HIFI-FORUM » Surround & Heimkino » Lautsprecher » Help: JBL EscXcite 5.1 SIMPLY CINEMA | |
Help: JBL EscXcite 5.1 SIMPLY CINEMA+A -A |
Andriuz
#1 erstellt: 21. Feb 2005, 21:20 | |
Hi Gents, Maybe someone of you had a chance to try or own JBL EscXcite 5.1 SIMPLY CINEMA® I almost could not find any user feedbacks or reviews of this product. Of course it is more budget system probably that's why. Still it is an interesting solution that includes build in amplifier and Dolby Digital - DTS - Dolby Pro Logic decoders. In addition it has 2 digital and 2 analog inputs. Almost everything what you need. Feature description is nice, but is it woth 270€ ? Any feedback is appreciated! http://international...ESC&language=ENGLISH SPECIFICATIONS: Audio Section • Surround Formats: Dolby Digital - DTS - Dolby Pro Logic • Frequency Response at 1W (+0dB, -3dB): 55Hz - 20 kHz • Signal-to-Noise Ratio (IHF-A): 80 dB Satellite Section • Frequency Response (-6db): 120 Hz-20 kHz • Sensitivity (2.83V @ 1m): 84 dB • Nominal Impedance: 4 Ohms • Recommended Amplifier Power: 25 Watts RMS (in sub) • Titanium Laminate HF: 12 mm • Paper Cone Midrange : 75 mm • Dimensions (H x W x D): 111 x 81 x 92 mm • Weight: 0.5 kg • Finish: silvergray Center Section • Frequency Response (-6db): 120 Hz-20 kHz • Sensitivity (2.83V @ 1m): 86 dB • Nominal Impedance: 4 Ohms • Recommended Amplifier Power: 25 Watts RMS (in sub) • Titanium Laminate HF: 12 mm • Paper Cone Midrange : dual 75 mm • Dimensions (H x W x D): 83 x 194 x 95 mm • Weight: 0.8 kg • Finish: silvergray Subwoofer Section • Low Frequency Cut-off: 40 Hz • High Frequency Cut-off: 160 Hz • Built-in Power Amplifier (RMS): 25 Watts x 5 + 60 Watts • Paper Cone Long Throw Driver : 165 mm • Dimensions (H x W x D): 315 x 300 x 310 • Weight: 7.2 kg • Finish: silvergray General Section • Power Requirement: 230V/50-60Hz • Power Consumption: 80 Watts |
JBL Simply Cinema ESC300 Wolli01 am 07.01.2009 – Letzte Antwort am 07.01.2009 – 8 Beiträge |
Problem JBL SIMPLY CINEMA 5.1 ESC 300 Loona69 am 01.01.2013 – Letzte Antwort am 02.03.2014 – 2 Beiträge |
Ersatz für JBL Simply Cinema Sub125 magnum007 am 05.12.2020 – Letzte Antwort am 06.12.2020 – 6 Beiträge |
Home Cinema JBL ESC550 Goevi am 18.09.2002 – Letzte Antwort am 03.11.2012 – 6 Beiträge |
Help - Surroundaufstellungsprobleme UdoG am 25.06.2005 – Letzte Antwort am 28.06.2005 – 8 Beiträge |
Jamo Blue Skyline 5.1 kennt das jemand ? Sven666 am 08.11.2009 – Letzte Antwort am 16.11.2009 – 6 Beiträge |
Need your Help! Magnat <-> Canton Phio2 am 23.03.2008 – Letzte Antwort am 24.03.2008 – 12 Beiträge |
Need Help Harman/Kardon JBL SCS200.5 Subwoofer schaltet ab seed am 04.12.2005 – Letzte Antwort am 04.12.2005 – 4 Beiträge |
Need help, Lautsprecheraufstellung Die_Brut am 14.02.2004 – Letzte Antwort am 15.02.2004 – 3 Beiträge |
Lautsprecheraufstellung Help plz man_in_black am 24.05.2004 – Letzte Antwort am 25.05.2004 – 17 Beiträge |
2005
- Plus/Minus vertauschen?
- Stammtisch " Heco Celan "
- Registrierte Mitglieder928.419 ( Heute: 6 )
- Neuestes Mitglied032.ua#Lviv
- Gesamtzahl an Themen1.558.167
- Gesamtzahl an Beiträgen21.695.664
