti Media Center Krawallus am 21.12.2013 – Letzte Antwort am 29.12.2013 – 2 Beiträge |
Mehrere Festplatten mit Zappiti Media Center aud Dune Smart D1 qfactor am 06.04.2015 – Letzte Antwort am 17.12.2015 – 2 Beiträge |
Media-Player gesucht (3D, BDIsos.) Memo1234 am 23.01.2014 – Letzte Antwort am 25.01.2014 – 2 Beiträge |
Dune HD mit Zappiti Media Center verbinden! knubbel5 am 24.04.2016 – Letzte Antwort am 24.04.2016 – 2 Beiträge |
Bluetimes BT-3550B 3D Media Player Henr1ck am 22.07.2012 – Letzte Antwort am 06.05.2013 – 16 Beiträge |
Günstiger Media Player UHD, mkv, dts, 3D hitch.b am 21.08.2017 – Letzte Antwort am 21.08.2017 – 2 Beiträge |
Zappiti Video johndo6 am 23.02.2022 – Letzte Antwort am 27.02.2022 – 4 Beiträge |
Zappiti 303D - Alternative zu Zappiti Dynamic K1lgoreTr0ut am 18.01.2015 – Letzte Antwort am 18.01.2015 – 2 Beiträge |
Top 10 Threads in Multimediaplayer der letzten 7 Tage
- Amazon Fire-Tv Stick und LG OLED55CX9LA
- HI RES Streaming über QOBUZ
- INNUOS ZENmini - ZEN - ZENith -Pulse Serie - Roon Erfahrungsaustausch
- Noxon iRadio 400 keine Internetsender mehr
- Lösung der DENON WLAN Probleme
- Pioneer N-70AE / N-50AE / N-30AE
- Bluesound VAULT 2i
- Kodi v20 KEINE MKV Dateien & erkennt Bibliothek nicht mehr auf Nvidia Shild
- Anleitung für DUMMIES: Audiophiler Raspberry Selbstbau Low Budget Musikplayer/-streamer
- Audio Netzwerkplayer was bringts?
Top 10 Threads in Multimediaplayer der letzten 50 Tage
- Registrierte Mitglieder927.123 ( Heute: 7 )
- Neuestes Mitgliedcelil
- Gesamtzahl an Themen1.554.846
- Gesamtzahl an Beiträgen21.623.212
