HIFI-FORUM » English » Stereo (Engl.) » Cleaning CD player | |
Cleaning CD player+A -A |
SUB_BOSS
Gesperrt |
09:44
erstellt: 05. Dez 2006, ||
Hi All, We all know we live in dusty environment and dust makes way into audio components. I agree the most suffered is CD player as it has moving parts. Please share your experiences about cleaning a CD player internals without any interfernce with it's mechanicals and share your ideas about lubricating the moving parts in oredr to maximise the life. Thanks |
Amp_Nut
06:14
erstellt: 06. Dez 2006, ||
If it dosent scratch .... DONT scratch.. ![]() |
Kamal
17:57
1.Cover with a plastic dust cover when not in use. 2.keep an blank/junked Cd in the tray when not in use-the Cd covers the lens assy- helps protect from dust to some extent. 3. use a good qlty lens cleaning Cd( e.g. Philips) at least once in a month. 4. Clean the CDP & Cd tray once in a while with a damp cloth. 5.Use the CDP frequently. Kamal |
SUB_BOSS
Gesperrt |
06:53
erstellt: 07. Dez 2006, ||
Or rather chief it ain't itching don't scratch.. ![]()
Thanks Kamal and how about opening up the CDP and doing a general clean up. |
Kamal
07:38
Not really reqd, if you follow the tips ,esp the one abt keeping the CDP covered with a plastic cover when not in use. I have not opened my unit for over 6 yrs & it's still working fine. Kamal |
Amp_Nut
07:48
Kamal, ALL your tips for the CD Player are GREAT, including the recent one, not to open the machine... I wanted to add 1 point... Often in India, we cover our TVs and Hi Fi, to prevent dust from getting in. Good practice. But please ENSURE that the cover is removed when using the equipment, ( as pointed out by Kamal) and re-covered only After The Equipment Has Cooled Down. A cover that does not let the heat get out, will be doing more bad than good. ![]() The life of many electronic components reduces by 50% for every 10 deg increase in the operating temperature, beyond the recommended. Hence a 20% C increase in internal temp will reduce yr equipment life to 25% compared to if it was properly ventilated. [Beitrag von Amp_Nut am 07. Dez 2006, 07:51 bearbeitet] |
Kamal
07:51
Thats right! Kamal |
SUB_BOSS
Gesperrt |
07:52
THANKS FOR YOUR TIPS KAMAL AND AMP_CHIEF ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Kamal
08:22
bhagwan69
08:27
Perfect - Well Put ! |
bhagwan69
08:30
This is a very very important thing to remember, I personally never cover any of my gear. Just not worth it. No matter how much you cover it with, dust will find a way to get in. So just let it be, I say; ![]() |
Kamal
08:46
Sorry, have to disagree-a good plastic cover can give a lot of ,if not 100% protection against dust, which is a killer esp of CDP's.Would you leave the dust to accumulate? Covers are a must, I say Kamal |
Arj
09:14
same here !! i have not found covers of any use dustwise... |
kallu
09:27
Covers are not required, if it is dust free environment. |
deepug
10:46
Any environment you take , dust comes absolutely free. ![]() best regards Deepu |
bhagwan69
10:51
Welcome to the forum; Nice Moniker - KALLU - |
SUB_BOSS
Gesperrt |
10:52
Hmmm excellent..... ![]() |
kallu
12:47
Thanks Bhagwan. Mainly in labs, like sci-fi movies, dust free environment exists. In other places, cover is must. |
Kamal
18:12
This is really incredible! Arj, are you trying to say that whether covers are used or not, the same amt of dust will get into the eqpt? Does that sound logical? C'mon, yaar! Kamal |
Arj
20:38
have never done a real 1:1 comparison to speak on this with authority ! and neither can discuss on how much it helps, its just my perception as I prefer a shelf/rack with a door to a cover.. anyway thats what i do anyway used to vacuum the components once a week ![]() |
Amp_Nut
04:09
erstellt: 08. Dez 2006, ||
Amp_Nut also a similar 'weird nut' ![]() |
Debu
19:15
erstellt: 10. Dez 2006, ||
How true, let me put another dimension ![]() Buy a CDP/ DVDP with as little external holes as possible, mine has none. - Debu |
Neutral
15:07
erstellt: 24. Dez 2006, ||
Better still, get an amp with no ventilation holes on top (mine has none). Do speakers benefit from covers? |
Arj
15:31
if you want to prevent dust you need to have dustproof seals..and that will only retard heat dissipation the effect of which is many times worse that dust..your amps life will go down drastically.. Also really am not sure of any amp which comes with no ventillation .do you have any example for this ? |
Kamal
17:59
#25
Guys, what was recommended was to cover the damn things WHEN NOT IN USE! ( Unlike some equipment which should be covered WHILE IN USE and uncovered thereafter. Thats all-why all the debate? Kamal [Beitrag von Kamal am 24. Dez 2006, 18:02 bearbeitet] |
Neutral
20:31
#26
Really quite simple, Arj! Choose an amp that has its ventilation holes under the amp. Less dust gets in that way. (Of course, this won't work for a class A or any high-power amp.) |
abhi.pani
09:29
#27
erstellt: 25. Dez 2006, ||
Dont you think its a ridiculous criterea to select an amp ?? ![]() First of all finding an amp that matches your expectations in sonic characteristics, power handling, service backup and budget is in itself a herculean task (which most achieve with some form of compromise)..you want to add one more..."Ventilation Direction" !!!! ![]() |
Debu
19:40
#28
Agree, anyway dust should be much less a problem in Amp compared to CDP/ DVDP (as these have moving parts). Just wanted to know if anyone had a dust related problem in Amp/ receiver, IMO the probability is rare. - Debu |
Your signature SUB_BOSS am 04.12.2006 – Letzte Antwort am 02.01.2007 – 109 Beiträge |
Share your thoughts with me! Shaman am 19.09.2003 – Letzte Antwort am 07.12.2010 – 19 Beiträge |
Speaker Design & Building What Is It All About ? jsa_ind am 21.08.2005 – Letzte Antwort am 02.11.2005 – 125 Beiträge |
Expensive Audio CD player - what difference does it make? jayashree am 18.10.2008 – Letzte Antwort am 06.11.2008 – 33 Beiträge |
Ayre cd players square_wave am 15.05.2009 – Letzte Antwort am 14.08.2009 – 8 Beiträge |
how about this Sonic_Master am 02.06.2005 – Letzte Antwort am 03.06.2005 – 4 Beiträge |
cleaning connections filmguy am 14.03.2005 – Letzte Antwort am 13.04.2005 – 12 Beiträge |
Finding the Fault The_Bullet am 20.09.2005 – Letzte Antwort am 20.09.2005 – 3 Beiträge |
Are we moving towards a transport-less future ? square_wave am 30.06.2008 – Letzte Antwort am 21.07.2008 – 65 Beiträge |
Amp and cd player Kel... am 14.04.2005 – Letzte Antwort am 18.04.2005 – 7 Beiträge |
2006
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 11 )
- Neuestes MitgliedPeterHifi281
- Gesamtzahl an Themen1.558.307
- Gesamtzahl an Beiträgen21.699.411
