HIFI-FORUM » Surround & Heimkino » Lautsprecher » JBL Boxen EON 1500 | |
JBL Boxen EON 1500+A -A |
Vohwinkeler
#1 erstellt: 05. Okt 2008, 18:05 | |
Kann mir jemand Sagen welche Werte die "Sofitten" in der Box haben?
Eminenz
#2 erstellt: 05. Okt 2008, 18:06 | |
JBL EON1500 Specifications Description15" 2-way Multi-purpose ApplicationMain speaker for music playback and live sound, stage monitor Frequency Range55-16 kHz Sensitivity (1w/1m)98 dB Nominal Coverage60°x 90° Power Handling Avg 225 W Peak 900 W Max SPL129 dB Nominal Impedance8 ohms Dimension (HxWxD)686 x 430 x 444 mm 27 x 17 x 17.5 in Weight17.24 kg 38 lbs Key Features and Attributes 15" 2-way speaker system. 55 Hz to 16 kHz frequency response. 98 dB sensitivity (1 watt @ 1 meter) 8 ohms impedance 225 watts continuous pink noise power handling, 900 watts peak. Now with Parallel 1/4" and NL4 input connectors (previous version only had dual 1/4" connectors). Liquid cooled titanium-diaphragm compression driver. Molded one-piece baffle with integral 60° x 90° constant directivity horn. SonicGuard™ circuitry unobtrusively protects the compression driver from overpowering. Multi-angle enclosure for flexibility - use EON1500 as a main PA speaker or floor monitor. Handsome, all black enclosure is unobtrusive and professional in appearance. Enclosure and baffle are molded of tough, durable co-polymer material. EON 1500 will stand up to impact that would cause the joints on a conventional enclosure to separate. A heavy-duty, perforated metal grill protects the woofer. Ergonomically designed and balanced handle and lightweight enclosure for easy and comfortable carrying Net weight: a mere 38 lbs. (17.2 kg.). Attachment points for wall or ceiling-mounting brackets (brackets available separately). Integral 35 mm pole mount receptacle with securing thumb screw |
Vohwinkeler
#3 erstellt: 07. Okt 2008, 22:44 | |
Die Maße, Gewichte etc. habe ich schon. Es geht darum die defekten Sofitten zu erneuern. Leider ist weder auf der Platine, noch an den alten sofitten etwas lesbares. Wäre schön jemanden zu finden der so was schon mal repariert hat. |
Wer kennt JBL MX 1500 ? Fact am 21.04.2004 – Letzte Antwort am 21.04.2004 – 3 Beiträge |
kennt jemand JBL CS 1500? redroomboy99 am 16.12.2007 – Letzte Antwort am 18.12.2007 – 8 Beiträge |
jbl boxen bugsbunchy am 02.08.2003 – Letzte Antwort am 05.08.2003 – 3 Beiträge |
Frage zu JBL Boxen Momba am 15.08.2003 – Letzte Antwort am 11.09.2003 – 6 Beiträge |
Magnat oder JBL Boxen Punami am 25.02.2005 – Letzte Antwort am 27.02.2005 – 3 Beiträge |
Boxen Montage JBL SCS Serien am 07.04.2004 – Letzte Antwort am 20.04.2004 – 2 Beiträge |
Boxen für ca 1500 für Denon 3805! GHOSTMAN am 26.12.2005 – Letzte Antwort am 26.12.2005 – 2 Beiträge |
welche boxen zu yamaha rxv 650 bzw. 1500 lublu am 18.03.2005 – Letzte Antwort am 18.04.2005 – 3 Beiträge |
Jbl RMS_power am 02.12.2004 – Letzte Antwort am 03.12.2004 – 3 Beiträge |
Teufel, Canton, JBL? ich brauch HILFE ! hartmensch am 15.09.2006 – Letzte Antwort am 15.09.2006 – 4 Beiträge |
Top Produkte in Lautsprecher
- Plus/Minus vertauschen?
- Stammtisch " Heco Celan "
- Registrierte Mitglieder927.132 ( Heute: 1 )
- Neuestes MitgliedTongKyr
- Gesamtzahl an Themen1.554.851
- Gesamtzahl an Beiträgen21.623.434
