HIFI-FORUM » Stereo » Lautsprecher » Welches ist das unter anbetracht der Physik beste... | |
Welches ist das unter anbetracht der Physik beste Wandlerkonzept?+A -A |
LineArray
#101 erstellt: 15. Mrz 2011, 01:23 | |
Aus Abschnitt 4, "Conclusion": "The combined effects of playback level and delay have strong implications to the perceived perception of nonlinear distortion. It is not possible to say, without complicated objective tests, if what is being perceived is a nonlinearity in the system or a nonlinearity in the subjective perception as described in this paper. This has profound implications to the subjective evaluation of nonlinear distortion in audio systems most particularly loudspeakers where the delay factor can be quite strong. Time delayed resonances, nearby cabinet reflections and edge diffraction, waves in horns; all have delay times on the same order as this study. A loudspeaker that is evaluated at 70–80 dB (SPL) may have a very different perception at 90-100 dB even if it is completely linear. A THD distortion curve will not reveal this effect, nor will a frequency response graph. A careful look at the impulse response might yield the best insight, however this has not been quantified. Methods for measuring the nonlinear effects of our subjective perception are currently under investigation. Another point is that the usefulness of a loudspeaker for audio playback can have a sound power output limit that is independent of its electrical power handling or its nonlinear distortion characteristics. Loudspeaker evaluations that take place at a fixed level, are seriously inadequate at revealing the true quality of these systems." --- "Audibility of Linear Distortion with Variations in Sound Pressure Level and Group Delay" Lidia W. Lee, Earl R. Geddes AES Convention, October 2006 [Beitrag von LineArray am 15. Mrz 2011, 01:26 bearbeitet] |
audiophilanthrop
#102 erstellt: 17. Mrz 2011, 22:00 | |
Wenn ich das Paper richtig verstehe, könnte das erklären, warum wir Kammfiltereffekte (und diese wurden ja letztlich simuliert, siehe Fig. 2) wahrnehmen können - was an sich ein alter Hut ist. Die erwähnten Gruppenlaufzeit-Unregelmäßigkeiten sollten dann im Bereich der schmalen Interferenz-Einbrüche liegen (Minimalphasigkeit). Im Umkehrschluß hieße das, daß geglättete Frequenzgangmessungen ggf. eine zu grobe Vereinfachung darstellen. |
LineArray
#103 erstellt: 18. Mrz 2011, 14:57 | |
Daß zu viel Glättung auch zu viel Vereinfachung beim Amplitudenfrequenzgang bedeutet, sehe ich ebenfalls so. Andererseits sind ungeglättete Frequenzgänge oft schwer zu interpretieren, da ist sicher je nach Zweck immer ein gesundes Maß an Glättung gefragt. Was ich an dem Lee/Geddes Paper interessant finde, ist die Verschiebung der Wahrnehmungsschwellen für die Gruppenlaufzeitverzerrungen mit dem Pegel. --- Der Effekt der GL auf die Wahrnehmung von Klirr lässt sich aus dem Lee/Geddes Paper übrigens nicht direkt entnehmen, auch wenn Lee/Geddes zum Schluss nahelegen, nichtlineare Verzerrungen und GL Verzerrungen gemeinsam und immer in Abhängigkeit vom Pegel zu betrachten. In Post #99 hätte es also anstatt: "Hierzu eine Untersuchung aus dem Jahr 2006, in dem gezielt mit harmonischen Verzerrungen bei gleichzeitiger Anwesenheit von Laufzeitverzerrungen experimentiert wurde" heissen müssen: "Hierzu eine Untersuchung aus dem Jahr 2006, in dem gezielt mit linearen Verzerrungen bei gleichzeitiger Anwesenheit von Laufzeitverzerrungen experimentiert wurde" Sorry, geschlampt ! --- Der Effekt der niedrigeren Wahrnehmungsschwelle für Klirr bei ungünstiger Verschiebung von Klirr Komponenten innerhalb der zeitlichen Hüllkurve ( was durch GL- Verzerrungen geschieht) wurde wohl erstmals von Schroeder/Mehgart in "Auditory masking in the perception of speech" berichtet. Ich habe leider momentan keine genaueren bibliographischen Angaben zur Hand. Prof. Dr. Manfred Schröder Grüße Oliver [Beitrag von LineArray am 18. Mrz 2011, 16:52 bearbeitet] |
Chohy
#104 erstellt: 18. Mrz 2011, 16:29 | |
Wenn man nicht wie einige Fachzeitschriften alles glattbügelt, dürfte man doch einen guten Kompromiss haben und dazu dann der ungeglättete Amplitudenfrequenzgang falls Minimalphasigkeiten von Interesse sind. Muss nicht zwangsläufig nur ein "hübsches" Bildchen geben. gruß chohy |
LineArray
#105 erstellt: 18. Mrz 2011, 17:17 | |
Die Darstellung von Messergebnissen ist für mich so etwas wie eine eigenes Genre innerhalb der Künste ... Ich bin immer wieder erstaunt, daß allein der Begriff "Messung" im Zusammenhang mit irgendeinem Bildchen sehr schnell bei bestimmten Leuten den Anschein von "Objektivität" erweckt. Dabei gibt es so viele Freiheitsgrade was und wie man etwas darstellt. Da bleibt die Frage nach der Relevanz der jeweiligen Messdaten und deren Vergleichbarkeit oft auf der Strecke, denn sobald man einem Menschen ein Bild vor die Nase hält, hält er sich seinerseits an dem Bild fest. Das Auge ist bei normalsichtigen Menschen das "Führungsorgan", das macht uns anfällig für Dinge auf Bildern, deren akustische Relevanz wir gar nicht richtig einschätzen können. Ich halte jedenfalls die Gruppenlaufzeit über der Frequenz für eine sehr interessante und aussagefähige Kurve. Aber hier stellt sich genauso die Frage nach der Glättung und den Bedingungen unter denen gemessen wird. Auch eine geeignete oder wenigstens "übliche" frequenzabhängige Bewertungsfunktion für Gruppenlaufzeitverzerrungen im Hörfrequenzbereich existiert meines Wissens nach nicht. Genau wie beim Amplitudenfrequenzgang sollte auch hier m.E. nicht allein eine bestimmte Mikrofonposition "auf Achse" auschlaggebend sein. Das ist alles ein bischen so, als ob man im Kino die Bildqualität auf der Leinwand in einem briefmarkengroßen Abschnitt in der Mitte messen würde und daraus "die Bildqualität" ermittelt. Ob die Ränder (in dem Fall vielleicht 99,999% der Fläche) wackeln, lila verfärbt oder vielleicht ganz schwarz aussehen interessiert dann keinen mehr, bzw. ist nicht mehr Gegenstand der "objektiven Messung". Grüße Oliver [Beitrag von LineArray am 18. Mrz 2011, 17:25 bearbeitet] |
Chohy
#106 erstellt: 18. Mrz 2011, 17:57 | |
Jap, hab ich letztens auch gemerkt, das man mit sowas wie der Impuls/Sprungantwort per se nicht unbedingt viel anfangen kann (solange Furiertransformation nicht zum Kopfrechnen gehört ), und Phasenschweinereien, da wo sie z.b. leichter auffallen (v.a. Tieftonbereich) durch eine ordentliche Phase in den übrigen Frequenzen kaschiert werden kann und genauso umgekehrt. So wäre es imho zum. sinvoll die Gruppenlaufzeit über die Frequenz anzugeben. Es wäre mit der on-axis Messung doch wenigstens ein Anfang. Vllt denkt sich in den kommenden Jahren noch jemand was passendes dazu aus . Z.z. ist z.b. der lineare FQ-Gang auf Achse im Freifeld leider immer noch DAS Kriterium für "neutralen" Klang im (Wohn)Raum , obwohl es nur notwendig nicht aber hinreichend ist. Aber die Hersteller und Presse würden einen Teufel tun, das zu verändern. gruß chohy [Beitrag von Chohy am 18. Mrz 2011, 17:58 bearbeitet] |
Audio Physik Virgo 5 Heimai am 26.12.2014 – Letzte Antwort am 26.12.2014 – 2 Beiträge |
Audio Physik Yara/Spark Horus am 30.05.2004 – Letzte Antwort am 31.05.2004 – 9 Beiträge |
Audio physik Tempo wertstoff am 25.04.2005 – Letzte Antwort am 26.04.2005 – 5 Beiträge |
Welches Lautsprecherprinzip ist heutzutage das BESTE ? Magnolia am 17.05.2009 – Letzte Antwort am 21.05.2009 – 13 Beiträge |
Welches Boxenset unter 800 EUR? zippopippo am 16.05.2004 – Letzte Antwort am 16.05.2004 – 4 Beiträge |
beste lautsprecher für den pc lol1995 am 03.12.2009 – Letzte Antwort am 06.12.2009 – 8 Beiträge |
audio Physik Spark mit welchem Verstärker? bredi am 11.12.2006 – Letzte Antwort am 12.12.2006 – 10 Beiträge |
KEF iQ 50 - tro Testergebnisse ! Beste StandLS unter 1000 Euro? sabireil am 06.12.2008 – Letzte Antwort am 05.01.2009 – 23 Beiträge |
Welches Kabel für KRK Rp5 G2 BLND am 12.03.2011 – Letzte Antwort am 12.03.2011 – 7 Beiträge |
beste lautsprecher der welt? Qoma am 04.03.2007 – Letzte Antwort am 05.03.2007 – 21 Beiträge |
- Schneider Lautsprecher
- TSM kennt die jemand?
- Ecouton
- Ecouton
- Registrierte Mitglieder928.456 ( Heute: 11 )
- Neuestes Mitglied*Sephiroth*
- Gesamtzahl an Themen1.558.243
- Gesamtzahl an Beiträgen21.697.791
