HIFI-FORUM » English » Stereo (Engl.) » Amp has gone kaput. Again! | |
Amp has gone kaput. Again!+A -A |
Savyasaachi
16:11
erstellt: 14. Jul 2006, |
Dear All, I write this with a heavy heart. My amplifier has given out again. This time the damage is pretty serious. One of the transformers seem to have gone kablooie.... the entire cabinet was billowing with smoke when i opened the top... Its going to be a long long time before i get it up and running again...i.e if at all i decide to do. ![]() ![]() Warm Regards, Sachi |
Amp_Nut
17:33
Savyasaachi Sorry to hear that.... Was this the DIY Gainclone you had built, which initially had a Hum problem ? Sorry to hear the news.... |
Savyasaachi
17:41
Its the very same one amp nut... this time though i am plannig to do either one of these things.. 1>convert the active into a passive speaker which calls for extensive crossover design in which i am a novice. 2>replace the transformer and the ones that are working with one single 1Kva toroidal tranny(from Miracle) and seperate the power supply from the amplifier chassis... Both require extensive work...will need to decide on the course of action.. am currently leaning towards a passive setup.. I don't suppose that the amplifier modules have been destroyed...they seem intact. |
abhi.pani
18:24
Hey buddy, when did that happen ??? Its really sad, if you have to dismantle your setup and convert it into something else (Passive) that too after all this hard work. Somehow I tend to adsuggest you to go ahead with the Passive thing...atleast you would be able to use the speaker in case of a amp running into trouble or the vice versa...that somewhat justifies both the money spent as well as your hard work |
Amp_Nut
03:07
erstellt: 15. Jul 2006, |
Check out the amp Modules. ICs are Very fragile, and often give up the ghost at the slightest provocation.The Only way I can think of, for the transformers to have blown, is that the rectifiers failed or the trnasformers were in a wooden box, and overheated. My call, if the amp modules are OK, would be to change the transformers Only, .... with multiple ones like you are currently using ( but good quality, not the market-off-the-shelf ones. What you are using, are Good quality ones ? Or something off the shelf ? A single transformer would mean one with multipole taps, to cater to the different voltages for the different power gainclones.... [Beitrag von Amp_Nut am 15. Jul 2006, 03:10 bearbeitet] |
Amp_Nut
16:43
erstellt: 16. Jul 2006, |
Ah ! I Think I know what blew the transformers..... Your UPS. And its not really the Sine wave the manufacturer claims it to be.... The only silver lining in this case would be that the rest of your Home made amp would be intact, except probably the rectifiers.... Do use the UPOS on a Linear power supply based device. Change yr transfo, to 1 big one or multiple smaller ones....( a single big one will be more cost effective) as long as U dont use the UPS Would be interesting to have yr feedback on this one... Thanks |
Savyasaachi
19:02
Hey amp nut.. no its not the UPS.. The fault was in a stray strand of thin wire(almost invisible) which seems to have shorted the capacitors on the mids/highs.. This seems to have shorted out the transformer. The other transformer( from the same manufacturer)one is working fine. |
Amp_Nut
02:10
erstellt: 17. Jul 2006, |
Thanks for that feedback ! I guess that feedback, will also answer yr previous question.... a single new Transfo or to stay with multiple transfos... Since some of yr Transfos have survived.... replace only the blown ones and stay multiple. ![]() So yr UPS IS a sine wave UPS. Just for other forum members, the ONLY way to be sure that the UPS delivers Sine waves, is to see its waveform on an oscilloscope. Incidentally, did the Gainclone ICs survive ? |
Savyasaachi
03:02
Some of the gain clones did survive...but a couple...maybe 3 look iffy...would do good to change all three of them. |
DAC 14AWG srikarkav am 10.08.2009 – Letzte Antwort am 12.08.2009 – 4 Beiträge |
Entry level tube/valve amp advice murrydigga am 14.05.2010 – Letzte Antwort am 03.06.2010 – 12 Beiträge |
Norge website Krish am 11.10.2007 – Letzte Antwort am 19.10.2007 – 32 Beiträge |
amp better than marantz pm7200? kimber-frank am 03.07.2003 – Letzte Antwort am 12.11.2003 – 22 Beiträge |
Any Indian Class'A' ,SS Amp? hifinovice1 am 24.03.2005 – Letzte Antwort am 26.03.2005 – 10 Beiträge |
Bright amp with which speaker. Alymangy am 02.02.2005 – Letzte Antwort am 02.02.2005 – 12 Beiträge |
How important is impedance matching? zhopudey am 06.10.2007 – Letzte Antwort am 17.10.2007 – 10 Beiträge |
Pulz Volume Control XandY am 07.12.2005 – Letzte Antwort am 12.12.2005 – 24 Beiträge |
Bi-Amp confusion vpriyan am 10.10.2008 – Letzte Antwort am 11.10.2008 – 3 Beiträge |
Sonic T amp square_wave am 28.02.2006 – Letzte Antwort am 11.03.2006 – 28 Beiträge |
2006
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 12 )
- Neuestes Mitgliedclaribelrimmer
- Gesamtzahl an Themen1.558.307
- Gesamtzahl an Beiträgen21.699.431
