Wharfdale 9.1/9.2 Bookshelves
juggy_25
#1 erstellt: 27. Apr 2006, 21:05
Cud someone give a review on Wharfedale 9.1/9.2 Bookshelf speakers?
As per the Product Manual, the nominal impedance shows 6 ohms, but will it function normally with an 8 ohm Amp?
How is the Wharfdale 9.1/9.2 for Movies & Muzik?
square_wave
#2 erstellt: 28. Apr 2006, 09:06
If the amp clearly asks you stay away from anything lower than 8ohms, stay away from 6 ohm speakers. During music passages they won't stay at 6 ohms. They will dip again and this is asking for trouble. Most amps are 4 ohm to 16 ohm which is pretty safe with most speakers.
The 9.1 are pretty good with the mids and highs. Low end will be lacking when you use them with movies. You may need a sub woofer.
Behram
#3 erstellt: 28. Apr 2006, 09:12
I was previously using a Sansui AU 217 amplifier which stated on the rear panel "Speaker impedance to be 8 ohms or higher". I used it with a speaker impedance of 4 ohms and nothing ever happened even with it being driven at high volumes.
This may be an exception rather than the rule, but its better to be safe than sorry.
square_wave
#4 erstellt: 28. Apr 2006, 09:43
This is actually a design issue. Most older sansui amps are build like tanks. I had one long back and was using it with a bose 401 which was a 4ohm speaker and nothing happened. But I sold the speaker to a friend and he blew his technics amp which was rated at 8ohms. If the poster has a well designed amp with good power supplies, it could be safe.........
Amp_Nut
#5 erstellt: 28. Apr 2006, 10:56
square_wave, I agree with you.
Generally, the amps that have Integrated Circuits (ICs) as their output power devices are fragile.
Often, the lowest price amp in the range uses Power ICs.
I THINK ( Not sure ) the cheapest Yamaha has Power ICs. The next in the rage onwards, uses discrete power transistors..
juggy_25
#6 erstellt: 28. Apr 2006, 12:48
Thanx. I am planning to get the Wharfedale SW-150 sub with the Diamonds.
Is there much difference between the 9.1 and 9.2??
Manek
#7 erstellt: 29. Apr 2006, 05:23
I would go for the 9.2.
MS 902i bookshelves
Tim_Choco am 02.02.2007  –  Letzte Antwort am 08.02.2007  –  18 Beiträge
Quad Bookshelves (11L & 12L)
juggy_25 am 28.04.2006  –  Letzte Antwort am 03.05.2006  –  9 Beiträge
Yamaha AX497 amp - how is it?
Bibs am 03.02.2006  –  Letzte Antwort am 08.02.2006  –  4 Beiträge
speakers for NAD 320BEE
sammygeorge am 10.10.2005  –  Letzte Antwort am 30.11.2005  –  25 Beiträge
Wharfdale 8.1 or Monitor Audio B2
Voodoo_CHild am 20.09.2006  –  Letzte Antwort am 22.09.2006  –  8 Beiträge
Help with speakers connections
pranab31 am 27.02.2006  –  Letzte Antwort am 28.02.2006  –  5 Beiträge
Suggestion for budget bookshelf/floor standing speakers
vivekama am 06.08.2005  –  Letzte Antwort am 08.08.2005  –  3 Beiträge
Need help in choosing speakers
trivisingh am 25.01.2005  –  Letzte Antwort am 11.02.2005  –  25 Beiträge
how to wire my speakers into my amp?
pumpanani am 14.12.2004  –  Letzte Antwort am 15.12.2004  –  2 Beiträge
bookshelf 2 way speakers with 90db+ sensitivity
Manek am 16.09.2008  –  Letzte Antwort am 22.09.2008  –  34 Beiträge
2006
  • Registrierte Mitglieder928.479 ( Heute: 7 )
  • Neuestes Mitgliedeunicen907643281
  • Gesamtzahl an Themen1.558.306
  • Gesamtzahl an Beiträgen21.699.380
