speaker stands
juggy_25
#1 erstellt: 08. Jun 2006, 16:23
how much does the speaker stands effect/affect the quality of music?
How is a Solid metal, sand filled, spikes mounted stands different from elegant looking Glass stands (sound qualitywise)?
what are the recommendations?
purnendu
#2 erstellt: 09. Jun 2006, 10:16
Dont skimp on stands. Stands do make a respectable difference simply because you can optimise the position of the speakers vis a vis the room. Small speakers especially benefit from correct location. For many years I used my stands without filling them up with sand. Couple of years ago I loaded them with sand, and yes clearly there was an improvement in the sound. The bass got firmer and more authoritative so to say. I use Target stands and they work fine by me. The other mainstream brand available here is Appollo I gather. Dont know about glass stands,even if sand filled. Would not glass resonate? I wonder. Check TNT audio for some ideas on DIY stands if you dont want to spend too much.
I would appreciate advise from anyone on fixing the speaker to the plate with an adhesive. Double sided tape mars the finish of the speaker if you have to remove it sometime. Is there some non discolouring stuff I can use. I have heard of Blue Tack but dont know what it is? Is it a kind of chewing gum or plasticine? Where could I get it.
Purnendu
Amp_Nut
#3 erstellt: 09. Jun 2006, 10:36
Blu Tack is like a plastercine. Its blue ( sorry for stating the Obvious ) and its Freely available atleast my side of Bombay. Ask at stationary stores. Its about Rs 100 for a packet... yes, the origina - imported stuff.
If you can get it, pm me, and I will send U.
Blu Tack hardens when its left in place for months. I am not SURE if it stains, long term or not.
But yes, Blu Tack is the better option for speker mounting.
Arj
#4 erstellt: 09. Jun 2006, 10:39
it does stain the speaker in fact causes discoloration as i found out for myself
Amp_Nut
#5 erstellt: 09. Jun 2006, 10:40
Glass is a acoustically hard material, and resonates.
Many consider Glass a Complete Phoo-Phoo for ANYthing audiophile.
Pexiglass is considered not audiophile appropriate, even though Glass looks better, etc etc.
Yes there are Turntables with Glass platters, but many consider these a mistake.
Sorry, no experience with Glass speaker stands, but extrapolating......
juggy_25
#6 erstellt: 11. Jun 2006, 13:40
So Metal Speaker Stands filled with sand is a good option, right? (or is wood better?)
How do you fix the speaker to the stand? I thought you use screws. Whats the Blue Tack adhesive story?!!
Amp_Nut
#7 erstellt: 12. Jun 2006, 01:59
Hi Guys,
BIG BOO BOO in my old post.
The correct post should be :
Pexiglass is considered MORE audiophile appropriate, even though Glass looks better, etc etc.
ani
#8 erstellt: 12. Jun 2006, 04:55
I have used double side adhesive cloth tape without causing damage to wood veneer, no stain or hard to remove glu after removal of the tape. This tape is used in printing industry to fix nylocast, blanket etc to printer drums, it looks and is similar to old type of surgical plaster, but with better adhesive on both sides, comes in different width with one side stuck to transparent polyester film.
Speaker Stands
Shahrukh am 30.08.2005  –  Letzte Antwort am 01.09.2005  –  9 Beiträge
Suggestions Speaker stands and Subwoofer
kvish am 09.09.2006  –  Letzte Antwort am 20.09.2006  –  21 Beiträge
How much will this cost?
SUNILYO am 11.07.2007  –  Letzte Antwort am 12.07.2007  –  13 Beiträge
What makes a good speaker stand?
zhopudey am 19.07.2007  –  Letzte Antwort am 15.08.2007  –  41 Beiträge
Importance of spks stands for bookshelf spks
Prithvi am 30.12.2004  –  Letzte Antwort am 07.01.2005  –  10 Beiträge
How much amplifier power do you need?
bombaywalla am 17.09.2009  –  Letzte Antwort am 15.10.2009  –  53 Beiträge
"Speaker Placement " The Magical hands.
Sonic_Master am 17.02.2007  –  Letzte Antwort am 21.02.2007  –  34 Beiträge
What is a Good Speaker?
SDhawan am 04.10.2004  –  Letzte Antwort am 06.10.2004  –  3 Beiträge
cd sound quality
filmguy am 11.04.2005  –  Letzte Antwort am 12.04.2005  –  9 Beiträge
Speaker Break In
Behram am 06.10.2005  –  Letzte Antwort am 14.10.2005  –  25 Beiträge
2006
  • Registrierte Mitglieder928.479 ( Heute: 6 )
  • Neuestes Mitgliedintruder#
  • Gesamtzahl an Themen1.558.302
  • Gesamtzahl an Beiträgen21.699.300
