HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » MAGNETOPHON 3000 HIFI TELEFUNKEN UMSCHALTER VORBAN... | |
MAGNETOPHON 3000 HIFI TELEFUNKEN UMSCHALTER VORBAND/HINTERBAND+A -A |
GIORGIO_MARTINI
#1 erstellt: 01. Aug 2020, 15:31 | |
Hi from Italy, I have this telefunken 3000 reel-to-reel tape recorder. Can someone explain to me if listening to the speakers I have to use the selector a or b? because the sound changes a lot. With A sound more closed listening, with B sound more open. I don't understand from German. I understand that A is for listening through headphones and B for listening through external speakers. Is this so? see description image. Thanks in advance |
CarlM.
#2 erstellt: 01. Aug 2020, 15:57 | |
Hello Georgio, I'm just returning from my Italian café and then I read your message. I will not translate 1:1 but I will try to explain the content. While you are recording you will have two options to listen. Using switch "18" you can change between these two options. Option A: Then you will listen to the signal before it has been recorded. Therefore you are listening to the input signal of the source that will be recorded. Option B: Then you are listening to the signal that has already passed the head and that already has been recorded on the tape. You can say that "A" is the input signal and "B" is the signal taken from the tape directly after recording. Content of the last three lines: Option to listen (options to control the signal): a.) by headphones using jack 14 b.) using an amplifier or receiver connected to jack 33. Best wishes ... Carl |
GIORGIO_MARTINI
#3 erstellt: 01. Aug 2020, 16:26 | |
Dear Carl. first of all very beautiful message and now I understand perfectly. I could not understand why in the translation from german with google I had to first convert an image to ocr format and then translate the text and the words were confused. in the Italian translation I could not understand and unfortunately I did not find the manual in English for this recorder. thank you very much now is all clear for me!! .. Happy holidays and thanks again dear Carl! Giorgio |
Haube Telefunken Magnetophon 3002 awr13 am 30.04.2013 – Letzte Antwort am 30.01.2015 – 2 Beiträge |
Telefunken Magnetophon 75 Riemensatz nohpgam am 14.09.2016 – Letzte Antwort am 16.09.2016 – 2 Beiträge |
Riemen für Telefunken Magnetophon Automatic ossinator71 am 27.02.2015 – Letzte Antwort am 05.02.2017 – 15 Beiträge |
Magnetophon: Band fädelt aus grasso am 30.04.2015 – Letzte Antwort am 20.06.2015 – 6 Beiträge |
Telefunken TRX 3000 Digitalanzeige pepe56 am 15.01.2008 – Letzte Antwort am 17.01.2008 – 4 Beiträge |
Telefunken TRX 3000 idurschelap am 03.04.2008 – Letzte Antwort am 04.04.2008 – 2 Beiträge |
Telefunken TRX 3000 Glühbirnchen germi1982 am 11.11.2008 – Letzte Antwort am 21.01.2021 – 17 Beiträge |
Telefunken TRX 3000 nady_90 am 23.01.2011 – Letzte Antwort am 23.01.2011 – 2 Beiträge |
REPERATUR: Telefunken TRX 3000 nady_90 am 13.05.2011 – Letzte Antwort am 21.05.2011 – 3 Beiträge |
Telefunken TRX 3000 Albertl am 07.10.2011 – Letzte Antwort am 20.06.2016 – 10 Beiträge |
2020
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder927.030 ( Heute: 1 )
- Neuestes MitgliedLoraDub
- Gesamtzahl an Themen1.554.577
- Gesamtzahl an Beiträgen21.617.080
